GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
10-19-2007, 06:54 | #1306 (permalink) | |
Junior Member Join Date: Sep 2007 Location: Melbourne, AU
Member: 589625 Status: Offline Thanks Meter: 3 | Quote:
I just made a cer file for you using your IMIE and signed Route 66 v545 sis file with that. So you just need to download the sis file from the link provided below and install on your phone. Let me know how you go or if any help needed... http://rapidshare.com/files/63579880...rWizard4it.sis | |
10-19-2007, 08:11 | #1307 (permalink) |
Junior Member Join Date: Oct 2007
Member: 611410 Status: Offline Thanks Meter: 0 | hello i managed to sign route 66 and install it on my n95 the first time i used it the voice commands worked fine but now for some reason they don't and is not beacuse they switched off i tryed uninstalling and that didn't work either maybe i should format the memory card and re install ? do you have any solution for this ? |
10-19-2007, 09:23 | #1308 (permalink) | |
No Life Poster Join Date: May 2007 Location: UK
Member: 503346 Status: Offline Thanks Meter: 2,582 | have you installed route 66 v7 - 486 or 545 Quote:
10-19-2007, 10:08 | #1309 (permalink) | |
Member: 611410 Status: Offline Thanks Meter: 0 | Quote:
i'm currently using 7.3.545 and the phone is brand new any way after i posted this uninstalled route 66 then i erased all the files in my memory card, recopied route66_7.3.545.patched.unsigned.signed.sis & Britain.prm to my memory card, then installed the sis file and run the application from the application folder. Gave me the msg that some files are missing so i replugged the usb and moved Britain.prm to system>route 66>Maps after that i could heard the woman saying welcome seems to be working now | |
10-19-2007, 11:03 | #1310 (permalink) |
Major Poster Join Date: Aug 2006
Member: 331838 Status: Offline Thanks Meter: 4 | The voices folder needs to be on the memory card on build 545, otherwise it mutes. This means that you either must install to the card or move the folder manually afterwards... So... Anyone got the full R66 Western Europe map running on a N95? |
10-19-2007, 11:43 | #1313 (permalink) |
Insane Poster Join Date: Sep 2007
Member: 598694 Status: Offline Thanks Meter: 4 | BLUEDWARF, Thankyou heaps, just downloaded the file you saved for me, will attempt install on wife's phone when she gets home tonight. Any idea what causes the error - unable to install, constrained by certificate, means ? Cheers again wizard4it |
10-19-2007, 12:20 | #1314 (permalink) |
Junior Member Join Date: Feb 2007
Member: 447710 Status: Offline Thanks Meter: 2 | Tomtom 5 on PPC Hi Bu, I have installed TTN 5.000 with UK & major roads of WE v660 on ipaq 3950. I have few unanwered doubts, please can you help. 1) Which latest version can be installed on PPC running Windows CE3.0(ipaq 3950.) ( I tried to install version 6.0 but failed, dont know why) 2) is it possible to install maps v675 on TTN5.00. 3) I have been regularly updating sppe camera database on my TTN6.0, running on N73( Thanks to Umster and you). now when i installed this database on my Ipaq and selected these as POI alerts, it asked me to choose the alarm for each ( this never happened on TTN6 on my N73, alerts for sppedcams are in voices) are there any files missing . please help cheers |
10-19-2007, 12:45 | #1315 (permalink) |
Junior Member Join Date: Oct 2007 Location: Australia
Member: 608577 Status: Offline Thanks Meter: 0 | hi wizard4it the error message you are receiving basically means that you havent signed it properly to that exact version and a reset could make the difference or even just a memory card format. and then just copy the maps over to your memory card and all should be well |
10-19-2007, 15:43 | #1317 (permalink) |
Member: 598694 Status: Offline Thanks Meter: 4 | BLUEDWARF, Ok it installed ok, even runs, put maps in system/apps/route66 in a folder caled maps. It finds the maps, so far so good. The original route66 is still attached to the swirly star button on the hone, any way I can point that button to the version I just installed ? Also when first loading it ( at this stage via applications folder ) you get a voice ( female ) saying welcome to route66 showing the route66 title screen. Now it says no gps! gps! in red ( pretty cute font ) if I go outside it changes and all ok. So in essence it works. Exiting program and opening up again, this time I get tittle screen for route66 but no voice. Any ideas why I lose the voice and possible all sound when reopening the aplication again, it still find GPS approx 6 to 9 sats. I am at a lose to why no sound after the first opening of it. wizard4it |
10-19-2007, 17:45 | #1320 (permalink) |
Member: 589625 Status: Offline Thanks Meter: 3 | Yes, it greets you only once when you first start the program. Afterwards only when navigating....so try navigating anywhere, should get the voice again...cheers |
Need crack for route 66 mobile 7 for n95 and australia maps. | carulli | Nokia Multimedia | 3 | 04-04-2009 11:14 |
MDictionary v6.7 S60v3 SymbianOS9.x Signed ML and Dictionaries (Update:15.03.09) | aapkae | Nokia Multimedia | 0 | 03-16-2009 10:01 |
Route 66 Wms Latest Uk Maps ??? | markcoopz | GPS devices , Navigators & Maps | 0 | 03-18-2007 13:34 |
Denmark map for TT 5.2 or Route 66 mobile 7 | lordb24 | Nokia Multimedia | 0 | 01-15-2006 21:12 |
Route 66 Mobile 2005 and GPS BT Receiver | fido59 | Nokia Multimedia | 1 | 10-11-2005 07:34 |
