Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Sharp
Old 04-30-2006, 05:32   #46 (permalink)
Member: 259629
hi , every body ,we have usb data cable for sharp . good price and high quanlity
kitty:**************
email: *******************
this is not sales section.
Old 05-11-2006, 18:35   #47 (permalink)
Member: 274834
Hello, and Thanks
Thanks, about to try on GX15, much appreciated.
Originally Posted by neotrino
Drivers for flashing gx15 are included in the gx15 upgrading tool:
http://sharp.hacked.in/gx15/the%20gx...0installer.zip
You must install this software, and when is istalled connect your phone WITHOUT battery to your usb cable (with charging funcion) and then windows will auto install drivers from the folder of gx15 upgrading tool.
Once drivers are installed open the program and flash the phone
Old 05-12-2006, 20:19   #48 (permalink)
Member: 150697
Thanks Meter: 7
Originally Posted by baboom
Get it : http://www.i-phone.org/main/product....t=155&prod=226
P.S.
Why you don't try to use "search" button before posting ????
if i dont have RS232 on my computer, can I use GX30 COM cable on PS2 or RJ45?
edit:
I am not comfortable making the cable myself, so I would prefer if I could just buy a PS2 cable to use with my cruiser 4in1 or RJ45 to use with my alcatel USB-RJ45 adapter.
Old 05-13-2006, 07:14   #49 (permalink)
baboom's Avatar
Member: 59935
Thanks Meter: 131
@Kevbodian
You must bye USB to Serial converter cable (USB to RS232).
Then plug the Sharp30 serial cable into the converter.
Old 05-13-2006, 21:57   #50 (permalink)
Member: 275918
Hy to everybody, i'm trying to understand how can i modify my usb cable (of gx30)... i want cut the usb terminal and plug the rs232... it is possible? there is a pin connector scheme?
Sorry for my bad english..
ps: in the last gx30i firmware, is there italian language?
Thanx!!!!
Old 05-14-2006, 10:21   #51 (permalink)
baboom's Avatar
Member: 59935
Thanks Meter: 131
Thanx!!!!
Its not posibble.
You must bye serial (RS232) cable to use with GX30 phones.
baboom
Old 05-14-2006, 13:00   #52 (permalink)
Member: 275918
Its not posibble.
baboom
There is the schematic ciruit of the cable? For auto made it? I look the pic 2, but it's not complete.
Thanx a lot!
Old 05-16-2006, 04:37   #53 (permalink)
Member: 259629
hello , everybody ,could you tell me what is the different of flash cable / usb data cable / unlocking cable ??? thanks
Old 05-26-2006, 18:22   #54 (permalink)
Member: 275918
is this the cirrect cable?
i've make it, but don't work!
Old 05-27-2006, 12:36   #55 (permalink)
baboom's Avatar
Member: 59935
Thanks Meter: 131
This is the correct schematic.
Should work !!!
Old 05-27-2006, 14:39   #56 (permalink)
Member: 275918
Thank you baboom!
But it still not work, is there a document that explain the exact procedure to connect the cable to phone, with the program of Platijet? The com setting is the default setting? The software work with winxp sp2?
Thank for the patiences.
Old 05-28-2006, 08:45   #57 (permalink)
baboom's Avatar
Member: 59935
Thanks Meter: 131
Thank you baboom!
First read carefully HERE
Second check your cable. (check Rx-Tx pins , pin 8 must be connected together with pin 10 , 10k resistor needed to Tx pin)
The flasher works well on WinXP SP2.
Old 06-29-2006, 14:59   #58 (permalink)
Member: 302773
Hi!
I have an unlocked sh903, which is seen by computer as a sx833 device.
Where I can get the USB drivers for the SX833, since they dissapeared from the well-known address http://www.sharp-phone.com/_assets/d...ROM_all_b5.exe and I couldn't find them anywhere else, not even on p2p nets?
Thank you in advance!
Old 06-29-2006, 15:04   #59 (permalink)
Platijet's Avatar
Member: 26279
Thanks Meter: 273
modem: http://www.sharp-phone.com/binary.ph...00_all_b16.exe
USB: http://www.sharp-phone.com/binary.ph...00_all_b16.exe
Old 06-29-2006, 15:22   #60 (permalink)
Member: 302773
I've already tested the drivers in these links and they're not working,
since they're looking for a 903 device and the firmware inside is sx833.
BR\mobot
About Sharp 802SH Unlocking with Cruiser NeTRaW Cruiser Suite 21 05-09-2006 10:56
about Sharp 3G Tool v1.1, EUROPE and CHINESE Flash files in Support Area UnlockerPT SonyEricsson (USB-Smart) 7 09-16-2005 15:24
Question about Sharp 902 franklee628 Cruiser Suite 0 06-14-2005 02:00
i havequestion about sharp gx10i's IrDa Brandon_lee Sharp 0 05-01-2005 12:27
New site about Sharp (tools, unlocking, flashing) FreaX Sharp 132 03-23-2005 13:56
Page generated in 0.21452 seconds with 10 queries
