10-15-2012, 15:31 | #3571 (permalink) |
Junior Member Join Date: Jan 2008
Member: 671983 Status: Offline Thanks Meter: 0 | |
10-15-2012, 20:03 | #3572 (permalink) |
Freak Poster Join Date: Jan 2011 Location: Serbia
Member: 1494989 Status: Offline Thanks Meter: 2 | Hi, I have problem with iPhone 3gs. iPhone is simfree, and I instal ios6, but after 15 minits he going in recovery mode. I trying install firmware again, but itunes stoped on "Waiting for iphone" when unplug usb iTunes show error 9 ... Any solution??? I think this is hardware problem ! |
10-15-2012, 20:03 | #3573 (permalink) |
10-19-2012, 00:22 | #3574 (permalink) |
Junior Member Join Date: Dec 2011
Member: 1706932 Status: Offline Sonork: special-cell Thanks Meter: 0 | plz help i have an iphone 4g on baseband 3.10 and i try to software it on the new redsnow to prevent the base band but it dosent work .my iphone was stuck and i need to make an software ios 6 but leave the baseband on 3.10 !!!!plzzz reply quikly |
10-19-2012, 09:18 | #3575 (permalink) |
Junior Member Join Date: Dec 2005
Member: 213271 Status: Offline Thanks Meter: 0 | iphone 4 water damage freezing Hi i have an iphone 4 running slow and freezing after water damage. Clean pcb, rehot crystal palms no luck olso problem on back camera. What can i do more please help. Thenks!! |
10-20-2012, 08:25 | #3577 (permalink) |
Freak Poster Join Date: Mar 2006 Location: INDIA
Member: 239707 Status: Offline Thanks Meter: 14 | how do I check phone is factory unlocked or not? Iphone 4, 01.59.00, ios 5.0.1 jb and ultrasnow unlocked. IMEI: 012419007722125 Carrier : Optus -AUS Let me help. Thanks in advance |
10-20-2012, 09:10 | #3578 (permalink) |
Junior Member Join Date: Oct 2011
Member: 1668596 Status: Offline Thanks Meter: 0 | hi.i have a 3gs and all the time restarts. I see a short-circuit in the U25RF chip in the big capacitor. Whats the problem? I change the capacitor but i have the same problem. Also 2 resistors are missing. If i make a short-circuit it will be dangers for the motherboard??? |
10-21-2012, 00:05 | #3579 (permalink) |
Junior Member Join Date: Feb 2012 Location: USA>Texas>Fort Worth
Member: 1723140 Status: Offline Sonork: --------- Thanks Meter: 1 | ipod touch problems. i have an ipod touch 3G 8 GB (so basically 2G) one is stuck on charging screen, the other is having no touch screen (logic board problem not the digitizer) also i have an ipod touch 4G with the camera shutter wont open (not a camera problem) i know ipod touches are fragile in a weird way. what do i need to look at? all the logic boards appear to be fine, nothing out of the ordinary. ive done hard resets and restores on all with no results. iver replaces digitizers, cameras, and batterys and got no results. and again ive taken a close look at the logic boards but none seem to show any signs of damage. |
10-21-2012, 00:50 | #3580 (permalink) |
Junior Member Join Date: Oct 2012
Member: 1828232 Status: Offline Sonork: iphone 3g Thanks Meter: 0 | Hi. Not whether to appear and my English is bad (use google translator). My iPhone 3G jailbreak I did everything right and it worked for 2 months and I want to update reboot and since then I get the error 9 and 1611. I tried to jailbreak again, update and nothing ... Here a video trying to fix it but it's always the same: Any help please? Thanks |
10-21-2012, 15:47 | #3581 (permalink) |
Junior Member Join Date: Sep 2006
Member: 346116 Status: Offline Thanks Meter: 0 | sir, iphone4s only show connect to iTunes. need help pls... already try update and restore. still no luck, all connector and battery good. still connect to iTunes... thanks... br. |
10-21-2012, 22:40 | #3582 (permalink) |
Member: 1827228 Status: Offline Thanks Meter: 1 | Hello, Have a 3G which had dim backlight but worked, Then it got stuck on apple logo, tried restoring few times, then it gave me 1015 error so i exited recover, opened the phone again put back together and now nothing. Phone is dead, battery has lots of power left but it doesn't switch on, doesn't show in itunes, doesn't light up. I was wondering what the best option was first, what should I check voltages, how can I check the battery is making proper contact to the logic board and even so wouldn't it show up in itunes without battery detected? Also if the dock connector is faulty wouldn't it power on with the battery charged? Thanks in advance. |
10-22-2012, 02:43 | #3584 (permalink) |
Member: 1828732 Status: Offline Thanks Meter: 0 | Iphone 4 locked to AT&T, Unlocked Done but can't ACTIVATE? Action Taken: I tried Other PC, Activate with wifi, put AT&T Sim card and Other Sim but still can't activate. Always the same error! |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
