Old 11-27-2008, 20:32   #1 (permalink)
Member: 91558
Thanks Meter: 66
zte a211 unlock done
COM3 [VCP0] selected
module v2.48
Action: unlock
unlock method: smart fast
Model: ZTE-A211
Checking data, wait...
19200 autodetect
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:31FC:000C
Connecting, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6223,E05
Date: 2000.00.00
Version: 1.0
Version: PE-PT-TMN-P109A2V1.0.2B05
Version: 07AZTENJ23_07A_PMJ
44 byte(s) read
imei: 35547302011433
connection Ok
157 byte(s) read
reading data...
building new data...
writing data...
145 byte(s) read
reading data...
writing data...
verifying...
verification Ok
done
Finished, time used: 12 sec
Remove/Install battery now !
thanks to infinity team
The Following User Says Thank You to Terrab.s For This Useful Post:
Old 11-27-2008, 21:02   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Thank you very much for test report !
Each test report with attached logs is very important for us so we can see how is Infinity-Box
software works and what is possible problems (so we will be able to fix it) and successfully done work.
Old 07-06-2009, 11:26   #3 (permalink)
Member: 190217
Thanks Meter: 3
can you please tell me wich cable did you use.
Thanks and regards
The Following User Says Thank You to Ronin69 For This Useful Post:
Old 07-08-2009, 09:51   #4 (permalink)
Member: 130995
Thanks and regards
Hello,
Here is an instruction how to get cable/pinout information:
1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update
2. run Infinity-Box Shell
3. select required model
4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information)
Here is an example of information given by Infinity-Box Shell:
Here is information how to build your own cable:
http:///vbb/showthread.php?t=342807
Old 10-09-2010, 11:58   #5 (permalink)
Member: 1373116
Thanks Meter: 3
ZTE A211 pinout PANFINDER
RX1
TX2
Old 05-24-2014, 20:41   #6 (permalink)
kikodog's Avatar
Member: 37736
Sonork: 100.108250
Thanks Meter: 222
https://www.youtube.com/watch?v=gHHs...oztbwjwaryztmt&fs=1" width="644" height="390">https://www.youtube.com/watch?v=gHHs...oztbwjwaryztmt&fs=1" />https://www.youtube.com/watch?v=gHHs...oztbwjwaryztmt">http://www.youtube.com/watch?v=https://www.youtube.com/watch?v=gHHs...oztbwjwaryztmt
@InfinitySupport: ZTE-A136(ZONG) Unlock Done yawarniazi Infinity-Box 143 02-03-2009 12:45
ZTE A35 unlock done without any problem mitch_md3 Infinity-Box 3 01-16-2009 00:06
zte A36 unlock done but still locked tolski Infinity-Box 8 05-29-2008 14:57
vodafone zte 225 unlock done vodafone_banha FuriousGold 7 02-24-2008 21:49
Page generated in 0.15451 seconds with 9 queries
