04-04-2008, 13:53 | #1156 (permalink) |
Freak Poster Join Date: Aug 2005 Location: Ghana Age: 43
Member: 171776 Status: Offline Thanks Meter: 17 | please help me Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V_05wk47v51.4_29-08-07_RM-133_(c)_Nokia. IMEI: 359569012637642 SP LOCK status: Config Key: 2382000000000000 Block 1: CLOSED Type 5 Data: 23820F Block 2: CLOSED Type 5 Data: 23830F Block 3: CLOSED Type 5 Data: 23820F Block 4: CLOSED Type 5 Data: 23830F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 4 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes ERROR: 11200001 ERROR: 30020033 |
04-04-2008, 16:53 | #1157 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | n73 done Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V_05wk47v34.1_05-10-06_RM-133_(c)_Nokia. IMEI: 358634010130825 SP LOCK status: Config Key: 2342000000000000 Block 1: CLOSED Type 5 Data: 23420F Block 2: CLOSED Type 5 Data: 23420F Block 3: CLOSED Type 5 Data: 23594F Block 4: CLOSED Type 5 Data: 23594F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-133_358634010130825_Locked_Keycnt_0_Fbuscnt_0__V_0 5wk47v34.1_05-10-06_RM-133_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2342000000000000 Block 1: OPEN Type 5 Data: 23420F Block 2: OPEN Type 5 Data: 23420F Block 3: OPEN Type 5 Data: 23594F Block 4: OPEN Type 5 Data: 23594F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
04-04-2008, 22:06 | #1158 (permalink) |
Banned Join Date: Jul 2007
Member: 549986 Status: Offline Thanks Meter: 5 | E65 succes unlock ------ Operation: UNLOCK V2 Date: 04-04-2008 Time: 20:27:57 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-208 Version: V_1.0615.25_10-01-07_RM-208_(c)_Nokia. IMEI: 354832019530540 SP LOCK status: Config Key: 2140100000000000 Block 1: CLOSED Type 5 Data: 21401F Block 2: CLOSED Type 5 Data: 21401F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-208_354832019530540_Locked_Keycnt_0_Fbuscnt_0__V_1 .0615.25_10-01-07_RM-208_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-208_354832019530540_Locked_Keycnt_0_Fbuscnt_0__V_1 .0615.25_10-01-07_RM-208_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2140100000000000 Block 1: CLOSED Type 5 Data: 21401F Block 2: CLOSED Type 5 Data: 21401F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 14 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2140100000000000 Block 1: OPEN Type 5 Data: 21401F Block 2: OPEN Type 5 Data: 21401F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
04-05-2008, 11:47 | #1159 (permalink) |
No Life Poster Join Date: Jul 2006 Location: I.N.D.I.A(PUNJAB)
Member: 309398 Status: Offline Sonork: 100.1590052 Thanks Meter: 5,455 | N95 Unlock Succes onnecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-159 Version: V_06wk41v31_05-06-07_RM-159_(c)_Nokia IMEI: 354835015543771 SP LOCK status: Config Key: 5050600042465540 Block 1: CLOSED Type 5 Data: 50506F Block 2: CLOSED Type 5 Data: 50599F Block 3: CLOSED Type 5 Data: 50506F Block 4: CLOSED Type 5 Data: 50599F Block 5: CLOSED Type 5 Data: 00101F Block 6: CLOSED Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-159_354835015543771_Locked_Keycnt_0_Fbuscnt_0__V_0 6wk41v31_05-06-07_RM-159_(c)_Nokia.bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 5050600042465540 Block 1: OPEN Type 5 Data: 50506F Block 2: OPEN Type 5 Data: 50599F Block 3: OPEN Type 5 Data: 50506F Block 4: OPEN Type 5 Data: 50599F Block 5: OPEN Type 5 Data: 00101F Block 6: OPEN Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfu |
04-05-2008, 12:33 | #1160 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Phnom Penh(CAMBODIA)
Member: 447590 Status: Offline Thanks Meter: 378 | E65 well done Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-208 Version: V_1.0615.25_10-01-07_RM-208_(c)_Nokia. IMEI: 353262013488969 SP LOCK status: Config Key: 2080100000000000 Block 1: CLOSED Type 5 Data: 20801F Block 2: CLOSED Type 5 Data: 20801F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-208_353262013488969_Locked_Keycnt_0_Fbuscnt_0__V_1 .0615.25_10-01-07_RM-208_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2080100000000000 Block 1: OPEN Type 5 Data: 20801F Block 2: OPEN Type 5 Data: 20801F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
04-06-2008, 14:56 | #1161 (permalink) |
No Life Poster Join Date: Jul 2007 Location: PK
Member: 539052 Status: Offline Sonork: 100.1585495 Thanks Meter: 119 | Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_05.50_14-08-07_RM-217_(c)_Nokia. IMEI: 359537010280301 SP LOCK status: Config Key: 2720200000000000 Block 1: CLOSED Type 5 Data: 27202F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-217_359537010280301_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-217_(c)_Nokia..bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2720200000000000 Block 1: OPEN Type 5 Data: 27202F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
04-07-2008, 09:08 | #1162 (permalink) |
No Life Poster Join Date: Apr 2007 Location: Inside Samsung Pocket Age: 40
Member: 489331 Status: Offline Thanks Meter: 1,141 | Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_03.81_09-05-06_RM-78_(c)_Nokia IMEI: 352264016041374 SP LOCK status: Config Key: 4250100000000000 Block 1: CLOSED Type 5 Data: 42501F Block 2: CLOSED Type 5 Data: 42510F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 4096 bytes Saving autobackup to file: RM-78_352264016041374_Locked_Keycnt_0_Fbuscnt_0__V_03 .81_09-05-06_RM-78_(c)_Nokia.bin Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-78_352264016041374_Locked_Keycnt_0_Fbuscnt_0__V_03 .81_09-05-06_RM-78_(c)_Nokia.bin Writting PM Field 308 Subfield 1 with length 4096 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 4250100000000000 Block 1: CLOSED Type 5 Data: 42501F Block 2: CLOSED Type 5 Data: 42510F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 4250100000000000 Block 1: OPEN Type 5 Data: 42501F Block 2: OPEN Type 5 Data: 42510F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
04-07-2008, 11:13 | #1163 (permalink) |
Member: 447590 Status: Offline Thanks Meter: 378 | 6085 spansion well done Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-198 Version: V_04.30_30-08-07_RM-198_(c)_Nokia. IMEI: 354831014570584 SP LOCK status: Config Key: 3101700000000000 Block 1: CLOSED Type 5 Data: 310150 Block 2: CLOSED Type 5 Data: 310170 Block 3: CLOSED Type 5 Data: 311180 Block 4: CLOSED Type 5 Data: 310410 Block 5: CLOSED Type 5 Data: 310980 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-198_354831014570584_Locked_Keycnt_0_Fbuscnt_0__V_0 4.30_30-08-07_RM-198_(c)_Nokia..bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 3101700000000000 Block 1: OPEN Type 5 Data: 310150 Block 2: OPEN Type 5 Data: 310170 Block 3: OPEN Type 5 Data: 311180 Block 4: OPEN Type 5 Data: 310410 Block 5: OPEN Type 5 Data: 310980 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
04-07-2008, 16:03 | #1164 (permalink) |
Member: 309398 Status: Offline Sonork: 100.1590052 Thanks Meter: 5,455 | 6300 Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_05.50_14-08-07_RM-217_(c)_Nokia. IMEI: 359810011601530 SP LOCK status: Config Key: 2720200000000000 Block 1: CLOSED Type 5 Data: 27202F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-217_359810011601530_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-217_(c)_Nokia..bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2720200000000000 Block 1: OPEN Type 5 Data: 27202F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
04-08-2008, 13:15 | #1165 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Nowhere Age: 44
Member: 25067 Status: Offline Thanks Meter: 81 | Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-89 Version: V_1.0533.47.14_18-04-06_RM-89_(c)_Nokia. IMEI: 356211000993231 SP LOCK status: Config Key: 2342000000000000 Block 1: CLOSED Type 5 Data: 23420F Block 2: CLOSED Type 5 Data: 23420F Block 3: CLOSED Type 5 Data: 23594F Block 4: CLOSED Type 5 Data: 23594F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-89_356211000993231_Locked_Keycnt_0_Fbuscnt_0__V_1. 0533.47.14_18-04-06_RM-89_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2342000000000000 Block 1: OPEN Type 5 Data: 23420F Block 2: OPEN Type 5 Data: 23420F Block 3: OPEN Type 5 Data: 23594F Block 4: OPEN Type 5 Data: 23594F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
04-08-2008, 14:18 | #1166 (permalink) |
Member: 489331 Status: Offline Thanks Meter: 1,141 | 6300 well done ------ Operation: UNLOCK V2 Date: 07-04-2008 Time: 21:46:03 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_04.71_28-02-07_RM-217_(c)_Nokia. IMEI: 356401016925638 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-217_356401016925638_Locked_Keycnt_0_Fbuscnt_0__V_0 4.71_28-02-07_RM-217_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-217_356401016925638_Locked_Keycnt_0_Fbuscnt_0__V_0 4.71_28-02-07_RM-217_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2343300000000000 Block 1: OPEN Type 5 Data: 23433F Block 2: OPEN Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
04-08-2008, 14:18 | #1167 (permalink) |
Member: 489331 Status: Offline Thanks Meter: 1,141 | 6280 well done ------ Operation: UNLOCK V2 Date: 07-04-2008 Time: 20:58:06 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_06.43_30-03-07_RM-78_(c)_Nokia IMEI: 358669016794109 SP LOCK status: Config Key: 4250100000000000 Block 1: CLOSED Type 5 Data: 42501F Block 2: CLOSED Type 5 Data: 42510F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 4096 bytes Saving autobackup to file: RM-78_358669016794109_Locked_Keycnt_0_Fbuscnt_0__V_06 .43_30-03-07_RM-78_(c)_Nokia.bin Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-78_358669016794109_Locked_Keycnt_0_Fbuscnt_0__V_06 .43_30-03-07_RM-78_(c)_Nokia.bin Writting PM Field 308 Subfield 1 with length 4096 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 4250100000000000 Block 1: CLOSED Type 5 Data: 42501F Block 2: CLOSED Type 5 Data: 42510F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 4250100000000000 Block 1: OPEN Type 5 Data: 42501F Block 2: OPEN Type 5 Data: 42510F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
04-08-2008, 14:19 | #1168 (permalink) |
Member: 489331 Status: Offline Thanks Meter: 1,141 | 6280 well done Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_03.81_09-05-06_RM-78_(c)_Nokia IMEI: 352264016041374 SP LOCK status: Config Key: 4250100000000000 Block 1: CLOSED Type 5 Data: 42501F Block 2: CLOSED Type 5 Data: 42510F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 4096 bytes Saving autobackup to file: RM-78_352264016041374_Locked_Keycnt_0_Fbuscnt_0__V_03 .81_09-05-06_RM-78_(c)_Nokia.bin Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-78_352264016041374_Locked_Keycnt_0_Fbuscnt_0__V_03 .81_09-05-06_RM-78_(c)_Nokia.bin Writting PM Field 308 Subfield 1 with length 4096 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 4250100000000000 Block 1: CLOSED Type 5 Data: 42501F Block 2: CLOSED Type 5 Data: 42510F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 4250100000000000 Block 1: OPEN Type 5 Data: 42501F Block 2: OPEN Type 5 Data: 42510F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
04-08-2008, 14:55 | #1169 (permalink) |
Member: 220603 Status: Offline Thanks Meter: 1,164 | e65 done Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-208 Version: V_1.0615.25_10-01-07_RM-208_(c)_Nokia. IMEI: 353263012971278 SP LOCK status: Config Key: 5050600042465540 Block 1: CLOSED Type 5 Data: 50506F Block 2: CLOSED Type 5 Data: 50599F Block 3: CLOSED Type 5 Data: 50506F Block 4: CLOSED Type 5 Data: 50599F Block 5: CLOSED Type 5 Data: 00101F Block 6: CLOSED Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 9 wrong tries from max. 10 tries Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-208_353263012971278_Locked_Keycnt_0_Fbuscnt_9__V_1 .0615.25_10-01-07_RM-208_(c)_Nokia..bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 5050600042465540 Block 1: OPEN Type 5 Data: 50506F Block 2: OPEN Type 5 Data: 50599F Block 3: OPEN Type 5 Data: 50506F Block 4: OPEN Type 5 Data: 50599F Block 5: OPEN Type 5 Data: 00101F Block 6: OPEN Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
04-08-2008, 16:17 | #1170 (permalink) |
Member: 447590 Status: Offline Thanks Meter: 378 | N75 well done Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-128 Version: V_06wk15v37_08-03-07_RM-128_(c)_Nokia. IMEI: 354815013021509 SP LOCK status: Config Key: 3101700000000000 Block 1: CLOSED Type 5 Data: 310150 Block 2: CLOSED Type 5 Data: 310150 Block 3: CLOSED Type 5 Data: 310170 Block 4: CLOSED Type 5 Data: 310170 Block 5: CLOSED Type 5 Data: 310410 Block 6: CLOSED Type 5 Data: 310410 Block 7: CLOSED Type 5 Data: 311180 Block 8: CLOSED Type 5 Data: 311180 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-128_354815013021509_Locked_Keycnt_0_Fbuscnt_0__V_0 6wk15v37_08-03-07_RM-128_(c)_Nokia..bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 3101700000000000 Block 1: OPEN Type 5 Data: 310150 Block 2: OPEN Type 5 Data: 310150 Block 3: OPEN Type 5 Data: 310170 Block 4: OPEN Type 5 Data: 310170 Block 5: OPEN Type 5 Data: 310410 Block 6: OPEN Type 5 Data: 310410 Block 7: OPEN Type 5 Data: 311180 Block 8: OPEN Type 5 Data: 311180 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
★★★★★★ post here all phone unlocked with bb5 trk unlocker ★★★★★★ | ProfesionalGSM | BB5 Box by D.K. | 98 | 06-11-2010 21:29 |
Post Here all phones repair with this latest updat! | Faheem Anjum | Universalbox | 1 | 11-19-2009 08:50 |
POST HERE === BB5 Phones TESTED with 3/3 10/10 Cnt Rst === | sudeeshveekey | BB5BOX | 11 | 04-26-2008 23:01 |
post here all phones unlocked with V32 | RaMCES | BB5BOX | 4 | 01-13-2008 10:27 |
