HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
11-11-2014, 22:20 | #16 (permalink) | |
Junior Member Join Date: Nov 2014
Member: 2291093 Status: Offline Thanks Meter: 0 | Going Crazy, been trying for weeks to fix sprint htc one m7 hboot 1.57 Quote:
I have tried everything.I don't know what else to do. I keep getting errors when flashing a ruu and such. I've tried so many different things it's becoming a blurr As of right now I have an unlocked bootloader and hboot 1.57 s-on and twrp recovery. I've been spending hours and days trying to figure this out. The phone boots to a white htc screen and that's it. Before it would act like it had a rom but no touch, black screen with navigation bar only. Any help will be greatly appreciated. | |
11-14-2014, 17:47 | #17 (permalink) |
Junior Member Join Date: Apr 2012
Member: 1753790 Status: Offline Thanks Meter: 0 | Hello, Message to Rizwan. I need S-OFFing my HTC One M7 (M7_UL) Hboot : 1.57 OS 6.12.163.5 (SFR-France) I realized your methed step by step (HTC One M7 4.4.2 S-off) I had : The first bottle is open chugging.......... whelp, that bottle is empty, opening bottle 2 ............... ............... chugging.......... whelp, that bottle is empty, opening bottle 12 all out of bottles and still no buzz reboot device by holding power and try again I repeated the cycle 3 times, I had all time the same result : adb wait-for-device push firewater /data/local/tmp adb shell su chmod 755 /data/local/tmp/firewater /data/local/tmp/firewater Thanx for help |
11-14-2014, 19:03 | #18 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
Try and try changing Room, Kernel, and try many times if want for FREE, can be you are lucky at first attempt how is possible you configuraction isn't compatible and have need days or weeck, but i can say that work 100%, basic steps are these, now is you ability get S-OFF, P.d. if not want wait and have this S-OFF in 2 min.s must need BOX. Br allumts | |
11-14-2014, 20:16 | #19 (permalink) |
Freak Poster Join Date: Apr 2013 Location: PAP-Haiti Age: 36
Member: 1914596 Status: Offline Sonork: 100.1619364 Thanks Meter: 59 | Solved HTC One Sprint 4.4.2 hbott 1.57 1) You have to unlock bootloader 2) Flash recovery with this file "philz_touch_6.48.4-m7spr.img" 3) Download this ROM "Bad_Boyz_Sprint_ONE_Sense_6_v1.0.zip" here :[ROM] Bad Boyz Sprint ONE ROMz | 4.4.2 | Sense 6 | Deodexed | BB Updater | - xda-developers DevDB adb past it to phone. if your htc cant power on in normal just put the in revovery mode connected to pc, open cmd and type: (to do easy place the ROM to C:// location) cd\ [Enter] adb devices [Enter] (to check device is connected to pc) adb push Bad_Boyz_Sprint_ONE_Sense_6_v1.0.zip /sdcard/ [Enter] wait few minutes. After flash phone via recovery and dont forget to wipe too Htc will power on normal 4) To S-OFF, you need to flash kernel download it here : https://www.androidfilehost.com/?fid=23329332407568531. Flash it via recovery After done use "Firewater s-off" 5) You can get an error when flashing htc with Sprint_HTC_One_m7wls_1.29.651.10_RUU. At this time you may flash you hboot to change version get this "hboot_hexed.zip" and flash cmd command: Put in fastboot and connect to pc Type : fastboot devices fastboot oem rebootRUU fastboot flash zip hboot_hexed.zip fastboot reboot Now you can proccess your downgrade and your Ruu will work fine. 6) You know that you can do to sim unlock it if you need to get phone unlocked gsm Last edited by technisoft; 11-14-2014 at 20:23. |
11-19-2014, 07:13 | #21 (permalink) |
Member: 1753790 Status: Offline Thanks Meter: 0 | To "technisoft", Your explination about flashing, tye second message before, it was for my HTC On M7 ? My HTC One M7 (UL), european, with Vodafone (SFR-France) rom. It's : Unlocked HBoot : 1.57 OS:6.12.163.5 Can I flash a sprint rom and kernel to obatin the S-OFF ? Thanx |
11-19-2014, 21:19 | #22 (permalink) | |
BR allumts | |
11-20-2014, 11:03 | #23 (permalink) | |
Member: 1753790 Status: Offline Thanks Meter: 0 | Quote:
Which box you use ? Thanx | |
11-20-2014, 19:50 | #25 (permalink) |
No Life Poster Join Date: Aug 2012 Location: Bamako Mali
Member: 1803689 Status: Offline Sonork: 100.1659873 Thanks Meter: 154 | Hi i have HTC ONE M7 PN072 +++unlocked+++ M7_WLS PVT SHIP S-ON RH HBOOT-1.57.0000 RADIO-1.01.20.0515 OpenDSP-v32.120.274.0909 OS-5.03.651.3 eMMC-boot 2048MB May 15 2014,16:31:22.0 How to proced to SIM UNLOCK? Thanks to all for your help very urgent |
11-20-2014, 21:34 | #26 (permalink) | |
BR | |
The Following User Says Thank You to allumts For This Useful Post: |
