Old 01-15-2020, 07:32   #62026 (permalink)
Luckey1's Avatar
Member: 2197212
Sonork: N/A
Thanks Meter: 680
Rivo s625 read user code done
Operation : Read UserCode [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 28 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6260_S0000
BB_CPU_SN : 1FCEA5DAB7046724B15CC07534A52415
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
InitRes : 00000000
DEV[0] : C800 6000 1800 0000
DEV[1] : 0000 0000 0000 0000
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00F4 , [GigaDevice] GD25LQ128
[0] : FLASH_DIE : 00C8 0060 0018 0000
[0] : FLASH_LEN : 0x01000000
INT_RAM : 0x0000D000
EXT_RAM : 0x00800000
Read ExtData
Sorting ExtData
Reading UserCode
Active : Yes , Code : 5588
Privacy Lock :6
Done!
Elapsed: 00:00:34
Reconnect Power/Cable!
Old 01-15-2020, 10:29   #62027 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,999
QMobile X30 Flash
Brand     : TINNO
ProdName  : QMobile X30
ProdModel : QMobile X30
Device    : QMobile X30
AndroidVer: 4.4.2
MTKxCPU   : MT6572
MTKxPRJ   : ALPS.KK1.MP7.V1
Done!
Elapsed: 00:00:09
Scatter Load Ok , BaseBand : MT6572 , Project : s4050ap , Storage : EMMC
Files found : 11 , Set to Flash : 10
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A48344732611101C19B8A5C6235
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , a2G4
[eMMC] : FLASH_CID : 90014A48344732611101C19B8A5C6235
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID    : 0xD5229C2529493CF118F22B7ADA5BB6AA
INT RAM    : 0x00020000
EXT RAM    : 0x20000000 [512 MiB]
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : s4050ap , Storage : EMMC
Setting : AFF verify :  Disabled
Setting : HW verify :  Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3724 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000C00000-0x0000000000100000
Erase : 0x0000000002900000-0x00000000E5E00000
Flash Pre-Erase Done, time used : 00:00:00
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_s4050ap.bin
Preloader Sent , Init passed
PartCount : 0012
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:02:50
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:03:14
Old 01-15-2020, 10:30   #62028 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,999
Nokia 1 Frp
Brand     : Nokia
ProdName  : Frontier_00WW
ProdModel : Nokia 1
Device    : FRT
AndroidVer: 8.1.0
Done!
Elapsed: 00:00:09
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 7 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
SecCfgVal : 0x01000000
BromVer   : 0x00FF
BLVersion : 0x0002
BootLdrSS : SIGNED with SPRELOADER
Processing DA stage
DA Select done, will use SecMode DA
Running DA ver.4.2 on BBID : 0x9B
eMMC Flash : 484A0190613447383537A5326189253E
[eMMC] : FLASH_INF : [HYNIX] , 2a4G8
[eMMC] : FLASH_CID : 90014A483847346132A537353E253561
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID    : 0xD5229C25640204222A84C22FFE4F8064
EXT RAM    : 0x40000000 [1 GiB]
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:13
Old 01-15-2020, 10:31   #62029 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,999
OPPO A37f Pattern Read
Brand     : OPPO
ProdName  : A37f
ProdModel : A37f
Device    : A37f
AndroidVer: 5.1.1
SWVersion : A37fEX_11.A.28_INT_028_201710081545
Manufact. : OPPO
SysPatch  : LMY47V
DevComTime: 10/8/2017 9:26:49 AM
QLMxCPU   : MSM8916
USERData : NORMAL
GCSec    : EMPTY
Done!
Elapsed: 00:00:18
Operation : Read PatternLock [ v1.16 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 410 [MSM8916]
ID_BLOCK_S : 26D3FDBE
ID_BLOCK_L : CB3D57AF0E94818C7BD0202DEAB1C109
ID_BLOCK_L : 8EC54BE2D77EE065985738F1F3322C2F
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ]
ExtInfo : 0x00004000/00004000/00001000/00001000/00000200
Boot Ok!
Read Ok! Trying decrypt ...
PatternLock sequence : 4589
Done!
Elapsed: 00:00:26
Old 01-15-2020, 10:31   #62030 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,999
QMobile i6i Flash
Brand     : QMobile
ProdName  : QMobile i6i
ProdModel : QMobile i6i
Device    : QMobile
AndroidVer: 5.1
MTKxCPU   : MT6580
MTKxPRJ   : ALPS.L1.MP6.V2_TINNO6580.WE.L
Done!
Elapsed: 00:00:28
Scatter Load Ok , BaseBand : MT6580 , Project : s5030 , Storage : EMMC
Files found : 9 , Set to Flash : 8
Ready to Flash!
======= Flash
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x94
eMMC Flash : 150100464A32374D42026D9DCCE7A25F
[eMMC] : FLASH_INF : [SAMSUNG] , BM72J
[eMMC] : FLASH_CID : 150100464A32374D42026D9DCCE7A25F
DEV RID    : 0xD5229C25D94926AB344A8129437296FE
EXT RAM    : 0x30000000 [768 MiB]
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6580 , Project : s5030 , Storage : EMMC
BL : Skip checking by User request!
BL : BatteryLevel : 3186 mV
BL : [WARNING] : BatteryLevel LOW!!!
Total blocks to Erase : 1
Erase : 0x0000000001C80000-0x00000000E6300000
Flash Pre-Erase Done, time used : 00:00:02
Preloader Download skipped by user request!
PartCount : 0014
Repartition Done!
Use FLN Mode
Flash now : LK
Image Flash Ok
Flash now : BOOT
Image Flash Ok
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : SECRO
Image Flash Ok
Flash now : SYSTEM
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USERDATA
Image Flash Ok
Flash Write Done, time used : 00:03:02
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:03:21
Old 01-15-2020, 10:32   #62031 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,999
QMobile i8i PRO Frp
Patch Level    : NRD90M
Display ID     : QMobile_i8i PRO_MP_31_01
Ver. Incmt     : 62
Ver. CodeName  : REL
Ver. Release   : 7.0
Sec. Patch     : 2017-12-05
Build Time     : 1518318739
Product Model  : QMobile i8i PRO
Product Brand  : Qmobile
Product Name   : i8i_PRO
Product Device : i8i_PRO
Product Board  : sp7731cea
Product Manfct : Qmobile
Board Platform : sc8830
Product Info   : i8i_PRO
Update DataBase ...
Platform Version: MOCORTM_W17.14.5_Debug
Project Version:   sc7731C_CP0_modem
BASE  Version:    TM_BASE_W17.14.5
MMI Version:       sc7731C_modem
HW Version:        sc7731C_CP0_modem
CMP_Time : 04-07-2017 14:07:41
MODEM TAG : MOCORTM_W17.14.5_Debug_TM_BASE_W17.14.5_sc7731C_CP0_modem_sc7731C_CP0_modem_sc7731C_modem
UserData : STATE : PLAIN
Done!
Elapsed: 00:01:29
Operation : Format FS / Reset Settings [ v2.04 ]
Mode : Reset FRP
BootMode : FLASH
1. Power off device, wait 10-15 seconds
2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- )
3. Insert cable in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC7731x_BASE : SC7731C_eMMC_1GB_NS
Sending Init Boot ...
Boot sent!
Kick FDL ...
BootVersion : Spreadtrum Boot Block version 1.1
Protocol setup ...
Port speed : 921600
Sending Flash Boot ...
Boot sent!
Kick FLASH FDL ...
ProtoEx :  : TRCC not supported!
FDL : Control transfered!
Boot Done!
Wipe Ok : FRP
Done!
Elapsed: 00:01:06
Old 01-15-2020, 10:33   #62032 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,999
GFive Falak Format
Operation : Format FileSystem [ v1.05 ]
1. Power off device
2. Press and hold BootKey or use BootCable
3. Insert cable and battery in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootSource  :  InternalLibrary
BootVersion : Infinity SCR SC6531E Loader v 1.2
Port speed : 921600
FDL Flash  : Control transfered!
Boot Done!
CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ]
Make backup of sensetive data
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_0E6641347378_NVM.nv
Executing FormatFFS ...
Format FFS Done!
Done!
Elapsed: 00:00:24
Old 01-15-2020, 10:33   #62033 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,999
QTab_V3 Flash
Brand     : QTab
ProdName  : QTab_V3
ProdModel : QTab V3
Device    : QTab
AndroidVer: 4.4.2
MTKxCPU   : MT6572
MTKxPRJ   : ALPS.KK1.MP7.V1.43
Done!
Elapsed: 00:00:05
Scatter Load Ok , BaseBand : MT6572 , Project : qmobile12c_9120 , Storage : EMMC
Ready to Flash!
======= Flash
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 8801034E436172642042A1543156A231
[eMMC] : FLASH_VEN : 0x88 , OEM : 0103
[eMMC] : FLASH_INF : [FORESEE] , draC
[eMMC] : FLASH_CID : 8801034E436172642042A1543156A231
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000
[eMMC] : FLASH_LEN : 0x00000001CE100000
[eMMC] : FLASH_UCP : 7393 MiB [eMMC 8 GiB]
DEV RID    : 0xD5229C2542CF1464A83D667250F5ED64
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : qmobile12c_9120 , Storage : EMMC
BL : BatteryLevel : 3525 mV
Erase : 0x0000000001000000-0x0000000000100000
Erase : 0x0000000002D00000-0x00000001CA320000
PartCount : 0012
Repartition Done!
Use FLN Mode
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:02:39
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:02:58
Old 01-15-2020, 10:34   #62034 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,999
G Five Champ Format
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_188FEB0105C8_NVM.nv
Format FFS Done!
Done!
Elapsed: 00:00:23
Old 01-15-2020, 11:24   #62035 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Remi 5 Plus Mi Acount Reset Doone With King Infinity CM2
Operation : Reset Settings [ v1.16 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 625 [MSM8953]
ID_BLOCK_S : 52AA2EB6
ID_BLOCK_L : A81172501CEBDD80314B1550C4B64689
ID_BLOCK_L : 7282F85F9EB9A9817EC90AFD7AEC386D
Running FireHose on BBID : MSM8953 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ]
ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200
Storage : MFR : 0x45 , VENDOR : SANDISK , NAME : DL2032
Boot Ok!
MIAccount reset passed!
Device may relock back on WiFi/Network enable!
Done!
Elapsed: 00:00:22
Old 01-15-2020, 14:09   #62036 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
symphony v98 frp reset done
Card found : CA7920A6 , v0139
Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.04
Load IDBase v1119 Ok!
Mode : Reset FRP
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : Symphony : i68
Boot sent!
Kick FDL ...
ERROR : FDL NOT started!
Error : Fail to boot FDL!
Unsupported device with selected fdl! Change settings!
Mode : Reset FRP
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
Wipe Ok : FRP
Done!
Elapsed: 00:00:37
The Following 2 Users Say Thank You to kothamamun For This Useful Post:
Old 01-15-2020, 14:48   #62037 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
symphony v98 identify and read flash done by great cm2
Operation : Identify [ v2.04 ]
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
Device info :
Patch Level    : OPM2.171019.012
Display ID     : OPM2.171019.012 release-keys
Ver. Incmt     : 1536803841
Ver. CodeName  : REL
Ver. Release   : 8.1.0
Sec. Patch     : 2018-08-05
Build Time     : 1536804131
Product Info   : k121
Product Model  : V98
Product Brand  : Symphony
Product Name   : V98
Product Device : V98
Product Manfct : Symphony
Product Board  : k121
Board Platform : sp7731e
Update DataBase ...
Platform Version: MOCORTM_17C_W18.23.4_P2_Debug
Project Version:   pike2_pub
BASE  Version:    FM_BASE_17C_W18.23.4_P2
HW Version:        sc7731e_modem
MODEM TAG : MOCORTM_17C_W18.23.4_P2_Debug_FM_BASE_17C_W18.23.4_P2_sc7731e_modem_pike2_pub
Done!
Elapsed: 00:01:48
Operation : Read FW [ v2.04 ]
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
Device info :
Ver. CodeName  : REL
Product Info   : k121
Product Model  : V98
Product Name   : V98
AndroidVer : 8
VlnrLevel : 0x00
SP7731E__Symphony__V98__8.1.0__OPM2.171019.012__k121
Read : prodnv.img
ExtSparse : Compression ratio : 19%
Read : phase.cfg
Read : recovery.img
Read : tos.bin
Read : sml.bin
Read : u-boot.bin
Read : boot_logo.bmp
Read : fastboot_logo.bmp
Read : nvitem_w.bin
Make : persist.img
Read : gnssmodem.bin
Read : gnssbdmodem.bin
Read : modem_wcn.img
Read : modem_w.bin
Read : deltanv_w.bin
Read : gdsp_w.bin
Read : pm_sys.bin
Read : boot.img
Read : system.img
ExtSparse : Compression ratio : 70%
Make : cache.img
Read : vendor.img
ExtSparse : Compression ratio : 49%
Read : vbmeta.img
Make : userdata.img
Read : u-boot-spl.bin
Firmware size : 0x4D9961A4 ( 1.21 GiB )
Android Info saved : _Android_info.txt
Done!
Elapsed: 00:35:25
The Following User Says Thank You to kothamamun For This Useful Post:
Old 01-15-2020, 15:12   #62038 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Oppo A37f QLM Pattren Reset Done With Lose Data With King Infinity CM2
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_S : 26D84E80
ID_BLOCK_L : 05FF9561CC5A47423D12E2E32C77FFCF
ID_BLOCK_L : B3C24CDFD043EB789D583DEAF837212A
Boot Ok!
PatternLock sequence : 75369
Done!
Elapsed: 00:00:19
Old 01-15-2020, 19:35   #62039 (permalink)
Manikanika81's Avatar
Member: 2897012
Thanks Meter: 400
TECNO KC6 frp lock reset done by cm2
Operation : Identify [ v2.07 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM146)
MODE : PRELOADER PORT
PORT : 146
Waiting BOOT ack ...
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
     CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200
     TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x00000005
BROM : SecMode  : SBC+SDA
BROM : PRELOADER PORT
MODE : TECNO : SECURE_v2 | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA_SWSEC.bin
AGENT : Found MT6761
AGENT : MTK_DOWNLOAD_AGENT
     BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
     DA : AGENT started!
DA : SYNC
     DA : MODE : PRELOADER
DA : EXT_RAM initialized!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
        SRAM: 0x00080000 [ 512,00 KB ]
        DRAM: 0x80000000 [ 2,00 GB ]
        EMMC: 700100464D42434541202723570D9649
        EMMC: VEN : KINGSTON | OEM : 01 | DEV : FMBCEA
        EMMC:
              BOOT1  : 0x00400000 [ 4,00 MB ]
              BOOT2  : 0x00400000 [ 4,00 MB ]
              RPMB   : 0x00400000 [ 4,00 MB ]
              USER   : 0x74A000000 [ 29,16 GB ]
        CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000
        RNID : 49ED93273F44961F7C33B093DD48B54
DA : USB : HIGH-SPEED
Boot done!
Patch Level    : PPR1.180610.011
Display ID     : KC6-H6114IJK-P-191005V117
Ver. CodeName  : REL
Ver. Release   : 9
Sec. Patch     : 2019-08-05
Build Time     : 1570283400
Product Model  : TECNO KC6
Product Brand  : TECNO
Product Name   : H6114
Product Device : TECNO-KC6
Product Manfct : TECNO MOBILE LIMITED
Product Info   : kc6_h6114
Product Board  : TECNO-KC6
Board Platform : mt6761
USERDATA : ENCRYPTED
Backup sensetive data [ 10 ]
Backup path : Backup\MT6761__49ED93273F44961F07C33B093DD48B54\
[0] Read : PRELOADER
Backup done!
STORAGE : LifeStatus : Verify NOT supported by DA/HW!
Done!
Elapsed: 00:00:32
Operation : Reset Settings/Format FS [ v2.07 ]
PORT : 146
BROM : Init BROM
BROM init passed!
BROM : DA sent
     DA : AGENT started!
DA : SYNC
        EMMC:
Boot done!
Format Ok : USERDATA
Format Ok : CACHE
Format Ok : RESET PROTECTION
Done!
Elapsed: 00:00:55
The Following 2 Users Say Thank You to Manikanika81 For This Useful Post:
Old 01-16-2020, 07:46   #62040 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,551
Smile LYF-F211S AND:6.0 SP9820E KAIOS READ NVRAM & BRUSH BAG Done
SUCCESSFULLY READ NVRAM & BRUSH BAG(LYF-F211S AND:6.0 SP9820E KAIOS)USB
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC9820E_BASE : SC9820e_eMMC_512MB_RS
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
Device info :
Patch Level : MRA58K
Display ID : LYF-F211S-000-02-14-130619
Ver. Incmt : LYF-F211S-000-02-14-130619
Ver. CodeName : REL
Ver. Release : 6.0
Sec. Patch : 2016-07-01
Build Time : 1560422652
Product Model : F211S
Product Brand : LYF
Product Name : sd208_cww_221
Product Device : sd208_cww_221
Product Board : sd208_cww_221
Product Manfct : Skyworth
Board Platform : sp9820e
Product Info : sd208_cww_221
Update DataBase ...
SecInfo :
IMEI[1] : 911xxxxxxxxxx32
IMEI[2] : 86xxxxxxxxxxx20
IMEI[3] : 86xxxxxxxxxxx38
WIFIMAC : FFFFFFFFFFFF
BT_MAC : FFFFFFFFFFFF
SIMLOCK : SignedType
Done!
Elapsed: 00:01:18
Operation : Read NVM [ v2.04 ]
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
NVMng : SecurityInfo
NVMng : Backup Ok , 0x000C61C4
Done!
Elapsed: 00:00:31
NOTE : AFTER READ FULL INFO CLOSE TOOL AND REOPEN AND WILL GET YOUR MODEL IN LIST SELECT AND READ BRUSH BAG SUCCESSFULLY(HINT IF GET ERROR PRESS SHIFT KEY TO READ BRUSH BAG)
Extra : Ignore CriticalPart Verify : Enabled
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : LYF : F211S
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
Device info :
Ver. CodeName : REL
Ver. Release : 6.0
Product Brand : LYF
AndroidVer : 6
VlnrLevel : 0x02
SP9820E__Skyworth__F211S__6.0__LYF-F211S-000-02-14-130619__MRA58K__sd208_cww_221
Read : u-boot.bin
Read : sml.bin
Read : tos.bin
Read : modem_l.bin
Read : ldsp_l.bin
Read : gdsp_l.bin
Read : nvitem_l.bin
Read : pm_sys.bin
Read : boot.img
Read : recovery.img
Make : persist.img
Read : system.img
ExtSparse : Compression ratio : 32%
Make : userdata.img
Make : cache.img
Read : prodnv.img
ExtSparse : Compression ratio : 16%
Make : udisk.img
Read : deltanv_l.bin
Read : phase.cfg
Firmware size : 0x17CC5408 ( 380.77 MiB )
Done!
Elapsed: 00:27:53
THANKS INFINITY-BOX TEAM
The Following User Says Thank You to gracy_elec For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.75710 seconds with 10 queries
