Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GPS devices , Navigators & Maps
GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc
Old 10-24-2007, 23:34   #1426 (permalink)
titan05's Avatar
Member: 613875
Thanks Meter: 61
Originally Posted by BuMobiles View Post
hi mate,
the device certificate maker does work with windows vista
the csr file created by the devcert program is in the format that www.symbiansigned.com needs to process it to make a certificate!
if any help is needed about signing just visit www,symbiansigned.com and select help!
OK thank, I did manage to get a Cert, now what?
Old 10-24-2007, 23:36   #1427 (permalink)
BuMobiles's Avatar
Member: 503346
Thanks Meter: 2,582
TomTom One V3, Go520 and Go 720 Custom Cursors
As the Navcore Version 7 Custom Cursors thread has grown so large it has become necessary to gather all the submitted work on one page for easy reference!
Installation Instructions
At present custom cursors are only supported on the 520 and 720 models. We will update this with other compatible models as they become known to us.
To install you need to copy the .bmp (bitmap) version of the cursor to the art\cars folder on your TomTom device. The .bmp file version of the cursor can be obtained by double-clicking the previews below. the image that is then displayed is in the correct .bmp file format and can be saved to your PC.
Install
A new page will load with the .bmp version of the cursor displayed.
Save this image to your desktop or a folder on your computer. For PC's you right-click the image and choose 'Save As', for Apple Macs right-click and choose 'Save image to the desktop'.
Connect your TomTom to your computer as normal.
All that remains is for the image you saved in step 3. above to be copied to the correct folder. If you browse your TomTom device you will see a folder called art. Within this folder is a sub folder called cars. Paste the cursor image into this folder.
Activate
To select the new cursor on your device:
Open 'Change Preferences' from the Main Menu.
Select 'Change Car Symbol'
If you have correctly followed the steps above your new cursor will be shown amongst those available for you to choose from.
Select the new cursor.
Creating your own
If you want to make your own it is a simple process
Locate a suitable image or take a photo of your own car. The best cursors are those that are viewed from the rear but slightly above the car rather than from directly behind.
The image size should be re-sized to 80 x 80 pixels.
TomTom automatically sets any part of the image that is red (RGB 255,000,000) to transparent
For optimum results a continuous 1 pixel white border should be added around the cursor.
The image should be saved as .bmp (bitmap).
You can easily experiment with your cursors or take a look at some of the ones supplied with the device to see how they have been designed.
Old 10-24-2007, 23:55   #1428 (permalink)
Member: 616788
cert for n95
hi bumobile. please can you organise a cert for my n95 imei 352255010451429. i will appreciate it alot.thanx
Old 10-25-2007, 00:29   #1429 (permalink)
titan05's Avatar
Member: 613875
Thanks Meter: 61
OK I'm at this stage, please help. I'm trying to do this on my own and is a novice. Thanks
Old 10-25-2007, 00:48   #1430 (permalink)
titan05's Avatar
Member: 613875
Thanks Meter: 61
OK, I give up, unless some one can sign me a cert.
Nokia N95
Route66.Mobile.v7.3.545.cracked.unsigned
IMEI# 356962019638536
Thank You
Old 10-25-2007, 03:02   #1431 (permalink)
Member: 263389
i can make the csr, but the fexplorer.sis file is not made when i click on auto_signis it does not make the fexplorer.sis
can someone help
Old 10-25-2007, 08:33   #1432 (permalink)
Member: 616995
Could someone please do me a cert for route 66 7.3.545 N95 IMEI 354835012118577. It would be greatly appreciated.
Old 10-25-2007, 13:55   #1433 (permalink)
BuMobiles's Avatar
Member: 503346
Thanks Meter: 2,582
easy from there
right, 1st copy the route 66 to the memory card and install
then copy maps onto the memory card in the folder called system\apps\route66\maps
easy as 1-2-3
Old 10-25-2007, 14:10   #1434 (permalink)
Member: 615960
Originally Posted by NutCutlets View Post
Please can sombody with a symbiansigned account obtain a cert file for the attached csr? Many many thanks in advance.
Hi, I have got the cer file, but when I try and sign the app i get the message: could not verify signature with known algorithm, exiting. encryption error, not a DSA certificate.
Does this mean there is something wrong with the cer file i downloaded from symbiansinged or am i doing something wrong. your help is much appreciated.
Old 10-25-2007, 16:10   #1435 (permalink)
Member: 615960
Done it
Done it! If I can, anyone can! You need to register at symbiansigned then get a cer file from your csr file. use this to sign the unsigned sis file and install it. bingo! read back through the thread BU has covered all the steps in some detail. Good work BU.
Old 10-25-2007, 16:13   #1436 (permalink)
titan05's Avatar
Member: 613875
Thanks Meter: 61
Look like we are both at the same stage. Same message I got. If I can figure this thing out I'll be in a position to help others.
Old 10-25-2007, 20:32   #1437 (permalink)
titan05's Avatar
Member: 613875
Thanks Meter: 61
Got it too
Finally figured out what I did wrong. Thanks to BuMobile and others who gave me hint. It would have been easy to have someone did it for me but I'm glad I stuck with it and figured it out. Now I can help others that need help.
Thank you
Old 10-25-2007, 21:01   #1438 (permalink)
titan05's Avatar
Member: 613875
Thanks Meter: 61
OK, spoke too soon.
Got Route 66 sign version on the phone memory card, it's there but say resource missing. Also trying to install the maps but I can't find system\apps\route66\maps anywhere on the memory card. Almost there, just a little more help please. Thank you
Old 10-25-2007, 21:19   #1439 (permalink)
Member: 572787
Thanks Meter: 3
titan05 ,
You will find it if you use either a card reader or connect your phone to the pc in Mass Storage mode.Then You are done.
Old 10-25-2007, 21:33   #1440 (permalink)
titan05's Avatar
Member: 613875
Thanks Meter: 61
Do I only put the Signed version of Route 66 7.3.486. into the phone memory? I was reading that I need to put in a .rar version first?
Need crack for route 66 mobile 7 for n95 and australia maps. carulli Nokia Multimedia 3 04-04-2009 11:14
MDictionary v6.7 S60v3 SymbianOS9.x Signed ML and Dictionaries (Update:15.03.09) aapkae Nokia Multimedia 0 03-16-2009 10:01
Route 66 Wms Latest Uk Maps ??? markcoopz GPS devices , Navigators & Maps 0 03-18-2007 13:34
Denmark map for TT 5.2 or Route 66 mobile 7 lordb24 Nokia Multimedia 0 01-15-2006 21:12
Route 66 Mobile 2005 and GPS BT Receiver fido59 Nokia Multimedia 1 10-11-2005 07:34
Page generated in 0.25533 seconds with 10 queries
