04-24-2008, 15:59 | #1201 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Phnom Penh(CAMBODIA)
Member: 447590 Status: Offline Thanks Meter: 378 | Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-128 Version: V_06wk15v37_08-03-07_RM-128_(c)_Nokia. IMEI: 354815012688647 SP LOCK status: Config Key: 3101700000000000 Block 1: CLOSED Type 5 Data: 310150 Block 2: CLOSED Type 5 Data: 310150 Block 3: CLOSED Type 5 Data: 310170 Block 4: CLOSED Type 5 Data: 310170 Block 5: CLOSED Type 5 Data: 310410 Block 6: CLOSED Type 5 Data: 310410 Block 7: CLOSED Type 5 Data: 311180 Block 8: CLOSED Type 5 Data: 311180 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-128_354815012688647_Locked_Keycnt_0_Fbuscnt_0__V_0 6wk15v37_08-03-07_RM-128_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 3101700000000000 Block 1: OPEN Type 5 Data: 310150 Block 2: OPEN Type 5 Data: 310150 Block 3: OPEN Type 5 Data: 310170 Block 4: OPEN Type 5 Data: 310170 Block 5: OPEN Type 5 Data: 310410 Block 6: OPEN Type 5 Data: 310410 Block 7: OPEN Type 5 Data: 311180 Block 8: OPEN Type 5 Data: 311180 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
04-24-2008, 16:02 | #1202 (permalink) |
Member: 447590 Status: Offline Thanks Meter: 378 | E65 well done Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-208 Version: V_1.0615.25_10-01-07_RM-208_(c)_Nokia. IMEI: 354832013575129 SP LOCK status: Config Key: 2081000000000000 Block 1: CLOSED Type 5 Data: 20810F Block 2: CLOSED Type 5 Data: 20810F Block 3: CLOSED Type 5 Data: 64710F Block 4: CLOSED Type 5 Data: 64710F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-208_354832013575129_Locked_Keycnt_0_Fbuscnt_0__V_1 .0615.25_10-01-07_RM-208_(c)_Nokia..bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2081000000000000 Block 1: OPEN Type 5 Data: 20810F Block 2: OPEN Type 5 Data: 20810F Block 3: OPEN Type 5 Data: 64710F Block 4: OPEN Type 5 Data: 64710F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
04-24-2008, 16:05 | #1203 (permalink) |
Member: 447590 Status: Offline Thanks Meter: 378 | 6133 well done Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-126 Version: V_05.61_14-12-06_RM-126_(c)_Nokia. IMEI: 352736011566455 SP LOCK status: Config Key: 3102000000000000 Block 1: CLOSED Type 5 Data: 20416F Block 2: CLOSED Type 5 Data: 21630F Block 3: CLOSED Type 5 Data: 21901F Block 4: CLOSED Type 5 Data: 23001F Block 5: CLOSED Type 5 Data: 23102F Block 6: CLOSED Type 5 Data: 23203F Block 7: CLOSED Type 5 Data: 23430F Block 8: CLOSED Type 5 Data: 25001F Block 9: CLOSED Type 5 Data: 25502F Block 10: CLOSED Type 5 Data: 26002F Block 11: CLOSED Type 5 Data: 26201F Block 12: CLOSED Type 5 Data: 310160 Block 13: CLOSED Type 5 Data: 310200 Block 14: CLOSED Type 5 Data: 310210 Block 15: CLOSED Type 5 Data: 310220 Block 16: CLOSED Type 5 Data: 310230 Block 17: CLOSED Type 5 Data: 310240 Block 18: CLOSED Type 5 Data: 310250 Block 19: CLOSED Type 5 Data: 310260 Block 20: CLOSED Type 5 Data: 310270 Block 21: CLOSED Type 5 Data: 310280 Block 22: CLOSED Type 5 Data: 310300 Block 23: CLOSED Type 5 Data: 310310 Block 24: CLOSED Type 5 Data: 310580 Block 25: CLOSED Type 5 Data: 310660 Block 26: CLOSED Type 5 Data: 310800 Block 27: CLOSED Type 5 Data: 20416F Block 28: CLOSED Type 5 Data: 21630F Block 29: CLOSED Type 5 Data: 21901F Block 30: CLOSED Type 5 Data: 23001F Block 31: CLOSED Type 5 Data: 23102F Block 32: CLOSED Type 5 Data: 23203F Block 33: CLOSED Type 5 Data: 23430F Block 34: CLOSED Type 5 Data: 25001F Block 35: CLOSED Type 5 Data: 25502F Block 36: CLOSED Type 5 Data: 26002F Block 37: CLOSED Type 5 Data: 26201F Block 38: CLOSED Type 5 Data: 310160 Block 39: CLOSED Type 5 Data: 310200 Block 40: CLOSED Type 5 Data: 310210 Block 41: CLOSED Type 5 Data: 310220 Block 42: CLOSED Type 5 Data: 310230 Block 43: CLOSED Type 5 Data: 310240 Block 44: CLOSED Type 5 Data: 310250 Block 45: CLOSED Type 5 Data: 310260 Block 46: CLOSED Type 5 Data: 310270 Block 47: CLOSED Type 5 Data: 310280 Block 48: CLOSED Type 5 Data: 310300 Block 49: CLOSED Type 5 Data: 310310 Block 50: CLOSED Type 5 Data: 310580 Block 51: CLOSED Type 5 Data: 310660 Block 52: CLOSED Type 5 Data: 310800 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-126_352736011566455_Locked_Keycnt_0_Fbuscnt_0__V_0 5.61_14-12-06_RM-126_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 5555555555555555 Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Phone unlocked succesfull |
04-24-2008, 16:06 | #1204 (permalink) |
Member: 447590 Status: Offline Thanks Meter: 378 | N75 well done Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-128 Version: V_06wk15v37_08-03-07_RM-128_(c)_Nokia. IMEI: 354815012163104 SP LOCK status: Config Key: 3101700000000000 Block 1: CLOSED Type 5 Data: 310150 Block 2: CLOSED Type 5 Data: 310150 Block 3: CLOSED Type 5 Data: 310170 Block 4: CLOSED Type 5 Data: 310170 Block 5: CLOSED Type 5 Data: 310410 Block 6: CLOSED Type 5 Data: 310410 Block 7: CLOSED Type 5 Data: 311180 Block 8: CLOSED Type 5 Data: 311180 Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 6 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-128_354815012163104_Locked_Keycnt_3_Fbuscnt_6__V_0 6wk15v37_08-03-07_RM-128_(c)_Nokia..bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using cable codes ... Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 14 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 3101700000000000 Block 1: OPEN Type 5 Data: 310150 Block 2: OPEN Type 5 Data: 310150 Block 3: OPEN Type 5 Data: 310170 Block 4: OPEN Type 5 Data: 310170 Block 5: OPEN Type 5 Data: 310410 Block 6: OPEN Type 5 Data: 310410 Block 7: OPEN Type 5 Data: 311180 Block 8: OPEN Type 5 Data: 311180 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
04-25-2008, 06:50 | #1205 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | n73 done Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V_05wk47v48_26-06-07_RM-133_(c)_Nokia. IMEI: 353641017471388 SP LOCK status: Config Key: 5050600042465540 Block 1: CLOSED Type 5 Data: 50506F Block 2: CLOSED Type 5 Data: 50599F Block 3: CLOSED Type 5 Data: 50506F Block 4: CLOSED Type 5 Data: 50599F Block 5: CLOSED Type 5 Data: 00101F Block 6: CLOSED Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-133_353641017471388_Locked_Keycnt_0_Fbuscnt_0__V_0 5wk47v48_26-06-07_RM-133_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 5050600042465540 Block 1: OPEN Type 5 Data: 50506F Block 2: OPEN Type 5 Data: 50599F Block 3: OPEN Type 5 Data: 50506F Block 4: OPEN Type 5 Data: 50599F Block 5: OPEN Type 5 Data: 00101F Block 6: OPEN Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
04-25-2008, 08:04 | #1206 (permalink) |
Member: 447590 Status: Offline Thanks Meter: 378 | N75 well done Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-128 Version: V_06wk15v37_08-03-07_RM-128_(c)_Nokia. IMEI: 354815012523703 SP LOCK status: Config Key: 3101700000000000 Block 1: CLOSED Type 5 Data: 310150 Block 2: CLOSED Type 5 Data: 310150 Block 3: CLOSED Type 5 Data: 310170 Block 4: CLOSED Type 5 Data: 310170 Block 5: CLOSED Type 5 Data: 310410 Block 6: CLOSED Type 5 Data: 310410 Block 7: CLOSED Type 5 Data: 311180 Block 8: CLOSED Type 5 Data: 311180 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-128_354815012523703_Locked_Keycnt_0_Fbuscnt_0__V_0 6wk15v37_08-03-07_RM-128_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 3101700000000000 Block 1: OPEN Type 5 Data: 310150 Block 2: OPEN Type 5 Data: 310150 Block 3: OPEN Type 5 Data: 310170 Block 4: OPEN Type 5 Data: 310170 Block 5: OPEN Type 5 Data: 310410 Block 6: OPEN Type 5 Data: 310410 Block 7: OPEN Type 5 Data: 311180 Block 8: OPEN Type 5 Data: 311180 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
04-27-2008, 06:26 | #1207 (permalink) |
No Life Poster Join Date: Apr 2008 Location: TO SERVE AND PROTECT
Member: 739429 Status: Offline Sonork: FIND TO GOOGLES Thanks Meter: 85 | Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V_05wk47v51.5_29-08-07_RM-133_(c)_Nokia. IMEI: 351851018954900 SP LOCK status: Config Key: 5150200000000000 Block 1: CLOSED Type 5 Data: 51502F Block 2: CLOSED Type 5 Data: 51502F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-133_351851018954900_Locked_Keycnt_0_Fbuscnt_0__V_0 5wk47v51.5_29-08-07_RM-133_(c)_Nokia..bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 5150200000000000 Block 1: OPEN Type 5 Data: 51502F Block 2: OPEN Type 5 Data: 51502F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull thank you bb5 team |
04-27-2008, 07:27 | #1208 (permalink) |
Member: 220603 Status: Offline Thanks Meter: 1,164 | n73 done Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V_05wk47v38.1_19-01-07_RM-133_(c)_Nokia. IMEI: 359568015138327 SP LOCK status: Config Key: 2343000000000000 Block 1: CLOSED Type 5 Data: 23430F Block 2: CLOSED Type 5 Data: 23430F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-133_359568015138327_Locked_Keycnt_0_Fbuscnt_0__V_0 5wk47v38.1_19-01-07_RM-133_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2343000000000000 Block 1: OPEN Type 5 Data: 23430F Block 2: OPEN Type 5 Data: 23430F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
04-27-2008, 08:17 | #1209 (permalink) |
Member: 739429 Status: Offline Sonork: FIND TO GOOGLES Thanks Meter: 85 | Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V_05wk47v28.1_22-06-06_RM-133_(c)_Nokia. IMEI: 352757010941002 SP LOCK status: Config Key: 2341500000000000 Block 1: CLOSED Type 5 Data: 23415F Block 2: CLOSED Type 5 Data: 23415F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-133_352757010941002_Locked_Keycnt_0_Fbuscnt_0__V_0 5wk47v28.1_22-06-06_RM-133_(c)_Nokia..bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2341500000000000 Block 1: OPEN Type 5 Data: 23415F Block 2: OPEN Type 5 Data: 23415F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
04-27-2008, 16:56 | #1210 (permalink) |
Member: 220603 Status: Offline Thanks Meter: 1,164 | 5300 done Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-146 Version: V_04.70_24-01-07_RM-146_(c)_Nokia. IMEI: 356959015822353 SP LOCK status: Config Key: 2343000000000000 Block 1: CLOSED Type 5 Data: 23430F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-146_356959015822353_Locked_Keycnt_0_Fbuscnt_0__V_0 4.70_24-01-07_RM-146_(c)_Nokia..bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2343000000000000 Block 1: OPEN Type 5 Data: 23430F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
10-24-2008, 05:53 | #1212 (permalink) |
No Life Poster Join Date: Apr 2007 Location: INDIA-uttranchal-rishikesh Age: 47
Member: 484665 Status: Offline Sonork: 100.1578012 Thanks Meter: 175 | successfull unlock 6280..... 6280 successfull unlock yesterday.... Code: Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_06.43_30-03-07_RM-78_(c)_Nokia IMEI: 357603005063839 SP LOCK status: Config Key: 2342000000000000 Block 1: CLOSED Type 5 Data: 23420F Keyboard wrong codes counter: 2 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-78_357603005063839_Locked_Keycnt_2_Fbuscnt_10__V_06.43_30-03-07_RM-78_(c)_Nokia.bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2342000000000000 Block 1: OPEN Type 5 Data: 23420F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
11-15-2008, 16:09 | #1213 (permalink) |
No Life Poster Join Date: Jul 2007 Location: PK
Member: 539052 Status: Offline Sonork: 100.1585495 Thanks Meter: 119 | 6085H SUCCESSFUL UNLOCK..... Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-198 Version: V_04.30_30-08-07_RM-198_(c)_Nokia. IMEI: 35483700000000 SP LOCK status: Config Key: 3101700000000000 Block 1: CLOSED Type 5 Data: 310150 Block 2: CLOSED Type 5 Data: 310170 Block 3: CLOSED Type 5 Data: 311180 Block 4: CLOSED Type 5 Data: 310410 Block 5: CLOSED Type 5 Data: 310980 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-198_354837012135841_Locked_Keycnt_0_Fbuscnt_0__V_0 4.30_30-08-07_RM-198_(c)_Nokia..bin Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-198_354837012135841_Locked_Keycnt_0_Fbuscnt_0__V_0 4.30_30-08-07_RM-198_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 3101700000000000 Block 1: CLOSED Type 5 Data: 310150 Block 2: CLOSED Type 5 Data: 310170 Block 3: CLOSED Type 5 Data: 311180 Block 4: CLOSED Type 5 Data: 310410 Block 5: CLOSED Type 5 Data: 310980 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 3101700000000000 Block 1: OPEN Type 5 Data: 310150 Block 2: OPEN Type 5 Data: 310170 Block 3: OPEN Type 5 Data: 311180 Block 4: OPEN Type 5 Data: 310410 Block 5: OPEN Type 5 Data: 310980 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
11-17-2008, 15:06 | #1214 (permalink) |
Member: 539052 Status: Offline Sonork: 100.1585495 Thanks Meter: 119 | 6300b successful unlock. Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-222 Version: V_04.71_28-02-07_RM-222_(c)_Nokia. IMEI: 354************ SP LOCK status: Config Key: 3027200000000000 Block 1: CLOSED Type 5 Data: 302370 Block 2: CLOSED Type 5 Data: 302720 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-217_354827013556764_Locked_Keycnt_0_Fbuscnt_0__V_0 4.71_28-02-07_RM-222_(c)_Nokia..bin Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-217_354827013556764_Locked_Keycnt_0_Fbuscnt_0__V_0 4.71_28-02-07_RM-222_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 3027200000000000 Block 1: CLOSED Type 5 Data: 302370 Block 2: CLOSED Type 5 Data: 302720 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 3027200000000000 Block 1: OPEN Type 5 Data: 302370 Block 2: OPEN Type 5 Data: 302720 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
11-19-2008, 13:43 | #1215 (permalink) |
Member: 539052 Status: Offline Sonork: 100.1585495 Thanks Meter: 119 | 7373 successful unlock Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-209Version: V_04.70_24-01-07_RM-209_(c)_Nokia. IMEI: 3562****** SP LOCK status: Config Key: 2341000000000000 Block 1: CLOSED Type 5 Data: 23410F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-209_356291010167430_Locked_Keycnt_0_Fbuscnt_0__V_0 4.70_24-01-07_RM-209_(c)_Nokia..bin Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-209_356291010167430_Locked_Keycnt_0_Fbuscnt_0__V_0 4.70_24-01-07_RM-209_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2341000000000000 Block 1: CLOSED Type 5 Data: 23410F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2341000000000000 Block 1: OPEN Type 5 Data: 23410F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull Last edited by multicom_fsdpk; 11-19-2008 at 13:48. |
The Following User Says Thank You to multicom_fsdpk For This Useful Post: |
★★★★★★ post here all phone unlocked with bb5 trk unlocker ★★★★★★ | ProfesionalGSM | BB5 Box by D.K. | 98 | 06-11-2010 21:29 |
Post Here all phones repair with this latest updat! | Faheem Anjum | Universalbox | 1 | 11-19-2009 08:50 |
POST HERE === BB5 Phones TESTED with 3/3 10/10 Cnt Rst === | sudeeshveekey | BB5BOX | 11 | 04-26-2008 23:01 |
post here all phones unlocked with V32 | RaMCES | BB5BOX | 4 | 01-13-2008 10:27 |
