02-10-2010, 14:17 | #1 (permalink) |
Freak Poster Join Date: Sep 2003 Location: bangalore Age: 56
Member: 40136 Status: Offline Thanks Meter: 7 | Flashing Error 5530 RM-504 Does cyclone Support flashing Nokia 5530 RM- 504. When i try i get the following Error :- Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101051105 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1100020C7280005215297CA28C261A6BE49729C3 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: B8C3ADECFC997FCD8081D3DEAF870B8C CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 Failed to Check BB5 Flashing Bus -> Failed to Boot / Prepare Phone Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101051105 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1100020C7280005215297CA28C261A6BE49729C3 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: B8C3ADECFC997FCD8081D3DEAF870B8C CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 Failed to Check BB5 Flashing Bus -> Failed to Boot / Prepare Phone |
02-10-2010, 16:09 | #3 (permalink) |
Member: 40136 Status: Offline Thanks Meter: 7 | I think the cable should be ok because i can read the info of the phone, and cannot flash with USB EITHER. THANKS FOR YOU FAST REPLY PLEASE LOOK IN TO THE MATTER |
02-10-2010, 16:51 | #4 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | You can try, if you have any tool like the TMA adapter to use a BSI value Higher (about 5kohm more then it should be) and try again to check the flashing bus. Normally this issue happend when the mobile has APE problems. If you can check the flashing bus using the suggestion given before, try a full flash and report. BR Alex |
Nokia 5530 RM-504 F-Bus pinout | Dr_Wolodya | Nokia Base Band 5 ( BB-5 ) | 9 | 01-21-2011 14:00 |
5530 rm-504 Off when making Calls,Flash Ok --Same. | blaiseid | Nokia Base Band 5 ( BB-5 ) | 43 | 07-10-2010 00:19 |
nokia 5530 rm-504 | BekoMobil | MT-BOX | 5 | 02-10-2010 13:00 |
5530 rm-504 flash error | ltc | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 12-26-2009 08:53 |
help unlock 5530 RM-504 | dauyeuqn | Nokia Base Band 5 ( BB-5 ) | 4 | 09-15-2009 12:55 |
