07-23-2014, 16:29 | #19576 (permalink) |
No Life Poster Join Date: Oct 2010 Location: INDIA (WEST BENGAL)
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | Rm-704---- Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm704__03.82.mcusw PPM : rm704__03.82.ppm_r CNT : rm704__03.82_001.image_r_ctv_cn_9m2k5 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.44_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 352409055059320 IMEI 2 : 352409055059338 PCcode : 059N4J7 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\352409055059320_2n d_XG213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm704__03.82.mcusw Image : rm704__03.82.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:05 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01940000 Erasing, wait ... Erase done, time : 00:02:21 Write , Start : 0x40280000 , Len : 0x018C0000 Flashing , wait ... Region flash done, time : 00:00:38 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xE70B ===Flashing [PPM]=== File : rm704__03.82.ppm_r Image : package_r.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41BC0000 , Len : 0x00600000 Erasing, wait ... Erase done, time : 00:00:23 Write , Start : 0x41BC0000 , Len : 0x003EEA60 Flashing , wait ... Region flash done, time : 00:00:04 CRC check passed , 0xD711 ===Flashing [CNT]=== File : rm704__03.82_001.image_r_ctv_cn_9m2k5 Image : /1WORKAREAS40/Project_Snapshot/rm-704/rm704_sw_settings/temp/ Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x424C0000 , Len : 0x01960000 Erasing, wait ... Erase done, time : 00:03:38 Write , Start : 0x424C0000 , Len : 0x00B60000 Flashing , wait ... Region flash done, time : 00:00:17 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:07 No write data, skip CRC check passed , 0x012F Flashing done! Total flash time : 00:07:41 Reboot phone now... Reading Phone Info.... Connected phone - C2-00 Software Info: V 03.82 17-10-11 RM-704 (c) Nokia IMEI: 352409055059320 PPM version : V 03.82 17-10-11 RM-704 (c) Nokia R Product code: 059M2K5 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Resetting LifeTimer Reset Done! Check and Upload User Certificates ... Total - 42 certs Certificates found, skip upload ... Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! |
07-23-2014, 16:31 | #19577 (permalink) |
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | Rm-618 registered to: PAUL-TELECOM Connect phone on selected interface... Core : v1.92 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm618__08.35.mcusw PPM : rm618__08.35.ppm_mh CNT : rm618__08.35.image_mh_0595236 Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000000000000022000509200C0000 CPU ID : BroadCom 21351 , Features : Dead-Test, USBRPL, FullUSB EM0 ID: 00005361 PUBLIC ID: 0000000000280855330A2398D618DC9BAD44989A ASIC MODE ID: 00 ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E ROM ID: DE56D582BDDE7A3A Use BCM21351_usb2nd.fg , Rev : 2.1 Ver : 12.8.0 Processing RAWLOADER... FLIC : 003000EC Req : XSR 1.6 Use BCM21351_XSR16_usbalg.fg , Rev : 2.1 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : E9700989029D9E899915F781B1582048E042A738 ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 357898048085811 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\357898048085811_CR T_2nd.rpl === SW Version Check === - > REFLASHING === SW Version Check === ===Flashing [MCU]=== Erase : Processing rm618__08.35.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm618__08.35.mcusw CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [ISA+DYNSW] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [UPDAPP] Total writen 511 blocks TIME : Write time : 00:00:05 MCU Write done ADL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ===Flashing [PPM]=== Erase : Processing rm618__08.35.ppm_mh Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm618__08.35.ppm_mh Total writen 117 blocks TIME : Write time : 00:00:01 PPM Write done ADL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ===Flashing [CNT]=== Erase : Processing rm618__08.35.image_mh_0595236 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm618__08.35.image_mh_0595236 Total writen 378 blocks TIME : Write time : 00:00:04 CNT Write done ADL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ADL: Close_Session Content: 000300000000030000000300000000 ADL: Reboot Flashing done! Total flash time : 00:00:12 Reboot phone now... Reading Phone Info.... Connected phone - Nokia X2-00 Software Info: V 08.35 09-01-12 RM-618 (c) Nokia IMEI: 357898048085811 PPM version : V 08.35 09-01-12 RM-618 (c) Nokia MH Product code: 059F8G7 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Resetting LifeTimer Reset Done! Check and Upload User Certificates ... Total - 39 certs Certificates found, skip upload ... Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:02:02 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
07-23-2014, 16:34 | #19578 (permalink) |
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | Rm-704- registered to: PAUL-TELECOM Connect phone on selected interface... Core : v1.92 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm704__03.82.mcusw PPM : rm704__03.82.ppm_r CNT : rm704__03.82_001.image_r_ctv_cn_9m2k5 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.44_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 352409055059320 IMEI 2 : 352409055059338 PCcode : 059N4J7 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\352409055059320_XG 213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm704__03.82.mcusw Image : rm704__03.82.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:05 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01940000 Erasing, wait ... Erase done, time : 00:02:13 Write , Start : 0x40280000 , Len : 0x018C0000 Flashing , wait ... Region flash done, time : 00:00:41 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xE70B ===Flashing [PPM]=== File : rm704__03.82.ppm_r Image : package_r.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41BC0000 , Len : 0x00600000 Erasing, wait ... Erase done, time : 00:00:20 Write , Start : 0x41BC0000 , Len : 0x003EEA60 Flashing , wait ... Region flash done, time : 00:00:05 CRC check passed , 0xD711 ===Flashing [CNT]=== File : rm704__03.82_001.image_r_ctv_cn_9m2k5 Image : /1WORKAREAS40/Project_Snapshot/rm-704/rm704_sw_settings/temp/ Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x424C0000 , Len : 0x01960000 Erasing, wait ... Erase done, time : 00:03:39 Write , Start : 0x424C0000 , Len : 0x00B60000 Flashing , wait ... Region flash done, time : 00:00:18 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:07 No write data, skip CRC check passed , 0x012F Flashing done! Total flash time : 00:07:35 Reboot phone now... Reading Phone Info.... Connected phone - C2-00 Software Info: V 03.82 17-10-11 RM-704 (c) Nokia IMEI: 352409055059320 PPM version : V 03.82 17-10-11 RM-704 (c) Nokia R Product code: 059N4J7 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Resetting LifeTimer Reset Done! Check and Upload User Certificates ... Total - 42 certs Certificates found, skip upload ... Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! |
07-23-2014, 16:35 | #19579 (permalink) |
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | Rm-625 registered to: PAUL-TELECOM Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Core : v1.92 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-625_51.1.002_prd.core.C00 PPM : RM-625_51.1.002_prd.rofs2.V21 PPM2 : RM-625_51.1.002_C01_prd.rofs3.fpsx CNT : RM625_51.1.002_000_001_U001.uda.fpsx Flashing phone now... [Gen] Rules accepted for : RAPIDO Generation Check files done... -> Check SW version... FlashFile version : 51.1.002 Phone version : V 51.1.002 -> Check SW version : Reflash Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok WMDRM read ... Ok SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\358614047830530_SI M.rpl Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101051105 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 064001191EBE005292BBF81020E4161B68456C3F ASIC MODE ID: 00 ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing RAP3NAND ... Processing PASUBTOC ... Processing PAPUBKEYS... Processing UPDAPP ... Boot Done! TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! RHASH : B8C3ADECFC997FCD8081D3DEAF870B8C RPAKeys : 7DC72D3FDC552426A4479BC820097D304CFB6C15 Pr.Code : 0594743 IMEI : 358614047830530 ADL : Auth done... === SW Version Check === - > REFLASHING or UPGRADE === SW Version Check === ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing RM-625_51.1.002_prd.core.C00 Found 5 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT Result: 0000 Erasing area 0x00400000 - 0x007FFFFF, NAND, CMT Result: 0000 Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT Result: 0000 Erasing area 0x00D60000 - 0x09E5FFFF, NAND, CMT Result: 0000 Erase partition 0x0A Partition erase Ok Partitioning : Ok [5] TIME : Erase time : 00:00:00 Write : Processing RM-625_51.1.002_prd.core.C00 Total 418 [418/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*ENO] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS+CORE] CMT : Writing Hash CERT [SOS+ROFS1] TIME : Write time : 00:00:30 MCU Write done ===Flashing [PPM]=== Erase : Processing RM-625_51.1.002_prd.rofs2.V21 Found 1 areas to erase Erasing area 0x06CE0000 - 0x0915FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-625_51.1.002_prd.rofs2.V21 Total 52 [52/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS2] TIME : Write time : 00:00:04 PPM Write done ===Flashing [PPM2]=== Erase : Processing RM-625_51.1.002_C01_prd.rofs3.fpsx Found 1 areas to erase Erasing area 0x09160000 - 0x09E5FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-625_51.1.002_C01_prd.rofs3.fpsx Total 28 [28/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS3] TIME : Write time : 00:00:02 PPM Write done ===Flashing [CNT]=== Erase : Processing RM625_51.1.002_000_001_U001.uda.fpsx Found 1 areas to erase Erasing area 0x09E60000 - 0x0F47FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM625_51.1.002_000_001_U001.uda.fpsx Total 69 [69/0/0] blocks to write, writing... TIME : Write time : 00:00:08 CNT Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:00:46 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5233 Software Info: V ICPR72_11w16.1 28-07-11 RM-625 (c) Nokia IMEI: 358614047830530 Ape Version: V 51.1.002 Product code: 0594743 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Resetting LifeTimer Reset Done! Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! |
07-23-2014, 16:37 | #19580 (permalink) |
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | Rm-625- registered to: PAUL-TELECOM Connect phone on selected interface... Core : v1.92 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-625_51.9.002_prd.core.C00 PPM : RM-625_51.9.002_prd.rofs2.V25 PPM2 : RM-625_51.9.002_C01_prd.rofs3.fpsx CNT : RM625_51.1.002_000_001_U002.uda.fpsx Flashing phone now... [Gen] Rules accepted for : RAPIDO Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101051105 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1AA0010AB0AC005235E2A061D8FED5F47FE731A6 ASIC MODE ID: 00 ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing RAP3NAND ... Processing PASUBTOC ... Processing PAPUBKEYS... Processing UPDAPP ... Boot Done! TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 Waiting for response: 28 Waiting for response: 27 Waiting for response: 26 Waiting for response: 25 Waiting for response: 24 Waiting for response: 23 Waiting for response: 22 Waiting for response: 21 ADL -> [2nd] changing... ADL Server confirm flashmode! RHASH : B8C3ADECFC997FCD8081D3DEAF870B8C RPAKeys : 7DC72D3FDC552426A4479BC820097D304CFB6C15 Pr.Code : 0594743 IMEI : 356264042595373 ADL : Auth done... === SW Version Check === - > DOWNGRADE DETECTED!!! - > Download latest Flash Files version and try again! - > Stop killing phone, break flashing! === SW Version Check === ================= ADL : End flashing ADL : Finalize... Elapsed: 00:00:38 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Core : v1.92 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-625_51.1.002_prd.core.C00 PPM : RM-625_51.1.002_prd.rofs2.V21 PPM2 : RM-625_51.1.002_C01_prd.rofs3.fpsx CNT : RM625_51.1.002_000_001_U001.uda.fpsx Flashing phone now... [Gen] Rules accepted for : RAPIDO Generation Check files done... -> Check SW version... FlashFile version : 51.1.002 Phone version : V 51.1.002 -> Check SW version : Reflash Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok WMDRM read ... Ok SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\356264042595373_SI M.rpl Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Batery valtage : 3655 mV -> Batery voltage less, than 3,8V (3655mV). Continue at user risk Reboot.... Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101051105 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1AA0010AB0AC005235E2A061D8FED5F47FE731A6 ASIC MODE ID: 00 ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing RAP3NAND ... Processing PASUBTOC ... Processing PAPUBKEYS... Processing UPDAPP ... Boot Done! TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! RHASH : B8C3ADECFC997FCD8081D3DEAF870B8C RPAKeys : 7DC72D3FDC552426A4479BC820097D304CFB6C15 Pr.Code : 0594743 IMEI : 356264042595373 ADL : Auth done... === SW Version Check === - > REFLASHING or UPGRADE === SW Version Check === ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing RM-625_51.1.002_prd.core.C00 Found 5 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT Result: 0000 Erasing area 0x00400000 - 0x007FFFFF, NAND, CMT Result: 0000 Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT Result: 0000 Erasing area 0x00D60000 - 0x09E5FFFF, NAND, CMT Result: 0000 Erase partition 0x0A Partition erase Ok Partitioning : Ok [5] TIME : Erase time : 00:00:00 Write : Processing RM-625_51.1.002_prd.core.C00 Total 418 [418/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*ENO] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS+CORE] CMT : Writing Hash CERT [SOS+ROFS1] TIME : Write time : 00:00:30 MCU Write done ===Flashing [PPM]=== Erase : Processing RM-625_51.1.002_prd.rofs2.V21 Found 1 areas to erase Erasing area 0x06CE0000 - 0x0915FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-625_51.1.002_prd.rofs2.V21 Total 52 [52/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS2] TIME : Write time : 00:00:03 PPM Write done ===Flashing [PPM2]=== Erase : Processing RM-625_51.1.002_C01_prd.rofs3.fpsx Found 1 areas to erase Erasing area 0x09160000 - 0x09E5FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-625_51.1.002_C01_prd.rofs3.fpsx Total 28 [28/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS3] TIME : Write time : 00:00:02 PPM Write done ===Flashing [CNT]=== Erase : Processing RM625_51.1.002_000_001_U001.uda.fpsx Found 1 areas to erase Erasing area 0x09E60000 - 0x0F47FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM625_51.1.002_000_001_U001.uda.fpsx Total 69 [69/0/0] blocks to write, writing... TIME : Write time : 00:00:08 CNT Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:00:46 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5233 Software Info: V ICPR72_11w16.1 28-07-11 RM-625 (c) Nokia IMEI: 356264042595373 Ape Version: V 51.1.002 Product code: 0594743 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Resetting LifeTimer Reset Done! Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:01:25 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
07-23-2014, 16:39 | #19581 (permalink) |
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | Rm-813 registered to: PAUL-TELECOM Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Check and Fix DataPackage... Error while fixing files! Run BEST as Admin (right click on BEST.exe - Run as Admin) Found files to fix : 13 Fixed files : 7 Done IDM initializing, wait... Checking access to Products folder... Folder for RM-813 not exist. Attempt to create Prepare done, collect info [Query] : rm813__15.09.mcusw , 31.87 MB [Query] : RM813_059K804_15.09_036.vpl , 3.63 KB [Query] : rm813__15.09.image_mh1_059K804 , 27.67 MB [Query] : rm813__15.09.ppm_mh1 , 6.25 MB Files to download : 4 Total size to download : 65.79 MB Downloading now, please, wait... [Download] : rm813__15.09.mcusw [Download] : RM813_059K804_15.09_036.vpl [Download] : rm813__15.09.image_mh1_059K804 [Download] : rm813__15.09.ppm_mh1 Verify files now ..... [Verify Ok] : rm813__15.09.mcusw [Verify Ok] : rm813__15.09.ppm_mh1 [Verify Ok] : rm813__15.09.image_mh1_059K804 All done, all files were downloaded! Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Core : v1.92 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm813__15.09.mcusw PPM : rm813__15.09.ppm_mh1 CNT : rm813__15.09.image_mh1_059K804 Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> Check SW version... FlashFile version : 15.09 Phone version : 14.78 31-08-12 RM-813 (c) Nokia -> Check SW version : Upgrade Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok WMDRM read ... Ok Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001051 EM1 ID: 00001060 PUBLIC ID: 1E3D0000FFFB7C40D913A0AFE07EC4E993CF567B ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 00400020 Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : 05BDE0ECC36CDEAA016A0565CB6BAE0B1585232E ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 354622051671595 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\354622051671595.rp l === SW Version Check === - > UPGRADE === SW Version Check === ===Flashing [MCU]=== Erase : Processing rm813__15.09.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm813__15.09.mcusw CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [ISA+DYNSW] CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [ISA+EXTDRV] Total writen 274 blocks TIME : Write time : 00:00:05 MCU Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [PPM]=== Erase : Processing rm813__15.09.ppm_mh1 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm813__15.09.ppm_mh1 Total writen 51 blocks TIME : Write time : 00:00:01 PPM Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [CNT]=== Erase : Processing rm813__15.09.image_mh1_059K804 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:02 Write : Processing rm813__15.09.image_mh1_059K804 Total writen 222 blocks TIME : Write time : 00:00:03 CNT Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Flashing done! Total flash time : 00:00:12 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 302 Software Info: V 15.09 22-05-13 RM-813 (c) Nokia IMEI: 354622051671595 PPM version : V 15.09 22-05-13 RM-813 (c) Nokia MH1 Product code: 059K805 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Resetting LifeTimer Reset Done! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:00:55 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
07-23-2014, 16:41 | #19582 (permalink) |
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | rm694_ registered to: PAUL-TELECOM Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Core : v1.92 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm694__12.04.mcusw PPM : rm694__12.04.ppm_mh CNT : rm694__12.04.image_mh_059D1Q7 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> Check SW version... FlashFile version : 12.04 Phone version : 12.04 20-05-13 RM-694 (c) Nokia -> Check SW version : Reflash Backup CRT308 data... CRT308 Backup Created Check communication with phone.... ADL req restart Communication verify done... Preparing... Check communication with phone... SL3 Simlock read (XGOLD) ... Ok WMDRM Key read ... Ok Reboot.... -> If Phone start charge - just reinsert battery fast Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.46_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 352430051658261 IMEI 2 : 352430051658279 PCcode : 059N1T6 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\352430051658261_XG 213.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm694__12.04.mcusw Image : rm694__12.04.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:06 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01980000 Erasing, wait ... Erase done, time : 00:02:21 Write , Start : 0x40280000 , Len : 0x01900000 Flashing , wait ... Region flash done, time : 00:00:39 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0x7B07 ===Flashing [PPM]=== File : rm694__12.04.ppm_mh Image : package_mh.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41C00000 , Len : 0x00700000 Erasing, wait ... Erase done, time : 00:00:36 Write , Start : 0x41C00000 , Len : 0x005D9644 Flashing , wait ... Region flash done, time : 00:00:07 CRC check passed , 0x50D2 ===Flashing [CNT]=== File : rm694__12.04.image_mh_059D1Q7 Image : package_mh_059D1Q7.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42300000 , Len : 0x01B20000 Erasing, wait ... Erase done, time : 00:03:55 Write , Start : 0x42300000 , Len : 0x00F60000 Flashing , wait ... Region flash done, time : 00:00:26 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:07 No write data, skip CRC check passed , 0x78C8 Flashing done! Total flash time : 00:08:24 Reboot phone now... Reading Phone Info.... Connected phone - X2-02 Software Info: V 12.04 20-05-13 RM-694 (c) Nokia IMEI: 352430051658261 PPM version : V 12.04 20-05-13 RM-694 (c) Nokia MH Product code: 059D1Q7 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Resetting LifeTimer Check phone mode... Phone in Test mode Seting Local mode... wait... Local mode set Reset Done! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! |
07-23-2014, 16:43 | #19583 (permalink) |
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | Rm-618- registered to: PAUL-TELECOM Connect phone on selected interface... Core : v1.92 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm618__08.35.mcusw PPM : rm618__08.35.ppm_mh CNT : rm618__08.35.image_mh_0595236 Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000000000000022000509200C0000 CPU ID : BroadCom 21351 , Features : Dead-Test, USBRPL, FullUSB EM0 ID: 00005361 PUBLIC ID: 0000000000280855330A2398D618DC9BAD44989A ASIC MODE ID: 00 ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E ROM ID: DE56D582BDDE7A3A Use BCM21351_usb2nd.fg , Rev : 2.1 Ver : 12.8.0 Processing RAWLOADER... FLIC : 003000EC Req : XSR 1.6 Use BCM21351_XSR16_usbalg.fg , Rev : 2.1 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : E9700989029D9E899915F781B1582048E042A738 ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 357898048085811 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\357898048085811_CR T_2nd.rpl === SW Version Check === - > REFLASHING === SW Version Check === ===Flashing [MCU]=== Erase : Processing rm618__08.35.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm618__08.35.mcusw CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [ISA+DYNSW] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [UPDAPP] Total writen 511 blocks TIME : Write time : 00:00:05 MCU Write done ADL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ===Flashing [PPM]=== Erase : Processing rm618__08.35.ppm_mh Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm618__08.35.ppm_mh Total writen 117 blocks TIME : Write time : 00:00:01 PPM Write done ADL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ===Flashing [CNT]=== Erase : Processing rm618__08.35.image_mh_0595236 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm618__08.35.image_mh_0595236 Total writen 378 blocks TIME : Write time : 00:00:04 CNT Write done ADL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ADL: Close_Session Content: 000300000000030000000300000000 ADL: Reboot Flashing done! Total flash time : 00:00:13 Reboot phone now... - > AfterFlash Failed! Reason : Downgrade try or HW Error Anyway - try reinsert battery and PowerUp phone manualy Connect phone on selected interface... Done! |
07-23-2014, 16:44 | #19584 (permalink) |
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | Rm-618-- card found: S/N registered to: PAUL-TELECOM Connect phone on selected interface... Core : v1.92 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm618__08.35.mcusw PPM : rm618__08.35.ppm_mh CNT : rm618__08.35.image_mh_0595236 Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000000000000022000509200C0000 CPU ID : BroadCom 21351 , Features : Dead-Test, USBRPL, FullUSB EM0 ID: 00005361 PUBLIC ID: 0000000000280855330A2398D618DC9BAD44989A ASIC MODE ID: 00 ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E ROM ID: DE56D582BDDE7A3A Use BCM21351_usb2nd.fg , Rev : 2.1 Ver : 12.8.0 Processing RAWLOADER... FLIC : 003000EC Req : XSR 1.6 Use BCM21351_XSR16_usbalg.fg , Rev : 2.1 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : E9700989029D9E899915F781B1582048E042A738 ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 357898048085811 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\357898048085811_CR T.rpl === SW Version Check === - > UPGRADE === SW Version Check === ===Flashing [MCU]=== Erase : Processing rm618__08.35.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm618__08.35.mcusw CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [ISA+DYNSW] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [UPDAPP] Total writen 511 blocks TIME : Write time : 00:00:05 MCU Write done ADL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ===Flashing [PPM]=== Erase : Processing rm618__08.35.ppm_mh Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm618__08.35.ppm_mh Total writen 117 blocks TIME : Write time : 00:00:01 PPM Write done ADL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ===Flashing [CNT]=== Erase : Processing rm618__08.35.image_mh_0595236 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm618__08.35.image_mh_0595236 Total writen 378 blocks TIME : Write time : 00:00:04 CNT Write done ADL: Request programm status NAND status : 00000003 / 00000003 / 00000000 ADL: Close_Session Content: 000300000000030000000300000000 ADL: Reboot Flashing done! Total flash time : 00:00:13 Reboot phone now... -------AFTER FLASH BREAKED BY USER------- - > AfterFlash Failed! Reason : Downgrade try or HW Error Anyway - try reinsert battery and PowerUp phone manualy Connect phone on selected interface... Done! Elapsed: 00:02:37 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Resetting selected items... Check phone mode... Phone in Normal mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:01:11 Phone disconected! |
07-25-2014, 07:44 | #19585 (permalink) |
No Life Poster Join Date: Apr 2008 Location: India
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Chinese Miracle-2 (Release) Reports: RDA/Coolsand Geotel S9300 Code: Operation : Format File System Settings : SmartFormat is On Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 880A , rev : 7002 CPU_CN : CoolSand CT , RDA8853B ==== FLASH FL_VEN : 60C8 , rev : 1800 FL_CNM : GigaDevice , GD25Q128 FL_CAP : 01000000 ==== Booting Sending RamRun Loader... Set : 880A , 01000000 Use : 880A_01000000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! NVMFAT Area : 0x00E00000 , Len : 0x001FC000 Recalculate Format Range Format User Area ... CSD WR : 81C056FC , 81C05710 CSD DR : A0000000 , A0008000 , A0010000 CSD MB : 00008000 Format Done Elapsed: 00:04:38 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to VIJAY2U2 For This Useful Post: |
07-26-2014, 14:05 | #19586 (permalink) |
Product Supporter Join Date: Jul 2011 Location: ISLAMIC & INDIA WITH MIRACLE T Age: 37
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Lg 3610 unlock COM104 [LGSIDIAG1] selected module v2.04 Device: LG-3610 operation: SP-unlock Phone should be Switched ON ! connecting... OFFLINE... sending boot... sending command... patching in progress... patching in progress 50%... patching in progress 100%... Done... Phones should be restarting now... Finished, time used: 24 sec |
The Following User Says Thank You to .::THE ROCK::. For This Useful Post: |
07-27-2014, 08:27 | #19587 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Asha 205 Read Code Done :) Code: Connect phone on selected interface... Backup Certificates now... Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF EBL Loader : Custom Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL : Custom EBL sent Ok EBL : Quantum_Bootloader_10.56_M1S1 Boot done! Read CRT block... Read EEPROM block... SL3 Simlock found (XGOLD) ... WMDRM Key found ... CMLA Key found ... ===== USER CODE ===== Executing Code extraction... - > Phone Lock Code : 80991 ===== USER CODE ===== MMC password not found (not set) NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... CMLA_KEY Data saved... RPL saved : F:\Flashing Softwares\12+Best dongle\InfinityBox\BEST\Backup\Cert\355947054xx_XG213.rpl Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
07-27-2014, 08:29 | #19588 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | 101 Factory Reset DOne :) Via Jaf Interface Code: Opening Connection... Device Location: 00000032 Connect Ok! Initializing Connection... JAF Firmware: 01.B4 Authentificate JAF BOX... TEA Authentication Completed... JAF S/N ODJAF000 boot - Ok Switch jaf to FBUS... FbusMode set Ok Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... SW ver : V 07.70 18-10-12 RM-769 (c) Nokia IMEI : 359752041538847 PPM : V 07.70 18-10-12 RM-769 (c) Nokia IJ PCode : 059G7N6 BPCode : 059F6L6 HWID : 1000 LCDVer : WIN:BOHAIv93 NT39121 IMEI : 359752041538847 Sl Conf : 001-01-00000000000 Sl Prof : 000000000004000-2 Sl Aux : 000B0000 Hw Sig : 49EBEEB88E669CF1 Country : Test SIM (Open) Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Done! Resetting selected items... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:09 |
07-27-2014, 09:35 | #19589 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | BY2 K8802 Code: Operation : Format File System Settings : SmartFormat is On Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 880A , rev : 7002 CPU_CN : CoolSand CT , RDA8853B ==== FLASH FL_VEN : 40C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 ==== Booting Sending RamRun Loader... Set : 880A , 00400000 Use : 880A_00400000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! NVMFAT Area : 0x003A0000 , Len : 0x0005C000 Range as Factory Defined Format User Area ... CSD WR : 81C056FC , 81C05710 CSD DR : A0000000 , A0008000 , A0010000 CSD MB : 00008000 Format Done Elapsed: 00:01:14 Reconnect Power/Cable! |
07-27-2014, 16:17 | #19590 (permalink) |
Junior Member Join Date: Feb 2011
Member: 1510003 Status: Offline Thanks Meter: 1 | >>> Getting Mobile Connection Info... VCC Pin: GND Pin:5, Signal Pin:1, 2, 3, 4, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 HardWare:VID:17_82 PID:4D_00 This is a Spreadtrun chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM53 Driver Name->>>SPRD U2S Diag >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.1 >>> Downloading Second Boot... Baud Rate is Switched To:921600 Flash ID:00002CBC Flash Size:20000000->512M Flash Name:NAND_SamSungMT29C4G48MAZAPAKD CPU Name:6820/8810 >>> Auto Formatting ... Format_RuntimeNV...Fail. Format_Cache...Fail. Format_Misc...Fail. Format_UserData...Success. All Done... |
