HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices |
02-12-2011, 16:22 | #6 (permalink) |
Banned Join Date: Apr 2008 Age: 44
Member: 761856 Status: Offline Sonork: seabird Thanks Meter: 7 | Dear Sir/ Madam, I have complain about mobile, having following configration. 1) T Mobile, MDA, HTC Innovation and Herm 300. Now my complain is when i put bettry in the mobile and i switch it on during the process it gets stop on booting. what i need is updated rom or provide me link so that i can install in my mobile. I would really appreciate your promt response. Best Regards. |
02-14-2011, 08:29 | #9 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Ahmedabad, Gujarat Age: 45
Member: 121078 Status: Offline Sonork: 100.1590676 Thanks Meter: 292 | ERROR [262] : UPDATE ERROR "This error occurs during the CE ROM code upgrade process. Solution: If this happens, you can just soft-reset/hard reset the device and run RUU again. The update process will then continue. Note: At this stage, the Wince is destroyed; instead, it is in upgrade mode" |
02-14-2011, 19:27 | #10 (permalink) |
Member: 761856 Status: Offline Sonork: seabird Thanks Meter: 7 | Dear Sir, Here i would like to bring your concentrtaion on following issue. When i put my mobile on ROM upgradation it get stop during the installation on 11% in this situation how can i reset activesync. my phone is stuck on booting how can i go on furhter processing? I got the following solution on XDA developers but do not understand it please explain it. Solution # 1 "In the end I had to uninstall ActiveSync and reinstall it. I also had to hard-reset my TyTn, but everything worked out in the end after about four hours of mayhem" Solution # 2 [ It sounds like ActiveSync went on holiday. I think there was a post somewhere regarding this that was along the tune of unplugging the phone from the USB, switch ports and/or computers, rebooting the computer (and while you do this, take the battery out of the phone), login back into the computer, put the battery back into the phone, restart ActiveSync. Also, make sure the power is stable. I'd use a laptop so in case the power goes up, the computer would stay on (and a lot of people had issues with Vista (*snicker*)). Something along these lines but I would try to get more verification of that. Were you trying to upgrade the RADIO or just the OS ROM? Personally, I'd recommend using mtty to install the OS. If it is the latter, I'd follow the wiki and do the mtty route (faster and virtually no choice to brick your phone).] Waiting for your response Thanks. |
02-14-2011, 23:28 | #11 (permalink) |
Member: 761856 Status: Offline Sonork: seabird Thanks Meter: 7 | boog32131st October 2009, 03:58 AM I might be stating the obvious but for newbies like me here if you do not follow the process and do not start by installing and running RaphaelHardSPL-Unsigned_190_1_3.exe first you will also get error [262]. It might be obvious to most of everybody around here but I can see how somebody new might get confused and skip this important first step! Good luck to all! They shouldn't install the RaphaelHardSPL, on their hermes. For the hermes, they should have this hardspl (Hard-SPL, Or How to Not Brick Your PDA Ever Again And Fix Bad Blocks! - xda-developers). |
02-14-2011, 23:38 | #12 (permalink) |
Member: 761856 Status: Offline Sonork: seabird Thanks Meter: 7 | RaphaelHardSPL-Unsigned_190_1_3.exe (this fill on run error) the application failed to initialize properly (0xc0000135).click on ok to terminate the application |
02-19-2011, 20:25 | #13 (permalink) | |
Member: 121078 Status: Offline Sonork: 100.1590676 Thanks Meter: 292 | Quote:
Software for Nokia Mobiles | Genata | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 09-20-1999 07:17 |
PERMANENT MOBILE PHONE SUPPLIER NEEDED | MILLENNIUM-INTERNATIONAL | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 21:25 |
PERMANENT MOBILE PHONE SUPPLIER NEEDED | MILLENNIUM-INTERNATIONAL | Wanted Products | 0 | 08-28-1999 21:23 |
Demand Mobile Phone and Parts of GSM | mariadaluz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-16-1999 18:20 |
