10-14-2014, 07:35 | #19921 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Romania,Sinaia
Member: 637351 Status: Offline Thanks Meter: 167 | Code: Connect phone on selected interface... Closing Zune and Launcher process... Looks like done, Zune will not start until PC reboot Phone found! WP7x Nokia Phone detected Read info... Ok === Main Info === Phone : RM-835|NOKIA Lumia 610 Phone SwVer : 1066.0000.8779.12201 Phone IMEI : 354127057050455 ProductCode : 059P6Q8 HW Version : 112.1569.1.0 === SimLock === State : Not Found [Not Locked] === Other === Battery Life : 63 SerialNum : 4A75BB1AB Base Code : 059L3R3 ModuleCode : 0205127 NCSD Ver : 1.9 BT MAC : 38192F695C670000FFFFFF Wlan MAC : 38192F6B312400 Public ID: 47870C497AFFFE3EDE5B9F90B2A95C Done! Core : v1.97 , WP7x FlashEngine : v7.8 ==== Settings : Reset EFS : Disabled Secure Erase : Disabled ==== Flash Files selected : AMSS : RM835_12w20_1_prod_generic_amss.esco WP : RM835_12201_prod_425_02_boot.esco UDA : RM835_12w20_1_prod_generic_user_area_erase.esco Check files done, All files are Ok Setting device to OSBL mode... Waiting for USB device... Connection opened successfully Establish connection with device... Kick ... OSBL alive Init Ok OSBL info Prt : 1.1 Ver : 1.0.0.0 Bld : 1 Tms : 22.02.2012 / 09:37:26 ==== AMSS ==== Processing : RM835_12w20_1_prod_generic_amss.esco amss.mbn.cert , Hash : 0A3B18ABC63D2CF5A23BEBC1500E56E22163B717 amss.mbn.enc , len : 0x0123C690 , Type : Data Will flash 1 regions AMSS flashing done ==== WINDOWS PHONE ==== Processing : RM835_12201_prod_425_02_boot.esco boot.img.cert , Hash : 0A3B18ABC63D2CF5A23BEBC1500E56E22163B717 boot.img , len : 0x14C3E400 , Type : Data Will flash 22 regions Windows Phone flashing done ==== USER DEFINED AREA ==== Processing : RM835_12w20_1_prod_generic_user_area_erase.esco user_area_erase.cert , Hash : 0A3B18ABC63D2CF5A23BEBC1500E56E22163B717 UDA file detected, will erase defined region Using Normal Erase method UDA erase done UDA flashing done Flashing done! Flashing time : 00:02:08 Reboot device Ok Phone disconected! Connect phone on selected interface... |
The Following User Says Thank You to sebY7676 For This Useful Post: |
10-14-2014, 09:19 | #19922 (permalink) | |
No Life Poster Join Date: May 2008 Location: hall road pakistan
Member: 782530 Status: Offline Thanks Meter: 8,136 | 1st in the world china tablet one cent 3g CHINA TABLET ONE CENT CENT 5 READ FLASHFILE info Read FlashfIle Logs Quote:
Regard FullFlashPak | |
The Following 4 Users Say Thank You to FullFlashPak For This Useful Post: |
10-14-2014, 09:19 | #19923 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Pakistan
Member: 192810 Status: Offline Sonork: Some people NEED change Thanks Meter: 860 | Samsung I8552 high copy Read Flash Done by Infinity Box |
The Following User Says Thank You to DUNIYA JAMAL For This Useful Post: |
10-14-2014, 10:19 | #19924 (permalink) |
Member: 192810 Status: Offline Sonork: Some people NEED change Thanks Meter: 860 | Voice V10 Mt6572 Read Flash Done by Infinity Box |
10-14-2014, 12:00 | #19925 (permalink) |
Member: 770503 Status: Offline Thanks Meter: 1,215 | YXTEL A301 Code: Operation : Read User Code [ v1.00 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 137 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Check data... Can take some time User Code : 01931396 Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
The Following User Says Thank You to mbiborna For This Useful Post: |
10-14-2014, 12:02 | #19926 (permalink) |
Member: 192810 Status: Offline Sonork: Some people NEED change Thanks Meter: 860 | Nokia 225 Rest user Lock without Userdata loss Done by Best Dongle |
10-14-2014, 12:42 | #19927 (permalink) |
No Life Poster Join Date: May 2012 Location: InfinityBox CM2
Member: 1763238 Status: Offline Thanks Meter: 370 | Micromax A76 Read flash 3.64 GB Code: Operation : Check / Read Info [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 80 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E355530304D02288D86E4A09D DA Stat : v4.2 on BBID : 0x88 Configure emi settings DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : M00U5 [eMMC] : FLASH_CID : 1501004E355530304D02288D86E4A09D [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Initial info read Ok! Done! Elapsed: 00:00:09 Reconnect Power/Cable! Operation : Read Flash [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 80 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E355530304D02288D86E4A09D DA Stat : v4.2 on BBID : 0x88 Configure emi settings DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : M00U5 [eMMC] : FLASH_CID : 1501004E355530304D02288D86E4A09D [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... USBDL : Init HSUSB Ok! Read Ok , collect info Brand : Micromax ProdName : A76 ProdModel : Micromax A76 Device : A76 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1 Saved to : C:\Documents and Settings\THE MOBILE SHOP\Desktop\MT6572__MICROMAX___Micromax_A76___A76__A76__ALPS.JB3.MP.V1__Android_4.2.2__20130905_022706.ispff Done! Elapsed: 00:16:32 Reconnect Power/Cable! |
The Following User Says Thank You to ishant For This Useful Post: |
10-14-2014, 14:39 | #19928 (permalink) |
Member: 1763238 Status: Offline Thanks Meter: 370 | Spice M-5566 Read info Code: Operation : Check / Read Info [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 80 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : F8FC42B68523EE915023E762AAB73F5C BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS : 0x00000000 , 0x00000000 Done! Elapsed: 00:00:22 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 80 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : F8FC42B68523EE915023E762AAB73F5C BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS : 0x00000000 , 0x00000000 Reading Flash Conent now ... Read Flash now Read Ok , 4194304 bytes read Check and collect compile info File_Info : RECTANGLE_S01A_PCB01_gprs_MT6250_S00.SPICE_M-5566_IND_VER8_0.bin FileVersion : SPICE_M-5566_IND_VER8_0 Saved to : C:\InfinityBox\CM2MTK\Read_out\RECTANGLE_S01A_PCB01_gprs_MT6250_S00.SPICE_M-5566_IND_VER8_0.bin Code: Operation : Flash [ v1.03 ] ======= Flash Files set for flashing : [ MCU ] : RECTANGLE_S01A_PCB01_gprs_MT6250_S00.SPICE_M-5566_IND_VER8_0.bin 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 80 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : F8FC42B68523EE915023E762AAB73F5C BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS : 0x00000000 , 0x00000000 File_Info : RECTANGLE_S01A_PCB01_gprs_MT6250_S00.SPICE_M-5566_IND_VER8_0.bin FileVersion : SPICE_M-5566_IND_VER8_0 Flash now Erase region , wait ... Write data , wait ... Write : RECTANGLE_S01A_PCB01_gprs_MT6250_S00.SPICE_M-5566_IND_VER8_0.bin Done! Elapsed: 00:00:35 Reconnect Power/Cable! |
10-14-2014, 14:44 | #19929 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Nokia 700 Code: Core : v1.97 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual -> File : RM-670_M012.19.emmc.fpsx not found! Check it! Check FlashFiles, Please, wait... Files Set for Flashing : CNT : RM-670_113.010.1506_U12.01_79u.uda.fpsx Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Custom mode selected Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok WMDRM read ... Ok Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001060 PUBLIC ID: 122C0000FFFB7C406AC6B7C0A7BC07769A14DCE8 ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 006000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : BD43E84B21F8AC7B9C66EA939355891E2A08044A ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 351956051138525 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\InfinityBox_install_BEST_v1.97\Backup\Cert\351956051138525.rpl === SW Version Check === - > REFLASHING === SW Version Check === ===Flashing [CNT]=== Erase : Processing RM-670_113.010.1506_U12.01_79u.uda.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing RM-670_113.010.1506_U12.01_79u.uda.fpsx Total writen 762 blocks TIME : Write time : 00:00:29 CNT Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot Flashing done! Total flash time : 00:00:30 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 700 Software Info: V 79u_sr2_12w20.8 20-08-12 RM-670 (c) Nokia IMEI: 351956051138525 Ape Version: 113.010.1506 Product code: 059G2P6 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Resetting LifeTimer Reset Done! Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:01:10 Connect phone on selected interface... |
The Following User Says Thank You to saeedullah_khan For This Useful Post: |
10-14-2014, 14:46 | #19930 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | Phone Lock Code Code: registered to: saeedullah_khan Connect phone on selected interface... Backup Certificates now... Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF EBL Loader : Custom Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL : Custom EBL sent Ok EBL : Quantum_Bootloader_10.56_M1S1 Boot done! Read CRT block... Read EEPROM block... SL3 Simlock found (XGOLD) ... WMDRM Key found ... ===== USER CODE ===== Executing Code extraction... - > Phone Lock Code : 22647 ===== USER CODE ===== MMC password not found (not set) NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\InfinityBox_install_BEST_v1.97\Backup\Cert\352439056014644_XG213.rpl Connect phone on selected interface... |
10-15-2014, 10:15 | #19932 (permalink) |
No Life Poster Join Date: Apr 2011 Location: Ukraine Khmelnytsky
Member: 1558427 Status: Offline Thanks Meter: 630 | Alcatel one toutch 282 Unlock to [MTK tab] Read Full & Eproom to [Alcatel 280x] tab Unlock to Format FS metod Code: COM5 [ProlificSerial0] selected Модуль v4.13 Action: reset settings ("format ffs") Модель: _Autodetect MT6205-6239 NOR Перевірка даних, чекайте ... Пристрій повинен бути вимкненим! Натисніть і тримайте кнопку включення! 19200 autodetect Ініціалізація [6223:8A08]... CPU: MT6223 висока швидкість завантаження On chip: 0011:601A:A00C status: 01 Connecting at 19200, wait... Відпустіть кнопку включення! Пристрій знайдений, чекайте ... Залізо: MT6223,E08 Дата: 2000.00.00 Версія: 1.0 Версія: MAUI.08A.W08.36.SP1.V28.F1 Версія: JRD23_NEP_08A_HW визначення структури #2... 1 2 3 5 7 8 9 11 13Готовий 80 byte(s) read IMEI: 86194100744612 зв'язок Ok building list... Готовий items to clear: 113 попередження: wrong packet cs елементів очищено: 112 of 113 building list... Готовий залишилося елементів: 1 Закінчено, знадобилося часу: 1 min 38 sec Від'єднайте / підключіть батарею! Read Full Eprom: Code: COM5 [ProlificSerial0] selected Модуль v4.13 Модель: Alcatel-280X Перевірка даних, чекайте ... покращений метод визначення флеші включений Action: read ffs/eeprom ffs/eeprom backup enabled, it may takes several minutes ! ====> Бут ... Натисніть і тримайте кнопку включення! 19200 fixed Підключення, чекайте ... Ініціалізація [6223:8A08]... CPU: MT6223 висока швидкість завантаження On chip: 0011:601A:A00C status: 01 Розмір пакету завантаження: 0400 Відпустіть кнопку включення! Бут Done ====> Ініціалізація ... detecting chip #00 in region #00... Флеш 01227E22102201:2BEA0000000000 Флеш Amd AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 detecting chip #01 in region #00... Флеш 01227E22102201:2BEA0000000000 Флеш Amd AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 визначена кількість флеш / областей: 02/01 Ініціалізація Done ====> Встановлення швидкості ... 460800 Встановлення швидкості Done ====> Ініціалізація додатки ... interesting cpu type found Ініціалізація додатки Done ====> Перевірка цілісності даних ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36_SP1_V28_F1.BIN project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 00700000/00100000 TCL-ID identification Версія: B3A provider: 282X-2CALGR1 Customization CMB3AK60 Customization XMB3AK60 TCL-ID identification done rom info structure: [standard] type (05) TCL-ID is present ffs/eeprom address assigned: 00700000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished статус блокування SIM: disabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Перевірка цілісності даних Done ====> Перевірка вмісту флеші ... Перевірка вмісту флеші Done ====> Створення резервної копії ... читання Alcatel-280X_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36_SP1_V28_F1__ffs... збережено: D:\ремонт\прога\Infinity BOX\alcatel\282\Alcatel-280X_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36_SP1_V28_F1__ffs_20141015-121357.B0E.bin оригінальний IMEI: 00000000000000 збережено: E:\Program Files\InfinityBox\MModule\backup_security\Alcatel-280X_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36_SP1_V28_F1__system_log__00000000_20141015-121431.B0X.bin Закінчено, знадобилося часу: 3 min 44 sec Від'єднайте / підключіть батарею! |
The Following User Says Thank You to Kolumb For This Useful Post: |
10-15-2014, 12:57 | #19933 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Comilla
Member: 465069 Status: Offline Sonork: 100.1661026 Thanks Meter: 190 | Huawei Y511-U30 flash file read ok Start at : [10/15/2014 / 4:14:00 PM] Operation : Read Flash [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 30 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164048601A377C7714F DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164048601A377C7714F [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Read Ok , collect info Brand : HUAWEI ProdName : Y511-U30 ProdModel : HUAWEI Y511-U30 Device : HWY511-U AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1 Saved to : E:\InfinityBox\CM2MTK\Flash\MT6572__HUAWEI__HUAWEI _Y511-U30__Y511-U30__HWY511-U__ALPS.JB3.MP.V1__Android_4.2.2__20131201_104202. ispff Done! |
The Following User Says Thank You to somonahmed For This Useful Post: |
10-15-2014, 14:21 | #19934 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | 110 Flash Done :) Code: Connect phone on selected interface... Core : v1.97 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm827__03.47.mcusw PPM : rm827__03.47.ppm_m4 CNT : rm827__03.47.image_m4_059N2R6 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.49_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 353656052666148 IMEI 2 : 353656052666155 PCcode : 059N2R0 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : F:\Flashing Softwares\12+Best dongle\InfinityBox\BEST\Backup\Cert\353656052666148_XG213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm827__03.47.mcusw Image : rm827__03.47.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:05 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01940000 Erasing, wait ... Erase done, time : 00:02:02 Write , Start : 0x40280000 , Len : 0x018C0000 Flashing , wait ... Region flash done, time : 00:00:34 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0x73FB ===Flashing [PPM]=== File : rm827__03.47.ppm_m4 Image : package_m4.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41BC0000 , Len : 0x00600000 Erasing, wait ... Erase done, time : 00:00:15 Write , Start : 0x41BC0000 , Len : 0x0038DD78 Flashing , wait ... Region flash done, time : 00:00:04 CRC check passed , 0xEF6A ===Flashing [CNT]=== File : rm827__03.47.image_m4_059N2R6 Image : package_m4_059N2R6.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x421C0000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:04:03 Write , Start : 0x421C0000 , Len : 0x00F80000 Flashing , wait ... Region flash done, time : 00:00:26 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:08 No write data, skip CRC check passed , 0x1047 Flashing done! Total flash time : 00:07:43 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 110 Software Info: V 03.47 31-05-13 RM-827 (c) Nokia IMEI: 353656052666148 PPM version : V 03.47 31-05-13 RM-827 (c) Nokia M4 Product code: 059N2R0 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:08:31 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
The Following User Says Thank You to syed tuqeer For This Useful Post: |
10-15-2014, 15:01 | #19935 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | X1-01 Factory Reset Done :) (Via Jaf Interface) Code: Connect phone on selected interface... Opening Connection... Device Location: 00000032 Connect Ok! Initializing Connection... JAF Firmware: 01.B4 Authentificate JAF BOX... TEA Authentication Completed... JAF S/N ODJAF000 boot - Ok Switch jaf to FBUS... FbusMode set Ok Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Resetting selected items... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:13 |
