HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices |
02-23-2010, 05:24 | #2 (permalink) |
No Life Poster Join Date: Jul 2006 Location: Bangladesh Age: 42
Member: 319447 Status: Offline Thanks Meter: 4,949 | Hi its an ELF Flash USPL, n after dat upgrade with English rom. everything can be found at sticky thread. |
The Following User Says Thank You to .:SUBRATA:. For This Useful Post: |
02-23-2010, 09:34 | #3 (permalink) |
Insane Poster Join Date: May 2009
Member: 1041731 Status: Offline Thanks Meter: 13 | you can download the file at sticky thread. upgrade with English Rom. u can also write the Rom with English Lang. |
The Following User Says Thank You to toy4u For This Useful Post: |
02-23-2010, 10:33 | #4 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Manama / BAHRAIN
Member: 100592 Status: Offline Sonork: 1578498 Thanks Meter: 245 | instructions: this is to flash any SPL: either update to hardspl this way or flash another spl over hardspl. 0. make sure your device is synced to activesync!! 1. Run the elf-uspl.exe from ELF CID Unlock HERE DOWNLOAD 2. Watch Screen and Press Enter When Asked. 3. Screen should Jump to White on Phone and on PC Flashing Loading Bar will Show. 4. Stuck in Black Ducky Loading Screen?, check Active Sync Connection or Do a hard reset on Phone first. But be sure to do the last Actual Flashing in White Screen. Sometimes this needs a few tries to go through white screen. 5. Done. ENGLISH ROM FROM HERE IMPORTANT: 2.26 and 2.28 are for both Elf and Elfin, but 3.07 and 3.10/3.14 sometimes don't work on 64mb Elf so if you have that device, test with USPL version first BR |
The Following User Says Thank You to HAROON's For This Useful Post: |
04-30-2010, 16:42 | #5 (permalink) |
No Life Poster Join Date: Mar 2004 Location: Cambodia
Member: 59030 Status: Offline Thanks Meter: 165 | Need Dopod S1 original chinese rom I need Dopod S1 original rom please if someone has or know where to download. I cannot flash any other rom now since the phone is stuck in bootloader (tri-color) mode... |
How to convert ATOM English to Chinese ? | BMobile | HTC & PDA WM( With Touchscreen) | 0 | 10-26-2006 08:15 |
if you want to see 3gp in win or you want to convert to avi | Doomsday | Nokia Multimedia | 0 | 07-05-2005 05:44 |
Motorola T205 data cable to convert to E365 | yeldar | Wanted Products | 2 | 03-22-2004 02:45 |
a50 dead trying to convert to c45 | patric | x1x to x45/x50 | 7 | 04-03-2003 20:48 |
