06-10-2005, 12:28 | #1 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,583 | Final Guide For Tp Unlock Lg U8180/u8330 !!! 1. Download latest setup from support. 2. Go to 'LG3G 2k's Flasher' and select from models 'U8180 TP' or 'U8330 TP'. 3. Select on flash space all files from 8138 v100(for U8180) or 8130 v101 (for U8330) from support area. 4. Start flashing operation and when required connect to GND testpoint and after on request disconnect it. 5. Wait flashin process to finish. Power ON/OFF phone. 6. Go to 'LG 3G' tab and select from models 'U8180 TP'/'U8330 TP' and wait codes to be read. 7. Disconnect phone. Remove TP. Power on phone with SIM INSIDE. Type 2945#*88110# and enter unlock code. Restart phone and enjoy. BELLOW ARE FINAL TP IMAGES ATTACHED !!!! P.S: Thx Morfeus. |
06-12-2005, 00:30 | #6 (permalink) | |
Junior Member Join Date: Nov 2004 Age: 47
Member: 91399 Status: Offline Thanks Meter: 0 | Quote:
06-12-2005, 01:08 | #7 (permalink) |
Freak Poster Join Date: Mar 2005
Member: 128018 Status: Offline Thanks Meter: 17 | plz lissen all member read this befor posting the error really found its not big job to do test point or to connect with furious or vygis but in sum model give this error i do this many time and secess with vygys and firous but in sum model not accept and give this error here in forum need to give solution and help not to repeat always (simply for the profesional unlocker ) and plz chek test point ok i check test point and and and but always sum problem ( Rem i have 8180 but in pcb is ( 8120 xxx) and flash ship when test point is 8180) in this cas the problem existe Loader version: 40318 1450 LLECXC1325413_CERTLOADER R3J Error ... ! but when u seccess ( if in the pcb is 8180 and in flash ship is 8180 all is good and phone unlocked and secess all pcb marked for exemple with 8180 and flash ship is 8180 all pass ok and good all pcb marked for exemple with 8120 and flash ship is 8180 problem not sloved and give this error Loader version: 40318 1450 LLECXC1325413_CERTLOADER R3J Error ... ! |
06-13-2005, 20:13 | #13 (permalink) | |
No Life Poster Join Date: Dec 2003 Location: United Kingdom, ENGLAND
Member: 47774 Status: Offline Thanks Meter: 185 | Quote:
Thanks before Furious. | |
06-14-2005, 13:24 | #14 (permalink) |
Freak Poster Join Date: Sep 2004 Age: 56
Member: 83577 Status: Offline Thanks Meter: 11 | hi always with furious Press Power On shortly ! Phone Detected ! Chip ID: 71000301 Loading ... Loader version: 40318 1450 LLECXC1325413_CERTLOADER R3J Error ... ! 8330 only 8380 working |
06-14-2005, 19:01 | #15 (permalink) |
Member: 47774 Status: Offline Thanks Meter: 185 | U8330 Use U8330 TP posted by hack3r2k * telemoveis just you need to connect TP with GND Frist and Click flash 1-Power on phone 2-soft ask u to connect TP ( Click Just ok d'ont disconnected TP ) 3-soft ask u to disconnected TP ( disconnected TP and click ok ) 4-Enjoy. Phone Flashed. Furious. |
U8380, U8360 - FLASH/UNLOCK , and U8180 , U8330 unlock without conversion | Gobi | VygisToolbox | 46 | 11-30-2007 18:23 |
LG U8180, U8330 - How to Unlock/Repair | Gobi | VygisToolbox | 36 | 07-27-2006 20:27 |
Lg 8180/8330 Fools Guide For Direct Unlock Withou Tp !!! | .:hack3r2k:. | FuriouS II | 23 | 07-23-2005 14:33 |
For Booting LG U8180 - U8330, connect the Testpoint THRU A RESITOR to the GND | Gobi | VygisToolbox | 0 | 06-08-2005 06:48 |
