GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
10-24-2007, 23:34 | #1426 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: Over Here
Member: 613875 Status: Offline Thanks Meter: 61 | Quote:
10-24-2007, 23:36 | #1427 (permalink) |
No Life Poster Join Date: May 2007 Location: UK
Member: 503346 Status: Offline Thanks Meter: 2,582 | TomTom One V3, Go520 and Go 720 Custom Cursors TomTom One V3, Go520 and Go 720 Custom Cursors ============================================== As the Navcore Version 7 Custom Cursors thread has grown so large it has become necessary to gather all the submitted work on one page for easy reference! Installation Instructions ========================= At present custom cursors are only supported on the 520 and 720 models. We will update this with other compatible models as they become known to us. To install you need to copy the .bmp (bitmap) version of the cursor to the art\cars folder on your TomTom device. The .bmp file version of the cursor can be obtained by double-clicking the previews below. the image that is then displayed is in the correct .bmp file format and can be saved to your PC. Install ======= A new page will load with the .bmp version of the cursor displayed. Save this image to your desktop or a folder on your computer. For PC's you right-click the image and choose 'Save As', for Apple Macs right-click and choose 'Save image to the desktop'. Connect your TomTom to your computer as normal. All that remains is for the image you saved in step 3. above to be copied to the correct folder. If you browse your TomTom device you will see a folder called art. Within this folder is a sub folder called cars. Paste the cursor image into this folder. Activate To select the new cursor on your device: Open 'Change Preferences' from the Main Menu. Select 'Change Car Symbol' If you have correctly followed the steps above your new cursor will be shown amongst those available for you to choose from. Select the new cursor. Creating your own If you want to make your own it is a simple process Locate a suitable image or take a photo of your own car. The best cursors are those that are viewed from the rear but slightly above the car rather than from directly behind. The image size should be re-sized to 80 x 80 pixels. TomTom automatically sets any part of the image that is red (RGB 255,000,000) to transparent For optimum results a continuous 1 pixel white border should be added around the cursor. The image should be saved as .bmp (bitmap). You can easily experiment with your cursors or take a look at some of the ones supplied with the device to see how they have been designed. Last edited by BuMobiles; 10-24-2007 at 23:37. Reason: Spelling Mistakes |
10-25-2007, 14:10 | #1434 (permalink) | |
Junior Member Join Date: Oct 2007
Member: 615960 Status: Offline Thanks Meter: 0 | Quote:
Does this mean there is something wrong with the cer file i downloaded from symbiansinged or am i doing something wrong. your help is much appreciated. | |
10-25-2007, 16:10 | #1435 (permalink) |
Member: 615960 Status: Offline Thanks Meter: 0 | Done it Done it! If I can, anyone can! You need to register at symbiansigned then get a cer file from your csr file. use this to sign the unsigned sis file and install it. bingo! read back through the thread BU has covered all the steps in some detail. Good work BU. |
10-25-2007, 16:13 | #1436 (permalink) | |
10-25-2007, 20:32 | #1437 (permalink) |
Member: 613875 Status: Offline Thanks Meter: 61 | Got it too Finally figured out what I did wrong. Thanks to BuMobile and others who gave me hint. It would have been easy to have someone did it for me but I'm glad I stuck with it and figured it out. Now I can help others that need help. Thank you |
10-25-2007, 21:01 | #1438 (permalink) |
Member: 613875 Status: Offline Thanks Meter: 61 | OK, spoke too soon. Got Route 66 sign version on the phone memory card, it's there but say resource missing. Also trying to install the maps but I can't find system\apps\route66\maps anywhere on the memory card. Almost there, just a little more help please. Thank you |
Need crack for route 66 mobile 7 for n95 and australia maps. | carulli | Nokia Multimedia | 3 | 04-04-2009 11:14 |
MDictionary v6.7 S60v3 SymbianOS9.x Signed ML and Dictionaries (Update:15.03.09) | aapkae | Nokia Multimedia | 0 | 03-16-2009 10:01 |
Route 66 Wms Latest Uk Maps ??? | markcoopz | GPS devices , Navigators & Maps | 0 | 03-18-2007 13:34 |
Denmark map for TT 5.2 or Route 66 mobile 7 | lordb24 | Nokia Multimedia | 0 | 01-15-2006 21:12 |
Route 66 Mobile 2005 and GPS BT Receiver | fido59 | Nokia Multimedia | 1 | 10-11-2005 07:34 |
