06-02-2018, 06:39 | #16 (permalink) |
No Life Poster Join Date: Mar 2010
Member: 1274135 Status: Offline Thanks Meter: 157 | Huawei's TRT-TL10 account removal completed To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode ------------------------------------------------------------------------- Starting Auto detect Warning: Set modem mode fail Detected Qualcomm Android Device at COM7 Removing security protection... Connecting to server Authorization successful Device Model: TRT-TL10 Firmware: HL1TRTM-TL10 Boot: Chipset-msm8940 5.1.0.1(0I7R)_SBL1 System: System 5.1.0.78(0D3C) IMEI A: 863559032796378 IMEI B: 863559033099608 Bt MAC address: 14:9D:09:A5:9D:B1 WiFi MAC address: 14:9D:09:A7:78:7C SN: 4NT7N17407012456 Board SN: 7N4BML174D097574 Vendor/Country code: cmcc/cn Auto detect done. Performed by 1.0.0.1 Software version. ------------------------------------------------------------------------- Starting Reset Huawei ID Resetting your device Reset Huawei ID done. Performed by 1.0.0.1 Software version. Last edited by Octopus box; 06-02-2018 at 08:20. |
The Following User Says Thank You to 308981113 For This Useful Post: |
06-04-2018, 06:55 | #17 (permalink) |
Member: 1274135 Status: Offline Thanks Meter: 157 | Huawei PLK-UL01H successfully solved ID Device Model: Huawei HiSilicon Device Firmware: PLK-UL00C17B908 Boot: PLK-C00B908_BOOT Fastboot: PLK-C00B000_FASTBOOT System: PLK-C00B908_SYSTEM Recovery: (unknow) IMEI A: 867628023245376 IMEI B: 867628022927131 Bt MAC address: 7C:7D:3D1:6A:E0 WiFi MAC address: 7C:7D:3D1:72:B0 SN: MYV0215918000349 Board SN: 023HFW159K008697 Vendor/Country code: cmccchannel/cn Auto detect done. Performed by 1.0.0.1 Software version. ------------------------------------------------------------------------- Starting Reset Huawei ID Resetting your device Reset Huawei ID done. Performed by 1.0.0.1 Software version. |
06-04-2018, 08:19 | #18 (permalink) |
Member: 1274135 Status: Offline Thanks Meter: 157 | Huawei PRO-AL00X Reset FRP successfully done Starting Reset FRP Put the phone in 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode Total interfaces: 1 Device Model: PRA-AL00X IMEI A: 866342034819341 IMEI B: 866342034836519 SN: SQRNW17812014700 Initializing Reset FRP process Connecting to server Writing Reset FRP data Reset FRP done. Performed by 1.0.0.1 Software version. |
06-04-2018, 14:14 | #19 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,806 | Huawei Y7 Prime 2017 BOOTLOADER CODE READ DONE HI CONNECT PHONE IN NORMAL MODE |
The Following User Says Thank You to profkefah For This Useful Post: |
06-04-2018, 14:23 | #20 (permalink) |
Member: 2371500 Status: Offline Thanks Meter: 5,806 | Huawei Y7 Prime 2017 TRT-L21A FRP REMOVE DONE HI just connect device in fastboot mode |
06-04-2018, 17:21 | #21 (permalink) |
Super Moderator Join Date: Jul 2008 Location: Villa del rosario/Nsd Colombia
Member: 813309 Status: Offline Thanks Meter: 1,912 | CAM-L03 IMEI Repair successfully done !!! Code: Performed by 1.0.0.1 Software version. ------------------------------------------------------------------------- Starting Connect Warning: Can't get device model. Warning: Can't get IMEI/MAC info. Removing security protection... Connecting to server Authorization successful Reading basic data... Reading secure data... Device Model: CAM-L03 Firmware: CAM-B120 Boot: DailyBuild_201712130607_BOOT Fastboot: DailyBuild_201712130607_FASTBOOT System: CAM-L03C900B120_SYSTEM Recovery: (unknow) IMEI A: 861092037632994 Bt MAC address: 44:C3:46:D7:32:AE WiFi MAC address: 44:C3:46:D7:26:F5 SN: NSXDU17210004571 Board SN: DU3UGD172D060278 Vendor/Country code: claro/la Connect done. Performed by 1.0.0.1 Software version. ------------------------------------------------------------------------- Starting Repair Info Reading basic data... Reading secure data... Writing public keys... Identifying security... Repairing IMEI A... Resetting your device Repair Info done. Performed by 1.0.0.1 Software version.
__________________ Please do not Personal Message me for help or troubleshooting. They will be ignored. Use the forums! Last edited by Octopus box; 06-05-2018 at 05:09. |
The Following User Says Thank You to Braycel For This Useful Post: |
06-07-2018, 20:44 | #22 (permalink) |
Member: 813309 Status: Offline Thanks Meter: 1,912 | SCL-L03 Reset FRP Successfully Done Code: 2018-06-07 19:35:37.381 Welcome to Octoplus/Octopus Huawei Software v.1.0.0.5 2018-06-07 19:35:37.384 2018-06-07 19:35:37.387 To enable 'Manufacture' mode dial 2018-06-07 19:35:37.394 - for Qualcomm and Hisilicon based models: *#*#2846579#*#* 2018-06-07 19:35:37.399 ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode 2018-06-07 19:35:37.402 2018-06-07 19:35:37.404 To enable 'Fastboot' mode 2018-06-07 19:35:37.408 1. Power off the phone. Remove SD and SIM cards 2018-06-07 19:35:37.413 2. Press 'Vol-' and insert USB cable 2018-06-07 19:35:37.416 3. Wait until phone enters 'Fastboot' mode 2018-06-07 19:35:37.493 Refreshing serial ports list 2018-06-07 19:35:37.518 Found COM ports: 2018-06-07 19:35:37.520 Loading application settings 2018-06-07 19:35:37.521 Saved skin number 0 2018-06-07 19:35:37.528 Init finished 2018-06-07 19:35:37.567 Enter show event 2018-06-07 19:36:01.561 Refreshing serial ports list 2018-06-07 19:36:01.576 Found COM ports: 2018-06-07 19:36:26.480 2018-06-07 19:36:26 GMT ------------------------------------------------- 2018-06-07 19:36:26.484 Starting Reset FRP 2018-06-07 19:36:26.485 2018-06-07 19:36:26.487 Put the phone in 'Fastboot' mode 2018-06-07 19:36:26.490 1. Power off the phone. Remove SD and SIM cards 2018-06-07 19:36:26.492 2. Press 'Vol-' and insert USB cable 2018-06-07 19:36:26.495 3. Wait until phone enters 'Fastboot' mode 2018-06-07 19:36:26.500 Selected device SCL-L03 2018-06-07 19:36:27.517 Total interfaces: 1 2018-06-07 19:36:27.519 Interface 0: flags: 1, name(73): \\?\usb#vid_18d1&pid_d00d#89e9d209#{f72fe0d4-cbcb-407d-8814-9ed673d0dd6b} 2018-06-07 19:36:28.318 Device Model: SCL-L03 2018-06-07 19:36:28.323 S/N: WTR7S15C25008533 2018-06-07 19:36:28.325 Initializing Reset FRP process... 2018-06-07 19:36:28.721 Connecting to server... 2018-06-07 19:36:30.212 FRP unlock 0 2018-06-07 19:36:30.614 Writing erase FRP data 2018-06-07 19:36:31.218 Writing Reset FRP data... 2018-06-07 19:36:31.621 2018-06-07 19:36:31.624 Reset FRP done. 2018-06-07 19:36:31.627 Performed by 1.0.0.5 Software version.
__________________ Please do not Personal Message me for help or troubleshooting. They will be ignored. Use the forums! Last edited by Octopus box; 06-08-2018 at 04:46. |
06-09-2018, 20:46 | #23 (permalink) |
Member: 2371500 Status: Offline Thanks Meter: 5,806 | Huawei Y7 Prime 2018 LDN-L21 FRP REMOVE DONE HI just connect device in fast boot mode Last edited by Octopus box; 06-10-2018 at 09:43. |
06-10-2018, 17:20 | #24 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Dubai.
Member: 625961 Status: Offline Sonork: 100.1590447 Thanks Meter: 1,285 | HUAWEI P10 Lite WAS-LX1A Reset FRP Successfully Done by Octopus Huawei Tool HUAWEI P10Lite FRP Done by Octopus Huawei Tool Starting Reset FRP Put the phone in 'Fastboot' mode Power off the phone. Remove SD and SIM cards Press 'Vol-' and insert USB cable Wait until phone enters 'Fastboot' mode Total interfaces: 1 Device Model: WAS-LX1A IMEI A: 8-------------- IMEI B: 8-------------- SN: 2XJ------------- Initializing Reset FRP process Connecting to server Writing erase FRP data Writing Reset FRP data Reset FRP done. Performed by 1.0.0.1 Software version. Last edited by Octopus box; 06-11-2018 at 05:11. |
The Following User Says Thank You to WAJID PNR For This Useful Post: |
06-12-2018, 14:03 | #25 (permalink) |
Freak Poster Join Date: Aug 2011
Member: 1639426 Status: Offline Sonork: khurram136 Thanks Meter: 94 | huwaei RNE-L21 frp done thanks octopus team 2018-06-12 04:37:26.434 Welcome to Octoplus/Octopus Huawei Software v.1.0.0.1 2018-06-12 04:37:26.436 2018-06-12 04:37:26.437 To enable 'Manufacture' mode dial 2018-06-12 04:37:26.442 - for Qualcomm and Hisilicon based models: *#*#2846579#*#* 2018-06-12 04:37:26.444 ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode 2018-06-12 04:37:26.445 2018-06-12 04:37:26.446 To enable 'Fastboot' mode 2018-06-12 04:37:26.447 1. Power off the phone. Remove SD and SIM cards 2018-06-12 04:37:26.449 2. Press 'Vol-' and insert USB cable 2018-06-12 04:37:26.450 3. Wait until phone enters 'Fastboot' mode 2018-06-12 04:37:26.452 Change app skin 0 2018-06-12 04:37:26.471 Refreshing serial ports list 2018-06-12 04:37:26.910 Found COM ports: 2018-06-12 04:37:26.910 1: COM3 USB Serial Port 2018-06-12 04:37:26.911 2: COM1 Communications Port 2018-06-12 04:37:26.911 Loading application settings 2018-06-12 04:37:26.912 Saved skin number 15 2018-06-12 04:37:26.914 Init finished 2018-06-12 04:37:26.924 Enter show event 2018-06-12 04:37:26.925 Change app skin 0 2018-06-12 04:38:35.560 Enter show event 2018-06-12 04:38:35.560 Change app skin 0 2018-06-12 04:38:37.692 ------------------------------------------------------------------------- 2018-06-12 04:38:37.693 Starting Reset FRP 2018-06-12 04:38:37.694 2018-06-12 04:38:37.695 Put the phone in 'Fastboot' mode 2018-06-12 04:38:37.696 1. Power off the phone. Remove SD and SIM cards 2018-06-12 04:38:37.697 2. Press 'Vol-' and insert USB cable 2018-06-12 04:38:37.698 3. Wait until phone enters 'Fastboot' mode 2018-06-12 04:38:38.819 Total interfaces: 1 2018-06-12 04:38:38.820 Interface 0: flags: 1, name(81): \\?\usb#vid_18d1&pid_d00d#ffy5t18319049226#{f72fe0 d4-cbcb-407d-8814-9ed673d0dd6b} 2018-06-12 04:38:40.219 Device Model: RNE-L21 2018-06-12 04:38:40.220 IMEI A:xxxxxxxxxxxxxxx 2018-06-12 04:38:40.221 IMEI B: xxxxxxxxxxxxxx 2018-06-12 04:38:40.223 SN: FFY5T18319049226 2018-06-12 04:38:40.224 Initializing Reset FRP process 2018-06-12 04:38:40.619 Connecting to server 2018-06-12 04:38:44.370 Writing erase FRP data 2018-06-12 04:38:45.208 Writing Reset FRP data 2018-06-12 04:38:45.209 2018-06-12 04:38:45.209 Reset FRP done. 2018-06-12 04:38:45.21 Performed by 1.0.0.1 Software version. 0 |
The Following User Says Thank You to khurram136 For This Useful Post: |
06-15-2018, 08:49 | #26 (permalink) |
Member: 1274135 Status: Offline Thanks Meter: 157 | Huawei MIA-AL00 one second accounts successfully reseted Welcome to Octoplus/Octopus Huawei Software v.1.0.0.1 To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode ------------------------------------------------------------------------- Starting Auto detect Warning: Set modem mode fail Detected Qualcomm Android Device at COM7 Removing security protection... Connecting to server Authorization successful Device Model: MLA-AL00 Firmware: HL1MLAM Boot: MLAC00B170_BOOT System: MLAC00B170_SYSTEM Recovery: MLAC00B170_RECOVERY IMEI A: 863292034880343 IMEI B: 863292036001021 Bt MAC address: F0:43:47:41:CB:03 WiFi MAC address: F0:43:47:41:C1:3E SN: EJL4C16A31002201 Board SN: 4C3TMB16AY065180 Vendor/Country code: all/cn Auto detect done. Performed by 1.0.0.1 Software version. ------------------------------------------------------------------------- Starting Reset Huawei ID Resetting your device Reset Huawei ID done. Performed by 1.0.0.1 Software version. Last edited by Octopus box; 06-15-2018 at 08:57. |
06-16-2018, 04:31 | #27 (permalink) |
Member: 1274135 Status: Offline Thanks Meter: 157 | Huawei TRT-AL00 Huawei account was successfully reseted Welcome to Octoplus/Octopus Huawei Software v.1.0.0.1 To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode ------------------------------------------------------------------------- Starting Auto detect Warning: Set modem mode fail Detected Qualcomm Android Device at COM7 Removing security protection... Connecting to server Authorization successful Device Model: TRT-AL00 Firmware: HL1TRTM-AL00 Boot: Chipset-msm8940 5.1.0.1(0MQD)_SBL1 System: System 5.1.0.78(0UOQ) IMEI A: 865767039719214 IMEI B: 865767039876477 Bt MAC address: 04:4F:4C:FD:9C:63 WiFi MAC address: 04:4F:4C:FD:F1:87 SN: QDY4C17831000007 Board SN: 4C4PNY1793029759 Vendor/Country code: all/cn Auto detect done. Performed by 1.0.0.1 Software version. ------------------------------------------------------------------------- Starting Reset Huawei ID Resetting your device Reset Huawei ID done. Performed by 1.0.0.1 Software version. Last edited by Octopus box; 06-16-2018 at 08:46. |
07-26-2018, 20:49 | #30 (permalink) |
Member: 813309 Status: Offline Thanks Meter: 1,912 | Huawei SCL-L03 Repair IMEI done Code: Starting Auto detect Detected Qualcomm Android Device at COM51 Removing security protection... Connecting to server... Authorization successful Device Model: SCL-L03 Firmware: HL3SCALEM Boot: SCL-L03C45B130_BOOT System: SCL-L03C45B130_SYSTEM Recovery: SCL-L03C45B130_RECOVERY MEID: 00000000000000 PESN: 00000000 IMEI A: 867539021053664 IMEI B: 867539021053664 Bluetooth MAC: 98:E7:F5:20:71:B3 WiFi MAC: 98:E7:F5:20:4D:C2 S/N: WTR7S15C25008533 Board S/N: 7S3FSG15CR051837 Vendor Code: tigo Country Code: co Auto detect done. Performed by 1.0.2 Software version. 2018-07-26 19:47:31 GMT ------------------------------------------------- Starting Repair Info Repairing Product Name... Error: Repair Product Name failed Repairing IMEI A... Resetting your device
__________________ Please do not Personal Message me for help or troubleshooting. They will be ignored. Use the forums! Last edited by Octopus box; 07-27-2018 at 05:01. |
