10-21-2007, 09:56 | #437 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: PHILIPPINES
Member: 101860 Status: Offline Sonork: 100.1582168 100.77603 Thanks Meter: 6,036 | 6126 Unlocked - Spansion Quote:
br RNC_EBM | |
10-21-2007, 10:54 | #439 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Denmark Age: 55
Member: 18805 Status: Offline Thanks Meter: 27 | 5500 sport v3.55 unlocked in first try... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-86 Version: V__03.55_23-11-06_RM-86_(c)_Nokia. IMEI: 351855018891103 SP LOCK status: Config Key: 2380200000000000 Block 1: CLOSED Type 5 Data: 23802F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-86_351855018891103_Locked_Keycnt_3_Fbuscnt_0__V__0 3.55_23-11-06_RM-86_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-86_351855018891103_Locked_Keycnt_3_Fbuscnt_0__V__0 3.55_23-11-06_RM-86_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2380200000000000 Block 1: CLOSED Type 5 Data: 23802F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2380200000000000 Block 1: OPEN Type 5 Data: 23802F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull WBR Falck |
10-21-2007, 15:53 | #441 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Now In USA Rim database Age: 47
Member: 248178 Status: Offline Sonork: 100.1579207 Thanks Meter: 323 | 5300 searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-146 Version: V_04.70_24-01-07_RM-146_(c)_Nokia. IMEI: 35xxxxxxxxxxxxx SP LOCK status: Config Key: 2343000000000000 Block 1: CLOSED Type 5 Data: 23430F Keyboard wrong codes counter: 1 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-146_35xxxxxxxxxxxxxx_Locked_Keycnt_1_Fbuscnt_0__V_ 04.70_24-01-07_RM-146_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-146_35xxxxxxxxxxxxx_Locked_Keycnt_1_Fbuscnt_0__V_0 4.70_24-01-07_RM-146_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343000000000000 Block 1: CLOSED Type 5 Data: 23430F Keyboard wrong codes counter: 1 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2343000000000000 Block 1: OPEN Type 5 Data: 23430F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
10-22-2007, 10:46 | #442 (permalink) | |
Member: 101860 Status: Offline Sonork: 100.1582168 100.77603 Thanks Meter: 6,036 | UNLOCKED USING MY N73 TESTPOINT ADAPTER, but after UNLOCKED THE PHONE, MY TP ADAPTER WAS BROKEN, BUT AGAIN, I HAVE MY OTHER NEW UNIVERSAL TESTPOINT ADAPTER Quote:
br RNC_EBM | |
10-22-2007, 16:46 | #443 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Phnom Penh(CAMBODIA)
Member: 447590 Status: Offline Thanks Meter: 378 | Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-208 Version: V_1.0615.25_10-01-07_RM-208_(c)_Nokia. IMEI: 353262013120158 SP LOCK status: Config Key: 2343300000000000 Block 1: OPEN Type 5 Data: 23433F Block 2: OPEN Type 5 Data: 23433F Block 3: OPEN Type 5 Data: 23486F Block 4: OPEN Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries |
10-23-2007, 08:38 | #444 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Harare, Zimbabwe/ South Africa Age: 44
Member: 46546 Status: Offline Sonork: 100.1577435 Thanks Meter: 85 | E62 done.... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-88 Version: Vp_2.0618.06.17_10-08-06_RM-88_(c)_Nokia._ IMEI: 357951005977726 SP LOCK status: Config Key: 3101700000000000 Block 1: CLOSED Type 5 Data: 310150 Block 2: CLOSED Type 5 Data: 310150 Block 3: CLOSED Type 5 Data: 310170 Block 4: CLOSED Type 5 Data: 310170 Block 5: CLOSED Type 5 Data: 310410 Block 6: CLOSED Type 5 Data: 310410 Block 7: CLOSED Type 5 Data: 311180 Block 8: CLOSED Type 5 Data: 311180 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-88_357951005977726_Locked_Keycnt_0_Fbuscnt_0__Vp_2 .0618.06.17_10-08-06_RM-88_(c)_Nokia._.bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-88_357951005977726_Locked_Keycnt_0_Fbuscnt_0__Vp_2 .0618.06.17_10-08-06_RM-88_(c)_Nokia._.bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 3101700000000000 Block 1: CLOSED Type 5 Data: 310150 Block 2: CLOSED Type 5 Data: 310150 Block 3: CLOSED Type 5 Data: 310170 Block 4: CLOSED Type 5 Data: 310170 Block 5: CLOSED Type 5 Data: 310410 Block 6: CLOSED Type 5 Data: 310410 Block 7: CLOSED Type 5 Data: 311180 Block 8: CLOSED Type 5 Data: 311180 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 3101700000000000 Block 1: OPEN Type 5 Data: 310150 Block 2: OPEN Type 5 Data: 310150 Block 3: OPEN Type 5 Data: 310170 Block 4: OPEN Type 5 Data: 310170 Block 5: OPEN Type 5 Data: 310410 Block 6: OPEN Type 5 Data: 310410 Block 7: OPEN Type 5 Data: 311180 Block 8: OPEN Type 5 Data: 311180 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
10-23-2007, 15:24 | #446 (permalink) |
No Life Poster Join Date: Jun 2005 Location: insane in da mad brain Age: 46
Member: 154522 Status: Offline Thanks Meter: 48 | nice update, n95 v12.0.013 unlocked succesful from Telia denmark Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-159 Version: V_06wk41v31_05-06-07_RM-159_(c)_Nokia IMEI: 35699601XXXXXXXX SP LOCK status: Config Key: 2382000000000000 Block 1: CLOSED Type 5 Data: 000000 Block 2: CLOSED Type 5 Data: FFF14F Block 3: CLOSED Type 5 Data: FFF20F Block 4: CLOSED Type 5 Data: FFF21F Block 5: CLOSED Type 5 Data: FFFFFF Block 6: CLOSED Type 5 Data: 000000 Block 7: CLOSED Type 5 Data: 000000 Block 8: CLOSED Type 5 Data: 000000 Block 9: CLOSED Type 5 Data: 7FFF6F Keyboard wrong codes counter: 1 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-159_35699601XXXXXX_Locked_Keycnt_1_Fbuscnt_0__V_06 wk41v31_05-06-07_RM-159_(c)_Nokia.bin Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-159_35699601XXXXXX_Locked_Keycnt_1_Fbuscnt_0__V_06 wk41v31_05-06-07_RM-159_(c)_Nokia.bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2382000000000000 Block 1: CLOSED Type 5 Data: 000000 Block 2: CLOSED Type 5 Data: FFF14F Block 3: CLOSED Type 5 Data: FFF20F Block 4: CLOSED Type 5 Data: FFF21F Block 5: CLOSED Type 5 Data: FFFFFF Block 6: CLOSED Type 5 Data: 000000 Block 7: CLOSED Type 5 Data: 000000 Block 8: CLOSED Type 5 Data: 000000 Block 9: CLOSED Type 5 Data: 7FFF6F Keyboard wrong codes counter: 1 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Delaying unlock procedure with 5000 miliseconds Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2382000000000000 Block 1: OPEN Type 5 Data: 000000 Block 2: OPEN Type 5 Data: FFF14F Block 3: OPEN Type 5 Data: FFF20F Block 4: OPEN Type 5 Data: FFF21F Block 5: OPEN Type 5 Data: FFFFFF Block 6: OPEN Type 5 Data: 000000 Block 7: OPEN Type 5 Data: 000000 Block 8: OPEN Type 5 Data: 000000 Block 9: OPEN Type 5 Data: 7FFF6F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
10-23-2007, 17:25 | #447 (permalink) |
Freak Poster Join Date: Jul 2005 Location: Brazil Age: 44
Member: 159096 Status: Offline Thanks Meter: 48 | ------ Operation: UNLOCK Date: 23-10-2007 Time: 11:14:57 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-88 Version: Vp_2.0618.06.17_10-08-06_RM-88_(c)_Nokia._ IMEI: 359742000379184 SP LOCK status: Config Key: 7240600086388183 Block 1: CLOSED Type 5 Data: 72406F Block 2: CLOSED Type 5 Data: 72410F Block 3: CLOSED Type 5 Data: 72411F Block 4: CLOSED Type 5 Data: 21407F Block 5: CLOSED Type 5 Data: 21402F Block 6: CLOSED Type 5 Data: 26806F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-88_359742000379184_Locked_Keycnt_0_Fbuscnt_0__Vp_2 .0618.06.17_10-08-06_RM-88_(c)_Nokia._.bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-88_359742000379184_Locked_Keycnt_0_Fbuscnt_0__Vp_2 .0618.06.17_10-08-06_RM-88_(c)_Nokia._.bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 7240600086388183 Block 1: CLOSED Type 5 Data: 72406F Block 2: CLOSED Type 5 Data: 72410F Block 3: CLOSED Type 5 Data: 72411F Block 4: CLOSED Type 5 Data: 21407F Block 5: CLOSED Type 5 Data: 21402F Block 6: CLOSED Type 5 Data: 26806F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 7240600086388183 Block 1: OPEN Type 5 Data: 72406F Block 2: OPEN Type 5 Data: 72410F Block 3: OPEN Type 5 Data: 72411F Block 4: OPEN Type 5 Data: 21407F Block 5: OPEN Type 5 Data: 21402F Block 6: OPEN Type 5 Data: 26806F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
10-23-2007, 17:27 | #448 (permalink) |
Member: 159096 Status: Offline Thanks Meter: 48 | Not success 6125 ------ Operation: UNLOCK Date: 23-10-2007 Time: 14:11:07 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-178 Version: V_04.20_13-11-06_RM-178_(c)_Nokia. IMEI: 354802012664745 SP LOCK status: Config Key: 7240600086388183 Block 1: CLOSED Type 5 Data: 72406F Block 2: CLOSED Type 5 Data: 72410F Block 3: CLOSED Type 5 Data: 72411F Block 4: CLOSED Type 5 Data: 21407F Block 5: CLOSED Type 5 Data: 21402F Block 6: CLOSED Type 5 Data: 26806F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-178_354802012664745_Locked_Keycnt_0_Fbuscnt_10__V_ 04.20_13-11-06_RM-178_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-178_354802012664745_Locked_Keycnt_0_Fbuscnt_0__V_0 4.20_13-11-06_RM-178_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 7240600086388183 Block 1: CLOSED Type 5 Data: 72406F Block 2: CLOSED Type 5 Data: 72410F Block 3: CLOSED Type 5 Data: 72411F Block 4: CLOSED Type 5 Data: 21407F Block 5: CLOSED Type 5 Data: 21402F Block 6: CLOSED Type 5 Data: 26806F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. |
10-24-2007, 03:11 | #449 (permalink) | |
Product Manager Join Date: Sep 2007
Member: 588059 Status: Offline Thanks Meter: 47 | What EXACTLY was flash chip on this 6125? Quote:
10-24-2007, 08:28 | #450 (permalink) |
No Life Poster Join Date: Feb 2006 Location: EDSELLULAR
Member: 236564 Status: Offline Sonork: 100.1667122 Thanks Meter: 816 | n73 softbank Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V_05wk47v48.3_02-07-07_RM-133_(c)_Nokia. IMEI: 3536410rea1One SP LOCK status: Config Key: 4402000000000000 Block 1: CLOSED Type 5 Data: 44020F Block 2: CLOSED Type 5 Data: 44020F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-133_3536410rea1One_Locked_Keycnt_0_Fbuscnt_0__V_05 wk47v48.3_02-07-07_RM-133_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 4402000000000000 Block 1: OPEN Type 5 Data: 44020F Block 2: OPEN Type 5 Data: 44020F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
★★★★★★ post here all phone unlocked with bb5 trk unlocker ★★★★★★ | ProfesionalGSM | BB5 Box by D.K. | 98 | 06-11-2010 21:29 |
Post Here all phones repair with this latest updat! | Faheem Anjum | Universalbox | 1 | 11-19-2009 08:50 |
POST HERE === BB5 Phones TESTED with 3/3 10/10 Cnt Rst === | sudeeshveekey | BB5BOX | 11 | 04-26-2008 23:01 |
post here all phones unlocked with V32 | RaMCES | BB5BOX | 4 | 01-13-2008 10:27 |
