10-30-2017, 19:26 | #45916 (permalink) | |||
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Operation : Check/Read Info [ v1.27 ] Quote:
The Following User Says Thank You to Yusuf Lawal For This Useful Post: |
10-31-2017, 05:48 | #45917 (permalink) |
Freak Poster Join Date: Feb 2017 Location: INDIA
Member: 2682035 Status: Offline Thanks Meter: 22 | Gionee s5.5 read pattren done by great cm2 dongle Operation : Read Pattern/DP Lock [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 25 ] Sync... Inital Boot Ok! BB_CPU_PID : 6592 BB_CPU_NME : [MediaTek] MT6592_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8A NAND Flash : NOT INSTALLED eMMC Flash : 150100523858314D42017C6D50E851AB Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM1X8 [eMMC] : FLASH_CID : 150100523858314D42017C6D50E851AB [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x278ABE87B96ED76409A9F01885B2B3FC INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... Get Locks ... PatternLock Sequnce : 7412365 Done! Elapsed: 00:00:27 Reconnect Power/Cable! |
The Following User Says Thank You to nihang For This Useful Post: |
10-31-2017, 06:46 | #45918 (permalink) |
Freak Poster Join Date: Jul 2016 Location: ubauro Distik Ghotki
Member: 2601587 Status: Offline Thanks Meter: 201 | QMobile S6 nand boot read firmware Done by cm2 Brand : QMobile ProdName : QMobileS6 ProdModel : QMobile S6 Device : QMobileS6 AndroidVer: 6.0 MTKxCPU : MT6580 MTKxPRJ : D3679_DD36791_QMOBILE-S6_L116 [Read Ok] : preloader_d3679.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6580 / V1.1.2 / d3679 / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 3093 MiB Scatter saved to : C:\Users\SAJJAD HUSSAIN\Desktop\S6\MT6580__QMobile__QMobile_S6__QM obileS6__6.0__D3679_DD36791_QMOBILE-S6_L116\ All done! Done! Elapsed: 00:12:03 Reconnect Power/Cable! |
The Following User Says Thank You to Sajjad_Hussain For This Useful Post: |
10-31-2017, 09:22 | #45920 (permalink) |
Member: 1677653 Status: Offline Thanks Meter: 2,769 | INFINIX X600 REPAIR SECURITY DONE Operation : Check / Read Info [ v1.58 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 460001154D3232387C6800424BA1846A Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM228 [eMMC] : FLASH_CID : 150100463832324D4200687C6A84534B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xDEC55C372668725903EC113704DBA387 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Infinix ProdName : full_rlk6753_65u_m0 ProdModel : Infinix-X600 Device : rlk6753_65u_m0 AndroidVer: 6.0 MTKxCPU : MT6735 MTKxPRJ : X600-H532-A1-M-20160317 MODEM : BaseBand : MT6735_S00_MOLY_LR9_W1444_MD_LWTG_MP_V68_P1_1_lwg_n EXTRA : LCD : Not info available :( LCD Res : 1280x720 TOUCH [0] : GT1XX CAM [0] : s5k3m2_mipi_raw CAM [1] : s5k3m2tvn_mipi_raw CAM [2] : s5k5e8yx_mipi_raw CAM [3] : gc2755_mipi_raw MODEM : rlk6753_65u_m0_lwg_dsds_h532_a1 LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES sw_TZ Done! Elapsed: 00:00:13 Reconnect Power/Cable! Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 460001154D3232387C6800424BA1846A Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM228 [eMMC] : FLASH_CID : 150100463832324D4200687C6A84534B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xDEC55C372668725903EC113704DBA387 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Set IMEI [00] : 358407071421361 Set IMEI [01] : 358407071421379 Prepare finished. Security check required! Wait for phone... Phone found! [ 5 ] Sync... Repair done! Done! Elapsed: 00:00:49 Reconnect Power/Cable! |
10-31-2017, 10:26 | #45921 (permalink) |
Freak Poster Join Date: Aug 2005 Location: tamil nadu Age: 38
Member: 170244 Status: Offline Thanks Meter: 418 | mi5 mi account removed successfully Operation : Reset Settings [ v1.13 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 820 [MSM8996] ID_BLOCK_S : D14574A2 ID_BLOCK_I : 009470E1 ID_BLOCK_L : DEADAF12E2155654D0A231FD303BC12B ID_BLOCK_L : BBD7701DCA6D9339A9D8D3A948053BE6 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8996 , FLASH : UFS , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000/00000200 Boot Ok! MIAccount reset passed! Normal reset : > Select "FORCED FIX" or "REPAIR" in FMT settings, press "Format FS / Reset Settings" > PowerOn device and use. IF Device stuck on black screen with cable - use another FMT > Not all devices supported yet! (tested on Hydrogen,Land,Redmi2) Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
The Following User Says Thank You to mohamedsafi123 For This Useful Post: |
10-31-2017, 10:43 | #45922 (permalink) |
Registered User Join Date: Mar 2008 Location: karachi
Member: 726546 Status: Offline Sonork: 100.1578784 Thanks Meter: 555 | lg ls980 reset user code done Card found : 963CDDB0 , v0136 Infinity-Box LG Service Tool [ LGS ] v1.03 Operation : Reset Settings/Format FS [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD VOLUME UP KEY! 3. Insert USB cable, wait until Download mode screen will appear Wait for phone... Connection opened successfully! Waiting for loader ... Handshake passed! Collect info... Prepare passed, mode 0x00 Boot done! Format UserData Format Cache Format done Reconnect Power/Cable! Done! Elapsed: 00:00:55 |
The Following User Says Thank You to jawad_anis For This Useful Post: |
10-31-2017, 11:19 | #45923 (permalink) |
Freak Poster Join Date: Aug 2017 Location: Mindanao Philippines
Member: 2752651 Status: Offline Thanks Meter: 182 | Eblu-Berry B732+ 3G Write Firmware Code: Start at : [10/31/2017 / 4:43:59 PM] Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1501004B3557564D4201BB7DC66FA065 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMVW5 [eMMC] : FLASH_CID : 1501004B3557564D4201BB7DC66FA065 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xE5C818C3BE13FD5A6D3EC6C3F9A407ED INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : b706_tab , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 4054 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000000E5680000 Flash Pre-Erase Done, time used : 00:00:02 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_b706_tab.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0013 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:02:44 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:03 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:16 Reconnect Power/Cable! |
The Following User Says Thank You to meerl329 For This Useful Post: |
10-31-2017, 13:07 | #45924 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | MICROMAX Q350 FRP LOCK REMOVE Done SUCCESSFULLY REMOVE FRP LOCK(MICROMAX Q350)USB Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 30 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483847316505072B843895336F Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A483847316505072B843895336F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xFD096D45B86D58FE7F1D86BAAC4F5112 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Micromax ProdName : Q350 ProdModel : Micromax Q350 Device : Q350 AndroidVer: 6.0 MTKxCPU : MT6580 MTKxPRJ : ALPS.W10.24.p0 SECURITY : IMEI_SW [1] : XXXXXXXXXXXXXX IMEI_SW [2] : XXXXXXXXXXXXXX BTMAC Addr : XXXXXXXX WiFi MAC : XXXXXXX MODEM : BaseBand : MT6580_S00_MOLY_WR8_W1449_MD_WG_MP_V41_P7_1_wg_n EXTRA : LCD : Not info available LCD Res : 854x480 TOUCH [0] : ektf2k TOUCH [1] : ft6336 CAM [0] : gc0310_mipi_yuv CAM [1] : ov5670_mipi_raw_sunwin CAM [2] : ov5670_mipi_raw_cmk CAM [3] : gc2355_mipi_raw CAM [4] : sp2508_mipi_raw MODEM : mt6580_v2800an_hspa_modem_B18_P7_mmx_in LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES hi_IN ta_IN te_IN bn_IN mr_IN gu_IN pa_IN ml_IN kn_IN or_IN hdpi Done! Elapsed: 00:00:19 Reconnect Power/Cable! ---------------------------------------------------------------------------------------------------------------------------------------------------- Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 30 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483847316505072B843895336F Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A483847316505072B843895336F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xFD096D45B86D58FE7F1D86BAAC4F5112 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:34 Reconnect Power/Cable! THANKS INFINITY-BOX TEAM |
The Following 2 Users Say Thank You to gracy_elec For This Useful Post: |
10-31-2017, 13:33 | #45925 (permalink) |
Freak Poster Join Date: Feb 2017 Location: Balochistan
Member: 2682425 Status: Offline Thanks Meter: 66 | succesfully flash nokia 500 nokia 500 flash successfully, under the battery wrong info given but i tried to flash on that wrong info but automatically it corrects it self to rm 750 and flash. Connect phone on selected interface... Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-697_22.0.007_prd.core.C00 PPM : RM-697_22.0.007_prd.rofs2.V05 PPM2 : RM-697_22.0.007.260.02_prd.rofs3.fpsx CNT : RM697_719_014_U001.uda.fpsx Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: CC0F0004FFFF3C4041B7DF62E49E065A8CBAA787 ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 005000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : F4C2F0A6BA76F178E59EBE710A8E1C85F3E122C0 ADL: phone is in flash mode ====== ERROR ======= - > Warning! MCU file not assigned to this ASIC! Flashing will kill phone! ====== ERROR ======= - > Check files and try again! Possible off this option in settings, but not recommended ====== ERROR ======= ADL: Close_Session Content: 000300000000020000000200000000 ADL: Reboot Elapsed: 00:00:40 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Resetting selected items... Operating mode is OK, no need change... Settings Full Factory Defaults... Set OK! Elapsed: 00:00:02 Resetting selected items... Operating mode is OK, no need change... Settings Full Factory Defaults... Set OK! Settings User Data Defaults... Set OK! Elapsed: 00:00:01 Phone disconected! Connect phone on selected interface... Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-697_22.0.007_prd.core.C00 PPM : RM-697_22.0.007_prd.rofs2.V05 PPM2 : RM-697_22.0.007.260.02_prd.rofs3.fpsx CNT : RM697_719_014_U001.uda.fpsx Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: CC0F0004FFFF3C4041B7DF62E49E065A8CBAA787 ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 005000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : F4C2F0A6BA76F178E59EBE710A8E1C85F3E122C0 ADL: phone is in flash mode ====== ERROR ======= - > Warning! MCU file not assigned to this ASIC! Flashing will kill phone! ====== ERROR ======= - > Check files and try again! Possible off this option in settings, but not recommended ====== ERROR ======= ADL: Close_Session Content: 000300000000020000000200000000 ADL: Reboot Elapsed: 00:00:15 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual -> File : RM-750_M003.011.emmc.fpsx not found! Check it! Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-750_111.021.0028_79u_prd.core.fpsx PPM : RM-750_111.021.0028_01.01_Euro1_79u_prd.rofs2.fpsx PPM2 : RM-750_111.021.0028_C21.01_Skip_Cherry_79u_prd.rofs3. fpsx CNT : RM-750_v0.017_APEONLY_prd.fpsx APE : RM-750_111.021.0028_U012.01_79u.uda.fpsx Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> Check SW version... FlashFile version : 111.021.0028 Phone version : 111.021.0028 -> Check SW version : Reflash Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: CC0F0004FFFF3C4041B7DF62E49E065A8CBAA787 ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 005000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : F4C2F0A6BA76F178E59EBE710A8E1C85F3E122C0 ADL: phone is in flash mode === SW Version Check === - > REFLASHING === SW Version Check === ===Flashing [MCU]=== Erase : Processing RM-750_111.021.0028_79u_prd.core.fpsx Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing RM-750_111.021.0028_79u_prd.core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [SOS+DECOMP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 499 blocks TIME : Write time : 00:00:16 MCU Write done ADL: Request programm status NAND status : 00000002 / 00000002 / 00000000 ===Flashing [PPM]=== Erase : Processing RM-750_111.021.0028_01.01_Euro1_79u_prd.rofs2.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-750_111.021.0028_01.01_Euro1_79u_prd.rofs2.fpsx CMT: Writing Hash CERT [SOS+ROFS2] Total writen 225 blocks TIME : Write time : 00:00:08 PPM Write done ADL: Request programm status NAND status : 00000002 / 00000002 / 00000000 ===Flashing [PPM2]=== Erase : Processing RM-750_111.021.0028_C21.01_Skip_Cherry_79u_prd.rofs3. fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-750_111.021.0028_C21.01_Skip_Cherry_79u_prd.rofs3. fpsx CMT: Writing Hash CERT [SOS+ROFS3] Total writen 2 blocks TIME : Write time : 00:00:00 PPM Write done ADL: Request programm status NAND status : 00000002 / 00000002 / 00000000 ===Flashing [CNT]=== Erase : Processing RM-750_v0.017_APEONLY_prd.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-750_v0.017_APEONLY_prd.fpsx CMT: Writing Hash CERT [SOS*ENO] Total writen 17 blocks TIME : Write time : 00:00:00 CNT Write done ADL: Request programm status NAND status : 00000002 / 00000002 / 00000000 ===Flashing [APE]=== Erase : Processing RM-750_111.021.0028_U012.01_79u.uda.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-750_111.021.0028_U012.01_79u.uda.fpsx Total writen 566 blocks TIME : Write time : 00:00:20 APE Write done ADL: Request programm status NAND status : 00000002 / 00000002 / 00000000 ADL: Close_Session Content: 000300000000020000000200000000 ADL: Reboot Flashing done! Total flash time : 00:00:48 Reboot phone now... Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:01:09 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
The Following User Says Thank You to mustafasayad For This Useful Post: |
10-31-2017, 14:41 | #45926 (permalink) |
Member: 1677653 Status: Offline Thanks Meter: 2,769 | LENOVO A830 FORMAT & READ FLASH DONE Operation : Check / Read Info [ v1.58 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6583 BB_CPU_NME : [MediaTek] MT6583|6589_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x86 NAND Flash : NOT INSTALLED eMMC Flash : 204A0190594E495814A11648874074B9 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , HYNIX [eMMC] : FLASH_CID : 90014A2058494E594816A114B9744087 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0xDEC55C37A055DE9EA4E857F047376A29 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Lenovo ProdName : A830 ProdModel : Lenovo A830 Device : A830 AndroidVer: 4.2.1 MTKxCPU : MT6589 MTKxPRJ : ALPS.JB2.MP.V1 SECURITY : IMEI_SW [1] : 860364029032660 IMEI_SW [2] : 860364029032678 BTMAC Addr : C8DDC9E6C862 WiFi MAC : C8DDC956C862 MODEM : BaseBand : MT6589_S00_A830_V10 EXTRA : LCD [0] : nt35516_qhd_dsi_cmd_ipsboe LCD [1] : otm9608a_qhd_cmd LCD Res : 960x540 TOUCH [0] : GT9XX CAM [0] : ov8825_mipi_raw CAM [1] : mt9v113_yuv MODEM : mt6589_md1_hspa_skypaband18_athena LOCALE : en_US es_ES zh_CN zh_TW ru_RU pt_BR fr_FR de_DE tr_TR it_IT in_ID ms_MY vi_VN ar_EG th_TH ldpi hdpi mdpi pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ hdpi xhdpi Done! Elapsed: 00:00:12 Reconnect Power/Cable! Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6583 BB_CPU_NME : [MediaTek] MT6583|6589_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x86 NAND Flash : NOT INSTALLED eMMC Flash : 204A0190594E495814A11648874074B9 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , HYNIX [eMMC] : FLASH_CID : 90014A2058494E594816A114B9744087 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0xDEC55C37A055DE9EA4E857F047376A29 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:27 Reconnect Power/Cable! Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6583 BB_CPU_NME : [MediaTek] MT6583|6589_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x86 NAND Flash : NOT INSTALLED eMMC Flash : 204A0190594E495814A11648874074B9 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , HYNIX [eMMC] : FLASH_CID : 90014A2058494E594816A114B9744087 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0xDEC55C37A055DE9EA4E857F047376A29 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... Brand : Lenovo ProdName : A830 ProdModel : Lenovo A830 Device : A830 AndroidVer: 4.2.1 MTKxCPU : MT6589 MTKxPRJ : ALPS.JB2.MP.V1 [Read Ok] : preloader_a830.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6589 / V1.0.0 / a830 / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 573 MiB Scatter saved to : C:\Users\Yuslam Unique\Desktop\SP Backup\MT6589__Lenovo__Lenovo_A830__A830__4.2.1__ALPS.JB2.MP.V1\ All done! Done! Elapsed: 00:03:54 Reconnect Power/Cable! |
10-31-2017, 14:56 | #45927 (permalink) |
Freak Poster Join Date: Jun 2009 Location: Nepal
Member: 1050365 Status: Offline Thanks Meter: 210 | Mi A1 FRP Remove Operation : Identify [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 625 [MSM8953] ID_BLOCK_S : F7CAB2B1 ID_BLOCK_I : 000460E1 ID_BLOCK_L : ADEA7955E7EED2850C401057CBBB4374 ID_BLOCK_L : 926218BF7E5949A15E29EADD9A0CD88D Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8953 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000E8F800000 [ eMMC 64 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RH64MB Boot Ok! USERData : ENCRYPTED GCSec : NORMAL Done! Elapsed: 00:00:18 Reconnect Power/Cable! Operation : Reset Settings [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 625 [MSM8953] ID_BLOCK_S : F7CAB2B1 ID_BLOCK_I : 000460E1 ID_BLOCK_L : ADEA7955E7EED2850C401057CBBB4374 ID_BLOCK_L : 926218BF7E5949A15E29EADD9A0CD88D Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8953 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000E8F800000 [ eMMC 64 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RH64MB Boot Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
The Following User Says Thank You to Bimal Shah For This Useful Post: |
10-31-2017, 15:53 | #45929 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | MICROMAX Q402 PLUS AndrVersion : 7.0 FRP REMOVE Done SUCCESSFULLY REMOVE FRP AndrVersion : 7.0(MICROMAX Q402 PLUS)USB Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 36 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9830 eMMC Generic Loader v2 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : Q402Plus Model Brand : Micromax Model Device: Q402Plus AndrVersion : 7.0 BaseBand CPU: MICROMAX CompileDate : 8/4/2017 3:51:59 AM Project Ver : MMX_Q402+_SW_V06_HW_V3.0_20170804 Model Ext : Micromax Q402Plus ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:19 Reconnect Power/Cable! ---------------------------------------------------------------------------------------------------------------------------------------------------- Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 36 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9830 eMMC Generic Loader v2 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x00000001357F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! THANKS INFINITY-BOX TEAM |
10-31-2017, 16:03 | #45930 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | MOTO XT1022 HANG ON FASTBOOT RECOVER Done SUCCESSFULLY RECOVER HANG ON FASTBOOT(MOTO XT1022)USB Infinity-Box Android Service Tool [AST] v1.02 Operation : Identify [ v1.02 ] Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! Main Info ============ CPU : MSM8210 CS CID : 0x0007 IMEI : XXXXXXXXXXXXXXXX UID : 1B8FC50412000000000000000000 Model Info ============ IntName : condor SW Info ============ DevSWVer : Blur_Version.23.201.3.condor_retaildsds.retaildsds all.en.03 DevQCVer : AU_LINUX_ANDROID_LNX.LA.3.5.1_RB1.04.04.02.048.045 BaseBand : MSM8610BP_18033.4614.45.00R EMEA_DSDS_CUST BootLDRv : 500E HW Info ============ eMMCInfo : 4GB Hynix REV=06 PRV=05 TYPE=17 DRAMInfo : 1024MB Hynix S4 SDRAM DIE=4Gb Lock Info ============ BLUnlock : no WarrantyVoid : no Done! ---------------------------------------------------------------------------------------------------------------------------------------------------- Operation : Flash [ v1.02 ] FlashFile : E:\MY BOX\MOTO\XT1022_CONDOR_RETAILDSDS_5.1_CFC.xml.zip Selected NormalFlash mode definition! Pre-Flash verification passed! Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! Processing Flashing ... READ INFO : MAX-SPARSE-SIZE Result : 268435456 Executing OEM operation OEM operation OK! FLASH : PARTITION Unpack file, please wait ... FileInfo : gpt.bin , Checksum : 5bcccfe466e7acb287c861bbdc591c37 Sending data ... This may take a few seconds, if a different partition table is being flashed since we need to backup and restore a few partitions Flashing primary GPT image... Flashing backup GPT image... FLASH operation OK! FLASH : MOTOBOOT Unpack file, please wait ... FileInfo : motoboot.img , Checksum : 50fa4c2ef75bc4f8238d22ab176b9183 Sending data ... flashing tz ... flashing rpm ... flashing sdi ... flashing aboot ... flashing sbl1 ... FLASH operation OK! FLASH : LOGO Unpack file, please wait ... FileInfo : logo.bin , Checksum : 1c958756245ce98d8809d9950dfb919f Sending data ... FLASH operation OK! FLASH : BOOT Unpack file, please wait ... FileInfo : boot.img , Checksum : 73e204ba3f6ed4a0b18fcc024c6eba7c Sending data ... FLASH operation OK! FLASH : RECOVERY Unpack file, please wait ... FileInfo : recovery.img , Checksum : 7d9044b045644ae1fa89eebf1286124a Sending data ... FLASH operation OK! FLASH : SYSTEM Unpack file, please wait ... FileInfo : system.img_sparsechunk.0 , Checksum : 2ebf466ec760150802bbd4f72e46da8d Sending data ... FLASH operation OK! FLASH : SYSTEM Unpack file, please wait ... FileInfo : system.img_sparsechunk.1 , Checksum : 5dff71d08deae559b2bc4ac2ff1b0929 Sending data ... FLASH operation OK! FLASH : SYSTEM Unpack file, please wait ... FileInfo : system.img_sparsechunk.2 , Checksum : efad0a29744c62c64b03a20f745abc4c Sending data ... FLASH operation OK! FLASH : SYSTEM Unpack file, please wait ... FileInfo : system.img_sparsechunk.3 , Checksum : 9dec6cc1fd348309a1a04126c88c29a8 Sending data ... FLASH operation OK! FLASH : MODEM Unpack file, please wait ... FileInfo : NON-HLOS.bin , Checksum : b52247b5af92ea056745ff592821eab2 Sending data ... FLASH operation OK! ERASE : MODEMST1 ERASE operation OK! ERASE : MODEMST2 ERASE operation OK! FLASH : FSG Unpack file, please wait ... FileInfo : fsg.mbn , Checksum : 53bff877a05ef7f3b9106e1c16dbbc7c Sending data ... FLASH operation OK! ERASE : CACHE ERASE operation OK! ERASE : USERDATA ERASE operation OK! Executing OEM operation OEM operation OK! Flashing finished! Done! THANKS INFINITY-BOX TEAM |
