08-08-2018, 17:51 | #52021 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | OPPO A37F Pattern Read Code: Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 26D2076D ID_BLOCK_L : 7A8AE01EB925525D0A7F91FE390090B8 ID_BLOCK_L : 89C44AE5D679E16267563BF0F23D2B10 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Brand : OPPO ProdName : A37f ProdModel : A37f Device : A37f AndroidVer: 5.1.1 SWVersion : A37fEX_11.A.23_INT_023_201707010938 Manufact. : OPPO SysPatch : LMY47V DevComTime: 7/1/2017 3:31:46 AM QLMxCPU : MSM8916 USERData : NORMAL GCSec : EMPTY Done! Elapsed: 00:00:16 Reconnect Power/Cable! Operation : Read PatternLock [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 26D2076D ID_BLOCK_L : 7A8AE01EB925525D0A7F91FE390090B8 ID_BLOCK_L : 89C44AE5D679E16267563BF0F23D2B10 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Read Ok! Trying decrypt ... PatternLock sequence : 2547 Done! Elapsed: 00:00:25 Reconnect Power/Cable! |
The Following User Says Thank You to Tanha0321 For This Useful Post: |
08-08-2018, 17:52 | #52022 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | QMobile X32 Frp Reset Code: Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 10 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x000000012ABF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:59 Reconnect Power/Cable! |
08-08-2018, 17:53 | #52023 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | RIVO Phantom PZ10 Pattern Read Code: Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 09762902 ID_BLOCK_L : 87611BE352D8C5C0BF947C61AEF57D4D ID_BLOCK_L : 2D20EE4132DD0D863BFADF141E918FCC Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000/00000000 Boot Ok! Brand : Rivo ProdName : RIVO_phantom_PZ10 ProdModel : Phantom PZ10 Device : I7A_Gright AndroidVer: 4.4.2 Manufact. : Rivo SysPatch : KVT49L DevComTime: 1/24/2015 1:54:29 AM QLMxCPU : MSM8610 USERData : NORMAL GCSec : NORMAL Done! Elapsed: 00:00:21 Reconnect Power/Cable! Operation : Read PatternLock [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 09762902 ID_BLOCK_L : 87611BE352D8C5C0BF947C61AEF57D4D ID_BLOCK_L : 2D20EE4132DD0D863BFADF141E918FCC Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000/00000000 Boot Ok! Read Ok! Trying decrypt ... PatternLock sequence : 2589 Done! Elapsed: 00:00:25 Reconnect Power/Cable! |
08-08-2018, 17:54 | #52024 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Telenor Infinity_i Frp Reset Code: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 460001154D32323795E5004227E59797 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM227 [eMMC] : FLASH_CID : 150100463732324D4200E59597976327 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xD5229C2586BCE6A6F3ED9B050B22768D INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : TELENOR ProdName : TELENOR_Infinity_i ProdModel : Infinity i Device : TELENOR_Infinity_i AndroidVer: 6.0 MTKxCPU : MT6735 MTKxPRJ : alps-mp-m0.mp1-V2.39.1_wtk6735m.35u.m0 Done! Elapsed: 00:00:08 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 460001154D32323795E5004227E59797 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM227 [eMMC] : FLASH_CID : 150100463732324D4200E59597976327 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xD5229C2586BCE6A6F3ED9B050B22768D INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
08-08-2018, 17:55 | #52025 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Infinix X557A1 Patern Reset Code: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100514531334D420DDF87E4B0543F Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM31E [eMMC] : FLASH_CID : 150100514531334D420DDF87E4B0543F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xD5229C25AE887FFFA78C054D54F636B1 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Infinix ProdName : X557A1 ProdModel : Infinix HOT 4 Device : X557 AndroidVer: 7.0 MTKxCPU : MT6580 MTKxPRJ : X557-H807AD-N-170626V86 Done! Elapsed: 00:00:06 Reconnect Power/Cable! Operation : Clear UserLocks [Pin/Pwd/Pattern/FVLock/GoogleAcc] [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100514531334D420DDF87E4B0543F Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM31E [eMMC] : FLASH_CID : 150100514531334D420DDF87E4B0543F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xD5229C25AE887FFFA78C054D54F636B1 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! LSSDB Ok! LSSWL Ok! LSSSH Ok! LSSNG Ok! LSSNP Ok! Security Settings : Clear Ok! [Info] : That feature NOT RESET "PRIVACY PASSWORD LOCK"! Use separate button! [Info] : That feature NOT RESET "FRP/GoogleLOCK"! Use separate "FRP" reset! [Info] : If phone stuck on "Logo" : 1. Wait 2-3 minutes. Power Off phone by long press "Power" button 2. Power On phone again 3. Or wait up to 3-7 minutes, until phone start by itself 4. Also recommended reboot phone twice before start use it Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
08-08-2018, 18:31 | #52026 (permalink) |
Freak Poster Join Date: Jul 2018
Member: 2852587 Status: Offline Thanks Meter: 92 | Qmobile L8i flash file read by Cm2 Grate Multi tool Qmobile L8i flash file read by Cm2 Grate Multi tool BR Mirza asim I AM Rocky Handsome PASSWORD rockyhandsome DOWNLOAD |
The Following User Says Thank You to rockyhansome For This Useful Post: |
08-08-2018, 18:37 | #52027 (permalink) |
Member: 2852587 Status: Offline Thanks Meter: 92 | Alcatel Flash File K107 BY CM2 Mtk TOOL Alcatel Flash File Wait for phone... Phone found! [ 40 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 31557F5296B4177F96A988828D6DF4AA BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Reading Flash Content now ... Read Flash now Read Ok , 4194304 bytes read Check and collect compile info File_Info : S629_K107_EN_PCB01_gprs_MT6261_S00.S629_K107_EN.bi n FileVersion : S629_K107_EN Saved to : C:\InfinityBox\CM2MTK\Read_out\S629_K107_EN_PCB01_ gprs_MT6261_S00.S629_K107_EN.bin Done! Elapsed: 00:00:12 Reconnect Power/Cable! S629_K107_EN_PCB01_gprs_MT6261_S00.S629_K107_EN DOWNLOAD DOWNLOAD I AM Rocky handsome |
08-09-2018, 05:40 | #52028 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Dera Ismail Khan (KPK) Pak
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | infinty box vodafone 340 successfully unlock COM26 [ProlificSerial0] selected module v4.48 Action: "sp-unlock" unlock method: smart fast Model: Vodafone-340 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:E003:A00F status: 01 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: BM35A1.V2.22.M00.02.42 Version: FOXLINK25_08B_HW 81 byte(s) read imei: 35592203234379 connection Ok 186 byte(s) read reading data... building new data... writing data... 174 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 20 sec Remove/Install battery now ! |
The Following User Says Thank You to rahihimkhan For This Useful Post: |
08-09-2018, 06:21 | #52029 (permalink) |
No Life Poster Join Date: Aug 2013 Location: CHENNAI, TAMILNADU,INDIA
Member: 2001848 Status: Offline Sonork: 100.1658212 Thanks Meter: 581 | REDMI 5A MCI3B MI Account Reset Done Via Infinity CM2 Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 425 [MSM8917] ID_BLOCK_S : 488529A1 ID_BLOCK_L : BDFA6945F7FE22751C50E0A73BAB5364 ID_BLOCK_L : 4FA9C362B5848E5C1BE227225DC91548 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : GD6BMB Boot Ok! MIAccount reset passed! Device may relock back on WiFi/Network enable! Done! Elapsed: 00:00:21 Reconnect Power/Cable! |
The Following User Says Thank You to mubarak2344 For This Useful Post: |
08-09-2018, 06:31 | #52030 (permalink) |
No Life Poster Join Date: May 2008
Member: 775581 Status: Offline Thanks Meter: 186 | Nokia 3 TA-1020 network unlock done. Operation : Identify [ v1.04 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM10) MODE : PRELOADER PORT PORT : 10 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY+DEV_CRT BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : Nokia_All_InOne_DA_v01.2018.0707 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 150100514531334D420D49AADEBCAF53 DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100514531334D420D49AADEBC4453 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QE13MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] DRAM: 0x00020000 [ 128.00 KB ] SRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 94593C2F917CA7E16AF816A28AB373A4 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT Boot done! --- SysInfoSub : Patch Level : NMF26O Display ID : 00WW_2_15H Ver. CodeName : REL Ver. Release : 7.1.1 Sec. Patch : 2017-12-01 Build Time : 1511256803 Product Model : NE1 Product Brand : alps Product Name : NE1_00WW_FIH Product Device : NE1 Product Manfct : alps Board Platform : mt6737m Product Info : NE1 --- SecuritySub : IMEI[0] : 356802084900223 NVRAM check : Passed! Done! Elapsed: 00:00:16 Reconnect Power/Cable! Operation : SP Unlock [ v1.04 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM10) MODE : PRELOADER PORT PORT : 10 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY+DEV_CRT BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : Nokia_All_InOne_DA_v01.2018.0707 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 150100514531334D420D49AADEBCAF53 DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100514531334D420D49AADEBC4453 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QE13MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] DRAM: 0x00020000 [ 128.00 KB ] SRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 94593C2F917CA7E16AF816A28AB373A4 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT Boot done! ID0 : Lock : Locked! | MNC : 256 | CNT : 5 | CODE : 1188496328424051 ID1 : Lock : Not Locked! ID2 : Lock : Not Locked! ID3 : Lock : Not Locked! ID4 : Lock : Not Locked! ID5 : Lock : Not Locked! ID6 : Lock : Not Locked! Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
08-09-2018, 06:56 | #52031 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Inside Universe
Member: 442808 Status: Offline Thanks Meter: 195 | Sucessfully Remove PIN Lock Redmi 4A Code: Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 425 [MSM8917] ID_BLOCK_S : 268E1E10 ID_BLOCK_L : 0E4BD8F6464DB3E6EFE14F36AA18E0D7 ID_BLOCK_L : 56A6DC7BBA9DB56512F52E1966D01C41 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : QE13MB Boot Ok! Brand : Xiaomi ProdName : rolex ProdModel : Redmi 4A Device : rolex AndroidVer: 6.0.1 Manufact. : Xiaomi SysPatch : MMB29M DevComTime: 3/29/2017 12:31:07 PM QLMxCPU : MSM8937 USERData : ENCRYPTED GCSec : NORMAL Done! Elapsed: 00:00:17 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 425 [MSM8917] ID_BLOCK_S : 268E1E10 ID_BLOCK_L : 0E4BD8F6464DB3E6EFE14F36AA18E0D7 ID_BLOCK_L : 56A6DC7BBA9DB56512F52E1966D01C41 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : QE13MB Boot Ok! Brand : Xiaomi ProdName : rolex ProdModel : Redmi 4A Device : rolex AndroidVer: 6.0.1 Manufact. : Xiaomi QLMxCPU : MSM8937 DevInfo : MSM8937__Xiaomi__Xiaomi__ANDR_v6.0.1__Redmi_4A__rolex__rolex Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sbl1.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : devcfg.mbn [Read Ok] : adspso.bin [Read Ok] : ddr.bin [Read Ok] : fs_gc.img [Read Ok] : sec.dat [Read Ok] : splash.img [Read Ok] : emmc_appsboot.mbn [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : persist.img [Read Ok] : misc.img [Read Ok] : mdtp.img [Read Ok] : lksecapp.mbn [Read Ok] : cmnlib.mbn [Read Ok] : cmnlib64.mbn [Read Ok] : keymaster.mbn [Read Ok] : cust.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8917 / eMMC Firmware Size : 3686 MiB Done! Elapsed: 00:04:42 Reconnect Power/Cable! Code: Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 425 [MSM8917] ID_BLOCK_S : 268E1E10 ID_BLOCK_L : 0E4BD8F6464DB3E6EFE14F36AA18E0D7 ID_BLOCK_L : 56A6DC7BBA9DB56512F52E1966D01C41 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : QE13MB Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
08-09-2018, 07:49 | #52032 (permalink) |
Member: 2001848 Status: Offline Sonork: 100.1658212 Thanks Meter: 581 | SECURE BOOT - MOTO XT1760 Format + Frp Reset Done In Single Click Via Infinity CM2 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 484A019061344741261EA532BB2595A4 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , 2a4GA [eMMC] : FLASH_CID : 90014A484147346132A51E26A49584BB [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0x97F8A39EF5C4171D80BB4A21EDA3C860 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:37 Reconnect Power/Cable! |
08-09-2018, 08:15 | #52033 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile X32 V2 MT6580 FRP Reset Done With King Infinity CM2 Card found : S/N : A19EC787 , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483847316505072BA3F0E1333B Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A483847316505072BA3F0E1333B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xD9C8F3954716A36FDC73C95F5BC69ADC INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:42 Reconnect Power/Cable! |
08-09-2018, 09:39 | #52034 (permalink) |
Member: 2001848 Status: Offline Sonork: 100.1658212 Thanks Meter: 581 | SAMSUNG J5 Prime G570F 7.0 Frp Reset Done In Download Via Infinity SM Step 1: Click Reset Frp In DMode Phone found on COM11 Phone In Download mode... Reset FRP Procedure started... Port open Ok! LOKE received! Prepare Ok! Enter Setup... Try download PIT... Download PIT Ok! Reset FRP done Reboot phone... Phone Disconnected Step 2: If It show Binary Blocked By Frp error then restart ur phone, Now it show download error.. Connect phone now and then press frp reset in Dmode again Phone found on COM11 Phone In Download mode... Reset FRP Procedure started... Port open Ok! LOKE received! Prepare Ok! Enter Setup... Try download PIT... Download PIT Ok! Reset FRP done Read Info After Frp Reset Phone found on COM91 Phone In Download mode... Connect ADB - Ok Model - SM-G570F Product - on5xeltejv CPU - exynos7570 Phone version - G570FDDU1BRE3 Android version - 7.0 CSC country code - India CSC sales code - Phone serial No - RZ8J7090C6L Phone SIM Slot count - 2 Phone IMEI - Not readed Phone not Rooted |
08-09-2018, 09:50 | #52035 (permalink) |
Member: 2001848 Status: Offline Sonork: 100.1658212 Thanks Meter: 581 | SAMSUNG J7 PRIME G610F 7.0 Frp Reset Done In Download Mode Via Infinity SM Step 1: Click Reset Frp In DMode Phone found on COM11 Phone In Download mode... Reset FRP Procedure started... Port open Ok! LOKE received! Prepare Ok! Enter Setup... Try download PIT... Download PIT Ok! Reset FRP done Reboot phone... Phone Disconnected Step 2: If It show Binary Blocked By Frp error then restart ur phone, Now it show download error.. Connect phone now and then press frp reset in Dmode again Phone found on COM11 Phone In Download mode... Reset FRP Procedure started... Port open Ok! LOKE received! Prepare Ok! Enter Setup... Try download PIT... Download PIT Ok! Reset FRP done Read Info After Frp Reset Phone found on COM92 Phone In Download mode... Connect ADB - Ok Model - SM-G610F Product - on7xeltedd CPU - exynos7870 Phone version - G610FDDU1BRB4 Android version - 7.0 CSC country code - India CSC sales code - Phone serial No - RZ8J80BJH1R Phone SIM Slot count - 2 Phone IMEI - Not readed Phone not Rooted |
The Following 3 Users Say Thank You to mubarak2344 For This Useful Post: |
