Old 07-06-2020, 09:09   #166 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
Originally Posted by talebamine8 View Post
Can you please explain how to remove passcode from oppo with ufs strorage like cph1937 a9 2020 after chip off?
Try to use "Reset Oppo" at UFS-> "Android" page of EasyJTAG Classic software
The Following User Says Thank You to layder For This Useful Post:
Old 07-09-2020, 23:57   #167 (permalink)
Member: 65061
Thanks Meter: 30
What about test points in board can you tell us more information about that I see some videos doing the process on samsung a50 without chip off
Old 07-12-2020, 22:12   #168 (permalink)
Member: 65061
Thanks Meter: 30
Hello guys i disassembly oppo find neo x2 and inside is ufs chip km8f8001mm is supported ?
Old 07-16-2020, 17:53   #169 (permalink)
MOORC's Avatar
Member: 1737647
Sonork: 100.1645466
Thanks Meter: 278
EMMC 13in1
https://moorc.com/emmc-131-p00082p1.html
UFS 2in1
https://moorc.com/ufs-2-1-p00080p1.html
从我的 iPhone 发送,使用 Tapatalk
Old 07-20-2020, 13:57   #170 (permalink)
Member: 1140831
Sonork: no
Thanks Meter: 232
oppo cph 1907 reno 2 how to unlock password plz help need isp pinout
Old 07-20-2020, 23:21   #171 (permalink)
Member: 65061
Thanks Meter: 30
Layder is this pinout correct?
TXD0P = DIN0T
TXD0N= DIN0C
RXD0P= DOUT0T
RXD0N=DOUT0C
Thanks
The Following User Says Thank You to rikimaer For This Useful Post:
Old 07-21-2020, 20:26   #172 (permalink)
parsa_dig's Avatar
Member: 1265640
Sonork: 100.1622602
Thanks Meter: 51
PHP Code:
Z3X EasyJtag Software ver3.7.0.17
UFS Socket Info
Serial01239AC90AD8D4E9EE
Description
EasyJTAG UFS Socket BGA-153 by EasyJTAG 19.05.19
Can
't open link, Code: -56, Reason: BOX: Chip not connected
Done.
Z3X EasyJtag Software ver. 3.7.0.17
UFS Socket Info.
Serial: 01239AC90AD8D4E9EE
Description: EasyJTAG UFS Socket BGA-153 by EasyJTAG 19.05.19
Identify UFS Chip.
UFS Chip Voltage: Low
VCC: 3314mV
VCCQ2: 1818mV
Chip Info:
Manufacturer: SKHYNIX
ProductName: H28U74301AMR
SerialNumber: 0x059850EAB9E6
OemID: 01AD
Firmware Version: E.0.0.6
UFS Version: 2.1
Maximum Number of LUs: 8
Number of LUs found: 7
   LUN 0:
      Block size: 0x1000
      Size: 0xED3800000 / 59,312,000,000B / 59GB
   LUN 1 (Boot A):
      Block size: 0x1000
      Size: 0x1000000 / 0,016,000,000B / 16MB
   LUN 2 (Boot B):
      Block size: 0x1000
      Size: 0x800000 / 0,008,000,000B / 8MB
   LUN 3:
      Block size: 0x1000
   LUN 4:
      Block size: 0x1000
      Size: 0xE800000 / 0,232,000,000B / 232MB
   LUN 5:
      Block size: 0x1000
   LUN 6:
      Block size: 0x1000
Number of W-LUs found: 1
   W-LUN 0xC4 (REPORT LUNS):
      Block size: 0x100
Full size: 0xEE6800000 / 59,616,000,000B / 59GB
Health:
 Device life time method A: 0x02 (10%-20% device life time used)
 Device life time method B: 0x01 (0%-10% device life time used)
 Pre End of Life: 0x01 (Used less then 80% of reserved blocks)
Checking LU0 for partitioning
LUN0 Have 19 partitions
LUN1 Have 7 partitions
LUN2 Have 3 partitions
LUN3 Have 5 partitions
LUN4 Have 29 partitions
LUN5 Have 5 partitions
LUN6 Have 2 partitions
------ Detected 70 partitions ------
LUN0 (LAF) [0x6000 0x3000000] Size: 48.0MB
LUN0 (MPT) [0x3006000 0x2000000] Size: 32.0MB
LUN0 (DRM) [0x5006000 0xa00000] Size: 10.0MB
LUN0 (SNS) [0x5a06000 0x600000] Size: 6.0MB
LUN0 (MISC) [0x6006000 0x2000000] Size: 32.0MB
LUN0 (FACTORY) [0x8006000 0x4200000] Size: 66.0MB
LUN0 (ENCRYPT) [0xc206000 0x80000] Size: 512.0KB
LUN0 (EKSST) [0xc286000 0x80000] Size: 512.0KB
LUN0 (RCT) [0xc306000 0x80000] Size: 512.0KB
LUN0 (SSD) [0xc386000 0x80000] Size: 512.0KB
LUN0 (KEYSTORE) [0xc406000 0x80000] Size: 512.0KB
LUN0 (PERSIST) [0xc486000 0x2000000] Size: 32.0MB
LUN0 (LAFBAK) [0xe486000 0x3000000] Size: 48.0MB
LUN0 (SYSTEM) [0x11486000 0x15d800000] Size: 5.460GB
LUN0 (CACHE) [0x16ec86000 0x20000000] Size: 512.0MB
LUN0 (CUST) [0x18ec86000 0x5000000] Size: 80.0MB
LUN0 (OP) [0x193c86000 0x12c00000] Size: 300.0MB
LUN0 (USERDATA) [0x1a6886000 0xd2cc00000] Size: 52.699GB
LUN0 (GROW) [0xed3486000 0x375000] Size: 3.457MB
LUN1 (XBL) [0x6000 0x300000] Size: 3.0MB
LUN1 (XBLBAK) [0x306000 0x300000] Size: 3.0MB
LUN1 (FOTA) [0x606000 0x400000] Size: 4.0MB
LUN1 (FSG) [0xa06000 0x200000] Size: 2.0MB
LUN1 (DIP) [0xc06000 0x100000] Size: 1.0MB
LUN1 (DEVINFO) [0xd06000 0x100000] Size: 1.0MB
LUN1 (GROW2) [0xe06000 0x1000] Size: 4.0KB
LUN2 (XBL2) [0x6000 0x300000] Size: 3.0MB
LUN2 (XBL2BAK) [0x306000 0x300000] Size: 3.0MB
LUN2 (GROW3) [0x606000 0x1000] Size: 4.0KB
LUN3 (DDR) [0x6000 0x200000] Size: 2.0MB
LUN3 (RESERVE) [0x206000 0x8000] Size: 32.0KB
LUN3 (CDT) [0x20e000 0x1000] Size: 4.0KB
LUN3 (SPARE1) [0x20f000 0x400000] Size: 4.0MB
LUN3 (GROW4) [0x60f000 0x1000] Size: 4.0KB
LUN4 (BOOT) [0x6000 0x2800000] Size: 40.0MB
LUN4 (RECOVERY) [0x2806000 0x2880000] Size: 40.500MB
LUN4 (RECOVERYBAK) [0x5086000 0x2880000] Size: 40.500MB
LUN4 (TZ) [0x7906000 0x200000] Size: 2.0MB
LUN4 (TZBAK) [0x7b06000 0x200000] Size: 2.0MB
LUN4 (ABOOT) [0x7d06000 0x200000] Size: 2.0MB
LUN4 (ABOOTBAK) [0x7f06000 0x200000] Size: 2.0MB
LUN4 (RAW_RESOURCES) [0x8106000 0x400000] Size: 4.0MB
LUN4 (RAW_RESOURCESBAK) [0x8506000 0x400000] Size: 4.0MB
LUN4 (RPM) [0x8906000 0x80000] Size: 512.0KB
LUN4 (RPMBAK) [0x8986000 0x80000] Size: 512.0KB
LUN4 (HYP) [0x8a06000 0x80000] Size: 512.0KB
LUN4 (HYPBAK) [0x8a86000 0x80000] Size: 512.0KB
LUN4 (PMIC) [0x8b06000 0x80000] Size: 512.0KB
LUN4 (PMICBAK) [0x8b86000 0x80000] Size: 512.0KB
LUN4 (DEVCFG) [0x8c06000 0x20000] Size: 128.0KB
LUN4 (DEVCFGBAK) [0x8c26000 0x20000] Size: 128.0KB
LUN4 (MODEM) [0x8c46000 0x5600000] Size: 86.0MB
LUN4 (SEC) [0xe246000 0x80000] Size: 512.0KB
LUN4 (KEYMASTER) [0xe2c6000 0x80000] Size: 512.0KB
LUN4 (KEYMASTERBAK) [0xe346000 0x80000] Size: 512.0KB
LUN4 (CMNLIB) [0xe3c6000 0x80000] Size: 512.0KB
LUN4 (CMNLIBBAK) [0xe446000 0x80000] Size: 512.0KB
LUN4 (CMNLIB64) [0xe4c6000 0x80000] Size: 512.0KB
LUN4 (CMNLIB64BAK) [0xe546000 0x80000] Size: 512.0KB
LUN4 (APDP) [0xe5c6000 0x80000] Size: 512.0KB
LUN4 (MSADP) [0xe646000 0x80000] Size: 512.0KB
LUN4 (DPO) [0xe6c6000 0x80000] Size: 512.0KB
LUN4 (GROW5) [0xe746000 0x1000] Size: 4.0KB
LUN5 (MODEMST1) [0x6000 0x200000] Size: 2.0MB
LUN5 (MODEMST2) [0x206000 0x200000] Size: 2.0MB
LUN5 (FSC) [0x406000 0x80000] Size: 512.0KB
LUN5 (SPARE2) [0x486000 0x200000] Size: 2.0MB
LUN5 (GROW6) [0x686000 0x1000] Size: 4.0KB
LUN6 (PERSISTENT) [0x6000 0x200000] Size: 2.0MB
LUN6 (GROW7) [0x206000 0x1000] Size: 4.0KB
Read SYSTEM from LUN0.
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x0011486000 (5.460GB)
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 344688
Short Android info:
Build ID:  NRD90M
Display Build ID:  NRD90M
Release Incremental ID:  1720118227df0
Release Base ID:  7.0
Security Path:  2017-04-01
Device Model:  LG-H990
Device Manufacturer:  lge
Device Name A:  elsa_global_com
Device Name B:  elsa
Device Board Name:  msm8996
Architecture ABI:  arm64-v8a
Device manufacturer:  LGE
Device Platform:  msm8996
Product ID:  elsa
Build Description:  elsa_global_com-user 7.0 NRD90M 1720118227df0 release-keys
Target Carrier:  GLOBAL
Target Country:  COM
FRP Partition Path:  /dev/block/bootdevice/by-name/persistent
LGE SW Version:  H99011b
LGE SW Version Short:  V11b
LGE SW Revision:  0
LGE SW Version:  LGH990AT-00-V11b-GLOBAL-COM-JUL-20-2017+0
Backup saved: BuildProp_20200721_1145.txt
Read USERDATA from LUN0.
Detected USERDATA USERDATA : 0x01A6886000 (52.699GB)
Unable to mount USERDATA , code : 95
Userdata Superblock contents::
 A09CD305 C8120000 087B8105 2E6E2201 FCAB3D0B C0C5BE75 60A4E005 E00A7D05     *œÓ.È....{...n".ü«=.Àžu`¤à.à.}.;
 5CAD3D0B A8AF3D0B 94A4E005 A8AF3D0B A09CD305 C8120000 60A4E005 9A245201     \*=.¨¯=.”¤à.¨¯=.*œÓ.È...`¤à.š$R.;
 A09CD305 50914E01 34787D01 30AC3D0B 00000000 C0C5BE75 60A4E005 50E75101     *œÓ.P‘N.4x}.0¬=.....Àžu`¤à.PçQ.;
 E5030000 50B03D0B 94A4E005 50B03D0B A09CD305 C8120000 60A4E005 9A245201     å...P°=.”¤à.P°=.*œÓ.È...`¤à.š$R.;
 A09CD305 C8120000 E5030000 9A245201 00000000 C0C5BE75 60A4E005 50E75101     *œÓ.È...å...š$R.....Àžu`¤à.PçQ.;
 E5030000 C0C5BE75 E5030000 E8E65101 E5030000 E5030000 087B8105 16EFDF00     å...Àžuå...èæQ.å...å....{...ïß.;
 00000000 C0C5BE75 C8AC3D0B 88AD3D0B D033360C 30B13D0B 94A4E005 30B13D0B     ....ÀžuȬ=..*=.Ð36.0±=.”¤à.0±=.;
 A09CD305 C8120000 60A4E005 9A245201 A09CD305 C8120000 E5030000 9A245201     *œÓ.È...`¤à.š$R.*œÓ.È...å...š$R.;
Done.
UFS Socket Info.
Identify UFS Chip.
VCC: 3314mV
VCCQ2: 1820mV
Chip Info:
OemID: 01AD
UFS Version: 2.1
   LUN 0:
      Block size: 0x1000
   LUN 1 (Boot A):
      Block size: 0x1000
   LUN 2 (Boot B):
      Block size: 0x1000
   LUN 3:
      Block size: 0x1000
   LUN 4:
      Block size: 0x1000
   LUN 5:
      Block size: 0x1000
   LUN 6:
      Block size: 0x1000
      Block size: 0x100
Health:
Read UFS Chip Config.
Output file :E:\Mobile dump\LG\LG-H990\UFS_H28U74301AMR_config.ini
Done.
UFS Socket Info.
Read UFS LUN1, Address: 0x0 ,Length: 0x1000000
Output file :E:\Mobile dump\LG\LG-H990\UFS_H28U74301AMR_LUN1_00000000_01000000.bin
Start
Read, time taken: 2 sec. Average Reading Speed: 6970 kB/s
Done.
UFS Socket Info.
Read UFS LUN2, Address: 0x0 ,Length: 0x800000
Output file :E:\Mobile dump\LG\LG-H990\UFS_H28U74301AMR_LUN2_00000000_00800000.bin
Start
Read, time taken: 1 sec. Average Reading Speed: 6944 kB/s
Done.
UFS Socket Info.
Can'
t init deviceCode: -112ReasonCan't boot device
Done.
UFS Socket Info.
Can'
Done.
UFS Socket Info.
Can'
Done.
UFS Socket Info.
Can'
Done.
UFS Socket Info.
Identify UFS Chip.
Can'
VCC: 3314mV
VCCQ2: 1820mV
Done.
UFS Socket Info.
Identify UFS Chip.
Can'
VCC: 3314mV
VCCQ2: 1820mV
Done.
UFS Socket Info.
Identify UFS Chip.
UFS Chip Voltage: High
Can'
VCC: 3314mV
VCCQ2: 2795mV
Done.
UFS Safe Mode is disabled...
UFS Socket Info.
Identify UFS Chip.
Can'
VCC: 3314mV
VCCQ2: 2795mV
Done.
this is dead?
The Following User Says Thank You to parsa_dig For This Useful Post:
Old 07-22-2020, 09:55   #173 (permalink)
rajeshbahri's Avatar
Member: 108747
Sonork: 100.108643
Thanks Meter: 655
support team reply please
ufs ic we can flash with ufs adapter
because i have a51 samsung phone dead after flash
my question is if i remove ufs ic from motherboard and flash supported in adapter by easy jtag plus ?
thanks
The Following User Says Thank You to rajeshbahri For This Useful Post:
Old 07-24-2020, 10:50   #174 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
thanks
we work to add write by vendor for Sasmung at UFS chips
but now you can work with UFS chips by paritions
Old 08-12-2020, 03:32   #175 (permalink)
Member: 1972033
Thanks Meter: 32
sir what about boot a and boot b ... and wat if i deleted one of them wat will happen for device
Old 08-12-2020, 16:31   #176 (permalink)
Member: 1972033
Thanks Meter: 32
bro parsa_dig r u trying to read luns?
Old 08-12-2020, 22:25   #177 (permalink)
parsa_dig's Avatar
Member: 1265640
Sonork: 100.1622602
Thanks Meter: 51
Originally Posted by nour2014 View Post
bro parsa_dig r u trying to read luns?.
yes , I knew easy jtag plus is not good for skynix ufs chip(wich used in most devices) .
Old 08-13-2020, 00:06   #178 (permalink)
Member: 1972033
Thanks Meter: 32
are you trying to make dump?
Old 08-13-2020, 00:08   #179 (permalink)
Member: 1972033
Thanks Meter: 32
sir layder what about (boot A) and (boot B) ... and wat if i deleted one of them wat will happen for device
Old 08-17-2020, 17:31   #180 (permalink)
Member: 2866741
Hello, can somebody help me? I have an EasyJtag Plus with bga 254 adaptor, I want to do remove MDM on n970F but if i use the las version of EasyJtag Plus Suite i got the error Can't connect: 0, i have to use an old version and downgrade the box firmware to 2.50, but in that version when i try the tab "Read by Vendor" i got the message: "Not Supported yet" i really need to remove the mdm on that phone, also the phone doesn't have download mode. so Please if somebody knows how to succesfully remove the mdm, please please help me. Thanks
Page generated in 0.33934 seconds with 9 queries
