04-15-2008, 10:06 | #1186 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-159 Version: V_06wk41v23.4_17-04-07_RM-159_(c)_Nokia IMEI: 352255012555870 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Block 3: CLOSED Type 5 Data: 23433F Block 4: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-159_352255012555870_Locked_Keycnt_0_Fbuscnt_0__V_0 6wk41v23.4_17-04-07_RM-159_(c)_Nokia.bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2343300000000000 Block 1: OPEN Type 5 Data: 23433F Block 2: OPEN Type 5 Data: 23486F Block 3: OPEN Type 5 Data: 23433F Block 4: OPEN Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
04-15-2008, 10:07 | #1187 (permalink) |
Member: 220603 Status: Offline Thanks Meter: 1,164 | 5200 done Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-174 Version: V_05.00_27-04-07_RM-174_(c)_Nokia. IMEI: 359550014832860 SP LOCK status: Config Key: 2340000100000000 Block 1: CLOSED Type 5 Data: 23430F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-174_359550014832860_Locked_Keycnt_0_Fbuscnt_0__V_0 5.00_27-04-07_RM-174_(c)_Nokia..bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2340000100000000 Block 1: OPEN Type 5 Data: 23430F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
04-16-2008, 14:37 | #1188 (permalink) |
No Life Poster Join Date: Jul 2007 Location: PK
Member: 539052 Status: Offline Sonork: 100.1585495 Thanks Meter: 119 | 6085 done ........... Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-198 Version: V_04.29_03-05-07_RM-198_(c)_Nokia. IMEI: 354831014902647 SP LOCK status: Config Key: 3101700000000000 Block 1: CLOSED Type 5 Data: 310150 Block 2: CLOSED Type 5 Data: 310170 Block 3: CLOSED Type 5 Data: 311180 Block 4: CLOSED Type 5 Data: 310410 Block 5: CLOSED Type 5 Data: 310980 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-198_354831014902647_Locked_Keycnt_0_Fbuscnt_0__V_0 4.29_03-05-07_RM-198_(c)_Nokia..bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 3101700000000000 Block 1: OPEN Type 5 Data: 310150 Block 2: OPEN Type 5 Data: 310170 Block 3: OPEN Type 5 Data: 311180 Block 4: OPEN Type 5 Data: 310410 Block 5: OPEN Type 5 Data: 310980 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
04-16-2008, 15:33 | #1189 (permalink) |
Banned Join Date: Apr 2004 Location: **NEDROMA** Age: 51
Member: 63194 Status: Offline Thanks Meter: 59 | e61 done!!!!!!!!!!!!!! Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-89 Version: V_3.0533.6_31-10-06_RM-89_(c)_Nokia. IMEI: 356211002616434 SP LOCK status: Config Key: 2081000000000000 Block 1: CLOSED Type 5 Data: 20810F Block 2: CLOSED Type 5 Data: 20810F Block 3: CLOSED Type 5 Data: 64710F Block 4: CLOSED Type 5 Data: 64710F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-89_356211002616434_Locked_Keycnt_0_Fbuscnt_0__V_3. 0533.6_31-10-06_RM-89_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-89_356211002616434_Locked_Keycnt_0_Fbuscnt_0__V_3. 0533.6_31-10-06_RM-89_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2081000000000000 Block 1: CLOSED Type 5 Data: 20810F Block 2: CLOSED Type 5 Data: 20810F Block 3: CLOSED Type 5 Data: 64710F Block 4: CLOSED Type 5 Data: 64710F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2081000000000000 Block 1: OPEN Type 5 Data: 20810F Block 2: OPEN Type 5 Data: 20810F Block 3: OPEN Type 5 Data: 64710F Block 4: OPEN Type 5 Data: 64710F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
04-17-2008, 12:51 | #1190 (permalink) |
No Life Poster Join Date: Apr 2007 Location: Inside Samsung Pocket Age: 40
Member: 489331 Status: Offline Thanks Meter: 1,141 | Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_06.10_21-12-06_RM-78_(c)_Nokia IMEI: 352264016009835 SP LOCK status: Config Key: 4250100000000000 Block 1: CLOSED Type 5 Data: 42501F Block 2: CLOSED Type 5 Data: 42510F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-78_352264016009835_Locked_Keycnt_0_Fbuscnt_0__V_06 .10_21-12-06_RM-78_(c)_Nokia.bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-78_352264016009835_Locked_Keycnt_0_Fbuscnt_0__V_06 .10_21-12-06_RM-78_(c)_Nokia.bin Writting PM Field 308 Subfield 1 with length 4096 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 4250100000000000 Block 1: CLOSED Type 5 Data: 42501F Block 2: CLOSED Type 5 Data: 42510F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 4250100000000000 Block 1: OPEN Type 5 Data: 42501F Block 2: OPEN Type 5 Data: 42510F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
04-17-2008, 16:53 | #1191 (permalink) |
Member: 489331 Status: Offline Thanks Meter: 1,141 | Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-208 Version: V_1.0615.25_10-01-07_RM-208_(c)_Nokia. IMEI: 353262016576513 SP LOCK status: Config Key: 4250200000000000 Block 1: CLOSED Type 5 Data: 42502F Block 2: CLOSED Type 5 Data: 42502F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-208_353262016576513_Locked_Keycnt_0_Fbuscnt_0__V_1 .0615.25_10-01-07_RM-208_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-208_353262016576513_Locked_Keycnt_0_Fbuscnt_0__V_1 .0615.25_10-01-07_RM-208_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 4250200000000000 Block 1: CLOSED Type 5 Data: 42502F Block 2: CLOSED Type 5 Data: 42502F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 4250200000000000 Block 1: OPEN Type 5 Data: 42502F Block 2: OPEN Type 5 Data: 42502F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
04-18-2008, 06:43 | #1192 (permalink) |
No Life Poster Join Date: Apr 2008 Location: TO SERVE AND PROTECT
Member: 739429 Status: Offline Sonork: FIND TO GOOGLES Thanks Meter: 85 | N92 Success Unlock Only 15secs Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-100 Version: V_05wk47v41.1_01-03-07_RM-100_(c)_Nokia. IMEI: 359393000174452 SP LOCK status: Config Key: 5150300000000000 Block 1: CLOSED Type 5 Data: 51503F Block 2: CLOSED Type 5 Data: 51503F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-100_359393000174452_Locked_Keycnt_0_Fbuscnt_0__V_0 5wk47v41.1_01-03-07_RM-100_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 5150300000000000 Block 1: OPEN Type 5 Data: 51503F Block 2: OPEN Type 5 Data: 51503F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull BGI THANKS TO MR_Z |
04-18-2008, 06:54 | #1193 (permalink) |
Member: 739429 Status: Offline Sonork: FIND TO GOOGLES Thanks Meter: 85 | 6300 Atd Flash Chips Version 5.50 Unlock Done.. HI... HERE THE LOG UNLOCK 6300 ATD FLASH CHIPS VERSION 5.50.. Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_05.50_14-08-07_RM-217_(c)_Nokia. IMEI: 359809016553100 SP LOCK status: Config Key: 2720100000000000 Block 1: CLOSED Type 5 Data: 27201F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-217_359809015593100_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-217_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2720100000000000 Block 1: OPEN Type 5 Data: 27201F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull BR |
04-20-2008, 06:56 | #1194 (permalink) |
Member: 220603 Status: Offline Thanks Meter: 1,164 | 8600 done. Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-164 Version: V_03.52_24-05-07_RM-164_(c)_Nokia. IMEI: 356287011142513 SP LOCK status: Config Key: 2343000000000000 Block 1: CLOSED Type 5 Data: 23430F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-164_356287011142513_Locked_Keycnt_0_Fbuscnt_0__V_0 3.52_24-05-07_RM-164_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2343000000000000 Block 1: OPEN Type 5 Data: 23430F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
04-23-2008, 09:55 | #1195 (permalink) |
Member: 739429 Status: Offline Sonork: FIND TO GOOGLES Thanks Meter: 85 | Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V_05wk47v34.1_05-10-06_RM-133_(c)_Nokia. IMEI: 353641013772268 SP LOCK status: Config Key: 5150300000000000 Block 1: CLOSED Type 5 Data: 51503F Block 2: CLOSED Type 5 Data: 51503F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-133_353641013772268_Locked_Keycnt_0_Fbuscnt_0__V_0 5wk47v34.1_05-10-06_RM-133_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 5150300000000000 Block 1: OPEN Type 5 Data: 51503F Block 2: OPEN Type 5 Data: 51503F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
04-24-2008, 14:18 | #1196 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Tunisia Age: 53
Member: 240499 Status: Offline Thanks Meter: 151 | Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-174 Version: V_03.92_13-10-06_RM-174_(c)_Nokia. IMEI: 356435018076230 SP LOCK status: Config Key: 2081000000000000 Block 1: CLOSED Type 5 Data: 20810F Block 2: CLOSED Type 5 Data: 64710F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-174_356435018076230_Locked_Keycnt_0_Fbuscnt_0__V_0 3.92_13-10-06_RM-174_(c)_Nokia..bin Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-174_356435018076230_Locked_Keycnt_0_Fbuscnt_0__V_0 3.92_13-10-06_RM-174_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2081000000000000 Block 1: CLOSED Type 5 Data: 20810F Block 2: CLOSED Type 5 Data: 64710F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2081000000000000 Block 1: OPEN Type 5 Data: 20810F Block 2: OPEN Type 5 Data: 64710F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
04-24-2008, 15:47 | #1197 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Phnom Penh(CAMBODIA)
Member: 447590 Status: Offline Thanks Meter: 378 | 6133 well done Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-126 Version: V_05.61_14-12-06_RM-126_(c)_Nokia. IMEI: 355536014918167 SP LOCK status: Config Key: 3102000000000000 Block 1: CLOSED Type 5 Data: 310160 Block 2: CLOSED Type 5 Data: 310170 Block 3: CLOSED Type 5 Data: 310200 Block 4: CLOSED Type 5 Data: 310210 Block 5: CLOSED Type 5 Data: 310220 Block 6: CLOSED Type 5 Data: 310230 Block 7: CLOSED Type 5 Data: 310240 Block 8: CLOSED Type 5 Data: 310250 Block 9: CLOSED Type 5 Data: 310260 Block 10: CLOSED Type 5 Data: 310270 Block 11: CLOSED Type 5 Data: 310310 Block 12: CLOSED Type 5 Data: 310490 Block 13: CLOSED Type 5 Data: 310530 Block 14: CLOSED Type 5 Data: 310580 Block 15: CLOSED Type 5 Data: 310590 Block 16: CLOSED Type 5 Data: 310640 Block 17: CLOSED Type 5 Data: 310660 Block 18: CLOSED Type 5 Data: 310800 Block 19: CLOSED Type 5 Data: 310160 Block 20: CLOSED Type 5 Data: 310170 Block 21: CLOSED Type 5 Data: 310200 Block 22: CLOSED Type 5 Data: 310210 Block 23: CLOSED Type 5 Data: 310220 Block 24: CLOSED Type 5 Data: 310230 Block 25: CLOSED Type 5 Data: 310240 Block 26: CLOSED Type 5 Data: 310250 Block 27: CLOSED Type 5 Data: 310260 Block 28: CLOSED Type 5 Data: 310270 Block 29: CLOSED Type 5 Data: 310310 Block 30: CLOSED Type 5 Data: 310490 Block 31: CLOSED Type 5 Data: 310530 Block 32: CLOSED Type 5 Data: 310580 Block 33: CLOSED Type 5 Data: 310590 Block 34: CLOSED Type 5 Data: 310640 Block 35: CLOSED Type 5 Data: 310660 Block 36: CLOSED Type 5 Data: 310800 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-126_355536014918167_Locked_Keycnt_0_Fbuscnt_0__V_0 5.61_14-12-06_RM-126_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 5555555555555555 Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Phone unlocked succesfull |
04-24-2008, 15:51 | #1198 (permalink) |
Member: 447590 Status: Offline Thanks Meter: 378 | 6085 well done Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-198 Version: V_04.30_30-08-07_RM-198_(c)_Nokia. IMEI: 352920021449874 SP LOCK status: Config Key: 3101700000000000 Block 1: CLOSED Type 5 Data: 310150 Block 2: CLOSED Type 5 Data: 310170 Block 3: CLOSED Type 5 Data: 311180 Block 4: CLOSED Type 5 Data: 310410 Block 5: CLOSED Type 5 Data: 310980 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-198_352920021449874_Locked_Keycnt_0_Fbuscnt_0__V_0 4.30_30-08-07_RM-198_(c)_Nokia..bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 3101700000000000 Block 1: OPEN Type 5 Data: 310150 Block 2: OPEN Type 5 Data: 310170 Block 3: OPEN Type 5 Data: 311180 Block 4: OPEN Type 5 Data: 310410 Block 5: OPEN Type 5 Data: 310980 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
04-24-2008, 15:54 | #1199 (permalink) |
Member: 447590 Status: Offline Thanks Meter: 378 | 6085 well done Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-198 Version: V_04.30_30-08-07_RM-198_(c)_Nokia. IMEI: 352920021449007 SP LOCK status: Config Key: 3101700000000000 Block 1: CLOSED Type 5 Data: 310150 Block 2: CLOSED Type 5 Data: 310170 Block 3: CLOSED Type 5 Data: 311180 Block 4: CLOSED Type 5 Data: 310410 Block 5: CLOSED Type 5 Data: 310980 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-198_352920021449007_Locked_Keycnt_0_Fbuscnt_0__V_0 4.30_30-08-07_RM-198_(c)_Nokia..bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 3101700000000000 Block 1: OPEN Type 5 Data: 310150 Block 2: OPEN Type 5 Data: 310170 Block 3: OPEN Type 5 Data: 311180 Block 4: OPEN Type 5 Data: 310410 Block 5: OPEN Type 5 Data: 310980 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
04-24-2008, 15:56 | #1200 (permalink) |
Member: 447590 Status: Offline Thanks Meter: 378 | 6085 well done Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-198 Version: V_04.26_16-03-07_RM-198_(c)_Nokia. IMEI: 358061010024594 SP LOCK status: Config Key: 5050100058056920 Block 1: CLOSED Type 5 Data: 50501F Block 2: CLOSED Type 5 Data: 50501F Keyboard wrong codes counter: 1 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-198_358061010024594_Locked_Keycnt_1_Fbuscnt_0__V_0 4.26_16-03-07_RM-198_(c)_Nokia..bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 5050100058056920 Block 1: OPEN Type 5 Data: 50501F Block 2: OPEN Type 5 Data: 50501F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
★★★★★★ post here all phone unlocked with bb5 trk unlocker ★★★★★★ | ProfesionalGSM | BB5 Box by D.K. | 98 | 06-11-2010 21:29 |
Post Here all phones repair with this latest updat! | Faheem Anjum | Universalbox | 1 | 11-19-2009 08:50 |
POST HERE === BB5 Phones TESTED with 3/3 10/10 Cnt Rst === | sudeeshveekey | BB5BOX | 11 | 04-26-2008 23:01 |
post here all phones unlocked with V32 | RaMCES | BB5BOX | 4 | 01-13-2008 10:27 |
