02-03-2017, 07:11 | #39796 (permalink) |
No Life Poster Join Date: Jul 2006 Location: punjab Age: 43
Member: 315867 Status: Offline Sonork: 100.1654770 Thanks Meter: 708 | ProdName : Aqua Wing ProdModel : Aqua Wing Device : Aqua Wing AndroidVer: 5.1 MTKxCPU : MT6735 MTKxPRJ : ALPS.L1.MP3.V2_MLT6735M.35GU.L1_P36 frp reset done Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 4400014530303153DABB0138A9ADB44A Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x45 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , 8001S [eMMC] : FLASH_CID : 45010044533130303801BBDA4AB413A9 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xB662A14E7666F7E1107FEFB542E6C4E4 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:13 Reconnect Power/Cable! |
02-03-2017, 07:11 | #39797 (permalink) |
Junior Member Join Date: Jan 2017
Member: 2672131 Status: Offline Thanks Meter: 16 | Operation : Format File System / Reset Settings [ v1.24 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x0000000147DF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Done! Elapsed: 00:00:23 Reconnect Power/Cable! |
02-03-2017, 07:12 | #39798 (permalink) |
Member: 315867 Status: Offline Sonork: 100.1654770 Thanks Meter: 708 | lenovo a319 dead recover done Scatter Load Ok , BaseBand : MT6572 , Project : huaqin72_cwet_1a_kk , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483447326111010397F14B625D Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x20000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A483447326111010397F14B625D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xB662A14EC228D6F27417C243C272F2D3 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : huaqin72_cwet_1a_kk , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled Switching to HSUSB HSUSB Init Ok BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3640 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x0000000094840000 Flash Pre-Erase Done, time used : 00:00:01 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_huaqin72_cwet_1a_kk.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:05:08 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:04 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:05:39 Reconnect Power/Cable! |
02-03-2017, 08:16 | #39799 (permalink) |
Member: 315867 Status: Offline Sonork: 100.1654770 Thanks Meter: 708 | Brand : OPPO ProdName : F1f ProdModel : F1f Device : F1f AndroidVer: 5.1.1 Manufact. : OPPO QLMxCPU : MSM8916 frp reset done info Operation : Identify [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 610 [MSM8936] ID_BLOCK_S : 081FDB3B ID_BLOCK_I : 0090B0E1 ID_BLOCK_L : 48B8D22C8B171C0FF8ADA7A87732428A ID_BLOCK_L : FA8937969B0AB431D42374ADA74E5863 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8936 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Brand : OPPO ProdName : F1f ProdModel : F1f Device : F1f AndroidVer: 5.1.1 Manufact. : OPPO QLMxCPU : MSM8916 Done! Elapsed: 00:00:06 Reconnect Power/Cable! reset frp Operation : Reset Settings [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 610 [MSM8936] ID_BLOCK_S : 081FDB3B ID_BLOCK_I : 0090B0E1 ID_BLOCK_L : 48B8D22C8B171C0FF8ADA7A87732428A ID_BLOCK_L : FA8937969B0AB431D42374ADA74E5863 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8936 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Remove FRP ( Google Reset Protection ) FRP removed! Done! Elapsed: 00:00:14 Reconnect Power/Cable! |
02-03-2017, 08:25 | #39800 (permalink) |
Member: 315867 Status: Offline Sonork: 100.1654770 Thanks Meter: 708 | Brand : OPPO ProdName : F1f ProdModel : F1f Device : F1f AndroidVer: 5.1.1 Manufact. : OPPO QLMxCPU : MSM8916 read full flash done Operation : Read Flash [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 610 [MSM8936] ID_BLOCK_S : 081FDB3B ID_BLOCK_I : 0090B0E1 ID_BLOCK_L : 48B8D22C8B171C0FF8ADA7A87732428A ID_BLOCK_L : FA8937969B0AB431D42374ADA74E5863 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8936 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Brand : OPPO ProdName : F1f ProdModel : F1f Device : F1f AndroidVer: 5.1.1 Manufact. : OPPO QLMxCPU : MSM8916 DevInfo : MSM8916__OPPO__OPPO__ANDR_v5.1.1__F1f__F1f__F1f Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : ddr.bin [Read Ok] : sec.dat [Read Ok] : sbl1.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : hyp.mbn [Read Ok] : pnvbak.img [Read Ok] : lsplash.img [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : persist.img [Read Ok] : misc.img [Read Ok] : driver.iso [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8936 / eMMC Firmware Size : 3092 MiB Done! Elapsed: 00:05:32 Reconnect Power/Cable! |
02-03-2017, 08:53 | #39801 (permalink) |
No Life Poster Join Date: Apr 2008 Location: India
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Lava_a59 LAVA_A59 Read Pattern Done Code: Operation : Check/Read Info [ v1.24 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 9 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : A59 Model Brand : Lava Model Device: A59 AndrVersion : 5.1 BaseBand CPU: SP7731CEB CompileDate : 5/13/2016 3:26:28 AM Project Ver : LAVA_A59_S112_20160513 Model Ext : A59 ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:17 Reconnect Power/Cable! Code: Operation : Read PatternLock [ v1.24 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 9 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! FlashMode Set : Ok! Reading PatternLock ... Read Ok , decrypt PatternLock Sequence : 3568 Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
02-03-2017, 10:45 | #39802 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Format : Qmobile Noir X25 Code: Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 88 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040502A2301CC197 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040502A2301CC197 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xE6C52A7DC0243F9BE4A04796082C7446 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:37 Reconnect Power/Cable! |
The Following User Says Thank You to Luckey1 For This Useful Post: |
02-03-2017, 12:46 | #39803 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Flash : Nokia E7-00 Code: Core : v2.24 , BB5XG FlashEngine : v10.3 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-626_111.040.1511_79u_prd.core.fpsx PPM : RM-626_111.040.1511_28.01_MEA_A_ArabicQwerty_79u_prd.rofs2.fpsx PPM2 : RM-626_111.040.1511_C05.01_MEA_79u_prd.rofs3.fpsx CNT : RM-626_111.040.1511_U10.01_79u.uda.fpsx APE : RM626_APE_ONLY_ENO_11w36_v0.037.fpsx Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> Check SW version... FlashFile version : 111.040.1511 Phone version : 111.040.1511 -> Check SW version : Reflash Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok WMDRM read ... Ok Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 1E000210796F5740A045B03175B7F89058A1D7D8 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 00680020 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : 8EABFDA6B8A757034233978C16A93B892CE2D4FA ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 354864048338686 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\354864048338686_2nd.rpl === SW Version Check === - > REFLASHING === SW Version Check === ===Flashing [MCU]=== Erase : Processing RM-626_111.040.1511_79u_prd.core.fpsx Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:07 Write : Processing RM-626_111.040.1511_79u_prd.core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [SOS+DECOMP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS+IVE3A] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 517 blocks TIME : Write time : 00:00:18 MCU Write done ADL: Request programm status NAND status : 00000014 / 00000014 / 00000000 ===Flashing [PPM]=== Erase : Processing RM-626_111.040.1511_28.01_MEA_A_ArabicQwerty_79u_prd.rofs2.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-626_111.040.1511_28.01_MEA_A_ArabicQwerty_79u_prd.rofs2.fpsx CMT: Writing Hash CERT [SOS+ROFS2] Total writen 195 blocks TIME : Write time : 00:00:07 PPM Write done ADL: Request programm status NAND status : 00000014 / 00000014 / 00000000 ===Flashing [PPM2]=== Erase : Processing RM-626_111.040.1511_C05.01_MEA_79u_prd.rofs3.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-626_111.040.1511_C05.01_MEA_79u_prd.rofs3.fpsx CMT: Writing Hash CERT [SOS+ROFS3] CMT: Writing Hash CERT [SOS+IVE3B] Total writen 4 blocks TIME : Write time : 00:00:00 PPM Write done ADL: Request programm status NAND status : 00000014 / 00000014 / 00000000 ===Flashing [CNT]=== Erase : Processing RM-626_111.040.1511_U10.01_79u.uda.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:08 Write : Processing RM-626_111.040.1511_U10.01_79u.uda.fpsx Total writen 850 blocks TIME : Write time : 00:00:28 CNT Write done ADL: Request programm status NAND status : 00000014 / 00000014 / 00000000 ===Flashing [APE]=== Erase : Processing RM626_APE_ONLY_ENO_11w36_v0.037.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM626_APE_ONLY_ENO_11w36_v0.037.fpsx CMT: Writing Hash CERT [SOS*ENO] Total writen 20 blocks TIME : Write time : 00:00:00 APE Write done ADL: Request programm status NAND status : 00000014 / 00000014 / 00000000 ADL: Close_Session Content: 000300000000140000001400000000 ADL: Reboot Flashing done! Total flash time : 00:01:11 Reboot phone now... Reading Phone Info.... Connected phone - Nokia E7-00 Software Info: V 79_sr1_12w18.5 27-07-12 RM-626 (c) Nokia IMEI: 354864048338686 Ape Version: 111.040.1511 Product code: 059C4R8 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:02:35 |
02-03-2017, 13:52 | #39804 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Format : Qmobile l1i Code: Operation : Format File System / Reset Settings [ v1.24 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 122 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:13 Reconnect Power/Cable! |
02-03-2017, 13:53 | #39805 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Flash : Nokia 215 Code: Core : v2.24 , MTKx FlashEngine : v10.2 Verify files ... MAUI : RM-1035_ROM_eMP_10.01.11 VIVA : RM-1035_VIVA_eMP_10.01.11 LANG : RM-1035_LANG_PACK_ROM_IJ_eMP_10.01.11_001 CUST : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 JMPT : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 - > MODE : FullFlash Software Info: 10.01.11 00-00-00 RM-1035 IMEI: 353686073995226 PPM version : IJ Product code: 059W037 Rebooting phone to FlashMode... Wait for phone... Phone found! [ 87 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 519CFDBB63B367AEA550207CF33520DB BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Crystal.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 SecureDecrypt : RM-1035_ROM_eMP_10.01.11 SecureDecrypt : RM-1035_VIVA_eMP_10.01.11 SecureDecrypt : RM-1035_LANG_PACK_ROM_IJ_eMP_10.01.11_001 SecureDecrypt : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 SecureDecrypt : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 OVRLP : 000069B900000001 PHPID : CRYSTAL.10.01.11.p2 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1035_ROM_eMP_10.01.11 Write : RM-1035_LANG_PACK_ROM_IJ_eMP_10.01.11_001 Write : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 Write : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 Write : RM-1035_VIVA_eMP_10.01.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1035_ROM_eMP_10.01.11 [VERIFY] DONE : RM-1035_LANG_PACK_ROM_IJ_eMP_10.01.11_001 [VERIFY] DONE : RM-1035_CUSTPACK_ROM_IJ_MEA_PK_eMP_10.01.11_001 [VERIFY] DONE : RM-1035_JUMP_TABLE_IJ_MEA_PK_eMP_10.01.11_001 [VERIFY] DONE : RM-1035_VIVA_eMP_10.01.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:01:06 Reboot phone Ok |
02-03-2017, 14:05 | #39806 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Flash : Samsung J110H Code: Phone found on COM109 Port open Ok! LOKE received! Prepare Ok! Enter Setup... Setup Done! Try download PIT... Download PIT Ok! Start flashing! Flashing boot.img Flashing recovery.img Flashing system.img Flashing cache.img Flashing hidden.img Flashing SPRDCP.img Flashing SPRDDSP.img Flashing done Reboot phone... Phone Disconnected |
02-04-2017, 06:55 | #39807 (permalink) |
No Life Poster Join Date: Apr 2008 Location: jammu
Member: 750118 Status: Offline Sonork: [email protected] Thanks Meter: 51 | Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.10 Operation : Reset Settings [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 0426982E ID_BLOCK_I : 009600E1 ID_BLOCK_L : BB4D27DF7EE4111CCBA050BD7AC15179 ID_BLOCK_L : FD903E91820DBD36CB2A6FA4AE415F7C Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Remove FRP ( Google Reset Protection ) FRP removed! Done! Elapsed: 00:00:09 Reconnect Power/Cable! Operation : Read Flash [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 0426982E ID_BLOCK_I : 009600E1 ID_BLOCK_L : BB4D27DF7EE4111CCBA050BD7AC15179 ID_BLOCK_L : FD903E91820DBD36CB2A6FA4AE415F7C Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Brand : LYF ProdName : LS-5009 ProdModel : LS-5009 Device : LS-5009 AndroidVer: 5.1.1 Manufact. : unknown QLMxCPU : MSM8909 QLMxPRJ : LS-5009-S11A_LYF_L11EN_213_160111113214 DevInfo : MSM8909__unknown__LYF__ANDR_v5.1.1__LS-5009__LS-5009__LS-5009__LS-5009-S11A_LYF_L11EN_213_160111113214 Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sbl1.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : misc.img [Read Ok] : splash.img [Read Ok] : fs_gc.img [Read Ok] : sec.dat [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : persist.img [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8909 / eMMC Firmware Size : 1900 MiB Done! Elapsed: 00:04:27 Reconnect Power/Cable! |
02-04-2017, 07:38 | #39808 (permalink) |
Member: 2672131 Status: Offline Thanks Meter: 16 | Card found : B3A4323F , v0134 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.09 Operation : Reset Settings [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 652 [MSM8976] ID_BLOCK_S : 03EA8CCD ID_BLOCK_I : 009B00E1 ID_BLOCK_L : 410E9DB90302F6A928BC0C7BEF5FBF90 ID_BLOCK_L : B242389F5E7969C1BE09CABDBA2CF8AD Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8976 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Storage : MFR : 0x11 , VENDOR : TOSHIBA , NAME : 032G34 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP ( Google Reset Protection ) FRP removed! Done! Elapsed: 00:00:13 Reconnect Power/Cable! |
The Following User Says Thank You to EMMC_KILLER For This Useful Post: |
02-04-2017, 07:48 | #39809 (permalink) |
Insane Poster Join Date: Apr 2016
Member: 2560333 Status: Offline Thanks Meter: 25 | LAVA_A67 frp done Operation : Format File System / Reset Settings [ v1.24 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 6 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x000000007C9F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x : Reset FRP Lock Reset Ok! Done! Model Name : A67 Model Brand : Lava Model Device: A67 AndrVersion : 5.1 BaseBand CPU: SP7731CEB Project Ver : LAVA_A67_S113_20160627 Model Ext : A67 |
02-04-2017, 08:07 | #39810 (permalink) |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | intex aqua curv mini repair security repair security Code: Card found : S/N : 32839D89 , v0135 Chinese Miracle II [MTK module] v 1.58 Operation : Repair Security [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 30 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473264040501A13383710D Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A4838473264040501A13383710D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x4AD5A99BBA0B828FB0FFD788F7AEEA88 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Set IMEI [00] : 911******* Set IMEI [01] : 913******* Prepare finished. Security check required! Wait for phone... Phone found! [ 30 ] Sync... Repair done! Done! Elapsed: 00:00:35 Reconnect Power/Cable! |
