01-11-2017, 08:03 | #1861 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | Code: Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port : Qualcomm HS-USB QDLoader 9008 (COM60) Driver Info : ShenQi Inc., squsbser.sys, 2.0.9.6 Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1507000 [8916] Initializing Protocol... OK Preparing Firehose Loader... Done Sending Firehose Loader... Done Executing Loader... OK Hardware : 8916, eMMC, 8 GB Warning! High Speed Driver not installed. Payload Info : In: 65536 [4096], Out: 16384, Sector Size: 512 Writing NON-HLOS.bin ... Done Writing sbl1.mbn ... Done Writing sbl1.mbn ... Done Writing emmc_appsboot.mbn ... Done Writing emmc_appsboot.mbn ... Done Writing rpm.mbn ... Done Writing rpm.mbn ... Done Writing tz.mbn ... Done Writing tz.mbn ... Done Writing hyp.mbn ... Done Writing hyp.mbn ... Done Writing splash.img ... Done [PROTECTIVE_FLASH] Skipping S86518C1_Online_V011.img Writing sec.dat ... Done Writing boot.img ... Done Writing system_1.img ... Done Writing system_2.img ... Done Writing system_3.img ... Done Writing system_4.img ... Done Writing system_5.img ... Done Writing system_6.img ... Done Writing system_7.img ... Done Writing system_8.img ... Done Writing system_9.img ... Done Writing system_10.img ... Done Writing system_11.img ... Done Writing system_12.img ... Done Writing system_13.img ... Done Writing system_14.img ... Done Writing system_15.img ... Done Writing system_16.img ... Done Writing system_17.img ... Done Writing system_18.img ... Done Writing system_19.img ... Done Writing system_20.img ... Done Writing system_21.img ... Done Writing system_22.img ... Done Writing system_23.img ... Done Writing system_24.img ... Done Writing system_25.img ... Done Writing system_26.img ... Done Writing system_27.img ... Done Writing system_28.img ... Done Writing system_29.img ... Done Writing system_30.img ... Done Writing persist_1.img ... Done Writing cache_1.img ... Done Writing cache_2.img ... Done Writing cache_3.img ... Done Writing cache_4.img ... Done Writing recovery.img ... Done Writing userdata_1.img ... Done Writing userdata_2.img ... Done Writing userdata_3.img ... Done Writing userdata_4.img ... Done Writing userdata_5.img ... Done Writing userdata_6.img ... Done Writing userdata_7.img ... Done Writing userdata_8.img ... Done Writing userdata_9.img ... Done Writing userdata_10.img ... Done Writing userdata_11.img ... Done Writing userdata_12.img ... Done Writing userdata_13.img ... Done Writing userdata_14.img ... Done Writing userdata_15.img ... Done Writing userdata_16.img ... Done Writing userdata_17.img ... Done Writing userdata_18.img ... Done Writing userdata_19.img ... Done Writing userdata_20.img ... Done Writing userdata_21.img ... Done Writing userdata_22.img ... Done Writing userdata_23.img ... Done Writing userdata_24.img ... Done Writing userdata_25.img ... Done Writing userdata_26.img ... Done Writing userdata_27.img ... Done Writing userdata_28.img ... Done Writing userdata_29.img ... Done Writing userdata_30.img ... Done Writing userdata_31.img ... Done Writing userdata_32.img ... Done Writing userdata_33.img ... Done Writing userdata_34.img ... Done Writing userdata_35.img ... Done Writing userdata_36.img ... Done Writing userdata_37.img ... Done Writing userdata_38.img ... Done Writing userdata_39.img ... Done Writing userdata_40.img ... Done Writing userdata_41.img ... Done Writing userdata_42.img ... Done Writing userdata_43.img ... Done Writing userdata_44.img ... Done Writing userdata_45.img ... Done Writing userdata_46.img ... Done Writing gpt_main0.bin ... Done Writing gpt_backup0.bin ... Done Applying Patches... Done Operation Finished. Remove cable, reconnect battery / hold Power Button ~15 se |
The Following 2 Users Say Thank You to rehmani For This Useful Post: |
01-11-2017, 11:34 | #1862 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | lava c180 flash,repair security,and unlock done Code: Port : COM10 : Qualcomm HS-USB Diagnostics 9004 (COM10) Baud Rate : 921600 Device : Lava C180 Operation : Flash [Emergency] Opening Port... OK Preparing Phone... OK Sending Bootloader... OK Executing Bootloader... OK Initializing Flash Chip... OK Chip Name : SAMSUNG K5N2833-66ATB Chip Size : 16 MB Firmware : LAVA_C180_040315_SW_V2.0_BLANK.BIN Fw. Size : 16 MB Flashing Firmware... OK Resetting Phone... OK Port Closed. Operation Finished. Time Taken: 08:12 Module Ver. [1.6] Log Saved to Logs\170111_160034.log Code: Port : COM10 : Qualcomm HS-USB Diagnostics 9004 (COM10) Baud Rate : 921600 Device : Lava M141 Operation : Read Info Opening Port... OK Reading Information... OK Compile : Mar 04 2015 19:45:41 Release : Apr 24 2010 00:00:00 Hw Ver. : 3350 ESN : 00000000 MEID : 00000000000000 IMEI : 000000000000000 BUILD : LAVA_C180_040315_SW_V2.0@ Reading Extended Information... OK User Code : 0000 SPC : 000000 Port Closed. Operation Finished. Time Taken: 00:06 Module Ver. [1.6] Log Saved to Logs\170111_160219.log Port : COM10 : Qualcomm HS-USB Diagnostics 9004 (COM10) Baud Rate : 921600 Device : Lava M141 Operation : MEID Repair Opening Port... OK Reading Information... OK Compile : Mar 04 2015 19:45:41 Release : Apr 24 2010 00:00:00 Hw Ver. : 3350 ESN : 00000000 MEID : 00000000000000 IMEI : 000000000000000 BUILD : LAVA_C180_040315_SW_V2.0@ Reading Extended Information... OK User Code : 0000 SPC : 000000 Writing MEID A100004288----... OK New MEID : A100004288---- Port Closed. Operation Finished. Time Taken: 00:03 Module Ver. [1.6] Log Saved to Logs\170111_160330.log Code: Port : COM10 : Qualcomm HS-USB Diagnostics 9004 (COM10) Baud Rate : 921600 Device : Lava C180 Operation : Unlock Opening Port... OK Reading Information... OK Compile : Mar 04 2015 19:45:41 Release : Apr 24 2010 00:00:00 Hw Ver. : 3350 ESN : 80FA11-- MEID : A100004288---- Build : LAVA_C180_040315_SW_V2.0@ User Code : 0000 Setting Download Mode... OK Reconnecting Phone... OK Preparing Phone... OK Sending Bootloader... OK Executing Bootloader... OK Initializing Flash Chip... OK Chip Name : SAMSUNG K5N2833-66ATB Chip Size : 16 MB Preparing Patch Data... OK Patching Firmware... OK Resetting Phone.. OK Port Closed. Operation Finished. Time Taken: 00:26 Module Ver. [1.6] Log Saved to Logs\170111_160425.log |
01-11-2017, 13:16 | #1864 (permalink) |
Junior Member Join Date: Feb 2014 Location: cumbum
Member: 2121940 Status: Offline Sonork: 100.1597028 Thanks Meter: 5 | moto e xt1022 flash done by umt mobile problumes 1.wifi not open 2.bluetooth not open http://postimg.org/image/7gyznnp8p/ after flash done by umt Last edited by bashabhaicumbum; 01-11-2017 at 13:23. |
01-12-2017, 10:13 | #1865 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | samsung g361f frp reset and format done Code: Port : ADB Interface Baud Rate : Not Applicable Device : Generic Operation : Motorola FRP Reset Searching for Device... Found Model : SM-G361F Version : 5.1.1 Hardware : pxa1908 Baseband : G361FXXU1APD5 SIM Card : ABSENT CPU : armeabi-v7a Type : Unknown MEID(1) : Null/Empty Root : Not Rooted Resetting FRP Lock... Done Operation Finished. Elapsed Time: 00:08 [Module Ver. 3.3] Log Saved to Logs\170112_144008.log Port : COM61 : SAMSUNG Mobile USB Modem #5 Baud Rate : 115200 Device : Samsung G361H Operation : Format Phone (AT) Opening Port... OK Reading Information... OK Model : SM-G361F IMEI : 35474707088---- Version Info : G361FXXU1APE1 : G361FVFG1APD3 : G361FXXU1APD5 : G361FXXU1APE1 Formatting Phone... OK Phone Will Reboot When Done. Port Closed. Operation Finished. Elapsed Time: 00:07 [Module Ver. 3.3] Log Saved to Logs\170112_144312.log |
The Following User Says Thank You to rehmani For This Useful Post: |
01-12-2017, 11:07 | #1866 (permalink) |
No Life Poster Join Date: May 2012 Location: InfinityBox CM2
Member: 1763238 Status: Offline Thanks Meter: 371 | Code: Redmi Note 3 Patternlock Reset Done Code: Searching for phone in sideload mode... Found Device Id : kenzo Version : V7.5.3.0.LHOMIDE Code Base : 5.1.1 Ext Info : GB, en, F Formatting Data... Done Operation Finished. Br ishant |
01-12-2017, 12:27 | #1868 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | j210 frp remove done Code: Device: SM-J210F Operation: Apply FRP Patch Port: COM15 : SAMSUNG Mobile USB Modem Checking for Device... Found [Download Mode] Reading Data from Phone... Done Chipset: SPRD8735 [HiSpeed] Applying Patch Data... . . . . . Done Closing Session... Done ---------------- IMPORTANT ---------------- Wait for phone to reboot and turn on fully or TURN ON manually. Please install driver once SAMSUNG_Android Device is detected. Once ADB Drivers are installed, use Reset FRP button. Elapsed Time: 00:22 [Ultimate Samsung Flasher v0.8] Device: SM-J210F Operation: Reset FRP Searching for Device... Found Model: SM-J210F Baseband: J210FXXU0APK3 Bootloader: J210FXXU0APF1 PDA: J210FXXU0APK4 Android Version: 6.0.1 Resetting FRP Lock... Done ---------------- IMPORTANT ---------------- Tap Next > Next > Accept Agreement on phone to enter Home Screen. Goto Menu > Settings > Backup and Reset > Factory data reset. Operation Finished. Elapsed Time: 00:10 [Ultimate Samsung Flasher v0.8] |
01-14-2017, 10:21 | #1871 (permalink) |
Product Supporter Join Date: Jul 2011 Location: ISLAMIC & INDIA WITH MIRACLE T Age: 37
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Samsung sm-j210f frp remove umt AFTER APPLY UFD Device: SM-J210F Operation: Reset FRP Searching for Device... Found Model: SM-J210F Baseband: J210FXXU0APF6 Bootloader: J210FXXU0APF1 PDA: J210FXXU0APF4 Android Version: 6.0.1 Resetting FRP Lock... Done ---------------- IMPORTANT ---------------- Tap Next > Next > Accept Agreement on phone to enter Home Screen. Goto Menu > Settings > Backup and Reset > Factory data reset. Operation Finished. Elapsed Time: 00:11 [Ultimate Samsung Flasher v0.8] |
The Following User Says Thank You to .::THE ROCK::. For This Useful Post: |
01-15-2017, 07:26 | #1872 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Now In USA Rim database Age: 47
Member: 248178 Status: Offline Sonork: 100.1579207 Thanks Meter: 323 | Samsung J710F FRP Reset With UMT Device: SM-J710F Operation: Apply FRP Patch Port: COM28 : SAMSUNG Mobile USB Modem #2 Checking for Device... Found [Download Mode] Reading Data from Phone... Done Chipset: LSI7870 [HiSpeed] Applying Patch Data... . . . . Done Closing Session... Done ---------------- IMPORTANT ---------------- Wait for phone to reboot and turn on fully or TURN ON manually. Please install driver once SAMSUNG_Android Device is detected. Once ADB Drivers are installed, use Reset FRP button. Elapsed Time: 00:19 [Ultimate Samsung Flasher v0.8] Device: SM-J710F Operation: Reset FRP Searching for Device... Found Model: SM-J710F Baseband: J710FXXU1APG2 Bootloader: J710FXXU1APG1 PDA: J710FXXU1APG2 Android Version: 6.0.1 Resetting FRP Lock... Done ---------------- IMPORTANT ---------------- Tap Next > Next > Accept Agreement on phone to enter Home Screen. Goto Menu > Settings > Backup and Reset > Factory data reset. Operation Finished. Elapsed Time: 00:08 [Ultimate Samsung Flasher v0.8] |
The Following User Says Thank You to G i l l a n i For This Useful Post: |
01-15-2017, 10:48 | #1873 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | MI NOTE 3 PATTERN LOCK FORMAT umt Searching for phone in sideload mode... Found Device Id : kenzo Version : V8.0.5.0.LHOMIDG Code Base : 5.1.1 Ext Info : GB, en, F Formatting Data... Done Operation Finished. |
01-15-2017, 12:32 | #1874 (permalink) |
Freak Poster Join Date: Sep 2009 Location: another place
Member: 1128422 Status: Offline Thanks Meter: 67 | SM-J105F Reset FRP DONE Code: Device: SM-J105F Operation: Apply FRP Patch Port: COM107 : SAMSUNG Mobile USB Modem #25 Checking for Device... Found [Normal Mode] Reading Phone Information... OK Model: SM-J105F IMEI: 358310071164868 Software: J105FXXU0APH3/J105FOLE0APH3/J105FXXU0APG2/J105FXXU0APH3 Init Download Mode... OK Port: COM24 : SAMSUNG Mobile USB Modem #4 Reading Data from Phone... Done Chipset: SPRD8735 [HiSpeed] Applying Patch Data... . . . . . Done Closing Session... Done ---------------- IMPORTANT ---------------- Wait for phone to reboot and turn on fully or TURN ON manually. Please install driver once SAMSUNG_Android Device is detected. Once ADB Drivers are installed, use Reset FRP button. Elapsed Time: 01:05 [Ultimate Samsung Flasher v0.8] Code: Device: SM-A310F Operation: Reset FRP Searching for Device... Found Model: SM-J105F Baseband: J105FXXU0APG2 Bootloader: J105FXXU0APB2 PDA: J105FXXU0APH3 Android Version: 5.1.1 Resetting FRP Lock... Done ---------------- IMPORTANT ---------------- Tap Next > Next > Accept Agreement on phone to enter Home Screen. Goto Menu > Settings > Backup and Reset > Factory data reset. Operation Finished. Elapsed Time: 00:07 [Ultimate Samsung Flasher v0.8] |
