Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Hardware & Hardware Repair > Nokia Repair Guide and FAQ
Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics
Old 04-12-2007, 09:33   #3481 (permalink)
wiliam's Avatar
Member: 241831
Thanks Meter: 18
thank you my problem is solve thanks
Old 04-12-2007, 14:38   #3482 (permalink)
Member: 210830
Thanks Meter: 4
Originally Posted by nolyboy View Post
hey guys post your problem here ill try to help
Nice work bro but i seem not to be lucky with my box cos just d other day i disconnected my box n since i reconnected, the program has refused to open well but rather gives this message "fbus interface not connected" pls how do i solve this cos i've exhausted all my options plssssssssssssssssssssssss!
Old 04-12-2007, 18:22   #3483 (permalink)
.::ricky rayya::.'s Avatar
Member: 254397
Thanks Meter: 224
6600 network prpoblem
i have 6600 network problem i already doing somthing
LIKE :-change hager,v.c.o.,26mhz,cristal,remove antina switch make jumper but problem still same anybody plz help me what i do more.
Old 04-12-2007, 18:28   #3484 (permalink)
hafizjee's Avatar
Member: 234653
Thanks Meter: 83
I have nokia 6230 auto restart.....
Hafiz Mobiles
Old 04-12-2007, 18:30   #3485 (permalink)
Member: 254397
Thanks Meter: 224
i have 6600 network not found its problem in receiving stage i already do somthing
LIKE:-change hager,26mhz cristal,v.c.o.,remove antina switch & make jumpers but problem still same anybody please help me what i doing more.
Old 04-13-2007, 04:42   #3486 (permalink)
nolyboy's Avatar
Member: 197247
Thanks Meter: 296
can you pls go to device manager and check the status of your box then post it
Old 04-13-2007, 04:43   #3487 (permalink)
nolyboy's Avatar
Member: 197247
Thanks Meter: 296
hi mate did you write pm???
Old 04-13-2007, 04:44   #3488 (permalink)
nolyboy's Avatar
Member: 197247
Thanks Meter: 296
Hafiz Mobiles
flash it first mate then post result
Old 04-13-2007, 04:46   #3489 (permalink)
nolyboy's Avatar
Member: 197247
Thanks Meter: 296
Originally Posted by Naedish View Post
Hi,
My Nokia 6280 was having issues so I flashed it to 6.10 using Phoenix (not that it fixed the problems but that's another story) and the other day I noticed that it had turned itself off (not the first time it's done that) but when I turned it on it wanted me to put in the time, date and timezone. Shortly after doing so it said battery empty and shut off again.
Since then, I haven't been able to get it to charge or turn on at all, even after getting a new battery. It's one month past warranty so I'm looking for a cheaper solution than Nokia repairing it if at all possible.
Any ideas?
Cheers,
Naed
do you have higher version than 6.10??
Old 04-13-2007, 06:54   #3490 (permalink)
Member: 254397
Thanks Meter: 224
SIR THANKS FOR REPLLY
i have 4/5 pm file i write one by one & errase , rewrite but problem still same
Old 04-13-2007, 07:23   #3491 (permalink)
ahmad5175's Avatar
Member: 246691
Thanks Meter: 54
is there any keys to formatt 9210i
Old 04-13-2007, 07:24   #3492 (permalink)
ahmad5175's Avatar
Member: 246691
Thanks Meter: 54
ranbir. try to erite pm file
Old 04-13-2007, 10:05   #3493 (permalink)
nolyboy's Avatar
Member: 197247
Thanks Meter: 296
try replacing P.A. mate
Old 04-13-2007, 11:28   #3494 (permalink)
Member: 210830
Thanks Meter: 4
Under Universal Serial Bus Controllers i have
JAF FLASHER INTERFACE
but it still is not working.
Old 04-13-2007, 11:37   #3495 (permalink)
Member: 210830
Thanks Meter: 4
Nolly pls giv me ur messenger id so i chat u online.
post me your problem in motorola and let me give you the rite solution greeni222000 Motorola Hardware Repair 2161 12-25-2023 05:54
Post me your BB5 problem here.. Ill try to help with Pict Rizal Arsyad Dini Nokia Hardware & Hardware Repair 13 10-05-2014 09:23
!!!!post Me Your Hardware Problem!!!! Ustad rajab.Com Nokia Hardware & Hardware Repair 32 01-18-2013 08:37
post me your all 6600 problem tommobil2005 Nokia Repair Guide and FAQ 459 01-17-2011 12:23
Page generated in 0.30043 seconds with 11 queries
