12-23-2010, 14:55 | #7456 (permalink) |
No Life Poster Join Date: May 2007 Location: uk
Member: 508072 Status: Offline Thanks Meter: 1,621 | module v1.41 Device: Samsung-SCH-B159 operation: DE-26 boot unlock (Force mode) Phone should be Switched ON ! connecting... samsung b159 boot mode... Patching in progress... patching done... Wait reconnecting for restart... Done... Phones should be restart now if not take out the battery... Finished, time used: 21 sec COM2 [VCP0] selected module v1.41 Device: Samsung-SCH-B159 operation: UART unlock Phone should be Switched ON ! connecting... Connecting, wait... Phone detected, wait... step-1/1 done step-1/2 done step-1/3 done step-1/4 done step-1/5 done step-2 done step-3 done operation finished Finished, time used: 24 sec |
The Following User Says Thank You to joni_rajpura For This Useful Post: |
12-23-2010, 15:21 | #7457 (permalink) |
No Life Poster Join Date: Mar 2007 Location: TUNISIA Age: 41
Member: 479816 Status: Offline Thanks Meter: 851 | X3(RM-540) succes flashe... Code: Connect phone on selected interface... Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm540__08.54.mcusw PPM : rm540__08.54.ppm_i CNT : rm540__08.54.image_i_0580824_006 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600000001020C192102034100 EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 2650010D2C4C0E49A836004E61BF30D5614CACBD ASIC MODE ID: 00 ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D ROM ID: 67E82268F29CEA60 Use RAP3Gv40_2nd.fg Processing RAWLOADER... FLIC : 003000EC Req : XSR 1.6 Use RAP3Gv40_XSR17_alg.fg Boot Done! :) TIME : Boot time : 00:00:05 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 351536043033875 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : D:\Documents and Settings\Administrateur\Bureau\BEST_v1.11\BEST_v1.11\Backup\Cert\351536043033875_CRT.rpl ===Flashing [MCU]=== Erase : Processing rm540__08.54.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm540__08.54.mcusw CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [ISA+DYNSW] Total writen 124 blocks TIME : Write time : 00:00:54 MCU Write done ADL: Request programm status NAND status : 00000002 / 00000002 / 00000000 ===Flashing [PPM]=== Erase : Processing rm540__08.54.ppm_i Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm540__08.54.ppm_i Total writen 24 blocks TIME : Write time : 00:00:12 PPM Write done ADL: Request programm status NAND status : 00000002 / 00000002 / 00000000 ===Flashing [CNT]=== Erase : Processing rm540__08.54.image_i_0580824_006 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm540__08.54.image_i_0580824_006 Total writen 64 blocks TIME : Write time : 00:00:33 CNT Write done ADL: Request programm status NAND status : 00000002 / 00000002 / 00000000 ADL: Close_Session Content: 000300000000020000000200000000 ADL: Reboot Flashing done! Total flash time : 00:01:42 Reboot phone now... Reading Phone Info.... Connected phone - Nokia X3-00 Software Info: V 08.54 25-10-10 RM-540 (c) Nokia IMEI: 351536043033875 PPM version : V 08.54 25-10-10 RM-540 (c) Nokia I Product code: 0580751 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 34 certs Data exist, skip certificate repair... AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:02:20 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia X3-00 Software ver : V 08.54 25-10-10 RM-540 (c) Nokia IMEI : 351536043033875 Ape Ver : APE Var : APE ADSP: DSP Ver : ICPR91_10w11_2 APE Test: PPM : V 08.54 25-10-10 RM-540 (c) Nokia I CNT : Content: i_0580824 V 08.54 25-10-10 RM-540 (c) Nokia Product SN : KKV002625 Product code : 0580751 Base Prd.code: 0578316 Module code : 0204201 Long Prod.SN : 0 Hardware info======= HWID : 2000 Retu : 40 Tahvo : 00 Batery: 3690 mV Camera: CMT BT: 1673-46038 APE BT: APE HW: LCDVer: SEIKO RF ic : Lock info =========== IMEI : 351536043033875 IMEI spNet : 3A 15 35 06 34 30 83 07 IMEI svNet : 33 15 35 06 34 30 83 57 F8 Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created... :) User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Phone disconected! |
The Following 4 Users Say Thank You to chimed09 For This Useful Post: |
12-23-2010, 15:54 | #7458 (permalink) |
No Life Poster Join Date: Jan 2008 Location: sai baba shirdi Age: 44
Member: 670629 Status: Offline Sonork: 100.1590208 Thanks Meter: 431 | mts---zte --s100 unlock COM26 [QCUSB_COM26_1] selected module v1.41 Device: ZTE-S100 operation: SP-unlock Phone should be Switched ON ! connecting... OFFLINE... send spc... disabling minlock... Done... Phones should be restarting now... Finished, time used: 7 sec |
The Following 2 Users Say Thank You to d.jain For This Useful Post: |
12-23-2010, 16:41 | #7459 (permalink) |
Freak Poster Join Date: Jul 2009 Location: In Ur Heart Age: 34
Member: 1066949 Status: Offline Sonork: 100.1593801 Thanks Meter: 44 | 2730sl3 successfully unlock bb5 easy tool Phone found! Series 40 Device detected! read info... - Ok Login: ?????? Password:?????? Connecting to server... user: 116E6C78.03 credit: ??? jobs in progress: 0 jobs done: 3 Unlock procedure started... Server version: 0.140 There are 62 free slots on the server. Looking for jobs...You have no current jobs. Archived jobs: 356058030165433: Code: #pw+112274286267910+7# 356057036548741: Code: #pw+880385869196981+7# 359306027641248: Code: #pw+012352698146900+7# Using F-bus count... Sending code 880385869196981 Level : 7 to SimLock Server... Simlock Server Answer: Unlock code Accepted! Done! Last edited by alonefriend07; 12-23-2010 at 16:47. |
The Following User Says Thank You to alonefriend07 For This Useful Post: |
12-23-2010, 17:30 | #7460 (permalink) |
Freak Poster Join Date: Oct 2010 Location: Dakar
Member: 1415435 Status: Offline Sonork: 1595155 Thanks Meter: 86 | Sony Ericsson J132 done with Infinity COM6 [VCP0] selected module v1.38 Device: Sony-Ericsson-J132 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 2088C0FFFFFFFF:2088C000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb Check hardware done Read data ... reading Sony-Ericsson-J132_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-J132_eeprom_calibration-1_20101220-121830.80E.bin Read data done Check data ... Check data done Write ... ..... flash: 2088C0FFFFFFFF:2088C000000000 Write: simlock Write done Finished, time used: 1 min 56 sec Remove/Install battery now ! |
The Following User Says Thank You to SenUnlock For This Useful Post: |
12-23-2010, 17:37 | #7461 (permalink) |
Member: 1415435 Status: Offline Sonork: 1595155 Thanks Meter: 86 | LG-KP235 done COM16 [VCP0] selected module v1.39 Device: LG-KP235 Checking data, wait... advanced flash detection enabled Action: reset Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005258 Boot Done Set baud ... 921600 Set baud Done Check flash ... current eeprom imei: 352127022664796 file saved: C:\Program Files\InfinityBox\LGA\eeprom_352127022664796_LG-KP235_20101209-002847.B1E.bin .... Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 116 sec Remove/Install battery now ! |
12-23-2010, 17:39 | #7462 (permalink) |
Member: 1415435 Status: Offline Sonork: 1595155 Thanks Meter: 86 | Another Aclcatel Ot-708 Done COM6 [VCP0] selected module v3.70 Device: Alcatel-708X, 708A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:7B03:A001 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000003:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb otp offset: 01FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: [protected] type (07), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.648ED 493.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_901BF1F0].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 648ED493 rom info ver: 07 sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN project-id: MAUI.08A.W08.40.SP1.V32, F0F11B90 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 TCL-ID identification version: 16Q provider: 708A-2ATGMX1 customization: CN16BM31 customization: XN16BM31 TCL-ID identification done rom info structure: [protected] type (07), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: disabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: disabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, cust) calculation... error: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN16BM31 customization name adjusted flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN16BM31 customization name adjusted flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000003:09EA0000000000 flash: 98006F00000003:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35400703349891 flash: 98006F00000003:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000003:09EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-708X,708A_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_0 8A_W08_40_SP1_V32__system_log_648ED493_901BF1F0_20 101220-181253.B0X.bin Finished, time used: 5 min 23 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
12-23-2010, 19:03 | #7463 (permalink) |
Junior Member Join Date: Oct 2005
Member: 190464 Status: Offline Thanks Meter: 1 | COM13 [VCP3] selected Модуль v3.25 Action: reset settings ("format ffs") Модель: Autodetect 6205-6239 NOR Проверка данных, ждите... Аппарат должен быть выключен ! Нажмите и ДЕРЖИТЕ кнопку включения ! 19200 autodetect Инициализация [6225:8A05:8A00]... CPU: MT6225 высокая скорость загрузки On chip: 0001:6303:000F status: FF Connecting at 19200, wait... Отпустите кнопку включения ! Аппарат найден, ждите... Железо: MT6225,E05 Дата: 2006.06.14 Версия: 1.0 Версия: MAUI.GEMINI.W08.12 Версия: KINGSTAR25_GEMINI_HW определение структуры #2... 5 11Готов 67 byte(s) read imei: 35395401233014 связь Ok building list... Готов items to clear: 197 предупреждение: wrong packet cs предупреждение: wrong packet cs элементов очищено: 197 of 197 building list... Готов осталось элементов: 0 Закончено, потребовалось времени: 30 sec Отключите/подключите батарею ! |
The Following User Says Thank You to alexbasf For This Useful Post: |
12-23-2010, 21:02 | #7464 (permalink) |
No Life Poster Join Date: Nov 2007
Member: 633231 Status: Offline Thanks Meter: 666 | COM1 [Serial0] selected module v3.64 Action: "sp-unlock" unlock method: smart fast Model: Huawei-G6600 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: E5.2JH01V01.04 Version: BYD35_09A_PMWY_HW 82 byte(s) read imei: 35751003613607 connection Ok 189 byte(s) read reading data... reading data #2... building new data... writing data... 177 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 16 sec Remove/Install battery now ! |
The Following User Says Thank You to thewolverine For This Useful Post: |
12-23-2010, 21:21 | #7465 (permalink) |
Member: 633231 Status: Offline Thanks Meter: 666 | Port COM1 open OK Connect phone on selected interface... Wait... Phone found... Phone in Normal mode Seting Local mode... Local mode set Phone Nokia 1680c-2b connected - Ok IMEI 011986000812047 Read Lock Info Locked to Orange;Dominican Republic Unlocking... Unlock - Ok Port COM1 close |
12-24-2010, 08:38 | #7466 (permalink) |
No Life Poster Join Date: Jan 2007 Location: udaipur, I N D I A Age: 37
Member: 422762 Status: Offline Sonork: 100.1593904 Thanks Meter: 973 | COM2 [VCP1] selected module v1.39 Device: LG-C3300 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 89881500010001:89881500000000 flash: 89881500010001:89881500000000 flash: Intel 128MBit-B Strata B 16Mb id: 00005271 Boot Done Set baud ... 921600 Set baud Done Check flash ... current eeprom imei: xxxxxx file saved: C:\Program Files\InfinityBox\LGA\eeprom_356021000xxxxx5_LG-C3300_20101224-130441.B1E.bin .. Check flash Done Check space ... current eeprom imei: 3560210xxxxxx.......................... finalization done Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... write: lock area-1 Write Done Finished, time used: 33 sec Remove/Install battery now ! |
The Following User Says Thank You to himanshu taldar For This Useful Post: |
12-24-2010, 11:07 | #7467 (permalink) |
Member: 508072 Status: Offline Thanks Meter: 1,621 | COM2 [VCP1] selected module v1.41 Device: Huawei-C2905 operation: SP-unlock Phone should be Switched ON ! connecting... OFFLINE... disable minlock... Phones should be restarting now... Finished, time used: 5 sec |
12-24-2010, 11:15 | #7468 (permalink) |
Member: 508072 Status: Offline Thanks Meter: 1,621 | COM2 [VCP1] selected module v3.70 Device: Spice-S415-2008-03-19 Checking data, wait... advanced flash detection disabled Action: "sp-unlock" unlock method: standard fast Unlock procedure can be faster if you skip ffs/eeprom area backup procedure. Do you want to disable ffs/eeprom backup ? ffs/eeprom backup disabled ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6205:8B00]... CPU: MT6205 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 7F22C400000000:18E59F00000000 flash: T 2Mb otp offset: 001F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < ffs/eeprom address can not be detected, value from database assigned: 001B0000/00050000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 7F22C400000000:18E59F00000000 Backup required data Done ====> Patch required data ... ...... lock area found Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... ..... required data found flash: 7F22C400000000:18E59F00000000 flash: 7F22C400000000:18E59F00000000 Write: area 1 (pass 1) ... area 1 patch applied Ok Special operation Done ====> Write ... flash: 7F22C400000000:18E59F00000000 flash: 7F22C400000000:18E59F00000000 Write: lock-area-1 Write Done ====> Finalization ... Finalization Done Finished, time used: 25 sec Remove/Install battery now ! |
12-24-2010, 15:09 | #7469 (permalink) |
Member: 508072 Status: Offline Thanks Meter: 1,621 | COM6 [VCP0] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware EASY25_GEMINI_PCB01_GPRS_MT6225_S00.KT_V903_DS_EN_ T3T4_T10_0623_16m_En_Ru_Fr_Es_Ml_Id_Th_Vn_Tr_Farsi _Pt_Ar.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:5503:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: EASY25_GEMINI_PCB01_GPRS_MT6225_S00.KT_V903_DS_EN_ T3T4_T10_0623.BIN project-id: KT.V903.DS.EN.T3T4.T10.0623, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Code CRC check error fix... firmware do not have "Code CRC check error" area Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... done detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: 2088C4FFFFFFFF:2088C400000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 9 min 53 sec Remove/Install battery now ! |
12-24-2010, 17:01 | #7470 (permalink) |
No Life Poster Join Date: Mar 2007 Location: punjab(india) Age: 45
Member: 467045 Status: Offline Sonork: 100.1603919 Thanks Meter: 1,705 | nokia 5233 flashing done card found: S/N 0390:0118 registered to: jindalgsm4255 DLL not found... Connect phone on selected interface... Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-625_21.1.102_prd.core.C00 PPM : RM-625_21.1.102_prd.rofs2.V21 PPM2 : RM-625_21.1.102_C02_prd.rofs3.fpsx CNT : RM-625_21.1.102_001_000_U001.uda.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006400C192101051105 EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 10300110699F00522D4E57BF9A0522606BC7E652 ASIC MODE ID: 00 ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing UPDAPP... Processing PAPUBKEYS... Processing UPDAPP... Boot Done! TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Auth done... ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing RM-625_21.1.102_prd.core.C00 Found 5 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT Result: 0000 Erasing area 0x00400000 - 0x007FFFFF, NAND, CMT Result: 0000 Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT Result: 0000 Erasing area 0x00D60000 - 0x09E5FFFF, NAND, CMT Result: 0000 Erase partition 0x0A Partition erase Ok Partitioning : Ok [5] TIME : Erase time : 00:00:00 Write : Processing RM-625_21.1.102_prd.core.C00 Total 401 [401/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*ENO] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS+CORE] CMT : Writing Hash CERT [SOS+ROFS1] TIME : Write time : 00:00:27 MCU Write done ===Flashing [PPM]=== Erase : Processing RM-625_21.1.102_prd.rofs2.V21 Found 1 areas to erase Erasing area 0x06CE0000 - 0x0915FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-625_21.1.102_prd.rofs2.V21 Total 51 [51/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS2] TIME : Write time : 00:00:03 PPM Write done ===Flashing [PPM2]=== Erase : Processing RM-625_21.1.102_C02_prd.rofs3.fpsx Found 1 areas to erase Erasing area 0x09160000 - 0x09E5FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-625_21.1.102_C02_prd.rofs3.fpsx Total 29 [29/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS3] TIME : Write time : 00:00:02 PPM Write done ===Flashing [CNT]=== Erase : Processing RM-625_21.1.102_001_000_U001.uda.fpsx Found 1 areas to erase Erasing area 0x09E60000 - 0x0F47FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-625_21.1.102_001_000_U001.uda.fpsx Total 23 [23/0/0] blocks to write, writing... TIME : Write time : 00:00:01 CNT Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:00:36 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5233 Software Info: V ICPR72_10w21.3.1 08-09-10 RM-625 (c) Nokia IMEI: 353783048436145 Ape Version: V 21.1.102 Product code: 0594743 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:01:01 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
The Following 2 Users Say Thank You to JINDALGSM™ For This Useful Post: |
