HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices |
07-17-2005, 00:50 | #2 (permalink) |
No Life Poster Join Date: Aug 2001 Location: P A K I S T A N _____________ Age: 40
Member: 5932 Status: Offline Thanks Meter: 1,694 | KEEP power button PRESSED and also press reset button from the hole. if your problem will be not solved download latest firmware upgrade from I-mate official website. Br. A. Wahab |
07-18-2005, 07:30 | #4 (permalink) |
Member: 5932 Status: Offline Thanks Meter: 1,694 | @ask_n_ans, TRY THIS.. 1. Press and hold soft1 and soft2 keys. 2. Press and hold power button for around 1 to 1.5 seconds. Release power button. Keep hold soft1 and soft2 keys. 3. Later, screen shoould show instructions to ask user to press '0' key to reset to factory default. 4. Press '0' within the timeout period, which is only several seconds only. 5. If no instruction is shown on the screen, repeat steps 1 to 4. The timing is sensitive. Br. A. Wahab |
07-18-2005, 09:14 | #5 (permalink) |
No Life Poster Join Date: Oct 1999 Location: Hong Kong
Member: 596 Status: Offline Sonork: 100.33096 Thanks Meter: 514 | The best solution is hard reset , power+camer+reset switch , after you press that 3 keys you will see a engineering mode then you press the reset key all the user data will be refrashed (pw,contact messages etc) then you will get your phone back! Regards Bert |
09-06-2005, 09:25 | #6 (permalink) |
Freak Poster Join Date: Nov 2004 Location: Ngeria Age: 42
Member: 94542 Status: Offline Sonork: 104341 Thanks Meter: 77 | pls Friends i used the to solution but it respond to non of them what elsse can i do The phone is I-mate SP3i need to reset the phone may i still another way to do this regards |
09-07-2005, 05:32 | #7 (permalink) |
Member: 596 Status: Offline Sonork: 100.33096 Thanks Meter: 514 | Th SP3i is not this topic talking about! try following hw reset methods upvolum key+camera+power , after you press that 3 buttons at the same time shortly you will see a white screen then 3 color bar will show on the screen. after that you now need to power off it then on it. you wil get a clean phone back! |
The Following User Says Thank You to Bert For This Useful Post: |
09-07-2005, 07:20 | #8 (permalink) | |
Member: 5932 Status: Offline Thanks Meter: 1,694 | Quote:
THIS WORK 100% for SP3i, 1. Press and hold soft1 and soft2 keys. 2. Press and hold power button for around 1 to 1.5 seconds. Release power button. Keep hold soft1 and soft2 keys. 3. Later, screen shoould show instructions to ask user to press '0' key to reset to factory default. 4. Press '0' within the timeout period, which is only several seconds only. 5. If no instruction is shown on the screen, repeat steps 1 to 4. The timing is sensitive. Br. A. Wahab | |
09-09-2008, 09:34 | #9 (permalink) | |
No Life Poster Join Date: May 2006 Location: HEAVEN
Member: 285345 Status: Offline Thanks Meter: 324 | Quote:
MDA Compact / i-Mate Jam Unlocking? | virtualme | HTC & PDA WM( With Touchscreen) | 2 | 08-26-2006 16:27 |
i-mate jam is hang after on | aukonline | JAFWM | 7 | 08-21-2006 16:27 |
i need unlock for I-MATE and I-MATE JAM | cellularman | HTC & PDA WM( With Touchscreen) | 1 | 03-01-2006 23:33 |
I killed I-mate jam, please help !!! | DaliborDu | HTC & PDA WM( With Touchscreen) | 5 | 04-14-2005 18:35 |
Looking for XDAIIi and MDAcompact/I-Mate JAM, brand new. | netgsm | Wanted Products | 0 | 02-09-2005 21:09 |
