Old 09-09-2009, 12:24   #1 (permalink)
Dr_Wolodya's Avatar
Member: 75408
Thanks Meter: 1,190
Nokia 5530 RM-504 F-Bus pinout
JAF log:
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V ICPR72_09w20.7
25-06-09
RM-504
(c) Nokia
HW version: 0801
PCI version:
RFIC version:
DSP version:
APE SW Core version: V 10.0.050
APE Variant version: V 10.0.050V 10.0.050 10.0.050.215.02
APE Test version: rm504_ENO_x_09wk19v0.080
Retu version: 16
Tahvo version: 22
APE HW version: 256
APE ADSP SW version: 256
Content Pack version: V 10.0.050
Production serial number: CCI898237
Product code: 0588346
Module code:
Basic production code: 0569346
Flash code:
Order number:
Product specific data:
Long production SN: 0
ATO:
Default SN type:
IMEI plain: 354200030144444
LOCK STATUS:
CONFIG KEY: 8000000000000000
PROVIDER KEY: 2680600000000000
Provider: TMN;Portugal
Key Code count: 0, FBUS Code count: 0
Block 1:
Lock 1: CLOSED -> Lock Data: 26806F
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RM-504.ini
Done!
The Following 23 Users Say Thank You to Dr_Wolodya For This Useful Post:
Old 09-16-2009, 12:51   #2 (permalink)
serkandaisy's Avatar
Member: 148499
Thanks Meter: 33
Reading...
MCU SW version: V ICPR72_09w20.9
06-08-09
RM-504
(c) Nokia
HW version: 0802
PCI version:
RFIC version:
DSP version:
Retu version: 16
Tahvo version: 22
Production serial number: CIP732205
Product code: 0573169
Module code:
Flash code:
Order number:
ATO:
Default SN type:
IMEI plain: 354200037162656
IMEI spare to net: 3A 45 02 00 73 61 62 05
IMEI SV to net: 33 45 02 00 73 61 62 05 F5
LOCK STATUS:
CONFIG KEY: 0000000000000000
PROVIDER KEY: 2440700000000000
Provider: AT&T;U.S.A. (3650)
Block 1:
Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Old 09-17-2009, 16:35   #3 (permalink)
Dr_Wolodya's Avatar
Member: 75408
Thanks Meter: 1,190
2 serkandaisy
For what you post this log here?
Old 09-18-2009, 07:14   #4 (permalink)
Member: 148499
Thanks Meter: 33
Pinouts true.understand me
Old 09-18-2009, 08:21   #5 (permalink)
mobile_hotman's Avatar
Member: 214340
Thanks Meter: 906
I thought U r showing unlocking logs,,,lolz
The Following User Says Thank You to mobile_hotman For This Useful Post:
Old 11-19-2009, 12:43   #6 (permalink)
Member: 589712
Thanks Meter: 82
hi! whats wrong with thiS?
Card life counter: 100.00%
P-key nokia module version 01.02
Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30107
JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\
JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\
JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\
JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\
USB Cable Driver version: 7.1.17.0
Changing mode...Done!
Booting phone...
FAST PHONE detected!
CMT Boot Data:
Asic ID: 000000010000022600010006400C192101051105
Asic Mode ID: 00
Asic EM ID: 00000B22
Asic Public ID: 1A300001E27D0052A15C1B3EB3C60488D469CE98
HASH: B8C3ADECFC997FCD8081D3DEAF870B8C00000000
ROM ID: 4B9B75103E691FF8
Error finding cmt boot file...
Error on check....................................!
but ok on info.....................................!
CMT Boot Data:
Asic Mode ID: 00
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Reading...
MCU SW version: V ICPR72_09w20.10
25-08-09
RM-504
(c) Nokia
HW version: 0802
PCI version:
RFIC version:
DSP version:
Retu version: 16
Tahvo version: 22
Production serial number: CZC787338
Product code: 0577070
Module code:
Flash code:
Order number:
ATO:
Default SN type:
IMEI plain: 354200034781540
IMEI spare to net: 3A 45 02 00 43 87 51 04
IMEI SV to net: 33 45 02 00 43 87 51 04 F6
LOCK STATUS:
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Saved INI not found, loading INI list...
Setting local mode...
Reading product code...
Product Code: 0577070
Searching for JAF saved location of ini...
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-504\
Searching for default location of ini...
Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-504\
No ini files found...
Done!
Old 11-19-2009, 14:12   #7 (permalink)
Nicolayer's Avatar
Member: 93002
Sonork: 100.1617660
Thanks Meter: 19
@Mecaniko
You can't check Fbus because you don't have good Fbus loaders.
BR.
The Following User Says Thank You to Nicolayer For This Useful Post:
Old 12-28-2009, 14:34   #8 (permalink)
Member: 589712
Thanks Meter: 82
Originally Posted by Nicolayer View Post
@Mecaniko
BR.
where is good loader mate?
Old 10-31-2010, 12:18   #9 (permalink)
b12345's Avatar
Member: 758310
Sonork: 100.1601610
Thanks Meter: 71
flash it with mx key it works
Old 01-21-2011, 14:00   #10 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 11,110
Successful Repair Nokia 5530 RM-504 With ATF Box...................
                  TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 66846344  (0x88) bytes returned
Number of Sub Blocks 7  (0x07)
  1  SYSTEM_ASIC_ID 01
     Block Length  : 21  (15)
     BB ASIC Index : 0  (00)  CMT
     ID DWORD    0 : 00000001
     ID DWORD    1 : 00000226
     ID DWORD    2 : 00010006
     ID DWORD    3 : 400C1921
     ID DWORD    4 : 01051105
  2  ROM_ID 15
     Block Length  : 5  (05)
     ID DWORD    0 : 00000296
  3  ROM_ID 15
     ID DWORD    0 : 00000B22
  4  PUBLIC_ID 12
     ID DWORD    0 : 1D300108
     ID DWORD    1 : 64960052
     ID DWORD    2 : 48DEC565
     ID DWORD    3 : 9A247B70
     ID DWORD    4 : 2EFDB378
  5  ASIC_MODE_ID 13
     Block Length  : 2  (02)
     Mode Id       : 00
  6  ROOT_KEY_HASH 14
     Block Length  : 17  (11)
     Hash          :  B8 C3 AD EC FC 99 7F CD 80 81 D3 DE AF 87 0B 8C
  7  ROM_ID 15
     Block Length  : 9  (09)
     CRC         0 : 4B9B7510
     CRC         1 : 3E691FF8
Checksum           30
SearchForBootstrap_DCT5..
CMT Loader : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg
PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0"
PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0"
SearchForBootstrap_DCT5  : No Error - 0 (0x00)
Secondary Loader Sent...
TransmissionTypeRequest_DCT5_NewProtocol
TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX
TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C
Transmission Type Request Sent...
ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
MCU_CONFIGURATION_RESPONSE_BB5:
 MessageID  : C1
 SubBlocks  : 06
 1 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   BB ASIC Index     : CMT  00
   Device Type       : RAM  05
   Device Index      : 00
   Manufacturer Code : 0000 -> Flash
   Device ID         : 0000 -> not detected
   Extended/Fixed ID : 0000
   Revision ID       : 0000
 2 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : MMC  04
   Device Index      : 00
   Manufacturer Code : FFFF -> Flash
   Device ID         : 0000 -> BAD FLASH TYPE
   Revision ID       : 0000
 3 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : NOR  00
   Device Index      : 00
   Manufacturer Code : 0400 -> Flash
   Device ID         : 0000 -> Type not in database
   Revision ID       : 0000
 4 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Index      : 01
   Manufacturer Code : 0000 -> SPANSION
   Device ID         : 0001 -> not used
   Revision ID       : 0000
 5 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : MuxOneNAND  03
   Device Index      : 00
   Manufacturer Code : 00EC ->
   Device ID         : 0040 -> KAT00F00RA
   Revision ID       : 0231
 6 Sub Block ID      : 35  NAND_DRIVER_VERSION_BB5
   Block Length      : 09
   Data              : XSR 1.5
 Checksum   : 14
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0040 ExtID :0000 RevID :0231
 RAPIDOv11_XSR15_alg.fg
First Algo byte : 56
Flash Descriptor
   Device ID         : 0040
   Revision ID       : 0000
   Size              : 10000000 (256 MB)
   VPP Info          : 0000
   Erase10s          : 1E
   Block1s           : 32
   BErase1s          : 02
   Reserved0         : 00
   Reserved1         : 00
   Reserved2         : 00
VPP INFO :
C: \AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.fg
Algo Loader Sent...
SendCodeStart_NewProtocol :
SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00)
SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok...
VPP Enabled by Software
Using Internal VPP
FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4
Pabub KEY Request
PhoneInfoRequest_BB5 (Asic Index 00 )
PHONE_INFO_RESPONSE_BB5
   PAPUB_KEYS_HASH_RESP_BB5 2A
   BB Asic Index   : 01
PAPUB Keys Hash : F2B05364E563A348608C1C3C9E54FE42AAAA1ACF
Scanning Simlock Type...
OK
              PA_SL3 Phone detected
* Firmware Version Downgrade will KILL PHONE !!!
* Manual Full Erase WILL KILL PHONE!!!
* Simlocks are in PM 120 Only...
* PM 308 is Write Protected...
FlashInfo.RestartMode : 2
MCU: V ICPR72_10w21 26-05-10 RM-504 (c) Nokia
IMEI: 352683043440285
Model : Nokia 5530 XpressMusic
Product Serial Number: CZE391169
Product Code         : 0577070
Module Code          : 0204038
Basic Production Code: 0569346
Default SN Type      : 0
PPM Version          : V ICPR72_10w21 26-05-10 RM-504 (c) Nokia
HW Version           : 0803
RFIC Version         : 17141716
DSP Version          : ICPR72_10w16p1
Content Pack Version : v 30.0.001_001_000_U001 05-03-10 vanilla RM504
AHNE Version         : 11
APE SW Core Version  : V 31.0.005
APE Variant Version  : V 31.0.005V 31.0.005
APE Test Version     : 09wk19v0.130
Retu Version         : 16
Tahvo Version        : 22
APE HW Version       : 256
APE ADSP SW Version  : 256
   ********   Reading SimLock   ********
Provider  :  AT&T;U.S.A. (3650)
Counters  :  0/3  ,  0/10
   Block [1]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [2]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [3]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [4]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [5]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [6]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [7]  1:Open 2:Open 3:Open 4:Open 5:Open
SP Lock Status :  Not Locked
SIMLOCK_TEST             : PASSED
SECURITY_TEST           : PASSED
SUPER_DONGLE_TEST : PASSED
               SL3 Phone detected
PHONE_MODE              : TEST MODE
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post:
5530 rm-504 Off when making Calls,Flash Ok --Same. blaiseid Nokia Base Band 5 ( BB-5 ) 43 07-10-2010 00:19
Flashing Error 5530 RM-504 dilip kumar j Cyclonebox 3 02-10-2010 16:51
nokia 5530 rm-504 BekoMobil MT-BOX 5 02-10-2010 13:00
5530 rm-504 flash error ltc MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 12-26-2009 08:53
help unlock 5530 RM-504 dauyeuqn Nokia Base Band 5 ( BB-5 ) 4 09-15-2009 12:55
Page generated in 0.27519 seconds with 9 queries
