09-29-2016, 17:29 | #46 (permalink) | |
What to do: 1. Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files here - Index of pub/drivers/ Also you can insert Smart-Card into another Card-Reader. 2. Run DongleManager 3. Update Dongle firmware now ONLY ONE TIME | |
10-09-2016, 13:44 | #47 (permalink) |
Junior Member Join Date: Jul 2013
Member: 1990273 Status: Offline Thanks Meter: 3 | help me i m facing cm2 dongle not found error Box/Dongle type selected: Main Infinity-Box/Dongle ---------- Process started: 09-Oct-16 6:13:39 PM ---------- DongleManager [Infinity-Box] v1.66 [09-Oct-16 6:13:39 PM] PC HWID: D79D44308C6E7922F94037A2D58405ED Card-Reader: FT SCR2000 0 HWID: 0108A08424881292 Type: Main Infinity-Box/Dongle S/N: -------- Version: Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. |
10-09-2016, 19:38 | #48 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
What to do: 1. Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files here - Index of pub/drivers/ Also you can insert Smart-Card into another Card-Reader. 2. Run DongleManager 3. Update Dongle firmware now ONLY ONE TIME - DO NOT update Smart-Card many times otherwise your account will be locked automatically after 3 tries | |
10-10-2016, 06:05 | #49 (permalink) |
Member: 1990273 Status: Offline Thanks Meter: 3 | i m facing this error now.. Box/Dongle type selected: Main Infinity-Box/Dongle ---------- Process started: 10-Oct-16 10:25:13 AM ---------- DongleManager [Infinity-Box] v1.66 [10-Oct-16 10:25:13 AM] PC HWID: D79D44308C6E7922F94037A2D58405ED Card-Reader: FT SCR2000 0 HWID: 0108A08424881292 Type: Main Infinity-Box/Dongle S/N: -------- Version: Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Service stage 1 confirmed Securing session... Session secured ok Upgrading dongle... DO NOT disconnect Box/Dongle ! WAIT 3-4 minutes ! Error upgrading applets: Card returned error - 0000 at 319/8500 |
10-10-2016, 10:17 | #50 (permalink) | |
11-17-2016, 12:53 | #51 (permalink) |
Junior Member Join Date: Jan 2011 Location: Tanzania
Member: 1485647 Status: Offline Thanks Meter: 1 | Dear Sir, I have Main Infinity-Box/Dongle that i was updating but unfortunately the power went off now am stuck as i cannot use the box anymore. The following are the messages i get whenever i try to revive the box/dongle. I have used both the Dongle Manager v1.67 and CardID v1.06 which gives the following messages: DONGLE MANAGER: ==== [11/17/2016 1:02:20 PM] ==== Scanning... HWID: 0000D5F100001942 Select Box/Dongle Type: instead of Autodetect Box/Dongle type selected: Main Infinity-Box/Dongle HWID: 0000D5F100001942 Box/Dongle type selected: Main Infinity-Box/Dongle ---------- Process started: 11/17/2016 1:03:11 PM ---------- DongleManager [Infinity-Box] v1.67 [11/17/2016 1:03:11 PM] PC HWID: E8B6DF8C2B999DAFC47E5F46503B6FAD Card-Reader: Gemalto e-gate Smart Card 0 HWID: 0000D5F100001942 Type: Main Infinity-Box/Dongle S/N: -------- Version: Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 Infinity-Box CardID v1.06: Database: ./FSCard.ini Card-Reader: Gemalto e-gate Smart Card 0 ATR: 3B759400006202020201 Historical ATR bytes: 0062020202 Card Manager: A0000000030000 SerialNumber: -------- ROM: Integrated Circuit Fabricator: 4090 Integrated Circuit Type: 0062 OS: Identifier: 0011 Release Date: 0202 Release Level: 0100 EEPROM: Fabrication Date: 8171 Serial Number: -------- Batch Identifier: 0000 Module Fabricator: 1942 Module Packaging Date: 8171 IC Card Manufacturer: 1943 IC Em******* Date: 8171 Pre Personalizer: 1944 Pre Personalization Date: 8171 Pre Personalization Equipment Identifier: 0000C116 Personalizer: FFFF Personalization Date: FFFF Personalization Equipment Identifier: FFFFFFFF m_iopCard.Serial: 0000D5F100001942 Extended Info is not available: Card returned error message . ISO7816 error 0x6A86 (Wrong parameter(s) P1-P2. Incorrect parameters P1-P2 ) Your assistance is highly appreciated. |
11-17-2016, 16:01 | #52 (permalink) | |
Update it once again now. | |
11-17-2016, 19:06 | #53 (permalink) |
Member: 1485647 Status: Offline Thanks Meter: 1 | Thank you InfinityHelp, I get the following On running the Dongle Manager: FIRST STEP: - Register, Update dongle firmware, Activate Software: Box/Dongle type selected: Main Infinity-Box/Dongle ---------- Process started: 11/17/2016 8:14:52 PM ---------- DongleManager [Infinity-Box] v1.67 [11/17/2016 8:14:52 PM] PC HWID: E8B6DF8C2B999DAFC47E5F46503B6FAD Card-Reader: Gemalto e-gate Smart Card 0 HWID: 0000D5F100001942 Type: Main Infinity-Box/Dongle S/N: -------- Version: Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Service stage 1 confirmed Securing session... Session secured ok Upgrading dongle... DO NOT disconnect Box/Dongle ! WAIT 3-4 minutes ! Applet upgrade ok Checking Dongle Identification... Identification Ok. Finalizing... Finalizing ok Process completed SECOND STEP: - Read Dongle Serial Number, Username, Password, Configuration DongleManager [Infinity-Box] v1.67 [11/17/2016 8:53:11 PM] PC HWID: E8B6DF8C2B999DAFC47E5F46503B6FAD Scanning... Box/Dongle found: Main Infinity-Box/Dongle Card-Reader: Gemalto e-gate Smart Card 0 HWID: 0000D5F100001942 Box/Dongle Serial No (S/N): -------- Firmware version: 0132.02 "UK edition" status: Off Last launched Application: 0000 v.0000 => Activations: - 00: Main Infinity-Box/Dongle v.0132 THIRD STEP: - Read Online Service Username/Password On Pressing the Process Button, i get the following results: DongleManager [Infinity-Box] v1.67 [11/17/2016 8:57:30 PM] PC HWID: E8B6DF8C2B999DAFC47E5F46503B6FAD Scanning... Box/Dongle found: Main Infinity-Box/Dongle Card-Reader: Gemalto e-gate Smart Card 0 HWID: 0000D5F100001942 Box/Dongle Serial No (S/N): -------- Firmware version: 0132.02 "UK edition" status: Off Last launched Application: 0000 v.0000 => Activations: - 00: Main Infinity-Box/Dongle v.0132 => Online Service Account: http://www.infinity-box.com/service - Username: ---------- - Password: -------- Question: The username and password provided now fails to log me in to the Online Service Account. Should i login with the username and password or reset the previous username password. Login with the Username or Password provided now displays "Wrong Username or Password" Your assistance is highly appreciated. |
11-17-2016, 21:21 | #54 (permalink) | |
if you have updated IOS password and forgot it you should reset password. To reset password click here - http://www.infinity-box.com/support/?r=17 Instruction - http://www.infinity-box.com/support/?r=16&help=1 | |
01-31-2017, 19:55 | #56 (permalink) |
Junior Member Join Date: Jan 2012 Location: CUCUTA-COLOMBIA Age: 31
Member: 1715183 Status: Offline Sonork: 100.1626322 Thanks Meter: 3 | Box/Dongle found: Main Infinity-Box/Dongle HWID: 000259F3FF021982 Box/Dongle type selected: Main Infinity-Box/Dongle Box/Dongle found: Main Infinity-Box/Dongle ---------- Process started: 31/01/2017 12:18:04 p.m. ---------- DongleManager [Infinity-Box] v1.67 [31/01/2017 12:18:04 p.m.] PC HWID: 1838C7981A0243683AC68A2DD155203C Card-Reader: DITS CCID Smart Card Reader 0 HWID: 000259F3FF021982 Type: Main Infinity-Box/Dongle S/N: 235459F3 Version: 0134.02 Conectando al servidor Conexion establecida con el servidor Comprobando version de DongleManager ... tu DongleManager esta updateada hasta el momento Comprobando Identificaciond de dongle... Autenticación en el servidor... Autenticación exitosa Service stage 1 confirmed Asegurando sesion... Session Asegurada Actualizando dongle... DO NOT disconnect Box/Dongle ! WAIT 3-4 minutes ! La Card a Devuelto un error - 6A82 at 8489/8500 Error en actualizacion de los applets: La Card a Devuelto un error - 6A82 at 8489/8500 Disconnected |
05-18-2017, 18:08 | #57 (permalink) |
Insane Poster Join Date: Jan 2008
Member: 685001 Status: Offline Thanks Meter: 18 | please help === DongleManager [Infinity] v1.70 [18-May-17 22:04:54] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Gemalto e-gate Smart Card 0 HWID: 00015E3F00001942 === Process started: 18-May-17 22:04:54 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 |
05-19-2017, 11:43 | #58 (permalink) | |
05-20-2017, 08:48 | #59 (permalink) |
Freak Poster Join Date: Apr 2010 Location: BARGARH Age: 33
Member: 1291109 Status: Offline Sonork: 100.1607039 Thanks Meter: 19 | === DongleManager [Infinity] v1.70 [5/20/2017 13:13:51] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Gemalto e-gate Smart Card 0 HWID: 00032FFA00001942 === Process started: 5/20/2017 13:13:51 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 help me |
05-20-2017, 10:45 | #60 (permalink) | |
