01-02-2018, 10:26 | #47296 (permalink) |
No Life Poster Join Date: Mar 2016 Location: Ukraine
Member: 2550141 Status: Offline Thanks Meter: 1,115 | Lenovo K3 Note [K50-T5] FRP Reset Done with Infinity CM2 Lenovo K3 Note [K50-T5] FRP Reset Done with Infinity CM2 Read Info Code: Operation : Check / Read Info [ v1.57 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 67 ] Sync... Inital Boot Ok! BB_CPU_PID : 6752 BB_CPU_NME : [MediaTek] MT6732|MT6752_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8F NAND Flash : NOT INSTALLED eMMC Flash : 150100523832314D4200497FC2F0B2F5 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM128 [eMMC] : FLASH_CID : 150100523832314D4200497FC2F0B2F5 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x69E25B9AE3CA7C05E1FB58690C55B11F INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Lenovo ProdName : full_aio_otfp ProdModel : Lenovo K50-t5 Device : aio_otfp AndroidVer: 5.0 MTKxCPU : MT6752 MTKxPRJ : K50-T5_USR_ST1512_5.495.1_1503191926_MP6V3_CN SECURITY : IMEI_SW [1] : 867200023901299 IMEI_SW [2] : 867200023901307 BTMAC Addr : A0329994F9FB WiFi MAC : A03299A6F9FB MODEM : BaseBand : MT6752_S00_K50T5_LTG_V29_1_ltg_n EXTRA : LCD [0] : nt35595_fhd_dsi_cmd_truly_nt50358 LCD Res : 1920x1080 TOUCH [0] : GT9XX_hotknot CAM [0] : ov13850sunny_mipi_raw CAM [1] : ov13850ofilma50_mipi_raw CAM [2] : ov5670_mipi_raw CAM [3] : ov5670lite_mipi_raw MODEM : aio_5m_ltg_dsds aio_5m_lwg_dsds LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES Done! Code: Operation : Format FileSystem [ v1.57 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 67 ] Sync... Inital Boot Ok! BB_CPU_PID : 6752 BB_CPU_NME : [MediaTek] MT6732|MT6752_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8F NAND Flash : NOT INSTALLED eMMC Flash : 150100523832314D4200497FC2F0B2F5 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM128 [eMMC] : FLASH_CID : 150100523832314D4200497FC2F0B2F5 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x69E25B9AE3CA7C05E1FB58690C55B11F INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! |
The Following User Says Thank You to localizator For This Useful Post: |
01-02-2018, 11:09 | #47298 (permalink) |
Freak Poster Join Date: Apr 2015 Location: Samastipur (BIHAR) 9006357621
Member: 2383385 Status: Offline Thanks Meter: 98 | INTEX AQUA 4G MINI FRP DONE Card found: S/N : 805185C5 , v0136 Chinese Miracle II [SPD module] v 1.27 Set mode to : SP [SC773x] eMMC [Android 7.x] Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 7 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! DS : Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! Set mode to : SP [SC983x] eMMC [Generic Android 6.x] Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 7 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9832 eMMC LoaderV1 (c) Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x00000000565F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:46 Reconnect Power/Cable! |
The Following User Says Thank You to OM MOBILE REP For This Useful Post: |
01-02-2018, 12:17 | #47299 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile I6 Metal 1 MT6580 FRP Reset Done With Infinity CM2 Card found : S/N : A19EC787 , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483847316505073049946193AD Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A483847316505073049946193AD [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xD9C8F395C1A1244D32A70AE37996E2B8 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
The Following User Says Thank You to azhergoga007 For This Useful Post: |
01-02-2018, 12:18 | #47300 (permalink) |
Freak Poster Join Date: Jul 2005 Location: NT ROMANIA Age: 52
Member: 161051 Status: Offline Thanks Meter: 6 | Wait for phone... Phone found! [ 38 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x07000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with SLA Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : DONE Boot Error! how to solve this problem............ he phone is: orange rise 52(alcatel 5044p) i want reset frp but cannot conect android 7.0 mt6737M |
The Following User Says Thank You to crisss For This Useful Post: |
01-02-2018, 13:07 | #47301 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Pb - BRAZIL
Member: 689942 Status: Offline Thanks Meter: 312 | Frp successfully on the Multilaser Ms45s model Reading extended info ... Model Name : MS45S Model Brand : Multilaser Model Device: MS45S AndrVersion : 5.1 BaseBand CPU: SP7731GEA_LM_FS031 CompileDate : 23/02/2017 02:25:12 Project Ver : MS45S.v17_20170223 Model Ext : MS45S ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:37 Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 166 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x00000001591F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:39 Reconnect Power/Cable! |
The Following User Says Thank You to celltellpb For This Useful Post: |
01-02-2018, 13:40 | #47302 (permalink) |
No Life Poster Join Date: May 2011 Location: india
Member: 1583254 Status: Offline Sonork: 100.1602320 Thanks Meter: 4,792 | Lg D325 Hang on logo Done Infinity-Box LG Service Tool [ LGS ] v1.03 Loading firmware ... FType : KDZ file BB_Gen : QLM Model : LG-D325 Version : D32510g SWInfo : user File [0] : PrimaryGPT_0.bin File [1] : modem_8192.bin File [2] : sbl1_139264.bin File [3] : rpm_141312.bin File [4] : tz_142336.bin File [5] : sdi_143360.bin File [6] : aboot_144384.bin File [7] : rpmb_148480.bin File [8] : tzb_149504.bin File [9] : abootb_150528.bin File [10] : persist_204800.bin File [11] : laf_270336.bin File [12] : boot_319488.bin File [13] : recovery_364544.bin File [14] : factory_475136.bin File [15] : sbl1b_581632.bin File [16] : cust_655360.bin File [17] : system_770048.bin File [18] : system_1036984.bin File [19] : system_1298352.bin File [20] : system_1561272.bin File [21] : system_1822640.bin File [22] : system_2085560.bin File [23] : system_2346928.bin File [24] : system_2609848.bin File [25] : system_2871216.bin File [26] : system_3134136.bin File [27] : system_3395504.bin File [28] : system_3657648.bin File [29] : BackupGPT_7633920.bin Load Ok! Operation : Flash [ v1.03 ] Forced Flash : Disabled Factory Reset : Enabled 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD VOLUME UP KEY! 3. Insert USB cable, wait until Download mode screen will appear Wait for phone... Connection opened successfully! Waiting for loader ... Handshake passed! Collect info... Prepare passed, mode 0x00 Boot done! [INFO] : Low Battery level ignored by user request! Loading firmware Load ok! Checking compatibility Checking passed! Prepare device Prepare Passed! Secure prepare skipped! Start flashing device Flash : PrimaryGPT_0.bin Flash : modem_8192.bin Flash : sbl1_139264.bin Flash : rpm_141312.bin Flash : tz_142336.bin Flash : sdi_143360.bin Flash : aboot_144384.bin Flash : rpmb_148480.bin Flash : tzb_149504.bin Flash : abootb_150528.bin Flash : persist_204800.bin Flash : laf_270336.bin Flash : boot_319488.bin Flash : recovery_364544.bin Flash : factory_475136.bin Flash : sbl1b_581632.bin Flash : cust_655360.bin Flash : system_770048.bin Flash : system_1036984.bin Flash : system_1298352.bin Flash : system_1561272.bin Flash : system_1822640.bin Flash : system_2085560.bin Flash : system_2346928.bin Flash : system_2609848.bin Flash : system_2871216.bin Flash : system_3134136.bin Flash : system_3395504.bin Flash : system_3657648.bin Flash : BackupGPT_7633920.bin Processing Post-Flashing tune Flash done! Reconnect Power/Cable! Done! Elapsed: 00:03:45 |
The Following User Says Thank You to M0YAL For This Useful Post: |
01-02-2018, 14:05 | #47303 (permalink) |
Banned Join Date: Oct 2017 Location: pakistan kpk mansehra Age: 26
Member: 2765424 Status: Offline Thanks Meter: 1,039 | Qmoible q3310 mini reset code format done BOOT KEY {1} Card found : 7227D1EE , v0136 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.02 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR SPRD mode : SC6531 : REV : E000 : NOR Operation : Format FileSystem [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531E Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_006 248D34128_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:31 Reconnect Power/Cable! BOOT KEY {1} |
The Following User Says Thank You to taimur-ahmad For This Useful Post: |
01-02-2018, 14:08 | #47304 (permalink) |
Member: 2765424 Status: Offline Thanks Meter: 1,039 | Qmobiel 3310 mini read flash fiel done great cm2 QMOBIEL 3310 MINI READ FLASH FIEL DONE GREAT CM2 BOOT KEY {1} Operation : Read Flash [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531E Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Read Ok! Saved to : C:\Users\TAIMUR\Desktop\New folder\FLASH_DUMP.bin Done! Elapsed: 00:00:50 Reconnect Power/Cable! BOOT KEY ....1.... |
01-02-2018, 14:52 | #47305 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | MICROMAX A177 HANG ON LOGO RECOVER Done SUCCESSFULLY RECOVER HANG ON LOGO(MICROMAX A177)USB Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 21 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1501004B3558564D42011218C6AA41F9 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMVX5 [eMMC] : FLASH_CID : 1501004B3558564D42011218C6AA41F9 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xFD096D45916880159621E7A543AA4B4E INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Micromax ProdName : A177 ProdModel : Micromax A177 Device : A177 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ZA1005C_060B_V8_0_3 SECURITY : IMEI_SW [1] : XXXXXXXXXXXXXXX IMEI_SW [2] : XXXXXXXXXXXXXXX BTMAC Addr : XXXXXXXXX WiFi MAC : XXXXXXXX EXTRA : LCD [0] : hx8379a_dsi_vdo_fwvga_arising_a1005 LCD [1] : otm8018b_dsi_vdo_fwvga_txd_a1005 LCD Res : 854x480 TOUCH [0] : msg2138a_a1005 CAM [0] : s5k5eayx_yuv_a1005 CAM [1] : ov5645_mipi_yuv CAM [2] : gc0329_yuv CAM [3] : hi704_yuv MODEM : a1005_md1_hspa_gemini_g4w1_w2100 LOCALE : en_US hdpi Done! Elapsed: 00:00:09 Reconnect Power/Cable! ================================================== ================================================== ================ Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 21 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1501004B3558564D42011218C6AA41F9 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMVX5 [eMMC] : FLASH_CID : 1501004B3558564D42011218C6AA41F9 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xFD096D45916880159621E7A543AA4B4E INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:20 Reconnect Power/Cable! THANKS INFINITY-BOX TEAM |
The Following 2 Users Say Thank You to gracy_elec For This Useful Post: |
01-02-2018, 14:57 | #47306 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | MICROMAX E481 PATTERN & FRP LOCK REMOVE Done SUCCESSFULLY REMOVE PATTERN & FRP LOCK(MICROMAX E481)USB Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 25 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 484A01906532474189B407059D934DDE Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e2GA [eMMC] : FLASH_CID : 90014A48414732650507B489DE4DA29D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB800000 [eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB] DEV RID : 0xFD096D45E5ED4421A3C35BBE3EE2AA1C INT RAM : 0x00020000 EXT RAM : 0xC0000000 [3 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Micromax ProdName : E481 ProdModel : Micromax E481 Device : E481 AndroidVer: 5.1 MTKxCPU : MT6735 MTKxPRJ : ALPS.L1.MP3.V2.21_TINNO6753.65U.G_P60 SECURITY : IMEI_SW [1] : XXXXXXXXXXXXXX IMEI_SW [2] : XXXXXXXXXXXXXX BTMAC Addr : XXXXXXXXX WiFi MAC : XXXXXXX MODEM : BaseBand : MT6735_S00_MOLY_LR9_W1444_MD_LWTG_MP_V26_P23_1_lwg _n EXTRA : LCD : Not info available LCD Res : 1920x1080 TOUCH [0] : GT1XX CAM [0] : s5k3m2_mipi_raw CAM [1] : ov5648_mipi_raw_darling CAM [2] : ov5648_mipi_raw_sunwin MODEM : l5460_lwg_modem_b18_lteb3b5b40_mmx LOCALE : en_US en_IN hi_IN mr_IN bn_IN kn_IN te_IN ta_IN ml_IN gu_IN pa_IN or_IN de_DE fr_FR es_ES in_ID it_IT ms_MY pt_BR vi_VN tr_TR ar_EG zh_CN fa_IR ar_EG es_ES fr_FR ru_RU ro_RO my_ZG Done! Elapsed: 00:00:07 Reconnect Power/Cable! ================================================== ================================================== ================ Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 25 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 484A01906532474189B407059D934DDE Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e2GA [eMMC] : FLASH_CID : 90014A48414732650507B489DE4DA29D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB800000 [eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB] DEV RID : 0xFD096D45E5ED4421A3C35BBE3EE2AA1C INT RAM : 0x00020000 EXT RAM : 0xC0000000 [3 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:46 Reconnect Power/Cable! THANKS INFINITY-BOX TEAM |
01-02-2018, 15:08 | #47307 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | I-BALL BRAVO PLUS 1.8E READ USER CODE Done SUCCESSFULLY READ USER CODE(I-BALL BRAVO PLUS 1.8E)USB SPRD mode : SC6531 : REV : 0000 : NOR Operation : Identify [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531 Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] IMEI[1] : XXXXXXXXXXXXX IMEI[2] : XXXXXXXXXXXXX Done! Elapsed: 00:00:22 ================================================== ================================================== ================ Operation : Read UserCode [ v1.02 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531 Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] STATE : NOT ACTIVE : CODE : 42255 Done! Elapsed: 00:00:15 THANKS INFINITY-BOX TEAM |
01-02-2018, 19:19 | #47308 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | FERO MEGA LTE FORMAT DONE Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 12 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9832 eMMC LoaderV1 (c) Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : Mega_LTE Model Brand : FERO Model Device: Mega_LTE AndrVersion : 6.0 BaseBand CPU: SP9832A_2H11_VOLTE CompileDate : 8/18/2016 7:26:30 AM Project Ver : Fero_Mega_LTE_V07_20160818 Model Ext : Fero Mega LTE ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:20 Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 12 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9832 eMMC LoaderV1 (c) Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x0000000302DF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
The Following User Says Thank You to Yusuf Lawal For This Useful Post: |
01-03-2018, 03:27 | #47309 (permalink) |
Freak Poster Join Date: Jul 2016
Member: 2604648 Status: Offline Thanks Meter: 346 | ASUS_Z00LD 6.0.1 Read FW Done Code: Operation : Read Flash [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0FC736AD ID_BLOCK_E : 11112222 ID_BLOCK_L : 06925B8996B565E9171133C8354FBCFB ID_BLOCK_L : E4076480C6943FDC03FB013BE2E003E6 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Brand : asus ProdName : WW_Z00L ProdModel : ASUS_Z00LD Device : Z00L AndroidVer: 6.0.1 Manufact. : asus QLMxCPU : MSM8916 DevInfo : MSM8916__asus__asus__ANDR_v6.0.1__ASUS_Z00LD__Z00L__WW_Z00L Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : sbl1.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : hyp.mbn [Read Ok] : sec.dat [Read Ok] : emmc_appsboot.mbn [Read Ok] : splash.img [Read Ok] : fs_gc.img [Read Ok] : misc.img [Read Ok] : asdf.bin [Read Ok] : abootdebug.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : persist.img [Read Ok] : NON-HLOS.bin [Read Ok] : adf.bin [Read Ok] : apd.bin [Read Ok] : cache.img [Read Ok] : system.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8916 / eMMC Firmware Size : 3350 MiB Done! |
The Following 3 Users Say Thank You to buffer2k11 For This Useful Post: |
01-03-2018, 05:27 | #47310 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Pakistan Lower Dir kpk
Member: 651892 Status: Offline Thanks Meter: 205 | LG-F500L Nougat 7.0 FRP Reset Done Identify Code: Operation : Identify [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD VOLUME UP KEY! 3. Insert USB cable, wait until Download mode screen will appear Wait for phone... Connection opened successfully! Waiting for loader ... Handshake passed! Collect info... Running : MiniOS 3.0 , ver.1.1 , with proto ver.01000006 HWInfo : BaseBand : MSM8992 HWInfo : ChargeLv : 40% HWInfo : MEM_INFO : 032G74 , MEM_LEN : 0x03A3E000 [eMMC 32 GiB] DevInfo : Model : LG-F500L , Type : F500L30b DevInfo : ANDROID 7.0 DevInfo : PSN : PT01S150710002130 , PID : LGF500Ld9891d87 DevInfo : IMEI : 35776706xxxxxxx DevInfo : SecMode : S , Build : U , RCT : 000F4240 SWInfo : SWver : V30b , SW : LGF500LAT-00-V30b-LGU-KR-JUN-26-2017+0 SWInfo : FacSW : LGF500LAT-00-V30b-LGU-KR-JUN-26-2017+0 RegInfo : Region : KR , Provider : LGU Prepare passed, mode 0x01 Boot done! Brand : lge ProdName : p1_lgu_kr ProdModel : LG-F500L Device : p1 AndroidVer: 7.0 SWVersion : LGF500LAT-00-V30b-LGU-KR-JUN-26-2017+0 Manufact. : LGE LGMxCPU : MSM8992 Done! Elapsed: 00:00:09 Code: Operation : Reset Settings/Format FS [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD VOLUME UP KEY! 3. Insert USB cable, wait until Download mode screen will appear Wait for phone... Connection opened successfully! Waiting for loader ... Handshake passed! Collect info... Prepare passed, mode 0x01 Boot done! Format UserData Format Cache Format done Erase FRP#1 block Ok! Reconnect Power/Cable! Done! Elapsed: 00:00:15 |
The Following User Says Thank You to danishalnoor For This Useful Post: |
