Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones
Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included
Old 09-03-2007, 08:52   #1 (permalink)
Member: 4123
Thanks Meter: 27
CECT T689,restarting
I have CECT T689,and when I put sim inside phone is restarting,again and again,e.t.c.I try to restore factory,but it's the same.Maybe is hardware,because phone is not restarting without sim inside.
Old 09-03-2007, 18:16   #2 (permalink)
SE-THAILAND's Avatar
Member: 10084
Thanks Meter: 283
read backup file flash then forma
good luck
SE
Old 09-03-2007, 19:56   #3 (permalink)
Member: 563237
manul format by 1122
Old 09-04-2007, 06:37   #4 (permalink)
Member: 10084
Thanks Meter: 283
yes may can help.1122 is mean reset factory default.if not help try to format FAT
SE
Old 09-04-2007, 07:13   #5 (permalink)
Member: 4123
Thanks Meter: 27
HOw can I format?
GOw can I format this phoen,and with waht I can create buckap,and then format?I try with reset with 1122,but it's the same....Please help me
Old 09-04-2007, 07:17   #6 (permalink)
nasirkhan007's Avatar
Member: 553445
Sonork: 100.1585581
Thanks Meter: 8,184
hello bro
Format ffs This is pinout for you data cable
Cect-T689
keyboard top, connector_1x12_mini
6: Tx
7: Rx
12: Gnd
[email protected]
Old 09-04-2007, 07:18   #7 (permalink)
Member: 4123
Thanks Meter: 27
ok,but..
Ok,I wil make a cabel,but program to read flash and flash file,where I can find?
Tx
Old 09-04-2007, 07:23   #8 (permalink)
Member: 10084
Thanks Meter: 283
Tx
here http://forum.gsmhosting.com/vbb/showthread.php?t=415821
Old 09-04-2007, 07:41   #9 (permalink)
Member: 4123
Thanks Meter: 27
Tx,but
I have allready download this mtk tool,but I don't have flash files,and please explain how to make a cable.YOu give me the pinout,but on wich type of cable(rj45,rs232,)and wich box I must use.Tx
Old 09-04-2007, 08:09   #10 (permalink)
Dilip_Nath's Avatar
Member: 387110
Sonork: Not Use
Thanks Meter: 630
I think Mtk-Box will help you.
Old 09-04-2007, 08:31   #11 (permalink)
Member: 10084
Thanks Meter: 283
if ur fone restart with sim card u dont need to flash.this problem just format.
*** read flash backup be4 format ur fone ****
*** if ur fone CPU is MT6226BA DONT WRITE FLASH IF NOT UR FONE DAED
SE
Old 09-09-2007, 22:49   #12 (permalink)
Mehdi Ghorbani's Avatar
Member: 103931
Thanks Meter: 31
infinity box is best for repair this phone...only select cect t689 and press ffs(format ffs)
Old 09-10-2007, 17:13   #13 (permalink)
Member: 360553
Thanks Meter: 2
i thinks you need format with BOX( MTK, INFI , tIANMU,) if not oki . you try to flash the phone . i think your phone will be OK ! goodluck .
Old 09-21-2007, 14:43   #14 (permalink)
GSM SNIPER's Avatar
Member: 27291
Thanks Meter: 81
Originally Posted by nasirkhan007 View Post
hello bro
Cect-T689
6: Tx
7: Rx
12: Gnd
[email protected]
Wrang pinout brother ! try to give a corrct pinout
Old 09-21-2007, 15:04   #15 (permalink)
GSM SNIPER's Avatar
Member: 27291
Thanks Meter: 81
This is the proove :
COM14 [VCP3] selected
Device: Autodetect
Checking data, wait...
advanced flash detection active
Action: unlock
unlock method: standard
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6226:8A02:8A01]...
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:29EA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
Initialize Done
Set baud...
921600
Set baud Done
Check space...
device parameters autodetection in progress..
total flash region size: 01000000
detect device identification, method #1...
detection phase #1...
detect device parameters finished
memory structure: 2nd [enhanced] (or higher) generation
warning: make backup before any action !
identification data Ok
identification data backup saved: id.E3ED9EA7.[E550_A5ARABBT_E550_GPRS_MT6226_S01.PCBV3_0_01_2.BI N_22F6193A].rpl
identification detection finished
device-id: E3ED9EA7
protocol version: 04
version sw1: E550_A5ARABBT_E550_GPRS_MT6226_S01.PCBV3_0_01_2.BI N
version sw2: E550_A5ARABBT.PCBV3_0.01.2
ffs offset/size: 00800000/001FF000
detecting eeprom area in 1 chip(s)...
checking area[00000000]: 00000000-00FFFFFF...
eeprom found near: 00E00000
detecting eeprom size...
eeprom size: 00200000
eeprom chip: 00
eeprom area detected[00000000]: 00E00000-00FFFFFF
detecting structure pass 1...
detect standard location pass #1...
detect extended location pass #1...
detect standard offset pass #1...
detect standard data...
layout detection complete
eeprom element #1 detected ok
reading [eeprom[E550_A5ARABBT_E550_GPRS_MT6226_S01.PCBV3_0_01_2.BI N]]...
file saved: backup_eeprom[E550_A5ARABBT_E550_GPRS_MT6226_S01.PCBV3_0_01_2.BI N]_20070921-145819.B0E.bin
Check space Done
Manipulation...
detection procedure, wait...
detection procedure completed
Manipulation Done
Finalization...
Finalization Done
Write...
Write: eeprom
Write Done
file saved: backup_system_log_E3ED9EA7_[E550_A5ARABBT_E550_GPRS_MT6226_S01.PCBV3_0_01_2.BI N]_22F6193A_20070921-145856.B0X.bin
Finished, time used: 208 sec
Remove/Install battery now !
Device: Autodetect
Action: unlock
Boot...
19200
Connecting, wait...
high speed disabled
Boot Done
Initialize...
Initialize Done
Set baud...
921600
Set baud Done
Check space...
device-id: E3ED9EA7
eeprom chip: 00
Check space Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
Write: eeprom
Write Done
CECT T689 when inser sim restarting NOW? ismabdi SpiderMan 2 01-23-2009 06:14
CECT T689 restart when insert sim card? svchost Infinity-Box 5 11-15-2008 21:43
Cect t689 restart with sim card F@RUK S Infinity-Box 7 09-17-2008 21:50
CECT T689 Restarting Problem mooSa34 Chinese Models & Cloned Phones 19 03-23-2008 12:29
CECT T689 dual sim PDA Phone crvkva10 HTC & PDA WM( With Touchscreen) 1 07-12-2007 08:31
Page generated in 0.26781 seconds with 10 queries
