Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
06-18-2007, 05:35 | #3691 (permalink) |
Freak Poster Join Date: Feb 2006 Location: india.coimbatore Age: 47
Member: 233492 Status: Offline Thanks Meter: 93 | Nokia 7710 "user area format" process halts in the middle... did you try manually format it?? How to reformat Nokia 7700 and 7710? In case of serious problems with your Nokia 7700/7710 (if e.g. your phone doesn't start or it is very unstable) use the following method to reformat the device. Please, be aware that this function brings your phone back to a factory state, i.e. it removes all applications, files and data. Disconnect the charger and remove the battery. Wait for about ten seconds and insert the battery to start the device. When you see the NOKIA welcome screen, immediately press and hold two lower keys on the left side (the [= key and the Menu key) and shortly after that press and hold the second key from the top on the right side on the phone. Confirm that you want to format. Formatting will start. |
06-18-2007, 23:32 | #3692 (permalink) |
Junior Member Join Date: Jun 2007 Location: u.k
Member: 529811 Status: Offline Thanks Meter: 0 | n80 dead when unlock hi, i try to unlock n80 with jaff but phones went dead, someone told me it need write the rpl file, i donot know where i get that file and how i put in the phone secondly i ub box with me as well. |
06-19-2007, 03:59 | #3693 (permalink) |
Member: 526977 Status: Offline Thanks Meter: 0 | Hi! I have a problem which hasn't been solved yet... https://forum.gsmhosting.com/vbb/f148/6630-apparent-signal-related-problem-412990/ What do I do? |
06-19-2007, 19:39 | #3694 (permalink) | |
Freak Poster Join Date: Jun 2006 Location: dubai
Member: 302306 Status: Offline Thanks Meter: 44 | Quote:
FLASH PHONE WITH NEW VERSION I HOPE YOUR PROBLEM WILL SOLVE WITHOUT RPL FILE BR GSM STROONG | |
06-25-2007, 14:54 | #3701 (permalink) |
Junior Member Join Date: Mar 2007
Member: 478906 Status: Offline Thanks Meter: 0 | I have nokia N73 , any program for example call rec etc it gives an error even though it is compatible with n73 , unable to solve this prolem. please help with full instructions. Thanks. |
06-25-2007, 14:57 | #3702 (permalink) |
Member: 478906 Status: Offline Thanks Meter: 0 | I have nokia N73 , any program for example call rec etc i try to install it gives an error even though it is compatible with n73 , unable to solve this prolem. please help with full instructions. Thanks. |
06-28-2007, 13:02 | #3705 (permalink) |
Member: 536109 Status: Offline Thanks Meter: 0 | Hi there everybody, I am having a Nokia 1110, in which, I am facing a little bit strange problem. The keyguard code is not working. I mean, even when, we activate the keyguard code function, it does not ask for code when unlocking keyguard, it simple gives "now press *" and gets unlocked, what may be the problem ? All other things are working fine. I have tried soft reset, but no help. What could be done ? Do I need to reset it somehow else ? Please........any help is appreciated.......... Software Info: V 3.42 22-09-05 RH-70 (C) NMP 1110 |
post me your problem in motorola and let me give you the rite solution | greeni222000 | Motorola Hardware Repair | 2161 | 12-25-2023 05:54 |
Post me your BB5 problem here.. Ill try to help with Pict | Rizal Arsyad Dini | Nokia Hardware & Hardware Repair | 13 | 10-05-2014 09:23 |
!!!!post Me Your Hardware Problem!!!! | Ustad rajab.Com | Nokia Hardware & Hardware Repair | 32 | 01-18-2013 08:37 |
post me your all 6600 problem | tommobil2005 | Nokia Repair Guide and FAQ | 459 | 01-17-2011 12:23 |
