12-19-2014, 18:19 | #5071 (permalink) |
Insane Poster Join Date: Dec 2013
Member: 2090537 Status: Offline Sonork: 100.1654781 Thanks Meter: 11 | |
12-21-2014, 00:08 | #5072 (permalink) |
Major Poster Join Date: Feb 2007 Location: Sweden
Member: 454895 Status: Offline Thanks Meter: 0 | i have iphone 4. after changing new screen and back. the network signals are very low. only one signal shows. i changed antena from other iphone but same problem. and vibration is also not working after change screen and back. please tell me what to do |
12-26-2014, 01:45 | #5077 (permalink) |
Junior Member Join Date: Nov 2013
Member: 2065461 Status: Offline Thanks Meter: 0 | hey, i have a question about an iphone 5 that i own , the battery is draining fast (from 100 to 0% in less than 2 hours ) but its charging via usb . once the iphone is off ( when it reach 0%) i can't get it to boot on usb and charger . unless i remove the battery and charge it on another iphone then put it back . is it because of the u2 ic chip ?? or something else? thank you . |
12-26-2014, 09:28 | #5078 (permalink) |
Freak Poster Join Date: Jul 2007
Member: 545565 Status: Offline Thanks Meter: 19 | First change battery & check. Don't go directly to change any chip or IC. Because there are problems with iphone 5 batteries so company itself gives free replacement of iphone 5 battery, weather phone is out of warranty. Sent from my iPhone using Tapatalk |
The Following User Says Thank You to r2rajput For This Useful Post: |
12-27-2014, 02:04 | #5081 (permalink) |
Member: 2065461 Status: Offline Thanks Meter: 0 | i ve already charged the battery after putting it in another iphone 5 , even changed it with a full charged battery (the second battery is working fine on another iphone 5) , but still the same problem of power drain and no response (if the battery is totaly drained and the iphone is off it wont boot after plug in the charger ) . |
12-27-2014, 23:31 | #5083 (permalink) |
Junior Member Join Date: Nov 2014
Member: 2299252 Status: Offline Thanks Meter: 0 | Hi guys I have a problem with my iphone 4s 1. I have DFU loop and I can't exit this mode, I tried exit with tiny umbrella but I can use only fix recovery button but nothing happen 2. when I want to restore by itunes process stop at "waiting for iphone" and nothing for few hours, after disconnecting usb cable from PC itunes show error 9 I tried on different PC, cables, operating systems all the time "waiting for iphone" status battery is not orginal but is full charged any help? thx and sorry for my "english" |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
