GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
![]() | #1441 (permalink) |
Major Poster ![]() ![]() Join Date: Aug 2007
Member: 572787 Status: Offline Thanks Meter: 3 | Well my english is not that good,but i will try. First use PC suite to install the aplication.When it asks you where to install tell it to the memory card.After you do this you have to place whatever map you have in system\apps\route66\maps .This you have to do the way I wrote in my previos post.And then everithing must be OK.Good luck! |
![]() | #1443 (permalink) |
Member: 572787 Status: Offline Thanks Meter: 3 | You Can't see it trough the phone.Yo have to connect the phone to youre PC in Mass Storage Mode,and than you will see it FROM your PC.You are just a step away!Try! You maid need to create only the Maps folder if I remmember well... |
![]() | #1448 (permalink) |
Member: 572787 Status: Offline Thanks Meter: 3 | I have an Idea,what may be the problem.Try go to My Computer=>Tools=>Folder options=>View=>and check "Show hidden files and folders" This must work and then you will see that System folder in your memory card. Write what happend pleace! |
![]() | #1449 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2007 Location: Over Here
Member: 613875 Status: Offline Thanks Meter: 61 | Nothing for some reason I think the app is not installing right. OK I hook my phone up to PC, click on install aplication Nokia install application pop up I than chose the Route66 sign sig and click OK, it transfer to my phone it show up on the phone but when I click on it it say resource missing in the mass storage I see like above picture. ![]() |
![]() | #1450 (permalink) |
Member: 572787 Status: Offline Thanks Meter: 3 | It will say resource missing,because there is still not a map in system\apps\route66\maps.Now you have to see that System folder trough your PC witch might be hidden.Thats why you have to tell your PC to show you the hidden Fowders to.It seems to me that everithing with the aplication and installation is alright."Resource missing" in this case meens that you don't have a map copied to it's folder yet.Thats all I can guess.Hope you will do it.Good luck! |
![]() | #1453 (permalink) |
Member: 613875 Status: Offline Thanks Meter: 61 | Yeah I have it installed on the memory card. No system/apps/Route66/maps show up so I made a folder Still no work, thanks for your help anyway, really appreciate it. It's so close I don't want to give up, I will keep trying. |
Need crack for route 66 mobile 7 for n95 and australia maps. | carulli | Nokia Multimedia | 3 | 04-04-2009 11:14 |
MDictionary v6.7 S60v3 SymbianOS9.x Signed ML and Dictionaries (Update:15.03.09) | aapkae | Nokia Multimedia | 0 | 03-16-2009 10:01 |
Route 66 Wms Latest Uk Maps ??? | markcoopz | GPS devices , Navigators & Maps | 0 | 03-18-2007 13:34 |
Denmark map for TT 5.2 or Route 66 mobile 7 | lordb24 | Nokia Multimedia | 0 | 01-15-2006 21:12 |
Route 66 Mobile 2005 and GPS BT Receiver | fido59 | Nokia Multimedia | 1 | 10-11-2005 07:34 |
