12-19-2010, 11:35 | #7336 (permalink) |
No Life Poster Join Date: Oct 2010 Location: INDIA (WEST BENGAL)
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | 3110 success full flash registered to: NILOY Connect phone on selected interface... UFS S/N ------- boot - Ok Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Selected FlashSettings : FullFlash Files Set for Flashing : MCU : rm237__07.30.mcusw PPM : rm237__07.30.ppm_c CNT : rm237__07.30.image_c_tr_pink Check FlashFiles, Please, wait... Backup enabled, Will read Certificates now... Backup CRT308 CRT308 Backup Created... CRT308 Backup Created... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 08D00005D84C7E56DB77904F8FCAD757A10B9A49 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89810089 , CMT , NOR CMT Flash ID : 89810089 < INTEL => NU48F256 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg CMT Algo sent CMT PAPUB : E691EA16A7593A9BB28832D7312A39F7ED668D0500 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 12288 byte(s) IMEI : 353203033849400 CMT : Read CCC certificate... Cert size : 8192 byte(s) CMT : Read HWC certificate... Cert size : 12288 byte(s) CMT : Read VARIANT certificate... Cert size : 20480 byte(s) Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... WMDRM_PD Data saved... RPL saved : C:\Program Files\Best_v1.11\BEST_v1.11\Backup\Cert\3532030338 49400.rpl Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 08D00005D84C7E56DB77904F8FCAD757A10B9A49 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89810089 , CMT , NOR CMT Flash ID : 89810089 < INTEL => NU48F256 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg CMT Algo sent CMT PAPUB : E691EA16A7593A9BB28832D7312A39F7ED668D0500 Transmission mode : Dual (Ddr, TX2) Boot Done! Transmission mode : Dual (Ddr, TX2) Erase : Processing rm237__07.30.mcusw Found 9 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x000006BF CMT , NOR , Area : 0x000006C0 - 0x0001FFFF CMT , NOR , Area : 0x00020000 - 0x0007FFFF CMT , NOR , Area : 0x00080000 - 0x000DFFFF CMT , NOR , Area : 0x00100000 - 0x001FFFFF CMT , NOR , Area : 0x00200000 - 0x0031FFFF CMT , NOR , Area : 0x00320000 - 0x0105FFFF CMT , NOR , Area : 0x01060000 - 0x01067FFF CMT , NOR , Area : 0x01068000 - 0x0107FFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:01:27 Transmission mode : Dual (Ddr, TX2) Write : Processing rm237__07.30.mcusw CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [PMM_CONF] CMT: Writing Hash CERT [SBIF_CONF] Total writen 943 blocks TIME : Write time : 00:02:00 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm237__07.30.ppm_c Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01080000 - 0x0151FFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:20 Transmission mode : Dual (Ddr, TX2) Write : Processing rm237__07.30.ppm_c Total writen 240 blocks TIME : Write time : 00:00:30 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm237__07.30.image_c_tr_pink Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01520000 - 0x01FDFFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:55 Transmission mode : Dual (Ddr, TX2) Write : Processing rm237__07.30.image_c_tr_pink Total writen 236 blocks TIME : Write time : 00:00:29 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia 3110c Software Info: V 07.30 07-05-09 RM-237 (c) Nokia. IMEI: 353203033849400 Product code: 0581437 Checking... SimLock status : SimLock is Ok Security status : Security Damaged!!!!! Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following 2 Users Say Thank You to niloy2007 For This Useful Post: |
12-19-2010, 11:45 | #7337 (permalink) |
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | 7210c success full flash card found: S/N ------:0------- registered to: NILOY Connect phone on selected interface... UFS S/N -------- boot - Ok Connect phone on selected interface... Read and Check phone data... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 21D001055DBC7E56F7E246762810EF3013DEBFE7 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg CMT Algo sent CMT PAPUB : DCA5EA5203CD30A64D4D95ABCD621F4AB23026F100 Transmission mode : Dual (Ddr, TX2) Boot Done! Init Service mode... Wait... SimLock status : SimLock is Ok Security status : Security is Ok Done! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Selected FlashSettings : FullFlash Files Set for Flashing : MCU : rm436__07.23.mcusw PPM : rm436__07.23.ppm_c CNT : rm436__07.23.image_c_de Check FlashFiles, Please, wait... Backup enabled, Will read Certificates now... CRT308 Backup Created... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 21D001055DBC7E56F7E246762810EF3013DEBFE7 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg CMT Algo sent CMT PAPUB : DCA5EA5203CD30A64D4D95ABCD621F4AB23026F100 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 20480 byte(s) IMEI : 353180037503920 CMT : Read CCC certificate... Cert size : 30600 byte(s) CMT : Read HWC certificate... Cert size : 20480 byte(s) CMT : Read VARIANT certificate... Cert size : 0 byte(s) Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... RPL saved : C:\Program Files\Best_v1.11\BEST_v1.11\Backup\Cert\3531800375 03920.rpl Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 21D001055DBC7E56F7E246762810EF3013DEBFE7 CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg CMT Algo sent CMT PAPUB : DCA5EA5203CD30A64D4D95ABCD621F4AB23026F100 Transmission mode : Dual (Ddr, TX2) Boot Done! Transmission mode : Dual (Ddr, TX2) Erase : Processing rm436__07.23.mcusw Found 6 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x000006BF CMT , NOR , Area : 0x000006C0 - 0x0001FFFF CMT , NOR , Area : 0x00040000 - 0x000BFFFF CMT , NOR , Area : 0x000C0000 - 0x0013FFFF CMT , NOR , Area : 0x00140000 - 0x0119FFFF CMT , NOR , Area : 0x011A0000 - 0x0133FFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:01:30 Transmission mode : Dual (Ddr, TX2) Write : Processing rm436__07.23.mcusw CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] Total writen 1161 blocks TIME : Write time : 00:02:31 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm436__07.23.ppm_c Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01340000 - 0x01BDFFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:35 Transmission mode : Dual (Ddr, TX2) Write : Processing rm436__07.23.ppm_c Total writen 448 blocks TIME : Write time : 00:00:56 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm436__07.23.image_c_de Found 2 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01BE0000 - 0x01F7FFFF CMT , NOR , Area : 0x01F80000 - 0x03FBFFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:04:10 Transmission mode : Dual (Ddr, TX2) Write : Processing rm436__07.23.image_c_de Total writen 1424 blocks TIME : Write time : 00:02:58 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia 7210 Supernova Software Info: V 07.23 17-07-09 RM-436 (c) Nokia IMEI: 353180037503920 Product code: Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
12-19-2010, 12:59 | #7338 (permalink) |
No Life Poster Join Date: Dec 2005
Member: 213172 Status: Offline Sonork: 1582799 Thanks Meter: 265 | COM6 [VCP2] selected module v3.63 Action: "sp-unlock" unlock method: smart fast Model: ZTE-R221 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6064:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: TMO_UK_P109A17V1.0.1B04 Version: ZTENJ23D_09A_HW 86 byte(s) read imei: 35926403249094 connection Ok 192 byte(s) read reading data... reading data #2... building new data... writing data... 180 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 13 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to abdulwajid147 For This Useful Post: |
12-19-2010, 13:09 | #7339 (permalink) |
No Life Poster Join Date: Dec 2006 Location: P A K I S T A N
Member: 416286 Status: Offline Sonork: 100.1622339 Thanks Meter: 759 | ZTE-R221 UNLOCKED COM6 [VCP6] selected module v3.70 Action: "sp-unlock" unlock method: smart fast Model: ZTE-R221 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:47EA:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... warning: wrong packet cs Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: E-PK-T9SM-P109A17V1.0.0B02 Version: ZTENJ23D_09A_HW 86 byte(s) read imei: 35926403085146 connection Ok 192 byte(s) read reading data... building new data... writing data... 180 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 13 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to gsmpointhrp For This Useful Post: |
12-19-2010, 13:58 | #7340 (permalink) |
Freak Poster Join Date: Jul 2008
Member: 820550 Status: Offline Thanks Meter: 41 | Chinese mobile calibration done... CPU: MT6225 high speed boot On chip: 0001D03:0005 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: MAUI.GEMINI.W08.12.01_B001-1 Version: HEXING25_GEMINI_HWV02 detecting structure #2... 5 11 done 67 byte(s) read imei: 35599000917591 connection Ok detecting structure #5 (mode-2)... 0warning: wrong packet cs 1warning: wrong packet cs 2 3 done 209 byte(s) read reading data #2... 512 byte(s) read calibration value: 0 writing data... verification... verification Ok Power-On and test phone now If calibration is not completed yet: 1. make "Reverse calibration order" Checked and try again 2. try another calibration mode Finished, time used: 11 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to arjun_mobile For This Useful Post: |
12-19-2010, 15:08 | #7341 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | 2690 usb flashing done Connect phone on selected interface... Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm635__10.10.mcusw PPM : 4673D235_rm635__10.10.ppm_m_c CNT : DE4B81E4_rm635__10.10.image_m_c_silver Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! RAP_PUB: 22A0000766880056BA360AA43328E0A14EB5E1E6 CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm635__10.10.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT Result: 0000 Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:07 Write : Processing rm635__10.10.mcusw Total 1165 [1165/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:00:56 MCU Write done ===Flashing [PPM]=== Erase : Processing 4673D235_rm635__10.10.ppm_m_c Found 1 areas to erase Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:51 Write : Processing 4673D235_rm635__10.10.ppm_m_c Total 198 [198/0/0] blocks to write, writing... TIME : Write time : 00:00:10 PPM Write done ===Flashing [CNT]=== Checking content info... Check Image : Content size is 128k, use direct write mode Erase : Processing DE4B81E4_rm635__10.10.image_m_c_silver Found 2 areas to erase Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT Result: 0000 Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:05:08 Write : Processing DE4B81E4_rm635__10.10.image_m_c_silver Total 408 [408/0/0] blocks to write, writing... TIME : Write time : 00:00:19 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:09:33 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 2690 Software Info: V 10.10 22-04-10 RM-635 (c) Nokia IMEI: 353410040893863 PPM version : V 10.10 22-04-10 RM-635 (c) Nokia M_C Product code: 0592535 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:10:49 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following 2 Users Say Thank You to saeedullah_khan For This Useful Post: |
12-19-2010, 15:09 | #7342 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | 6300 usb flashing done Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm217__07.21.mcusw PPM : rm217__07.21.ppm_mea4 CNT : rm217__07.21.image_mea4_black Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! RAP_PUB: 08F0000785268C561FD61B152ECA254E4D5AF6FE CMT_ROOT: BAF3A9C3DBFA8454937DB77F2B8852B1 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:05 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm217__07.21.mcusw Found 9 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00020000 - 0x0007FFFF, NOR, CMT Result: 0000 Erasing area 0x00080000 - 0x000DFFFF, NOR, CMT Result: 0000 Erasing area 0x00100000 - 0x001FFFFF, NOR, CMT Result: 0000 Erasing area 0x00200000 - 0x0031FFFF, NOR, CMT Result: 0000 Erasing area 0x00320000 - 0x0105FFFF, NOR, CMT Result: 0000 Erasing area 0x01060000 - 0x01067FFF, NOR, CMT Result: 0000 Erasing area 0x01068000 - 0x0107FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:44 Write : Processing rm217__07.21.mcusw Total 944 [944/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] CMT : Writing Hash CERT [PMM_CONF] CMT : Writing Hash CERT [SBIF_CONF] TIME : Write time : 00:01:27 MCU Write done ===Flashing [PPM]=== Erase : Processing rm217__07.21.ppm_mea4 Found 1 areas to erase Erasing area 0x01080000 - 0x015FFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:11 Write : Processing rm217__07.21.ppm_mea4 Total 243 [243/0/0] blocks to write, writing... TIME : Write time : 00:00:24 PPM Write done ===Flashing [CNT]=== Checking content info... Resetting phone... Checking CNT sector PN<>FL PN CNT sector : 128 kb Converted content already exist, skip convert and using 128k Loader len: 248320, CHK: 3714 ADL -> Sending loader... Reset connection... ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok Erase : Processing rm217__07.21.image_mea4_black_128 Found 1 areas to erase Erasing area 0x01600000 - 0x01FDFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:29 Write : Processing rm217__07.21.image_mea4_black_128 Total 296 [296/0/0] blocks to write, writing... TIME : Write time : 00:00:28 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:03:46 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 6300 Software Info: V 07.21 05-11-08 RM-217 (c) Nokia. IMEI: 358288030872013 PPM version : V 07.21 05-11-08 RM-217 (c) Nokia. MEA Product code: 0537630 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:04:35 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Last edited by saeedullah_khan; 12-19-2010 at 15:12. Reason: model changing |
12-19-2010, 15:13 | #7343 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | 3110c usb flashing done Connect phone on selected interface... Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm237__07.30.mcusw PPM : rm237__07.30.ppm_b CNT : rm237__07.30.image_ora_pl_games Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! RAP_PUB: 2D600115F3DD6E5600775F6242C7443773258C12 CMT_ROOT: BAF3A9C3DBFA8454937DB77F2B8852B1 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:05 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm237__07.30.mcusw Found 9 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00020000 - 0x0007FFFF, NOR, CMT Result: 0000 Erasing area 0x00080000 - 0x000DFFFF, NOR, CMT Result: 0000 Erasing area 0x00100000 - 0x001FFFFF, NOR, CMT Result: 0000 Erasing area 0x00200000 - 0x0031FFFF, NOR, CMT Result: 0000 Erasing area 0x00320000 - 0x0105FFFF, NOR, CMT Result: 0000 Erasing area 0x01060000 - 0x01067FFF, NOR, CMT Result: 0000 Erasing area 0x01068000 - 0x0107FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:36 Write : Processing rm237__07.30.mcusw Total 945 [945/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [PAPUBKEYS] CMT : PAPUBKEYS skip, already sent CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] CMT : Writing Hash CERT [PMM_CONF] CMT : Writing Hash CERT [SBIF_CONF] TIME : Write time : 00:01:18 MCU Write done ===Flashing [PPM]=== Erase : Processing rm237__07.30.ppm_b Found 1 areas to erase Erasing area 0x01080000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:29 Write : Processing rm237__07.30.ppm_b Total 205 [205/0/0] blocks to write, writing... TIME : Write time : 00:00:19 PPM Write done ===Flashing [CNT]=== Checking content info... Resetting phone... Checking CNT sector PN<>FL PN CNT sector : 128 kb Converted content already exist, skip convert and using 128k Loader len: 253888, CHK: 17DB ADL -> Sending loader... Reset connection... ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok Erase : Processing rm237__07.30.image_ora_pl_games_128 Found 1 areas to erase Erasing area 0x01520000 - 0x01FDFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:09 Write : Processing rm237__07.30.image_ora_pl_games_128 Total 296 [296/0/0] blocks to write, writing... TIME : Write time : 00:00:23 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:05:16 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 3110c Software Info: V 07.30 07-05-09 RM-237 (c) Nokia. IMEI: 359539011643131 PPM version : V 07.30 07-05-09 RM-237 (c) Nokia. B Product code: 0544343 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:06:11 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
12-19-2010, 19:09 | #7344 (permalink) |
No Life Poster Join Date: Nov 2006 Location: DEATH VALLEY
Member: 394869 Status: Offline Sonork: TAKE NO CHANCES Thanks Meter: 500 | MOTOROLA-WX181 UNLOCKED SUCCESSFULY module v3.70 Device: Motorola-WX181 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:5E69:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088BAFFFFFFFF:2088BA00000000 flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 TCL-ID identification version: 564 provider: M181X-CARGAP5 customization: CM56DD10 customization: XM56DD10 TCL-ID identification done rom info structure: [standard] type (05) TCL-ID is present ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XM56DD10 customization name adjusted flash: 2088BAFFFFFFFF:2088BA00000000 flash: 2088BAFFFFFFFF:2088BA00000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... max address is too big, should be recalculated: 0827D124->0826B790 ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 2088BAFFFFFFFF:2088BA00000000 flash: 2088BAFFFFFFFF:2088BA00000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 0000D6D0A2442B flash: 2088BAFFFFFFFF:2088BA00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 2088BAFFFFFFFF:2088BA00000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Motorola-WX181_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_ W08_36_SP1_V28_F1__system_log__00000000_20101219-050138.B0X.bin Finished, time used: 1 min 59 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following 2 Users Say Thank You to KYEJUSA For This Useful Post: |
12-20-2010, 05:23 | #7345 (permalink) |
No Life Poster Join Date: May 2007 Location: uk
Member: 508072 Status: Offline Thanks Meter: 1,621 | rd 3510 done OFFLINE... sending boot... sending command... patching in progress... patching in progress 50%... patching in progress 100%... Done... Phones should be restarting now... Finished, time used: 24 sec |
The Following User Says Thank You to joni_rajpura For This Useful Post: |
12-20-2010, 06:21 | #7346 (permalink) |
Member: 213172 Status: Offline Sonork: 1582799 Thanks Meter: 265 | COM6 [VCP0] selected module v3.63 Action: "sp-unlock" unlock method: smart fast Model: Orange-Rome Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: ORANGE_ENG_EN_P107A1V1.0.4B02 Version: 08BZTENJ35_OG_08B 80 byte(s) read imei: 35424903286802 connection Ok 186 byte(s) read reading data... reading data #2... building new data... writing data... 174 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 3 min 13 sec Remove/Install battery now ! |
The Following User Says Thank You to abdulwajid147 For This Useful Post: |
12-20-2010, 07:34 | #7347 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Under Blue
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | NKTEL MODEL # A200. giving this msg. New firmware found (v.3.25, database date: 30.11.2010): N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_2CDGB_ S5_TM_V4_0_7.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) What is this ???? I have sent the backup file to support . Last edited by amn32; 12-20-2010 at 07:42. |
12-20-2010, 07:38 | #7348 (permalink) |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM12 [VCP0] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:E203:0007 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #02 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #03 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent ==================== New firmware found (v.3.25, database date: 24.10.2010): LC6225_GEMINI_PCB01_GPRS_MT6225_S00.LBBKY23_8_12_1 _0T01M1112_M571.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 04 sw version: LC6225_GEMINI_PCB01_GPRS_MT6225_S00.LBBKY23_8_12_1 _0T01M1112_M571.BIN project-id: LBBKY23.8.12.1.0T01M1112_M571, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: LC6225_GEMINI_PCB01_GPRS_MT6225_S00.LBBKY23_8_12_1 _0T01M1112_M571__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\LC6225_GEMINI_PCB 01_GPRS_MT6225_S00.LBBKY23_8_12_1_0T01M1112_M571__ ffs_20101220-113441.B0E.bin flash: EC240200000000:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC240200000000:18E59F00000000 Finalization Done Finished, time used: 2 min 9 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to cel_phon For This Useful Post: |
