Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Sharp
Old 11-23-2005, 22:16   #1 (permalink)
Platijet's Avatar
Member: 26279
Thanks Meter: 274
Thumbs up All about sharp cables
GX10-GX10i-GX20:
only COM cable or USB to COM converter cable.is the same for data/unlock/flash.
pinouts: http://forum.gsmhosting.com/vbb/show...14&postcount=9
GX15-GX17-GX25:
only USB cable,not COM.for data and unlock use sipmle original USB cable.
FOR FLASH YOU NEED NEC 3G CABLE OR USB CABLE WITH CHARGING FUNCTION(see pic1).
caution:usually you can't use flash cable for unlock.
GX30-GX30i-TM100:
you can use USB and COM cable for data BUT ONLY COM CABLE WITH EXTERNAL POWER FOR FLASH AND UNLOCK(see pic2).
3G SEMC PHONES (802-902 etc) :
you can use USB and COM cable for data BUT ONLY COM CABLE OR USB TO COM CONVERTER CABLE FOR FLASH AND UNLOCK.(see the pic3 for VIDEO CONNECTOR pinouts).the most famoys in this case is the 4 in 1 CRUISER cable.
YOU CAN USE ALSO GX30 CABLE(connected to the charging connector ofcourse) but in this case speed will be too slow(115200).Also SPST work's better with that cable.
since now every new thread or post(except this thread) about sharp cable will be deleted without any warning.
The Following 11 Users Say Thank You to Platijet For This Useful Post:
Old 11-25-2005, 23:25   #2 (permalink)
Member: 80571
Thats a bt confusing though where do buy one ready made anyway..
Old 11-25-2005, 23:39   #3 (permalink)
GSM SNIPER's Avatar
Member: 27291
Thanks Meter: 81
I am looking for Gx15 USB drivers
Hi Platijet !
Can you help me to find a drivers for Gx15 USB cable ??
Please!
The Following User Says Thank You to GSM SNIPER For This Useful Post:
Old 11-26-2005, 12:05   #4 (permalink)
Platijet's Avatar
Member: 26279
Thanks Meter: 274
searsch on sales section.
GX15/17/25 usb drivers for data and unlock: http://rapidshare.de/files/8176961/G...r_b14.exe.html
GX15/17/25 usb drivers for flash: http://rapidshare.de/files/8177246/gxdnldrv.rar.html
The Following 2 Users Say Thank You to Platijet For This Useful Post:
Old 11-26-2005, 17:10   #5 (permalink)
Member: 175119
Drivers for flashing gx15 are included in the gx15 upgrading tool:
http://sharp.hacked.in/gx15/the%20gx...0installer.zip
You must install this software, and when is istalled connect your phone WITHOUT battery to your usb cable (with charging funcion) and then windows will auto install drivers from the folder of gx15 upgrading tool.
Once drivers are installed open the program and flash the phone
Old 12-03-2005, 10:55   #6 (permalink)
hamzaa's Avatar
Member: 84694
Thanks Meter: 9
can someone please upload schematic for gx25 usb unlock cable.thanx
ps:@platijet
this has not been uploaded in this thread
Old 12-04-2005, 02:21   #7 (permalink)
Crazy Poster
Member: 147907
Thanks Meter: 9
@Platijet
If I don't have a Nec 3g cable and I want to make a USB cable with charging function (for gx25), do I wire up the cable as in pic 1? Where do I add the + and - for external power source? Finally, what is the ideal voltage for external power?
Old 12-04-2005, 03:20   #8 (permalink)
Crazy Poster
Member: 147907
Thanks Meter: 9
I found this diagram on the forums for GX15, it should work alright shouldn't it? Please clarify the voltage required. Thanks Platijet.
The Following 6 Users Say Thank You to mdp28 For This Useful Post:
Old 12-09-2005, 08:03   #9 (permalink)
Crazy Poster
Member: 147907
Thanks Meter: 9
For anyone else looking at this thread wire up the cable as in the picture above this post. It works fine, tried and tested successfully by me. I was a bit confused about all this charging function cable and external power crap. The cable takes its power from your usb port (5v), no other power is needed.
Old 12-09-2005, 14:10   #10 (permalink)
Platijet's Avatar
Member: 26279
Thanks Meter: 274
nobody says that external power needed for this cable
Old 12-12-2005, 17:51   #11 (permalink)
OLYMPIOS's Avatar
Member: 93568
Thanks Meter: 44
can i unlock sharp 703?
Old 12-14-2005, 16:34   #12 (permalink)
karismajaya's Avatar
Member: 42805
Thanks Meter: 16
can use cruiser cable sharp for unlock sharp GX25?
Old 12-14-2005, 17:30   #13 (permalink)
Platijet's Avatar
Member: 26279
Thanks Meter: 274
................................no................ ................
Old 12-19-2005, 15:57   #14 (permalink)
Member: 68008
Please provide GX30 correct USB to write the software definition, thanks
Old 12-28-2005, 14:55   #15 (permalink)
Cheater -Don't Deal with him-
chiragp's Avatar
Member: 106367
Sonork: 100.1577436
Thanks Meter: 2,452
as shown pic 2 i have modified cable but while unlocking gx30 i could not unlock it pls help i am using universal simlocker pls help using com cable with 9v batt
About Sharp 802SH Unlocking with Cruiser NeTRaW Cruiser Suite 21 05-09-2006 10:56
about Sharp 3G Tool v1.1, EUROPE and CHINESE Flash files in Support Area UnlockerPT SonyEricsson (USB-Smart) 7 09-16-2005 15:24
Question about Sharp 902 franklee628 Cruiser Suite 0 06-14-2005 02:00
i havequestion about sharp gx10i's IrDa Brandon_lee Sharp 0 05-01-2005 12:27
New site about Sharp (tools, unlocking, flashing) FreaX Sharp 132 03-23-2005 13:56
Page generated in 0.26862 seconds with 10 queries
