05-22-2010, 12:08 | #1 (permalink) |
Freak Poster Join Date: Feb 2007 Location: In Your Heart
Member: 451538 Status: Offline Thanks Meter: 98 | probably SUPERDONGLE_KEY corrupted Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V 05wk07v48.1 28-08-07 RM-84 (c) Nokia. ApeCoreSw: V 5.0737.3.0.1 13-09-07 RM-84 (C)Nokia Using cached productData[1B10011438C04951D0473A89AB8B8C3DD207AFC3] ... Authenticating to SUPERDONGLE using security server ... Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request can anyone solve this problam |
05-22-2010, 12:13 | #2 (permalink) |
Freak Poster Join Date: Apr 2005 Age: 45
Member: 132735 Status: Offline Thanks Meter: 88 | post whole info of logs here.. if your fone have security test failed problem,try to reinstall mxkey 3.4 its posibly server error. kindly check some posted solution here for that matter..the mxkey server is now working. |
05-22-2010, 12:35 | #6 (permalink) |
Member: 451538 Status: Offline Thanks Meter: 98 | Not solved Phone Type: RM-84 (Nokia N70) SW Version: V 05wk07v48.1 28-08-07 RM-84 (c) Nokia. Imei plain: 35366601255705-5 Product Code: 0524110 ApeCoreSw: V 5.0737.3.0.1 13-09-07 RM-84 (C)Nokia ApeVariant: V 5.0737.3.0.1-32.01 13-09-07 RM-84 (c)Nokia Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 353666012557055 Version: SIMLOCK SERVER VERSION 58 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF AFTER PM AUTH THIS ERROR Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V 05wk07v48.1 28-08-07 RM-84 (c) Nokia. ApeCoreSw: V 5.0737.3.0.1 13-09-07 RM-84 (C)Nokia Using cached productData[1B10011438C04951D0473A89AB8B8C3DD207AFC3] ... Authenticating to SUPERDONGLE using security server ... Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request |
05-22-2010, 13:41 | #10 (permalink) |
No Life Poster Join Date: Nov 2006 Location: maldives
Member: 389862 Status: Offline Sonork: guy_askali Thanks Meter: 54 | yes can fix 1. read full pm and 2. IMEI&security > IMEI rebuild > repair SD 3. agan pm > super SD auth > PMM auth > writ PM done 10000% work |
Corrupted eeprom data in 3210 | cole | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 03-02-2002 04:58 |
What to do if EEPROM is corrupted? | Nick-A | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 13 | 01-08-2002 08:50 |
dead 3310 due to corrupt fullflash | ambot | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 12-14-2001 17:10 |
GEOS.INI file has been corrupted | amana24 | Hardware Equipments for GSM | 1 | 11-14-2001 11:04 |
Russian in SAGEM MC 922 - is probably? | Jurik | Infineon C16X M51 & ARM7 M52 BASED | 0 | 08-05-2000 01:03 |
