05-01-2021, 14:07 | #9991 (permalink) |
No Life Poster Join Date: Apr 2011 Location: algerie Age: 54
Member: 1562854 Status: Offline Sonork: 1245 Thanks Meter: 259 | Oppo a15 (cph2185) reset done Code: Operation : Oppo/Realme Factory Reset (Meta) Checking for existing META ports... No existing META port found. Connect powered off phone... Make sure to leave Buttons as soon as phone is detected. Found MediaTek USB Port_V1632 (COM50) on COM50 Device Path : \\?\usb#vid_0e8d&pid_0003#5&136f0554&0&2#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Mode : BROM Rebooting to META mode... Waiting for phone in META mode... Found MediaTek ETS Port (COM165) on COM165 Device Path : ACPI\PNP0501 Configuring Communication Channel... Reading phone information... CPU : MT6765 SW Ver. : MOLY.LR12A.R2.TC16.Q.G35.PR1.SP.V2.P168 HW Ver. : OPPO_Q0MP1_K65V1_64_BSP_HW Brand: OPPO Model: unknown Name: OPPO A15 Platform: MT6765 OEM Prod.: CPH2185 OEM Device: OP4F2F Build Date: Sun Feb 14 16:52:43 CST 2021 Display ID: CPH2185_11_A.21 OTA Version: CPH2179PU_11.A.21_0210_202102141556 Patch Level: 2021-02-05 Starting Safe Factory Reset... Reset Success Operation finished If META method does not work, try Format FS in BROM mode. [UltimateMTK Ver. 4.2] |
The Following User Says Thank You to rai14 For This Useful Post: |
05-01-2021, 14:28 | #9992 (permalink) |
Freak Poster Join Date: Nov 2016 Location: India
Member: 2650288 Status: Offline Sonork: live:hackb151 Thanks Meter: 153 | realme 3 umt one clik done Operation : MTK One Click Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM3 Port Name: MediaTek USB Port_V1632 (COM3) Path: \\?\usb#vid_0e8d&pid_0003#7&1d2facea&0&4#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0788, [MT6771] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: False DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... - Result: 0xA1A2A3A4 Disable Auth Success Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port_V1632 (COM3) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : eMMC Reading Device Information... Build Date : Wed Jun 24 19:10:20 CST 2020 Build Flavor : full_oppo6771-user Build Desc. : full_oppo6771-user 10 QP1A.190711.020 08805472cb0b87b3 release-keys Android Ver. : 10 Display ID : QP1A.190711.020 release-keys Patch Level : 2020-06-05 Platform : MT6771 Board : RM6771_18601 Platform : mt6771 Platform : MT6771 Board : RM6771_18601 Platform : mt6771 Userdata is NOT ENCRYPTED Seeking Userdata... Formatting Userdata... - Success! Seeking FRP Data... Resetting FRP... - Success! Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.2] |
The Following User Says Thank You to neyaz007 For This Useful Post: |
05-02-2021, 07:50 | #9993 (permalink) |
Freak Poster Join Date: Aug 2010 Location: india, haryana,
Member: 1358048 Status: Offline Thanks Meter: 706 | Redmi Y1 mi account remove done Operation : Reset Mi Account (New) Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM6) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1B00600 [8937] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8937_003]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8937, EMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 5A [msm8937] [ugg] Brand : xiaomi Prod.Name : ugg Software : N2G47H, V11.0.2.0.NDKMIXM [Tue Oct 22 13:44:09 WIB 2019] Android Ver. : 7.1.2 Patch Level : 2019-08-01 Patching Mi Account...OK...Done Operation Finished. QcFire Ver. 6.7 |
The Following User Says Thank You to skakroliya For This Useful Post: |
05-03-2021, 12:34 | #9994 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Oppo A37f Pattern Read Code: Device : Oppo A37f Operation : Read Pattern Lock Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1507000 [8916] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A26AB1B4B3F1CF9E Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8916_014]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8916, EMMC, 16 GB LU Count : 1 [0x01D1F000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 16384, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : OPPO A37f [msm8916] Brand : OPPO Prod.Name : A37f Software : A37fEX_11_190711, 1480422943 [Thu Jul 11 03:29:34 CST 2019] Android Ver. : 5.1.1 Patch Level : 2018-03-01 USERDATA : Normal Reading Pattern Data...Done Pattern : 32569 Operation Finished. QcFire Ver. 6.7 |
The Following User Says Thank You to Tanha0321 For This Useful Post: |
05-03-2021, 12:36 | #9995 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | OPPO A5S Format Code: Operation : Factory Reset (New) Checking for existing META ports... Found MediaTek USB VCOM (Android) (COM36) on COM36 Device Path : usb\vid_0e8d&pid_200e&rev_0409&mi_01 Configuring Communication Channel... Reading phone information... CPU : MT6765 SW Ver. : MOLY.LR12A.R2.TC16.SP.V50.5.P97 HW Ver. : OPPO_O1MP6_K65V1_64_BSP_HW Brand: OPPO Model: CPH1909 Name: unknown Platform: unknown OEM Prod.: CPH1909 OEM Device: unknown Build Date: Fri Mar 19 19:50:27 CST 2021 Display ID: CPH1909EX_11_A.46 OTA Version: CPH1909EX_11.A.46_0460_202103191930 Patch Level: 2021-04-05 Starting Factory Reset... Reset success Operation finished [UltimateMTK Ver. 4.2] |
05-03-2021, 12:36 | #9996 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | OPPO F7 Youth Format Code: Operation : Oppo/Realme Factory Reset (Meta) Checking for existing META ports... No existing META port found. Connect powered off phone... Make sure to leave Buttons as soon as phone is detected. Found MediaTek PreLoader USB VCOM_V1632 (Android) (COM23) on COM23 Device Path : \\?\usb#vid_22d9&pid_0006#6&95b3d2f&0&4#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Rebooting to META mode... Waiting for phone in META mode... Found MediaTek PreLoader USB VCOM_V1632 (Android) (COM23) on COM23 Device Path : \\?\usb#vid_22d9&pid_0006#6&95b3d2f&0&4#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Configuring Communication Channel... Reading phone information... CPU : MT6771 SW Ver. : MOLY.LR12A.R2.PIE.P70.PR4.TC16.SP.V1.P15 HW Ver. : OPPO_P70_P0MP3_K71V1_64_BSP_HW Brand: OPPO Model: CPH1859 Name: OPPO F7 Youth Platform: MT6771 OEM Prod.: CPH1859 OEM Device: CPH1859 Build Date: Thu Mar 4 18:39:41 CST 2021 Display ID: CPH1859EX_11_C.17 OTA Version: CPH1859EX_11.C.17_1170_202103041800 Patch Level: 2021-03-05 Starting Safe Factory Reset... Reset Success Operation finished If META method does not work, try Format FS in BROM mode. [UltimateMTK Ver. 4.2] |
05-03-2021, 12:37 | #9997 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Vivo Y71 Format Frp Code: Device : Vivo Y71 Operation : Format FS 2 (Vivo) Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM65) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1600500 [8917] 00000000 OPK_DATA : 30315EBED1DD09CEAAE927CAE0EE967076BC178CA33718DB4FFF8F02A0E7FAD2 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8917_001]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8917, EMMC, 16 GB LU Count : 1 [0x01D5A000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : vivo vivo 1724 [msm8937_64] Brand : vivo Prod.Name : msm8937_64 Software : OPM1.171019.011 release-keys, eng.compil.20210113.122216 [Wed Jan 13 12:22:16 CST 2021] Android Ver. : 8.1.0 Patch Level : 2021-01-01 Preparing Data...Done Formatting Userdata......Done Resetting FRP Lock......Done Operation Finished. QcFire Ver. 6.7 |
05-03-2021, 12:37 | #9998 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | QMobile X30 Imei Repaire Code: Brand : QMobile Model : X30 Operation : Repair IMEI Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek PreLoader USB VCOM_V1632 (Android) (COM42) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Executing Flashing Task... Hardware : MT6572 Syncing with Target... Reading Partition Table... Storage : eMMC Reading Device Information... Brand : TINNO Manufacturer : QMobile Model : QMobile X30 Prod. Name : QMobile X30 Device : QMobile X30 Board : s4050ap Build Date : Mon May 4 14:50:25 CST 2015 Build Desc. : s4050ap-user 4.4.2 KOT49H eng.android.1430722047 test-keys Android Ver. : 4.4.2 Display ID : ALPS.KK1.MP7.V1 Brand : TINNO Manufacturer : QMobile Model : QMobile X30 Prod. Name : QMobile X30 Device : QMobile X30 Board : s4050ap Build Date : Mon May 4 14:50:25 CST 2015 Build Desc. : s4050ap-user 4.4.2 KOT49H eng.android.1430722047 test-keys Android Ver. : 4.4.2 Display ID : ALPS.KK1.MP7.V1 Userdata is NOT ENCRYPTED Reading NV IMEI Data... Failed to Seek! NV IMEI1 : NV IMEI2 : NVRAM Saved as: C:\UMTool\UltimateMTK\NVRAM\NV_QMobile_QMobile X30____210414_144016.nvf Detected IMEI Algo 0 New IMEI1 : 3523xxxxxxxxxxx New IMEI2 : 3523xxxxxxxxxxx Preparing IMEI data [1]... NV_OFFSET is unknown! Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.0] |
05-04-2021, 16:49 | #10001 (permalink) |
No Life Poster Join Date: Feb 2012 Location: india (rajasthan) Age: 32
Member: 1719279 Status: Offline Thanks Meter: 140 | vivo y30 1938n one click pattern unlock with great tool umt |
The Following User Says Thank You to jitendramobile. For This Useful Post: |
05-04-2021, 16:49 | #10002 (permalink) |
05-04-2021, 17:06 | #10003 (permalink) |
Member: 2650288 Status: Offline Sonork: live:hackb151 Thanks Meter: 153 | oppo reno 2z done one clik Operation : MTK One Click Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM21 Port Name: MediaTek USB Port_V1632 (COM21) Path: \\?\usb#vid_0e8d&pid_0003#7&1d2facea&0&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0788, [MT6771] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: False DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... - Result: 0xA1A2A3A4 Disable Auth Success Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port_V1632 (COM21) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : UFS Reading Device Information... Build Date : Thu Mar 25 02:11:30 CST 2021 Build Flavor : sys_oplus_mssi_64_cn-user Build Desc. : sys_oplus_mssi_64_cn-user 11 RP1A.200720.011 1615844163298 release-keys Android Ver. : 11 Display ID : RP1A.200720.011 release-keys Patch Level : 2021-04-05 Platform : MT6771 Board : oppo6771 Platform : mt6771 Platform : MT6771 Board : oppo6771 Platform : mt6771 Userdata is NOT ENCRYPTED Seeking Userdata... Formatting Userdata... - Success! Seeking FRP Data... Resetting FRP... - Success! Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.2] |
05-05-2021, 12:55 | #10004 (permalink) |
No Life Poster Join Date: Mar 2012 Location: punjab
Member: 1732025 Status: Offline Sonork: 100.1615024 Thanks Meter: 329 | 2.2 nokia done Code: Operation : Format FS CPU : MT6761 Storage : EMMC DA : Nokia 2.2 DA_UMT.bin [MTK_AllInOne_DA_v3.3001.2018/08/21.13:52] Using Custom DA! Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port_V1632 (COM61) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : eMMC Reading Device Information... Brand : Nokia Manufacturer : HMD Global Model : Nokia 2.2 Prod. Name : Wasp_00WW Device : WSP_sprout Build Date : Fri May 8 16:43:54 CST 2020 Build Flavor : full_wasp-user Build Desc. : full_wasp-user 10 QP1A.190711.020 152 release-keys Android Ver. : 10 Display ID : 00WW_2_300_SP03 Patch Level : 2020-05-05 Platform : MT6761 Board : MT6761 Platform : mt6761 Userdata is NOT ENCRYPTED Formatting userdata... - Done. Disconnect Battery/Cable and Power On Phone. Last edited by U.M.T; 05-05-2021 at 21:00. |
The Following User Says Thank You to ssony For This Useful Post: |
05-05-2021, 12:58 | #10005 (permalink) |
Member: 1732025 Status: Offline Sonork: 100.1615024 Thanks Meter: 329 | nokia 2.2 frp Operation : Reset FRP CPU : MT6761 Storage : EMMC DA : Nokia 2.2 DA_UMT.bin [MTK_AllInOne_DA_v3.3001.2018/08/21.13:52] Using Custom DA! Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port_V1632 (COM61) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : eMMC Reading Device Information... Brand : Nokia Manufacturer : HMD Global Model : Nokia 2.2 Prod. Name : Wasp_00WW Device : WSP_sprout Build Date : Fri May 8 16:43:54 CST 2020 Build Flavor : full_wasp-user Build Desc. : full_wasp-user 10 QP1A.190711.020 152 release-keys Android Ver. : 10 Display ID : 00WW_2_300_SP03 Patch Level : 2020-05-05 Platform : MT6761 Board : MT6761 Platform : mt6761 Userdata is NOT ENCRYPTED Resetting FRP... FRP Reset Done. Disconnect Battery/Cable and Power On Phone. |
