09-07-2021, 23:17 | #10321 (permalink) |
No Life Poster Join Date: Mar 2018 Location: <...< Egypt >...>
Member: 2821459 Status: Offline Thanks Meter: 806 | Oppo A83 Reset Done UMT PRO Code: Operation : Oppo/Realme Factory Reset (Meta) Checking for existing META ports... No existing META port found. Connect powered off phone... Make sure to leave Buttons as soon as phone is detected. Found MediaTek PreLoader USB VCOM_V1633 (Android) (COM26) on COM26 Device Path : \\?\usb#vid_22d9&pid_0006#5&2a3bd414&0&2#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Rebooting to META mode... Waiting for phone in META mode... Found MediaTek PreLoader USB VCOM_V1633 (Android) (COM26) on COM26 Device Path : \\?\usb#vid_22d9&pid_0006#5&2a3bd414&0&2#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Configuring Communication Channel... Retrying Connection... Found MediaTek PreLoader USB VCOM_V1633 (Android) (COM26) on COM26 Device Path : usb\vid_22d9&pid_0006&rev_???? Reading phone information... CPU : MT6763 SW Ver. : MOLY.LR12A.R1.TC16.SP.V26.P58 HW Ver. : OPPO6763_C66_N1_HW Brand: OPPO Model: CPH1729 Name: OPPO A83 Platform: unknown OEM Prod.: unknown OEM Device: unknown Build Date: Fri Sep 4 00:52:36 CST 2020 Display ID: CPH1729EX_11_A.35_200903 OTA Version: M6763D_11.A.35_0350_202009032342 Patch Level: 2019-10-05 Starting Safe Factory Reset... Reset Success Operation finished If META method does not work, try Format FS in BROM mode. [UltimateMTK Ver. 4.4] |
The Following 2 Users Say Thank You to Elgendi For This Useful Post: |
09-08-2021, 05:43 | #10322 (permalink) |
Freak Poster Join Date: Aug 2010 Location: india, haryana,
Member: 1358048 Status: Offline Thanks Meter: 706 | oppo a71 user lock reset done Device : Oppo A71 (CPH1801) Operation : Format FS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM6) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1A00900 [8953] 00000000 OPK_DATA : 557BAC65705B8A8303276B9FBB8FD533DBB33EA9E55BF80B47 647B8549C170B9 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953_015]...Done Executing Loader...OK Formatting Userdata...Done Disconnect phone and hold Power Button to reset. Operation Finished. QcFire Ver. 7.2 |
The Following 2 Users Say Thank You to skakroliya For This Useful Post: |
09-08-2021, 18:57 | #10323 (permalink) |
Freak Poster Join Date: May 2016 Location: BRAZIL
Member: 2578528 Status: Offline Thanks Meter: 139 | Operation : Reset FRP Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM72) Driver Info : Lenovo Inc., leusbser.sys, 2.0.9.6 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1A00900 [8953] 00002000 OPK_DATA : 58C5414A3A35B2E6DAA9C7A3B816E594DA247411000F7E9422 1BF5F13119812C Initializing Protocol...OK Sending Loader [prog_emmc_firehose_8953_ddr.mbn]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, EMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Software : RP1A.200720.012.A115MUBU2BUE1, A115MUBU2BUE1 [Tue May 4 08:49:32 KST 2021] Android Ver. : 11 Patch Level : 2021-04-01 Resetting FRP Lock......Done Operation Finished. QcFire Ver. 7.1 |
The Following 2 Users Say Thank You to marcelofigado For This Useful Post: |
09-08-2021, 18:57 | #10324 (permalink) |
09-09-2021, 06:23 | #10325 (permalink) |
No Life Poster Join Date: Apr 2015 Location: LOOLCANO Taba Day.
Member: 2385819 Status: Offline Sonork: No More Used Thanks Meter: 829 | JAT-L29 FRP Reset With TP. Operation : MTK One Click Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM4 Port Name: MediaTek USB Port_V1632 (COM4) Path: \\?\usb#vid_0e8d&pid_0003#6&f10c574&0&2#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0766, [MT6765] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: False DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... Disable Auth Success Preloader saved as : preloader_k62v1_64_mexico_210909_101707.bin DA : MTK_AllInOne_DA.bin Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port_V1632 (COM4) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : eMMC Reading Device Information... Unable to read! Userdata is ENCRYPTED Seeking FRP Data... Resetting FRP... - Success! Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.4] |
The Following 2 Users Say Thank You to ahmer5050 For This Useful Post: |
09-09-2021, 06:23 | #10326 (permalink) |
09-10-2021, 11:40 | #10327 (permalink) |
Member: 1358048 Status: Offline Thanks Meter: 706 | Redmi 5A mi account & frp done Code: Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM6) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1600500 [8917] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8917]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8917, EMMC, 16 GB LU Count : 1 [0x01D5A000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi 5A [msm8937] [riva] Brand : Xiaomi Prod.Name : riva Software : N2G47H, V10.1.1.0.NCKMIFI [Mon Oct 29 14:46:26 WIB 2018] Android Ver. : 7.1.2 Patch Level : 2018-07-01 Resetting FRP Lock......Done Operation Finished. QcFire Ver. 7.2 |
09-10-2021, 14:49 | #10328 (permalink) |
No Life Poster Join Date: Aug 2012 Location: Crimea
Member: 1797426 Status: Offline Thanks Meter: 289 | Reset FRP BQ6022G Operation : Reset FRP CPU : MT6580 Storage : EMMC DA : MTK_AllInOne_DA.bin [MTK_AllInOne_DA_v3.3001.01/21/2021.12:51] Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek PreLoader USB VCOM (Android) (COM31) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : eMMC Reading Device Information... Brand : BQru Manufacturer : BQru Model : BQ-6022G Prod. Name : BQru_6022G Device : BQru_6022G Board : BQru-6022G Build Date : Thu Jun 11 12:57:58 CST 2020 Build Flavor : BQru-6022G-user Build Desc. : BQru-6022G 9 PPR1.180610.011 1591851511 release-keys Android Ver. : 9 Display ID : BQru_BQ-6022G_Android_9.0_V01_2020-06-11 Patch Level : 2020-06-05 Platform : MT6580 Board : k80_bsp Platform : mt6580 Userdata is NOT ENCRYPTED Resetting FRP... FRP Reset Done. Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.4] Best regards. |
The Following 3 Users Say Thank You to ivannikolaevich For This Useful Post: |
09-11-2021, 07:30 | #10329 (permalink) |
Member: 1358048 Status: Offline Thanks Meter: 706 | Redmi 4a frp reset done Code: Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM6) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1600500 [8917] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8917]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8917, EMMC, 32 GB LU Count : 1 [0x03A3E000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi 4A [msm8937] [rolex] Brand : Xiaomi Prod.Name : rolex Software : N2G47H, V10.2.3.0.NCCMIXM [Wed Jun 5 18:30:47 WIB 2019] Android Ver. : 7.1.2 Patch Level : 2018-07-01 Resetting FRP Lock......Done Operation Finished. QcFire Ver. 7.2 |
The Following 3 Users Say Thank You to skakroliya For This Useful Post: |
09-11-2021, 16:05 | #10330 (permalink) |
Registered User Join Date: Aug 2016 Location: Multan Pakistan
Member: 2608490 Status: Offline Thanks Meter: 921 | Vivo Y11 Vivo Format FS / FRP Reset Device : Vivo Y11 Operation : Vivo Format FS / FRP Reset Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM9) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1F00B00 [8937] 00000000 OPK_DATA : 30315EBED1DD09CEAAE927CAE0EE967076BC178CA33718DB4F FF8F02A0E7FAD2 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8937_029]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8937, EMMC, 32 GB LU Count : 1 [0x03A3E000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : vivo vivo 1906 [PD1930F_EX] Brand : vivo Prod.Name : PD1930F_EX Software : PKQ1.190616.001 release-keys, compiler01140016 [Thu Jan 14 00:15:27 CST 2021] Android Ver. : 9 Patch Level : 2021-01-01 Formatting userdata...Done Resetting FRP Lock...Done Wipe cache / userdata from Recovery and reboot. First startup may take 2-5 minutes. Operation Finished. QcFire Ver. 7.2 |
The Following 3 Users Say Thank You to GSM AR For This Useful Post: |
09-11-2021, 16:14 | #10331 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: Ubá--Brazil Age: 34
Member: 194078 Status: Offline Sonork: no have Thanks Meter: 209 | LG K8+ LM-X120 FRP Remove One Click See the log Down: LG K8+ LM-X120 FRP Remove One Click Quote:
The Following 3 Users Say Thank You to daroas For This Useful Post: |
09-11-2021, 23:24 | #10332 (permalink) |
Member: 2821459 Status: Offline Thanks Meter: 806 | DRA-lX2 Reset Password&Frp Done DRA-lX2 Reset Password&Frp Done LOG Code: Operation : MTK One Click Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM3 Port Name: MediaTek USB Port_V1632 (COM3) Path: \\?\usb#vid_0e8d&pid_0003#5&2a3bd414&0&2#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0699, [MT6739] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: True DA Auth: False Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... Disable Auth Success Preloader saved as : preloader_dura64_210912_001341.bin DA : MTK_AllInOne_DA.bin Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port_V1632 (COM3) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : eMMC Reading Device Information... Brand : HUAWEI Manufacturer : HUAWEI Model : DRA-LX2 Prod. Name : DRA-LX2 Device : HWDRA-M Board : DRA-LX2 Build Date : Fri Apr 10 16:07:32 CST 2020 Build Flavor : full_dura64-user Build Desc. : "DRA-LX2-user 8.1.0 HUAWEIDRA-LX2 1.0.0.175(C185) release-keys" Android Ver. : 8.1.0 Display ID : DRA-LX2 1.0.0.175(C185) Patch Level : 2020-04-05 Board : DRA-LX2 Platform : mt6739 Board : DRA-LX2 Platform : mt6739 Userdata is ENCRYPTED Formatting Userdata... - Success! Seeking FRP Data... Resetting FRP... - Success! Disconnect Battery/Cable and Power On Phone. [Ultimate |
The Following 3 Users Say Thank You to Elgendi For This Useful Post: |
09-13-2021, 05:16 | #10333 (permalink) |
Member: 2385819 Status: Offline Sonork: No More Used Thanks Meter: 829 | A025f FRP One Click With TP Methode. Operation : Reset FRP Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1A00900 [8953] 00002000 OPK_DATA : 98431A976541787E851B78549BBDA354E64C343814B5A8618B B79571EF8267A5 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953_051]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, EMMC, 32 GB LU Count : 1 [0x03A3E000] Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Software : RP1A.200720.012.A025FXXS2BUF1, A025FXXS2BUF1 [Tue Jun 29 09:47:38 KST 2021] Android Ver. : 11 Patch Level : 2021-07-01 Resetting FRP Lock......Done Operation Finished. QcFire Ver. 7.2 |
The Following User Says Thank You to ahmer5050 For This Useful Post: |
09-13-2021, 05:16 | #10334 (permalink) |
09-13-2021, 09:08 | #10335 (permalink) |
Insane Poster Join Date: Jan 2008
Member: 668748 Status: Offline Thanks Meter: 110 | Vivo.s1 1907_19,android ver 11 Operation : MTK One Click Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM456 Port Name: MediaTek PreLoader USB VCOM (Android) (COM456) Path: \\?\usb#vid_0e8d&pid_2000#5&32a310c1&0&2#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Preloader Mode Detected, Trying to crash... - Success! Port: COM455 Port Name: MediaTek USB Port (COM455) Path: \\?\usb#vid_0e8d&pid_0003#5&32a310c1&0&2#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0707, [MT6768] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: False DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... Disable Auth Success Preloader saved as : preloader_k68v1_64_210911_121917.bin DA : MTK_AllInOne_DA.bin Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port (COM455) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : eMMC Reading Device Information... Build Date : Thu Jul 29 21:37:21 CST 2021 Build Flavor : full_k68v1_64-user Build Desc. : full_k68v1_64-user 11 RP1A.200720.012 eng.compil.20210729.214112 release-keys Android Ver. : 11 Display ID : RP1A.200720.012 release-keys Patch Level : 2021-08-01 Platform : MT6768 Board : k68v1_64 Platform : mt6768 Platform : MT6768 Board : k68v1_64 Platform : mt6768 Userdata is NOT ENCRYPTED Formatting Userdata... - Success! Seeking FRP Data... Resetting FRP... - Success! Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.4] |
