11-08-2015, 22:29 | #46 (permalink) | |
No Life Poster Join Date: Jun 2007 Location: Gampaha, Srilanka
Member: 527534 Status: Offline Sonork: 100.1606510 Thanks Meter: 193 | Quote:
11-08-2015, 23:23 | #47 (permalink) |
Member: 527534 Status: Offline Sonork: 100.1606510 Thanks Meter: 193 | I am stuck here.... Can I write factory firmware on this? or Can I write another boot file? Confused.... Need help to proceed this with Toshiba EMMC |
01-12-2016, 21:32 | #51 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | All YOU are very Lazy only for Read from First post? have all inside this thread but of course want all in front you eyes or anybody repeating samethings writed in this thread.....as always remain waiting w/o move a little. With Regards allumts |
01-13-2016, 13:38 | #52 (permalink) |
No Life Poster Join Date: Nov 2005 Location: morrocco
Member: 201359 Status: Offline Sonork: 100.1607870 Thanks Meter: 128 | cant detect emmc 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. ERROR: EMMC IS NOT Ready! (CMD1) Try to Adjust VCCIO Voltage CMD1 Reply: 0xFFFFFFFF Interface Reset OK! eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 2.6-2.7V 2.5-3.6V, 2.4-2.5V, 2.3-2.4V, 2.2-2.3V, 2.1-2.2V 2.0-2.1V, 1.9-2.0V, 1.8-1.9V, 1.7-1.8V, 1.65-1.7V 1.60-1.65V, 1.55-1.60V, 1.50-1.55V, 1.45-1.50V CID : FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF ERROR: EMMC_ALL_SEND_CID FAILED (CMD2) Check your Test Point Soldering! Try to Adjust VCCIO Voltage |
01-13-2016, 13:41 | #53 (permalink) |
Member: 201359 Status: Offline Sonork: 100.1607870 Thanks Meter: 128 | 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. ERROR: EMMC IS NOT Ready! (CMD1) Try to Adjust VCCIO Voltage CMD1 Reply: 0xFFFFFFFF Interface Reset OK! eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 2.6-2.7V 2.5-3.6V, 2.4-2.5V, 2.3-2.4V, 2.2-2.3V, 2.1-2.2V 2.0-2.1V, 1.9-2.0V, 1.8-1.9V, 1.7-1.8V, 1.65-1.7V 1.60-1.65V, 1.55-1.60V, 1.50-1.55V, 1.45-1.50V CID : FFFFFFFFFFFFFFFFFFFFFFFFFFFFF7FF (CRC7 Fail 0x6F) CSD : FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF ERROR: EMMC_SEND_EXT_CSD (CMD8) 0x01 Check GREEN Test Point Connection |
01-13-2016, 16:17 | #54 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | But what method are using?, are using Atf Light/Nitro with SmartGsm 4 in 1 adapter or what?, please show here photo of you connection pinout and voltage are using, for me you have Solder BAD wires or are using FAKE adapter...isn't detect how if not connected, post photo please NOTE: also w/o see any photo, can think you EMMC is broken. |
01-13-2016, 20:20 | #56 (permalink) | ||
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Wey, calm e quiet!!! Get in the trush this EMMC in this case, replace EMMC with new one. Quote:
09-03-2016, 13:57 | #59 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
Here can do only by ATF and W/O any JTAG activated, can try via EMMC direct, for Info about Pinout + Procedure + Video, read from first page the thread, not from last. Br allumts | |
09-23-2016, 10:40 | #60 (permalink) |
Member: 201359 Status: Offline Sonork: 100.1607870 Thanks Meter: 128 | ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 11010030303847453004D47055F51249 CSD : D05E00320F5903FFFFFFFFEF924000D3 eMMC Boot Information Revision 1.7 (for MMC v5.0, v5.01) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 4096 KB HC ERASE GROUP SIZE: 4096 KB USER AREA SIZE : 7818182656 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 4096 KB eMMC Device Information Manufacturer ID: TOSHIBA Device Type : Embedded BGA Application ID : 00 Product Name : 008GE0 Product Rev : 0.4 Product SN : D47055F5 Manufactured : January 1999 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 800 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 11010030303847453004D47055F51249.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ DETECTED BUT CANT REPAIRED |
