Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SETool2
Old 02-08-2008, 06:01   #1 (permalink)
Member: 671345
Thanks Meter: 7
Need Help To Convert K610 Cid 49 To 52
hi..can someone help me convert SE k610 cid 49 to cid 52..i have setool...
thnx..
Old 02-08-2008, 06:07   #2 (permalink)
Member: 686489
Thanks Meter: 11
just download the attachment file
Old 02-08-2008, 06:15   #3 (permalink)
Member: 433731
Thanks Meter: 49
if you have jaf p-key use jafseflaher
Old 02-08-2008, 06:45   #4 (permalink)
Member: 671345
Thanks Meter: 7
i got cid 49..can i use this process?thnx for response..
Old 02-08-2008, 07:00   #5 (permalink)
Registered User
Member: 20027
Thanks Meter: 5
write this "db2020 to cid52.txt" script with setool, next flash cid52 file from support or update phone sw via sonyericsson.com update service and your phone will be cid52
Old 02-08-2008, 07:03   #6 (permalink)
Member: 671345
Thanks Meter: 7
ok sir..thnx for the info..
Old 02-08-2008, 07:09   #7 (permalink)
Member: 686489
Thanks Meter: 11
you dont have write the attached file..
its a instruction guide for you..
you just have to read it..
put the attach file on misc then write it
File Type: txt DB2020_CID49_51_to_CID52.txt (769 Bytes, 149 views)
Old 02-08-2008, 08:37   #8 (permalink)
Member: 671345
Thanks Meter: 7
ok i'll try sir..i'll post result...
Old 02-08-2008, 08:43   #9 (permalink)
Member: 671345
Thanks Meter: 7
v0.914023/UNI
CARD SERIAL: 000*****
Loaded 51 flash descriptors
Open COM port OK
ChipID:9900,EMP protocol:0301
Speed:921600
Can't load ID loader !
Elapsed:5 secs.
Open COM port OK
Speed:921600
Flash ID check:897E
Flash props sent ok
OTP LOCKED:1 CID:49 PAF:1 IMEI:353*********** CERT:N/A
FLASH CID:51 COLOR:RED
Model:K610i
MAPP CXC article: R1ED001 prgCXC1250374_GENERIC_TH
MAPP CXC version: R1ED001
Language Package:C_ASIA
CDA article: CDA102295/1
CDA version: R2A
Default article: cxc1250376
Default version: R1ED001
PROVIDER: 000-00
SIMLOCKS NOT DETECTED
RESTORATION FILE PRESENT FOR DETECTED FIRMWARE
Elapsed:3 secs.
phone was converted to cid 51 sir...
Old 02-08-2008, 08:51   #10 (permalink)
Member: 671345
Thanks Meter: 7
i wrote script 2 times and phone was converted to cid 52..
thnx u guys...
Old 02-15-2008, 00:18   #11 (permalink)
papoo's Avatar
Member: 188374
Sonork: 1000.2
Thanks Meter: 203
Thanks Man
Thanks Man
Thanks Man
Old 02-15-2008, 01:15   #12 (permalink)
octavyus's Avatar
Member: 242469
Thanks Meter: 503
Exclamation cross CID ........... very easy
your solution is very easy, you can make change CID with two methods
Best Regard
Old 02-15-2008, 01:21   #13 (permalink)
Member: 543112
Thanks Meter: 7
use xs++ heres the link http://rapidshare.com/files/83734607..._unlocking.rar
how to write script to change k530i cid 49 to cid 52 with setool med26 Sony Ericsson 2 03-19-2010 09:08
how to change db2020 cid 49 to cid 52 ikram tabassum1 SETool2 8 03-11-2009 17:13
Need help, urgent ~~ K550i cid 49 change cid 52 jack_ho Sony Ericsson 2 07-22-2008 10:22
PLS I NEED STEP BY STEP PROCEDURE HOW TO CHANGE K800i CID 49 TO 52 ojs Cruiser Suite 1 03-31-2008 12:03
้how to convert w850 cid 49 to cid 52 t2520 Universalbox 2 06-15-2007 19:32
Page generated in 0.23316 seconds with 10 queries
