12-08-2011, 19:26 | #2071 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Moldova,Chisinau. Age: 38
Member: 1017374 Status: Offline Thanks Meter: 2,595 | Quote:
12-08-2011, 20:05 | #2072 (permalink) | |
No Life Poster Join Date: Dec 2009 Location: Malta Age: 36
Member: 1176031 Status: Offline Thanks Meter: 62 | Quote:
Attachment 1: Different Resistors on Back Side (x10 zoom) Attachment 2: How does the screen look when powered on Attachment 3: LCD Connector 1 Attachment 4: L12 Inductor Changed Attachment 5: Mainboard BackSide This is a new bootrom mainboard. Does it need a different LCD maybe? I also kept contact with the seller (who sold me this iphone) and told me that just before he packaged it he tested with his brand new LCD and it worked. Maybe he has a different version from mine? | |
12-08-2011, 20:58 | #2073 (permalink) | |
I remember someone posted a board like your and he told there wasn't this resistor. I don't think the problem is LCD,tell him to send that LCD to you. Also how you attach photos directly to forum because it give me error when i try? | |
12-08-2011, 21:10 | #2074 (permalink) | |
For images make sure each image is less than 200KB in size But the 66.6K is there on both boards I am more worried about the other resistors marked in the photo previously I showed you And which resistor are you referring to the 66.6k? | |
12-08-2011, 21:41 | #2076 (permalink) |
Junior Member Join Date: Dec 2011
Member: 1702322 Status: Offline Thanks Meter: 1 | Iphone 4 'not charging' I have a water damage iphone, first problem is that there is 0 Ohm between battery socket + and -, i think i don't have to say it turns on only on charger. The second problem, a man in a service tried DFU and recovery but without the battery... It's stuck in revovery btw until the emergency call window showed up it said there is no IMEI and couldn't find any service. How can i tell where is the short on the board? I put it on charger but every part was cold. This method works only with a source on the battery socket? And the basebend problem is because of the battery or i have to repair the battery problem then the IMEI problem too? Thanks! |
12-08-2011, 21:54 | #2077 (permalink) | |
I mean without resistor from bottom near GND check with multimeter and unsolder it. I tried to upload 3KB image same error. I even ask some moderators no response. I think it is disabled for me to upload photos,there also i read in FAQ that a member can create Albums with Photos there must be link in User CP but no such link available. | |
12-08-2011, 22:32 | #2079 (permalink) | |
12-08-2011, 23:32 | #2083 (permalink) |
Freak Poster Join Date: Jun 2011 Location: Lithuania Age: 34
Member: 1593210 Status: Offline Thanks Meter: 1 | Guys did you remember my iphone 3gs with camera problem? I unsolder this piece and now my camera wont open anymore, I did only one jumper, instead 4, cause i'm not able they are to small for me, I don't have such of tools do this job,, |
12-08-2011, 23:36 | #2084 (permalink) | |
Try solder that filter back. 4 track must be separated. | |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
