01-07-2017, 13:30 | #1847 (permalink) |
Product Supporter Join Date: Jul 2011 Location: ISLAMIC & INDIA WITH MIRACLE T Age: 37
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Samsung sm-j200g frp reject solved new method Device: Samsung Device Operation: Reset FRP (New Method) Port: COM4 : SAMSUNG Mobile USB Modem Checking for Device... Found [Download Mode] Reading Data from Phone... Done Chipset: LSI3475 [HiSpeed] Resetting FRP Lock Data... . Done Closing Session... Done ---------------- IMPORTANT ---------------- Wait for phone to reboot and turn on fully or TURN ON manually. Once Phone is completely ON, wait a few minutes and then. goto Menu > Settings > Backup and Reset and do Factory data Reset. Elapsed Time: 00:14 [Ultimate Samsung Flasher v0.8] |
The Following User Says Thank You to .::THE ROCK::. For This Useful Post: |
01-08-2017, 07:19 | #1848 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | j500f unlock done Code: Port : COM97 : SAMSUNG Mobile USB Serial Port (COM97) Baud Rate : 115200 Device : Samsung A500FU Operation : Unlock Opening Port... OK Reading Phone Information... OK Compile : May 11 2016 22:05:21 Release : Feb 19 2016 02:00:00 Hw. Ver. : EAAAANVZ ESN : B0000000 MEID : 00000000000000 IMEI : 35329008250---- Switching to Offline Mode... OK Preparing Phone... OK Unlocking Phone, Please wait... OK Resetting Phone... OK If Phone does not restart, do it manually. Port Closed. Operation Finished. Elapsed Time: 00:06 [Module Ver. 3.3] Log Saved to Logs\170108_104852.log Port : COM98 : SAMSUNG Mobile USB Modem #15 Baud Rate : 115200 Device : Samsung G361H Operation : Read Info Opening Port... OK Reading Information... OK Model : SM-J500F IMEI : 35329008250---- Version Info : J500FXXU1APE1 : J500FEUR1APE1 : J500FXXU1APE1 : J500FXXU1APE1 Port Closed. Operation Finished. Elapsed Time: 00:05 [Module Ver. 3.3] Log Saved to Logs\170108_105239.log |
01-08-2017, 09:21 | #1849 (permalink) |
No Life Poster Join Date: May 2012 Location: InfinityBox CM2
Member: 1763238 Status: Offline Thanks Meter: 370 | Code: J200G Reset FRP Done by New FRP Method Code: Device: Samsung Device Operation: Reset FRP (New Method) Port: COM52 : SAMSUNG Mobile USB Modem #4 Checking for Device... Found [Download Mode] Reading Data from Phone... Done Chipset: LSI3475 [HiSpeed] Resetting FRP Lock Data... . Done Closing Session... Done ---------------- IMPORTANT ---------------- Wait for phone to reboot and turn on fully or TURN ON manually. Once Phone is completely ON, wait a few minutes and then. goto Menu > Settings > Backup and Reset and do Factory data Reset. Elapsed Time: 00:10 [Ultimate Samsung Flasher v0.8] Br ishant |
01-08-2017, 11:16 | #1850 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | mi 4s account reset done Code: Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port : Qualcomm HS-USB QDLoader 9008 (COM91) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.1.2 Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1507000 [8916] Initializing Protocol... OK Preparing Firehose Loader... Done Sending Firehose Loader... Done Executing Loader... OK Hardware : 8916, eMMC, 16 GB Warning! High Speed Driver not installed. Payload Info : In: 65536 [4096], Out: 16384, Sector Size: 512 Reading Partition Table... OK Resetting Mi Account... Done Operation Finished. Remove cable, reconnect battery / hold Power Button ~15 seconds. |
01-08-2017, 11:34 | #1851 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | moto xt1022 flash done Code: Port : Fastboot Interface Baud Rate : Not Applicable Device : Motorola QC Operation : Flash Fw Model : condor_retaildsds Fw Version : condor_retaildsds-user 5.1 LPC23.13-34.2 2 release-keysMSM8610BP_18033.4614.45.00R Searching for Device in FastBoot Mode... OK Reading Phone Information... Model : XT1022 Boot Ver. : 5009 Baseband : Not Found Software : Blur_Version.21.12.40.condor_retaildsds.retaildsdsall.en.03 IMEI : 35929905222---- CPU : MSM8210 CS RAM : 1024MB Hynix S4 SDRAM DIE=4Gb EMMC : 4GB Toshiba REV=06 PRV=51 TYPE=17 Sending Data [partition]... Done Sending Data [motoboot]... Done Sending Data [logo]... Done Sending Data [boot]... Done Sending Data [recovery]... Done Sending Data [system]... Done Sending Data [system]... Done Sending Data [system]... Done Sending Data [system]... Done Sending Data [modem]... Done Erasing [modemst1]... Done Erasing [modemst2]... Done Sending Data [fsg]... Done Operation Finished. Elapsed Time: 02:29 [Module Ver. 3.3] Log Saved to Logs\170108_160156.log Port : Fastboot Mode Baud Rate : Not Applicable Device : Motorola QCOM Operation : Wipe UserData (Fastboot) Searching for Device in FastBoot Mode... OK Reading Phone Information... Model : XT1022 Boot Ver. : 5009 Baseband : Not Found Software : Blur_Version.21.12.40.condor_retaildsds.retaildsdsall.en.03 IMEI : 35929905222---- CPU : MSM8210 CS RAM : 1024MB Hynix S4 SDRAM DIE=4Gb EMMC : 4GB Toshiba REV=06 PRV=51 TYPE=17 Wiping Userdata.... Done Wiping Cache.... Done Operation Finished. Elapsed Time: 00:06 [Module Ver. 3.3] Log Saved to Logs\170108_160239.log Port : Fastboot Mode Baud Rate : Not Applicable Device : Motorola QCOM Operation : Reboot Normal (Fastboot) Searching for Device in FastBoot Mode... OK Reading Phone Information... Model : XT1022 Boot Ver. : 5009 Baseband : Not Found Software : Blur_Version.21.12.40.condor_retaildsds.retaildsdsall.en.03 IMEI : 35929905222---- CPU : MSM8210 CS RAM : 1024MB Hynix S4 SDRAM DIE=4Gb EMMC : 4GB Toshiba REV=06 PRV=51 TYPE=17 Rebooting to Normal Mode... Done Operation Finished. Elapsed Time: 00:01 [Module Ver. 3.3] Log Saved to Logs\170108_160409.log |
01-08-2017, 13:25 | #1852 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | samsung j500 unlock done Code: Port : COM105 : SAMSUNG Mobile USB Modem #18 Baud Rate : 115200 Device : Samsung G361H Operation : Read Info Opening Port... OK Reading Information... OK Model : SM-J500F IMEI : 35329008241---- Version Info : J500FXXU1AOL3 : J500FODD1AOL3 : J500FDDU1AOL3 : J500FXXU1AOL3 Port Closed. Operation Finished. Elapsed Time: 00:05 [Module Ver. 3.3] Log Saved to Logs\170108_171157.log Port : COM104 : SAMSUNG Mobile USB Serial Port (COM104) Baud Rate : 115200 Device : Samsung A500FU Operation : Unlock Opening Port... OK Reading Phone Information... OK Compile : May 11 2016 22:05:21 Release : Feb 19 2016 02:00:00 Hw. Ver. : EAAAANVZ ESN : B0000000 MEID : 00000000000000 IMEI : 35329008241---- Switching to Offline Mode... OK Preparing Phone... OK Unlocking Phone, Please wait... OK Resetting Phone... OK If Phone does not restart, do it manually. Port Closed. Operation Finished. Elapsed Time: 00:15 [Module Ver. 3.3] Log Saved to Logs\170108_172601.log |
01-09-2017, 19:44 | #1854 (permalink) |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,267 | Lenovo A6000 Read Firmware Code: Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port Driver Info : TCL, qcusbser.sys, 2.1.2.1 Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1507000 [8916] Initializing Protocol... OK Preparing Firehose Loader... Done Sending Firehose Loader... Done Executing Loader... OK Hardware : 8916, eMMC, 8 GB Warning! High Speed Driver not installed. Payload Info : In: 65536 [4096], Out: 16384, Sector Size: 512 Reading Partition Table... OK Reading Device Information... OK Device : LENOVO Lenovo A6000 [msm8916] Software : Kraft-A6000_S042_151012, Kraft-A6000_S042_151012 [Mon Oct 12 14:27:31 CST 2015] Android Ver. : 4.4.4 Reading [modem]... Done Reading [sbl1]... Done Reading [sbl1bak]... Done Reading [aboot]... Done Reading [abootbak]... Done Reading [rpm]... Done Reading [rpmbak]... Done Reading [tz]... Done Reading [tzbak]... Done Reading [hyp]... Done Reading [hypbak]... Done Reading [misc]... Done Reading [splash]... Done Reading [sec]... Done Reading [boot]... Done Reading [system]... Done Reading [persist]... Done Reading [cache]... Done Reading [recovery]... Done Reading [userdata]... Done Reading [PrimaryGPT]... Done Reading [BackupGPT]... Done Operation Finished. Remove cable, reconnect battery / hold Power Button ~15 seconds. |
The Following User Says Thank You to Fast Unlocking For This Useful Post: |
01-10-2017, 06:49 | #1855 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Panasonic p55 nova imei repair done Port : COM27 : MTK CDC Serial (COM27) Baud Rate : 921600 Device : MTK Android Operation : IMEI Repair (META) Opening Port... OK Reading Phone Information... Done CPU : MT6592, E00 Software : MOLY.WR8.W1315.MD.WG.MP.V62.P20 Hardware : DEWAV92_WET_KK_HSPA_HW Reading Data.... Done Writing IMEI[1] 35211207++++++.... Done Writing IMEI[2] 35211207++++++.... Done Operation Finished. Elapsed Time: 00:02 [Module Ver. 3.3] Log Saved to Logs\170110_111532.log |
01-10-2017, 12:33 | #1856 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | redmi 3s prime format done Searching for phone in sideload mode... Found Device Id : land_global Version : V8.1.1.0.MALMIDI Code Base : 6.0.1 Ext Info : GB, en, F Formatting Data... Done Operation Finished. |
The Following User Says Thank You to rehmani For This Useful Post: |
01-10-2017, 14:03 | #1857 (permalink) |
Freak Poster Join Date: Jul 2012 Location: The Golden State Punjab, India Age: 38
Member: 1788939 Status: Offline Sonork: 100.1625853 Thanks Meter: 307 | Samsung sm-j710f frp reset done Samsung J7 (2016) 6.0.1 FRP{Factory Reset Protection} Done By U.M.T Here is Log... Device: SM-J710F Operation: Apply FRP Patch Port: COM6 : SAMSUNG Mobile USB Modem Checking for Device... Found [Download Mode] Reading Data from Phone... Done Chipset: LSI7870 [HiSpeed] Applying Patch Data... . . . . Done Closing Session... Done ---------------- IMPORTANT ---------------- Wait for phone to reboot and turn on fully or TURN ON manually. Please install driver once SAMSUNG_Android Device is detected. Once ADB Drivers are installed, use Reset FRP button. Elapsed Time: 00:15 [Ultimate Samsung Flasher v0.8] BR, INDER |
The Following User Says Thank You to indergsm For This Useful Post: |
01-10-2017, 14:09 | #1858 (permalink) |
Junior Member Join Date: Feb 2014 Location: cumbum
Member: 2121940 Status: Offline Sonork: 100.1597028 Thanks Meter: 5 | SAMSUNG J200G FRP DONE BY UMT http://s28.postimg.org/mnckmqc99/screenshot_18.png http://s28.postimg.org/lnrbo53f1/screenshot_19.png |
01-10-2017, 14:46 | #1859 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | samsung s7582 flash done Code: Device: GT-I8190 Operation: Flash Firmware Port: COM20 : SAMSUNG Mobile USB Modem #2 Checking for Device... Found [Download Mode] Reading Data from Phone... Done Chipset: KyleProD [HiSpeed] Sending Partition [KERNEL]... Done Sending Partition [RECOVERY]... Done Sending Partition [DTS]... Done Sending Partition [modem]... Done Sending Partition [CSC]... Done Sending Partition [HIDDEN]... Done Sending Partition [system]... Done Sending Partition [PARAM]... Done Closing Session... Done Operation Finished. Elapsed Time: 08:45 [Ultimate Samsung Flasher v0.8] |
01-10-2017, 15:20 | #1860 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Lg-rd3530 unlock Port : COM49 : LGE Mobile USB Serial Port (COM49) Baud Rate : 38400 (Auto) Device : LG RD3530 Operation : Unlock Opening Port... OK Reading Information... OK Compile : Sep 17 2008 19:47:01 Release : Sep 17 2008 23:00:00 Hw Ver. : RD353F02 ESN : 7C420AD6 MEID : A00000104F126C Model : RD3530 Software : F02 Preparing Data... OK Setting Offline Mode... OK Security Unlock... OK Setting Download Mode... OK Preparing Bootloader... OK Sending Bootloader... OK Executing Bootloader... OK Erasing Flash Memory... OK Erasing Flash Memory... OK Writing Flash Memory... OK Writing Flash Memory... OK Resetting Phone... OK Port Closed. Operation Finished. Time Taken: 00:30 Module Ver. [1.6] Error Saving Log File! |
