HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices |
10-06-2008, 13:41 | #1 (permalink) |
Freak Poster Join Date: Dec 2006
Member: 412458 Status: Offline Thanks Meter: 6 | pls help imate pda2k stuck in align screen i have an imate pda2k pocket pc and is working good. Out of curiosity i tried hard reset and it ends to align screen. Everytime i made a hard reset the screen show " tap the screen to setup your pocket pc" then after tapping the screen it shows align screen , everytime i hit the screen the target continue moving but stay in align screen window. help any solution.... |
11-03-2008, 10:50 | #2 (permalink) |
No Life Poster Join Date: Oct 2006 Location: Hungary Age: 47
Member: 365452 Status: Offline Thanks Meter: 838 | Hi! On the align screen you have a cross.You have to tap in the middle of the cross,then it moves to the corners,allways in the middle of the cross.If you were not too accurate,then calibration will restart.If you dont have hardware problem with your touchscreen,then it has to work,but sometimes an area is damaged(not visibly) and you stuck on align screen. So I think you have to change your touchscreen. Tip:there are service programs to skip the calibration screen,you can use your pda after that normally(because the icons are bigger than 1 pixel).It's a cost-effective solution.Don't ask me for the program,I have never used it,just heard about this solution. Best regards! Szig |
newbie i need help ... my software stuck on terms screen | lunaticu | UST Pro II | 25 | 12-08-2008 09:41 |
Imate jasjam stuck in bootloader mode | unlock trigger | HTC & PDA WM( With Touchscreen) | 3 | 09-01-2008 22:43 |
Imate Jam Stop On Align Screen | Sonu Jawed | HTC & PDA WM( With Touchscreen) | 4 | 08-20-2008 15:34 |
Please help , my V3i stuck in bootloader !!!! | nova75c | Smart-Clip | 9 | 06-13-2007 22:50 |
