05-19-2015, 17:55 | #31 (permalink) |
No Life Poster Join Date: May 2003
Member: 28819 Status: Offline Thanks Meter: 222 | ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 45010053454D303847900D9117E07131 CSD : D00F00320F5903FFFFFFFFFF92404011 eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : BOOT PARTITION 1 PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : ENABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3072 KB HC ERASE GROUP SIZE: 4096 KB USER AREA SIZE : 7818182656 BYTES BOOT PARTITION SIZE: 2048 KB RPMB PARTITION SIZE: 128 KB eMMC Device Information Manufacturer ID: SANDISK Device Type : Embedded BGA Application ID : 00 Product Name : SEM08G Product Rev : 9.0 Product SN : 0D9117E0 Manufactured : January 1998 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 3 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 45010053454D303847900D9117E07131.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ |
06-13-2015, 15:36 | #33 (permalink) |
Junior Member Join Date: Nov 2014
Member: 2287364 Status: Offline Sonork: amd Thanks Meter: 2 | hi any body have boot file for toshiba emmc i try this files with sandisk and its worked and same files for toshiba not worked emmc was detected by atf thanks every body for your help |
The Following User Says Thank You to ahmedqabbara1 For This Useful Post: |
06-14-2015, 11:08 | #36 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
BR allumts | |
06-21-2015, 00:16 | #37 (permalink) |
Junior Member Join Date: Sep 2010
Member: 1389697 Status: Offline Thanks Meter: 0 | hello everyone? I'm new be here, I'm not a cellphone technician, new be also in world of android, but I am electronics hobbies through only my experience. i have Samsung gt-i8200 and I rooted it before then I decided to flash it using Odin and my phone never boot up again after successfully flashing. maybe that's the big mistake of mine is to attempt to root and flash my phone where is in under warranty, or maybe the firmware that I've flash is not compatible in my unit. now my unit is totally dead, bottom combi not works at all, PC even not recognized the unit. technician said it's dead boot and the only solution is JTAG but they haven't this kind of service. I don't have any idea to fix it back in life, I don't have any programmer besides Odin. is there any unexpensive way to fix this kind of hard brick phone? or any other step by step methods besides having ATF? have greatly appreciate your any kinds of help, best regards. |
06-21-2015, 14:33 | #38 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Hi, Change technician if this one haven't one ATF or any JTAG box. No other way FREE for repair this phone, if is only SW bricked. BR allumts |
The Following User Says Thank You to allumts For This Useful Post: |
06-21-2015, 21:36 | #39 (permalink) |
Member: 1389697 Status: Offline Thanks Meter: 0 | allumts, thanks for the reply, may change tech but they said last time my phone did not recognize with atf,. maybe JTAG is the only solution but in my local area there's nothing JTAG services. worries, there's no way. |
06-22-2015, 11:08 | #40 (permalink) | ||
And not for last Why you write here this: Quote:
BR allumts | ||
06-22-2015, 15:23 | #41 (permalink) |
Member: 1389697 Status: Offline Thanks Meter: 0 | sir allumts, you don't see any logs nor screen shots that what atf 's done because I haven't atf yet. as I mentioned above, that is done by my colleague technician as they said my phone did not recognized by their atf. I don't know what kinds of connection they have done, probably they don't know how to repair emmc as what other user have done with here.......Why I wrote it here? I'm searching for any alternative solution to fix my phone that does not use any boxes I haven't yet. but as mention above, at the moment there's no way to fix this kind of phone rather than to directly emmc program procedure. maybe sometime or sooner I have to purchase any of the boxes that support my phone, and I do it for myself. i preserve what I've learned in this thread, thanks a lot..... |
06-22-2015, 15:57 | #42 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Ok, change "Technician" and purchase Atf if you want repair this phone... For other info post in Samsung General section, this is only for Atf User. BR allumts |
08-26-2015, 13:43 | #43 (permalink) |
No Life Poster Join Date: Mar 2008 Location: FOCSANI Age: 39
Member: 718470 Status: Offline Thanks Meter: 79 | If I can please the picture instead of wires to specify what colors are ... 1V8 GND CLK CMD ? I gpg 5-1 ATF adapter and connections are not color are called CLK , CMD 1v8 , 3v3 please help me with the description |
08-29-2015, 23:39 | #45 (permalink) |
Freak Poster Join Date: Jan 2008 Location: phone care
Member: 667941 Status: Offline Sonork: 100.1611812 Thanks Meter: 61 | tnx for good information brother....just want to know is there any problem if i use that same fbus cable that i make before to repair boot nokia x.xl and i repair many device with that cable.or i need any another adopter to repair this device because with that cable i try to connect but its not i use two power supply one for 1.8 and another 3.3 but its not detect any adapter should i use or i can use that normal cable...... |
