HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices |
04-26-2010, 19:44 | #1 (permalink) |
Freak Poster Join Date: Aug 2007
Member: 571744 Status: Offline Thanks Meter: 17 | Need some Help from the expert... Hello... Need some help to revive my HIMALAYA O2 XDA IIi, After try to use this TofClock_HIMA_WM6_AKU.0.7, phone goes to BOOTLOADER MODE now ... Pls. Help Image TIA |
04-27-2010, 06:10 | #2 (permalink) |
No Life Poster Join Date: Jul 2006 Location: Bangladesh Age: 42
Member: 319447 Status: Offline Thanks Meter: 4,949 | its from O2 UK ? please let us know ur country from. so we can provide a perfect one to you. |
The Following User Says Thank You to .:SUBRATA:. For This Useful Post: |
04-27-2010, 10:22 | #4 (permalink) | ||
No Life Poster Join Date: Oct 2006 Location: Hungary Age: 47
Member: 365452 Status: Offline Thanks Meter: 838 | Quote:
I always faced this problem with Himalaya,no matter which ROM I used. My solution is: make a Goldcard and flash your device with Goldcard inside.Device will boot normally after flash this way. BR Szig | ||
The Following User Says Thank You to szig For This Useful Post: |
04-27-2010, 11:18 | #6 (permalink) | |
http://forum.gsmhosting.com/vbb/f98/...ldcard-931025/ BR Szig | |
04-27-2010, 13:12 | #10 (permalink) |
Member: 571744 Status: Offline Thanks Meter: 17 | One Question again... For example I make the Goldcard already.... may I know what is the file name of NBH file that should I put here... CAuse I want to try my GOLDCARD that I use before on my HERMES.... It will work??? TNX |
04-27-2010, 13:14 | #11 (permalink) | |
On some devices you must set the right security permissions via Registry Editor,if QMAT drops an error message: HKLM/Security/Policies/Policies/"00001001' set to integer 1 Use registry editor or total commander for PPC or Resco explorer. In Total commander you can find the registry under ///Plugins in the root of PPC. After the setting you can make Goldcard. BR Szig | |
The Following 2 Users Say Thank You to szig For This Useful Post: |
04-27-2010, 14:39 | #12 (permalink) |
Member: 571744 Status: Offline Thanks Meter: 17 | Hello... I already follow the instruction to make a GOLDCARD, and put the NBH file to the GOLDCARD this name did I use ( HIMAIMG.NBH ) is it right?. But if go to BOOTLOADER it just show SERIAL & v.101 on the screen... Pls Help me to do this. TIA |
04-27-2010, 17:30 | #13 (permalink) | |
Make Goldcard,put it into your device.Disable Activesync connections, in Activesync settings->untick "allow USB connections" Put device in bootloader mode,connect to PC and run an official upgrade utility on the PC.After flashing it should boot normally. BR Szig | |
04-28-2010, 13:47 | #15 (permalink) |
Member: 365452 Status: Offline Thanks Meter: 838 | Hi! I answered last night,but it seems to be lost. So,Goldcard in your device,your device in bootloader mode. On the tray, right click on Activesync icon,settings->untick "allow USB connections",click OK. Connect your device to PC and run an official upgrade on your PC.After flashing your device should boot normally. BR Szig And now it's here,weird! |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
