01-10-2012, 08:00 | #15151 (permalink) |
Crazy Poster Join Date: Nov 2010 Location: City Centre
Member: 1451726 Status: Offline Thanks Meter: 13 | Alcatel-V770X module v3.75 Device: Alcatel-V770X, V770A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6219:8B03:8B02]... CPU: MT6219 high speed boot On detected CPU: MT6226MA chip: 0031:AB29:A000 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22302200:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\InfinityBox\MModule\backup_security\id.7E7F6DB1 .[JRD26_06A_PCB01_GPRS_MT6226M_S02.MAUI_06A_W06_52_S P1_V31.BIN_FF269AC7].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 7E7F6DB1 rom info ver: 05 sw version: JRD26_06A_PCB01_GPRS_MT6226M_S02.MAUI_06A_W06_52_S P1_V31.BIN project-id: MAUI.06A.W06.52.SP1.V31, C79A26FF code offset: 00000000 ffs offset/size [01]: 01200000/00E00000 TCL-ID identification version: 22A provider: V770X-2ASFRE1 customization: CG22DF61 customization: XG22DF61 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 01200000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_Communication_Inc_SH_Branch area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XG22DF61 customization name adjusted flash: 01227E22302200:2BEA0000000000 flash: 01227E22302200:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 01227E22302200:2BEA0000000000 flash: 01227E22302200:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 3596xxxxxxxxxxx flash: 01227E22302200:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E22302200:2BEA0000000000 Finalization Done file saved: C:\InfinityBox\MModule\backup_security\Alcatel-V770X,V770A_JRD26_06A_PCB01_GPRS_MT6226M_S02.MAUI_ 06A_W06_52_SP1_V31__system_log_7E7F6DB1_FF269AC7_2 0120109-200553.B0X.bin Finished, time used: 4 min 3 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to 7seas For This Useful Post: |
01-10-2012, 12:08 | #15153 (permalink) |
No Life Poster Join Date: Aug 2009 Location: Future Age: 30
Member: 1093004 Status: Offline Thanks Meter: 4,382 | COM279 [VCP0] selected module v4.09 Action: "sp-unlock" unlock method: smart fast Model: Huawei-G6600_64mb Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: status: rom: Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: Date: Version: Version: Version: 82 byte(s) read imei: connection Ok 189 byte(s) read reading data... reading data #2... building new data... writing data... 177 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 38 sec Remove/Install battery now ! |
The Following User Says Thank You to dawood1208 For This Useful Post: |
01-10-2012, 21:53 | #15154 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Green Forest
Member: 1316000 Status: Offline Sonork: 100.1624093 Thanks Meter: 348 | COM3 [VCP5] selected module v4.13 Device: _Autodetect MT6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:7994:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #02 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #03 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #04 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #05 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #06 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #07 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #08 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #09 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #0A in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #0B in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #0C in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #0D in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #0E in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #0F in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 number of flash chip/regions detected: 10/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 7F227E220A2201:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00400000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent ==================== New firmware found (v.4.12, database date: 28.11.2011): SIMCOM23D_GEMINI_07B_PCB01_GSM_MT6223_S00.CY-T330-1_2012-32V01_01B02.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 04 sw version: SIMCOM23D_GEMINI_07B_PCB01_GSM_MT6223_S00.CY-T330-1_2012-32V01_01B02.BIN project-id: CY-T330-1_2012-32v01.01b02, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00060000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 003A0000 standard ffs/eeprom offset confirmed: 003A0000 detecting ffs/eeprom size... ffs/eeprom size: 00060000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:003A0000-003FFFFF firmware area: 00000000-0039FFFF detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent detecting ffs/eeprom structure pass 1... .......... ffs/eeprom: detect std location pass #1... ............... ffs/eeprom: detect ext location pass #1... .............. ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 7F227E220A2201:2BEA0000000000 Backup required data Done ====> Patch required data ... .............. lock area found Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 7F227E220A2201:2BEA0000000000 flash: 7F227E220A2201:2BEA0000000000 Write: lock-area-1 Write Done ====> Finalization ... Finalization Done Finished, time used: 1 min 36 sec Remove/Install battery now ! |
The Following User Says Thank You to net.tarik For This Useful Post: |
01-10-2012, 21:53 | #15155 (permalink) |
01-10-2012, 23:53 | #15156 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Under Blue
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | module v4.13 Action: reset settings ("format ffs") Model: _Autodetect MT6253 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: C100A3PLUS.GLS1.01.110315.01 Version: TELSDA53_SLIM_09A_HW ==================== New firmware found (v.4.13, database date: 22.12.2011): C100A3PLUS.GLS1.01.110315.01 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== detecting structure #2... 1 2 3 5 7 8 9 11 12 13 done 86 byte(s) read imei: 35373504204659 connection Ok warning: wrong packet cs building list... done items to clear: 155 warning: wrong packet cs warning: wrong packet cs items cleared: 155 of 155 building list... done items remains: 0 Finished, time used: 27 sec Remove/Install battery now ! |
The Following User Says Thank You to amn32 For This Useful Post: |
01-11-2012, 15:07 | #15158 (permalink) |
No Life Poster Join Date: May 2008 Location: persian Age: 43
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | Core version : 1.35 Rev : 1.5 Selected FlashSettings : Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-707_022.014_79.92_prd.core.fpsx PPM : RM-707_022.014_14.01_MEA_C_79.92_prd.rofs2.fpsx PPM2 : RM-707_022.014_C04.01_MEA1_79.92_prd.rofs3.fpsx CNT : RM-707_022.014_U06.01_79.92.uda.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Manual mode selected Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 2A100208BADC0344AF43C3FBA8346D6BB2E70D6A ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 11.48.0 Processing RAWLOADER... FLIC : 00680020 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 11.48.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : A777258432D3E9101D6160DBAC2702FCC602E752 ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 358609041737632 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : E:\BEST\Backup\Cert\358609041737632_2nd.rpl ===Flashing [MCU]=== Erase : Processing RM-707_022.014_79.92_prd.core.fpsx Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:06 Write : Processing RM-707_022.014_79.92_prd.core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 504 blocks TIME : Write time : 00:00:19 MCU Write done ADL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ===Flashing [PPM]=== Erase : Processing RM-707_022.014_14.01_MEA_C_79.92_prd.rofs2.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-707_022.014_14.01_MEA_C_79.92_prd.rofs2.fpsx CMT: Writing Hash CERT [SOS+ROFS2] Total writen 160 blocks TIME : Write time : 00:00:06 PPM Write done ADL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ===Flashing [PPM2]=== Erase : Processing RM-707_022.014_C04.01_MEA1_79.92_prd.rofs3.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-707_022.014_C04.01_MEA1_79.92_prd.rofs3.fpsx CMT: Writing Hash CERT [SOS+ROFS3] Total writen 407 blocks TIME : Write time : 00:00:00 PPM Write done ADL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ===Flashing [CNT]=== Erase : Processing RM-707_022.014_U06.01_79.92.uda.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:08 Write : Processing RM-707_022.014_U06.01_79.92.uda.fpsx Total writen 526 blocks TIME : Write time : 00:00:19 CNT Write done ADL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ADL: Close_Session Content: 000300000000030000000300000000 ADL: Reboot Flashing done! Total flash time : 00:01:01 Reboot phone now... Reading Phone Info.... Connected phone - Nokia X7-00 Software Info: V 92_11w25.1 01-07-11 RM-707 (c) Nokia IMEI: 358609041737632 Ape Version: 022.014 Product code: 059L738 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! AfterFlash operations done ;D Done! Elapsed: 00:01:22 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia X7-00 Software ver : V 92_11w25.1 01-07-11 RM-707 (c) Nokia IMEI : 358609041737632 Ape Ver : 022.014 APE Var : 022.014022.014.14.01022.014.C04.01 APE ADSP: 256 DSP Ver : 92_11w25 APE Test: rm707_ENO_11w15v001_prd PPM : CNT : Product SN : MDN403351 Product code : 059L738 Base Prd.code: 059J5W4 Module code : 0204661 Long Prod.SN : 0 Hardware info======= HWID : 1000 Retu : 40 Tahvo : 00 Batery: 3968 mV Camera: CMT BT: APE BT: HCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13. APE HW: 256 LCDVer: RF ic : Lock info =========== IMEI : 358609041737632 IMEI spNet : 3A 85 06 09 14 37 67 03 IMEI svNet : 33 85 06 09 14 37 67 13 F4 Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! Set phone in Normal mode... Restarting... Done! Connect phone on selected interface... |
The Following User Says Thank You to sirnavid2010 For This Useful Post: |
01-12-2012, 08:11 | #15159 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Mauritius Port Louis
Member: 762522 Status: Offline Thanks Meter: 156 | w377 unlock done COM28 [VCP0] selected module v1.38 Loading data, wait... Device: Motorola-W377 Action: unlock Press Power button now ! rom version: 0411 Connecting... booting... finalizing... working, one more step... flash: 0089:8813 working... Finished, time used: 3 min 16 sec Remove/Install battery now ! |
01-12-2012, 08:35 | #15160 (permalink) |
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | Core version : 1.35 Rev : 1.5 Selected FlashSettings : Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-625_50.1.001_prd.core.C00 PPM : RM-625_50.1.001_prd.rofs2.V12 PPM2 : RM-625_50.1.001_C01_prd.rofs3.fpsx CNT : RM625_50.1.001_000_000_U003.uda.fpsx Flashing phone now... Check files done... -> Check SW version... FlashFile version : 50.1.001 Phone version : V 40.1.003 -> Check SW version : Upgrade Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : E:\BEST\Backup\Cert\359287048682728_SIM_2nd.rpl Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Batery valtage : 3745 mV -> Batery voltage less, than 3,8V (3745mV). Continue at user risk Reboot.... Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006400C192101051105 CPU ID : RAPIDOv11 , Features : Dead-Test, USBRPL, WR/ER-USB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0530010C675A10525D568E2BB32BA99619CE130D ASIC MODE ID: 00 ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing RAP3NAND ... Processing PASUBTOC ... Processing PAPUBKEYS... Processing UPDAPP ... Boot Done! TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Auth done... ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing RM-625_50.1.001_prd.core.C00 Found 5 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT Result: 0000 Erasing area 0x00400000 - 0x007FFFFF, NAND, CMT Result: 0000 Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT Result: 0000 Erasing area 0x00D60000 - 0x09E5FFFF, NAND, CMT Result: 0000 Erase partition 0x0A Partition erase Ok Partitioning : Ok [5] TIME : Erase time : 00:00:00 Write : Processing RM-625_50.1.001_prd.core.C00 Total 417 [417/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*ENO] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS+CORE] CMT : Writing Hash CERT [SOS+ROFS1] TIME : Write time : 00:00:28 MCU Write done ===Flashing [PPM]=== Erase : Processing RM-625_50.1.001_prd.rofs2.V12 Found 1 areas to erase Erasing area 0x06CE0000 - 0x0915FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-625_50.1.001_prd.rofs2.V12 Total 81 [81/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS2] TIME : Write time : 00:00:05 PPM Write done ===Flashing [PPM2]=== Erase : Processing RM-625_50.1.001_C01_prd.rofs3.fpsx Found 1 areas to erase Erasing area 0x09160000 - 0x09E5FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-625_50.1.001_C01_prd.rofs3.fpsx Total 28 [28/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS3] TIME : Write time : 00:00:01 PPM Write done ===Flashing [CNT]=== Erase : Processing RM625_50.1.001_000_000_U003.uda.fpsx Found 1 areas to erase Erasing area 0x09E60000 - 0x0F47FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM625_50.1.001_000_000_U003.uda.fpsx Total 60 [60/0/0] blocks to write, writing... TIME : Write time : 00:00:05 CNT Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:00:42 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5233 Software Info: V ICPR72_11w10.3 24-03-11 RM-625 (c) Nokia IMEI: 359287048682728 Ape Version: V 50.1.001 Product code: 059B7L8 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:01:22 Connect phone on selected interface... |
01-12-2012, 09:14 | #15161 (permalink) |
Member: 1451726 Status: Offline Thanks Meter: 13 | Spice-D88N format COM6 [Serial3] selected module v3.75 Device: Spice-D88N Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6219:8B02:8B01]... CPU: MT6219 high speed boot On detected CPU: MT6226MA chip: 0031:1FC1:1C46 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: IACN26_07A_PMJ_PCB01_GPRS_MT6226M_S01.MAUI_07A_W07 _32_MP_V28.BIN project-id: MAUI.07A.W07.32.MP.V28, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/001E0000 rom info structure: [standard] type (04) TCL-ID is absent ffs/eeprom address assigned: 00E00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 98000300000001:2AEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:2AEA0000000000 Finalization Done Finished, time used: 56 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
01-12-2012, 11:50 | #15162 (permalink) |
No Life Poster Join Date: May 2007 Location: InsidE AndroiD Age: 37
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 473 | Alcatel S211 unlock done!! Code: COM12 [VCP0] selected module v1.38 Device: Alcatel-S211 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 203125 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-S211_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Alcatel-S211_eeprom_calibration-1_20120112-154644.80E.bin Read data done Check data ... Check data done Write ... ......... ......... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Write done Finished, time used: 3 min 37 sec Remove/Install battery now ! |
01-12-2012, 13:27 | #15163 (permalink) |
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | registered to: sirnavid Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - C2-02 Software ver : V 06.96 09-09-11 RM-692 (c) Nokia IMEI : 358641049358475 Ape Ver : APE Var : APE ADSP: DSP Ver : APE Test: PPM : V 06.96 09-09-11 RM-692 (c) Nokia MH1 CNT : Content: mh1_059H0R7 V 06.96 09-09-11 RM-692 (c) Nokia Product SN : CE913A5AI Product code : 059H0R7 Base Prd.code: 0593195 Module code : 0204666 Long Prod.SN : 0 Hardware info======= HWID : 2000 Retu : Tahvo : Batery: 3773 mV Camera: CMT BT: 19b5-22012 APE BT: APE HW: LCDVer: TPO RF ic : Lock info =========== IMEI : 358641049358475 IMEI spNet : 3A 85 46 01 94 53 48 07 IMEI svNet : 33 85 46 01 94 53 48 07 F5 Sl Conf : 001-01-00000000000 Sl Prof : 800000000003000-B Sl Aux : 000B0000 Hw Sig : 36F920DE7DF0C29D Provider : Default Test Operator Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; CRT308 Backup Created User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Core version : 1.35 Rev : 1.5 Selected FlashSettings : Check FlashFiles, Please, wait... Files Set for Flashing : PPM : rm692__06.96.ppm_m_a Flashing phone now... Check files done... -> SWversion check skipped : Custom mode selected Backup CRT308 data... CRT308 Backup Created Check communication with phone.... ADL req restart Communication verify done... Preparing... Check communication with phone... Batery voltage : 3783 mV -> Batery voltage less, than 3,8V (3783mV). Continue at user risk Reboot.... Connection opened successfully DBG : F00A1FB300020303010100FF CPUID : SGOLD 213 2nd boot Ok, 01 2nd ready, AA Sending Algo Algo sent Ok BL : Quantum_Bootloader_10.46_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! ===Flashing [PPM]=== File : rm692__06.96.ppm_m_a Image : package_m_a.ppm_ebl_psi.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41DC0000 , Len : 0x00700000 Erasing, wait ... Erase done, time : 00:00:10 Write , Start : 0x41DC0000 , Len : 0x00409AD8 Flashing , wait ... Region flash done, time : 00:00:04 Flashing done! Total flash time : 00:00:15 Reboot phone now... Reading Phone Info.... Connected phone - C2-02 Software Info: V 06.96 09-09-11 RM-692 (c) Nokia IMEI: 358641049358475 PPM version : V 06.96 09-09-11 RM-692 (c) Nokia M_A Product code: 059H0R7 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Checking User Certificates... Total - 42 certs Data exist, skip certificate repair... Set phone to Normal mode... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:00:52 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
The Following 2 Users Say Thank You to sirnavid2010 For This Useful Post: |
01-12-2012, 15:27 | #15164 (permalink) |
No Life Poster Join Date: Jun 2005 Location: rawalpindi,pakistan.
Member: 155992 Status: Offline Sonork: 1585672 Thanks Meter: 171 | zte r221 unlock COM7 [VCP2] selected module v3.91 Action: read unlock codes unlock method: read codes Model: ZTE-R221_16mb Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6CCB:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... warning: wrong packet cs Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: E-PK-T9SM-P109A17V1.0.0B02 Version: ZTENJ23D_09A_HW 86 byte(s) read imei: 35926403115747 connection Ok 192 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 180 byte(s) read reading data... 972 byte(s) read lock[1] code: + 604589997657 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if phone do not ask for a code try: *983*8284# if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone (do not remove battery) - read unlock codes - restore original imei Finished, time used: 11 sec Remove/Install battery now ! |
01-12-2012, 15:27 | #15165 (permalink) |
Freak Poster Join Date: Sep 2010 Location: searching Age: 39
Member: 1404229 Status: Offline Sonork: 100.1612419 Thanks Meter: 44 | module v3.62 Action: "sp-unlock" unlock method: smart fast Model: ZTE-R221 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A08]... CPU: MT6223 high speed boot On chip: 0011:4E91:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E08 Date: 2000.00.00 Version: 1.0 Version: TMO_UK_P109A17V1.0.1B07 Version: ZTENJ23D_09A_HW 86 byte(s) read imei: 86853300199520 connection Ok 192 byte(s) read reading data... reading data #2... building new data... writing data... 180 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 15 sec Remove/Install battery now ! |
