12-21-2010, 07:45 | #7381 (permalink) |
No Life Poster Join Date: Mar 2007 Location: punjab(india) Age: 45
Member: 467045 Status: Offline Sonork: 100.1603919 Thanks Meter: 1,705 | nokia 5130c done registered to: jindalgsm4255 DLL not found... Connect phone on selected interface... Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm495__07.97.mcusw PPM : rm495__07.97.ppm_mr CNT : rm495__07.97.image_mr_blu Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! RAP_PUB: 0800021510CA8B566C4A49773E29D7D6A45072B2 CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm495__07.97.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT Result: 0000 Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:20 Write : Processing rm495__07.97.mcusw Total 1178 [1178/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:00:55 MCU Write done ===Flashing [PPM]=== Erase : Processing rm495__07.97.ppm_mr Found 1 areas to erase Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:57 Write : Processing rm495__07.97.ppm_mr Total 470 [470/0/0] blocks to write, writing... TIME : Write time : 00:00:22 PPM Write done ===Flashing [CNT]=== Checking content info... Check Image : Content size is 128k, use direct write mode Erase : Processing rm495__07.97.image_mr_blu Found 2 areas to erase Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT Result: 0000 Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:05:05 Write : Processing rm495__07.97.image_mr_blu Total 664 [664/0/0] blocks to write, writing... TIME : Write time : 00:00:31 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:10:11 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5130c-2 Software Info: V 07.97 13-09-10 RM-495 (c) Nokia IMEI: 356944035881670 PPM version : V 07.97 13-09-10 RM-495 (c) Nokia MR Product code: 0585577 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:11:22 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following 2 Users Say Thank You to JINDALGSM™ For This Useful Post: |
12-21-2010, 08:10 | #7382 (permalink) |
No Life Poster Join Date: Nov 2007 Location: ☆I-LOVE Pakistan☆
Member: 627475 Status: Offline Sonork: 100.1594828 Thanks Meter: 1,144 | Flash done K-9000 COM4 [VCP0] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware AOXUN25_GEMINI_PCB01_GPRS_MT6225_S00.D10_V005_LDF_ TOSH_ML_080928__LDF-K-9000_16m_En_Ru_Fr_Es_It_Id_Th_Vn_Tr_Farsi_Ar.B0M.b in skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:9C03:0009 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #02 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #03 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE51050136500000F00 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: AOXUN25_GEMINI_PCB01_GPRS_MT6225_S00.D10_V005_LDF_ TOSH_ML_080928.BIN project-id: D10_V005_LDF_TOSH_ML_080928, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: AOXUN25_GEMINI_PCB01_GPRS_MT6225_S00.D10_V005_LDF_ TOSH_ML_080928__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\AOXUN25_GEMINI_PC B01_GPRS_MT6225_S00.D10_V005_LDF_TOSH_ML_080928__f fs_20101221-000352.B0E.bin flash: 98004900000002:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... done detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: 98004900000002:18E59F00000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 3 min 4 sec Remove/Install battery now ! |
The Following User Says Thank You to rafi_5217705 For This Useful Post: |
12-21-2010, 08:15 | #7383 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Jalandhar Age: 39
Member: 580966 Status: Offline Sonork: 100.1590311 Thanks Meter: 725 | Device: Spice-S404N Code: Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6205:8B00]... CPU: MT6205 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < ffs/eeprom address can not be detected, value from database assigned: 00300000/00100000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: EC22A000000000:18E59F00000000 Backup required data Done ====> Patch required data ... ........ lock area found Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... ................ error: area 1 can not apply patch detecting parameters to apply patch area 2... ................ error: area 2 can not apply patch detecting parameters to apply patch area 3... ................ error: area 3 can not apply patch detecting parameters to apply patch area 4... ..... required data found flash: EC22A000000000:18E59F00000000 flash: EC22A000000000:18E59F00000000 Write: area 4 (pass 1) ........... area 4 patch applied Ok Special operation Done ====> Write ... flash: EC22A000000000:18E59F00000000 flash: EC22A000000000:18E59F00000000 Write: lock-area-1 Write Done ====> Finalization ... Finalization Done Finished, time used: 35 sec Remove/Install battery now ! |
The Following User Says Thank You to KK Mobile For This Useful Post: |
12-21-2010, 09:00 | #7384 (permalink) |
No Life Poster Join Date: Jan 2007 Location: udaipur, I N D I A Age: 37
Member: 422762 Status: Offline Sonork: 100.1593904 Thanks Meter: 973 | haier C-2040 checking version... HA2040MT04Mar 31 2010 Haier C2040 version 04 compile Mar 31 2010 selected.. Downloading mode... Sending command... patching in progress... patching in progress 50%... patching in progress 100%... Done... Phones should be restarting now... Finished, time used: 19 sec |
The Following 2 Users Say Thank You to himanshu taldar For This Useful Post: |
12-21-2010, 09:27 | #7385 (permalink) |
No Life Poster Join Date: Apr 2008 Location: PROTECTED BY 308
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | LG-RD6100 Repair done QSC6010-RD6100 QSC6010-RD6100 LG RD6100 selected.. erasing... Done... Finished, time used: 1 min 12 sec |
The Following 2 Users Say Thank You to akashub For This Useful Post: |
12-21-2010, 10:36 | #7386 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Pakistan/UAE/WorldWide
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | C3 Flash Just in 10 Second registered to: mohsin Connect phone on selected interface... Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm614__07.25.mcusw PPM : rm614__07.25.ppm_p CNT : rm614__07.25.image_p_0594092 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000000000000022000509200C0000 EM0 ID: 00005361 PUBLIC ID: 0000000000B21EA5F6FEC8E8B8BDDCCF45DBEBF4 ASIC MODE ID: 00 ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E ROM ID: DE56D582BDDE7A3A Use BCM21351_usb2nd.fg Processing RAWLOADER... FLIC : 00300020 Req : XSR 1.6 Use BCM21351_XSR16_usbalg.fg Boot Done! TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 3553660423****** Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : D:\infinity bb5 tool\BEST 1.11\BEST_v1.11\Backup\Cert\3553660423*****_CRT.rp l ===Flashing [MCU]=== Erase : Processing rm614__07.25.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm614__07.25.mcusw CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [ISA+DYNSW] Total writen 528 blocks TIME : Write time : 00:00:05 MCU Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [PPM]=== Erase : Processing rm614__07.25.ppm_p Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm614__07.25.ppm_p Total writen 119 blocks TIME : Write time : 00:00:01 PPM Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [CNT]=== Erase : Processing rm614__07.25.image_p_0594092 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm614__07.25.image_p_0594092 Total writen 269 blocks TIME : Write time : 00:00:02 CNT Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Flashing done! Total flash time : 00:00:10 Reboot phone now... Reading Phone Info.... Connected phone - C3-00 Software Info: V 07.25 26-11-10 RM-614 (c) Nokia IMEI: 3553660423**** PPM version : V 07.25 26-11-10 RM-614 (c) Nokia P Product code: 0594149 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Checking User Certificates... Total - 39 certs Data exist, skip certificate repair... Set phone to Normal mode... AfterFlash operations done... Done! Elapsed: 00:01:34 Connect phone on selected interface... |
The Following 2 Users Say Thank You to Mohsin-* For This Useful Post: |
12-21-2010, 10:36 | #7387 (permalink) |
No Life Poster Join Date: May 2007 Location: uk
Member: 508072 Status: Offline Thanks Meter: 1,621 | COM6 [VCP0] selected module v3.25 Action: "repair imei" imei write method: mode-2 imei write channel: imei #1 for dual sim/mono CPU new imei: 352667004435111 Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:1903:0001 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: R206AG_GH_S206_F10A_V01_091117 Version: RONCENT25_GEMINI_08B_HW detecting structure #2... 1 2 3 5 7 8 9 11 13 done 80 byte(s) read imei: 35950200081865 connection Ok detecting structure #2... 1 2 3 5 7 8 9 11 13 done 80 byte(s) read verification... verification done: 35266700443511 Finished, time used: 14 sec Remove/Install battery now ! |
The Following User Says Thank You to joni_rajpura For This Useful Post: |
12-21-2010, 10:54 | #7388 (permalink) |
No Life Poster Join Date: Oct 2010 Location: INDIA (WEST BENGAL)
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | 2700c nokia logo success by best card found: S/N -----:----- registered to: NILOY Connect phone on selected interface... UFS S/N ------- boot - Ok Connect phone on selected interface... Read and Check phone data... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 12600203F3CF8A564500783A65E5A9E0DAA595EE CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg CMT Algo sent CMT PAPUB : A22A1DDA660002E56108DB5072A10F8709443FA800 Transmission mode : Dual (Ddr, TX2) Boot Done! Init Service mode... Wait... Init Service Mode Failed, can't proceed checking... Connect phone on selected interface... Selected FlashSettings : FullFlash Files Set for Flashing : MCU : rm561__09.95.mcusw PPM : rm561__09.95.ppm_mena_a CNT : rm561__09.95.image_mena_a_blac Check FlashFiles, Please, wait... Backup enabled, Will read Certificates now... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 12600203F3CF8A564500783A65E5A9E0DAA595EE CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg CMT Algo sent CMT PAPUB : A22A1DDA660002E56108DB5072A10F8709443FA800 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 20480 byte(s) IMEI : 354192037258164 CMT : Read CCC certificate... Cert size : 30600 byte(s) CMT : Read HWC certificate... Cert size : 20480 byte(s) CMT : Read VARIANT certificate... Cert size : 0 byte(s) Cert Read done! Init Service mode... Wait... Init Service Mode Failed! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\Best_v1.11\BEST_v1.11\Backup\Cert\3541920372581 64_CRT.rpl Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 12600203F3CF8A564500783A65E5A9E0DAA595EE CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg CMT Algo sent CMT PAPUB : A22A1DDA660002E56108DB5072A10F8709443FA800 Transmission mode : Dual (Ddr, TX2) Boot Done! Transmission mode : Dual (Ddr, TX2) Erase : Processing rm561__09.95.mcusw Found 6 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x000006BF CMT , NOR , Area : 0x000006C0 - 0x0001FFFF CMT , NOR , Area : 0x00040000 - 0x000BFFFF CMT , NOR , Area : 0x000C0000 - 0x0013FFFF CMT , NOR , Area : 0x00140000 - 0x0137FFFF CMT , NOR , Area : 0x01380000 - 0x0151FFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:01:38 Transmission mode : Dual (Ddr, TX2) Write : Processing rm561__09.95.mcusw CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] Total writen 1247 blocks TIME : Write time : 00:02:22 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm561__09.95.ppm_mena_a Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01520000 - 0x01DBFFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:33 Transmission mode : Dual (Ddr, TX2) Write : Processing rm561__09.95.ppm_mena_a Total writen 350 blocks TIME : Write time : 00:00:38 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm561__09.95.image_mena_a_blac Found 2 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01DC0000 - 0x0215FFFF CMT , NOR , Area : 0x02160000 - 0x03FBFFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:03:46 Transmission mode : Dual (Ddr, TX2) Write : Processing rm561__09.95.image_mena_a_blac Total writen 528 blocks TIME : Write time : 00:00:58 Init Service mode... Wait... Init Service mode Failed! Skip AfterFlash Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Backup Certificates now... CRT308 Backup Created... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006030C192101033000 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 12600203F3CF8A564500783A65E5A9E0DAA595EE CMT MODE ID : 00 CMT R_HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok MCU Configuration FLASHID : 89820089 , CMT , NOR CMT Flash ID : 89820089 < INTEL => 0046L0Y1GG/NU48F512 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo_v1331.fg CMT Algo sent CMT PAPUB : A22A1DDA660002E56108DB5072A10F8709443FA800 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 20480 byte(s) IMEI : 354192037258164 CMT : Read CCC certificate... Cert size : 30600 byte(s) CMT : Read HWC certificate... Cert size : 20480 byte(s) CMT : Read VARIANT certificate... Cert size : 0 byte(s) Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : C:\Best_v1.11\BEST_v1.11\Backup\Cert\3541920372581 64.rpl Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 2700 classic Software ver : V 09.95 02-04-10 RM-561 (c) Nokia IMEI : 354192037258164 Ape Ver : APE Var : APE ADSP: DSP Ver : ICPR72_09w26 APE Test: PPM : V 09.95 02-04-10 RM-561 (c) Nokia MEN CNT : Content: mena_a_black V 09.95 02-04-10 RM-561 (c) Nokia Product SN : ICS808313 Product code : 0588814 Base Prd.code: 0577212 Module code : 0204245 Long Prod.SN : 0 Hardware info======= HWID : 2000 Retu : 16 Tahvo : 22 Batery: 4869 mV Camera: CMT BT: 2222-302 APE BT: APE HW: LCDVer: SEIKO RF ic : 06540601 Lock info =========== IMEI : 354192037258164 IMEI spNet : IMEI svNet : Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Resetting selected items... Check phone mode... Phone already in Test mode, skip change... Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:02 Phone disconected! |
The Following 4 Users Say Thank You to niloy2007 For This Useful Post: |
12-21-2010, 11:00 | #7389 (permalink) |
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | Nokia 3110c successfull by best SUCCESS IS NOT 100% AFTER LONG TIME FLASH IS 100% NO NOKIA THEM & GRAPHIC CALCULATOR SIR RESOLVE IT SOON......... card found: S/N ------:------ registered to: NILOY Connect phone on selected interface... UFS S/N ------- boot - Ok Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Selected FlashSettings : Manual Files Set for Flashing : MCU : rm237__07.30.mcusw PPM : rm237__07.30.ppm_c CNT : rm237__07.30.image_c_tr Check FlashFiles, Please, wait... Backup enabled, Will read Certificates now... Backup CRT308 CRT308 Backup Created... CRT308 Backup Created... Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 0C00010533537B56850BF0DE869A8F8F2C9BA456 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok MCU Configuration FLASHID : 881C0020 , CMT , NOR CMT Flash ID : 881C0020 < ST => M39L0R807 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg CMT Algo sent CMT PAPUB : E691EA16A7593A9BB28832D7312A39F7ED668D0500 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 12288 byte(s) IMEI : 355728021381410 CMT : Read CCC certificate... Cert size : 8192 byte(s) CMT : Read HWC certificate... Cert size : 12288 byte(s) CMT : Read VARIANT certificate... Cert size : 20480 byte(s) Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... WMDRM_PD Data saved... RPL saved : C:\Best_v1.11\BEST_v1.11\Backup\Cert\3557280213814 10.rpl Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000353 CMT PUB ID : 0C00010533537B56850BF0DE869A8F8F2C9BA456 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok MCU Configuration FLASHID : 881C0020 , CMT , NOR CMT Flash ID : 881C0020 < ST => M39L0R807 FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg CMT Algo sent CMT PAPUB : E691EA16A7593A9BB28832D7312A39F7ED668D0500 Transmission mode : Dual (Ddr, TX2) Boot Done! Transmission mode : Dual (Ddr, TX2) Erase : Processing rm237__07.30.mcusw Found 9 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x000006BF CMT , NOR , Area : 0x000006C0 - 0x0001FFFF CMT , NOR , Area : 0x00020000 - 0x0007FFFF CMT , NOR , Area : 0x00080000 - 0x000DFFFF CMT , NOR , Area : 0x00100000 - 0x001FFFFF CMT , NOR , Area : 0x00200000 - 0x0031FFFF CMT , NOR , Area : 0x00320000 - 0x0105FFFF CMT , NOR , Area : 0x01060000 - 0x01067FFF CMT , NOR , Area : 0x01068000 - 0x0107FFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:57 Transmission mode : Dual (Ddr, TX2) Write : Processing rm237__07.30.mcusw CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [PMM_CONF] CMT: Writing Hash CERT [SBIF_CONF] Total writen 943 blocks TIME : Write time : 00:02:10 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm237__07.30.ppm_c Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01080000 - 0x0151FFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:15 Transmission mode : Dual (Ddr, TX2) Write : Processing rm237__07.30.ppm_c Total writen 240 blocks TIME : Write time : 00:00:33 Transmission mode : Dual (Ddr, TX2) Erase : Processing rm237__07.30.image_c_tr Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01520000 - 0x01FDFFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:44 Transmission mode : Dual (Ddr, TX2) Write : Processing rm237__07.30.image_c_tr Total writen 236 blocks TIME : Write time : 00:00:32 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia 3110c Software Info: V 07.30 07-05-09 RM-237 (c) Nokia. IMEI: 355728021381410 Product code: 0566963 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Resetting selected items... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Elapsed: 00:00:08 |
The Following 3 Users Say Thank You to niloy2007 For This Useful Post: |
12-21-2010, 11:28 | #7390 (permalink) |
No Life Poster Join Date: Nov 2006 Location: DEATH VALLEY
Member: 394869 Status: Offline Sonork: TAKE NO CHANCES Thanks Meter: 500 | ALCATEL 0T-305X UNLOCKED module v3.70 Device: Alcatel-305X, 305A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:BC6A:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:2BEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.C44F1 930.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN_6B2FA2BD].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: C44F1930 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, BDA22F6B code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 164 provider: 305X-2DVDKE1 customization: CP16CH10 customization: XP16CH10 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XP16CH10 customization name adjusted flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: EC240200000000:2BEA0000000000 flash: EC240200000000:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: FFFFFFFFFFFFFF flash: EC240200000000:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC240200000000:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-305X,305A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08 A_W08_36_SP1_V34__system_log_C44F1930_6B2FA2BD_201 01221-022121.B0X.bin Finished, time used: 3 min 29 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to KYEJUSA For This Useful Post: |
12-21-2010, 12:13 | #7391 (permalink) |
Freak Poster Join Date: Jun 2006 Location: KERALA , INDIA
Member: 287529 Status: Offline Thanks Meter: 62 | Samsung B189 unlock COM29 [VCP0] selected COM29 not available Abort operation ? COM29 not available Abort operation ? module v1.41 Device: Samsung-SCH-B139, B189 operation: SP-unlock Phone should be Switched ON ! connecting... Connecting, wait... Phone detected, wait... step-1 done step-2 done step-3 done operation finished Finished, time used: 32 sec |
The Following 2 Users Say Thank You to Cellcraft India For This Useful Post: |
12-21-2010, 12:35 | #7392 (permalink) |
Member: 508072 Status: Offline Thanks Meter: 1,621 | COM6 [VCP0] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware MT6225_08A_GEMINI_PCB01_GPRS_MT6225_S00.X5_HW3_0_1 3_TV_100422__Nokia-5800_2010-04-22_16m_En_Ru_Fr_Es_It_Ml_Id_Th_Vn_Tr_Farsi_Pt_Ar.B 0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:9F03:000B status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Code CRC check error fix... firmware do not have "Code CRC check error" area Special operation Done ====> Write ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < ffs/eeprom address can not be detected, value from database assigned: 00000000/00000000 sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: EC257E25082501:FFFFFF00000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 9 min 56 sec Remove/Install battery now ! |
12-21-2010, 13:02 | #7393 (permalink) |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,215 | COM3 [VCP0] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:9C03:000F status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: UNISTAR25_GEMINI_PCB01_GPRS_MT6225_S00.X12_S9325_V 3_0_0619_1.BIN project-id: X12_S9325_V3.0_0619_1, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: UNISTAR25_GEMINI_PCB01_GPRS_MT6225_S00.X12_S9325_V 3_0_0619_1__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\UNISTAR25_GEMINI_ PCB01_GPRS_MT6225_S00.X12_S9325_V3_0_0619_1__ffs_2 0101221-035957.B0E.bin flash: EC257E25082501:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC257E25082501:18E59F00000000 Finalization Done Finished, time used: 2 min 8 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to mbiborna For This Useful Post: |
12-21-2010, 13:05 | #7394 (permalink) |
Member: 394869 Status: Offline Sonork: TAKE NO CHANCES Thanks Meter: 500 | MOTOROLA-WX181 UNLOCKED module v3.70 Device: Motorola-WX181 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6A13:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088BAFFFFFFFF:2088BA00000000 flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 TCL-ID identification version: 564 provider: M181X-CARGAP5 customization: CM56DD10 customization: XM56DD10 TCL-ID identification done rom info structure: [standard] type (05) TCL-ID is present ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XM56DD10 customization name adjusted flash: 2088BAFFFFFFFF:2088BA00000000 flash: 2088BAFFFFFFFF:2088BA00000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... max address is too big, should be recalculated: 0827D124->0826B790 ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 2088BAFFFFFFFF:2088BA00000000 flash: 2088BAFFFFFFFF:2088BA00000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 00008C9083B27B flash: 2088BAFFFFFFFF:2088BA00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 2088BAFFFFFFFF:2088BA00000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Motorola-WX181_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_ W08_36_SP1_V28_F1__system_log__00000000_20101221-040132.B0X.bin Finished, time used: 2 min 12 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
12-21-2010, 13:57 | #7395 (permalink) |
No Life Poster Join Date: Jan 2008 Location: sai baba shirdi Age: 44
Member: 670629 Status: Offline Sonork: 100.1590208 Thanks Meter: 431 | mts -s100 unlock COM22 [QCUSB_COM22_1] selected module v1.41 Device: ZTE-S100 operation: SP-unlock Phone should be Switched ON ! connecting... OFFLINE... send spc... disabling minlock... Done... Phones should be restarting now... Finished, time used: 6 sec |
The Following 2 Users Say Thank You to d.jain For This Useful Post: |
