06-16-2020, 08:53 | #151 (permalink) |
Freak Poster Join Date: Jul 2013 Location: egypt alexandria
Member: 1972033 Status: Offline Thanks Meter: 32 | idk why u so mad and rude like this Last edited by layder; 06-16-2020 at 10:14. Reason: merge posts |
06-16-2020, 10:28 | #152 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,949 | Quote:
These things are for engineers. I wrote it to you above. You do not need to use this if you do not know how the UFS memory is arranged. and if you knew, but there wouldn’t be such questions | |
06-16-2020, 13:16 | #154 (permalink) | |
difficult to answer abstract questions Work with EMMCs is complicated, and with UFS chips it is even more difficult. when people ask "common" questions, I try to give them the same "common" answer. You asked how to enter the bootconfig at the UFS, I tried to explain to you that there is no bootconfig. you ask questions, the answers to which will take several pages of technical text. 99% of EasyJTAG users don’t need these. You were given a link to the technical documentation so that you better understand what you are interested in. I will add base instruction to work with UFS later. | |
The Following 5 Users Say Thank You to layder For This Useful Post: |
06-19-2020, 09:37 | #155 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Armenia
Member: 448264 Status: Offline Thanks Meter: 78 | which UFS chips supported? no one UFS chip not supported Setting interface to EasyJtag2/UFS Socket Information : Socket Mark: EasyJTAG UFS Socket BGA-95 by EasyJTAG 25.06.19 Socket Serial: 0123D2BFCB989276EE UFS Power Information : Mode: High, VCC: 3289mV, VCCQ2: 2799mV UFS Device Information : UFS Manufacturer: SKHYNIX, UFS ProductName: HBG4a UFS OemID: 01AD, UFS SerialNumber: 0x0310538AC2C0 Maximum Number of LUs: 0, Number of LUs found: 0, Number of WLUs found: 0, LUs Re-configure: Enabled This UFS is temporarily not supported. UFS Init completed. |
06-19-2020, 10:14 | #156 (permalink) | |
https://forum.gsmhosting.com/vbb/f67...l#post13914088 | |
06-19-2020, 19:59 | #158 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,949 | We can't know, why this chips was be dead. We buy some Hynix IC at china and it work fine. But chips from board was dead after some operations with it I was wrote above: "You can check/uncheck <Disable UFS safe mode> at setting to work with Hynix UFS" Last edited by layder; 06-20-2020 at 08:07. |
06-22-2020, 11:34 | #161 (permalink) |
No Life Poster Join Date: Jan 2005 Location: Mobile Phone Repairing
Member: 108747 Status: Offline Sonork: 100.108643 Thanks Meter: 655 | when i start to flash below error Setting interface to EasyJtag2/UFS Socket Information : Socket Mark: EasyJTAG UFS Socket 3 in 1 by MOORC 15.05.19 Socket Serial: 0123687D97CAxxxxxx UFS Power Information : Mode: Low, VCC: 3222mV, VCCQ2: 1791mV UFS Device Information : UFS Manufacturer: SKHYNIX, UFS ProductName: hB8aL1 UFS OemID: 01AD, UFS SerialNumber: 0x04 Maximum Number of LUs: 8, Number of LUs found: 7, Number of WLUs found: 1, LUs Re-configure: Enabled UFS LUN 0 Capacity: 30188 MB (00075EC00000) UFS LUN 1 (Boot A) Capacity: 32 MB (000002000000) UFS LUN 2 (Boot B) Capacity: 8 MB (000000800000) UFS LUN 3 Capacity: 8 MB (000000800000) UFS LUN 4 Capacity: 232 MB (00000E800000) UFS LUN 5 Capacity: 8 MB (000000800000) UFS LUN 6 Capacity: 8 MB (000000800000) UFS W-LUN 0xC4 (REPORT LUNS) Capacity: 16 MB (000001000000) UFS Init completed. Not supported yet and i need lg h872 dump file Last edited by layder; 06-23-2020 at 17:13. Reason: merge posts |
06-23-2020, 13:19 | #163 (permalink) | |
Member: 448264 Status: Offline Thanks Meter: 78 | Quote:
Setting interface to EasyJtag2/UFS Socket Information : Socket Mark: EasyJTAG UFS Socket BGA-95 by EasyJTAG 25.06.19 Socket Serial: 0123D2BFCB989276EE UFS Power Information : Mode: High, VCC: 3289mV, VCCQ2: 2799mV UFS Device Information : UFS Manufacturer: SKHYNIX, UFS ProductName: HBG4a UFS OemID: 01AD, UFS SerialNumber: 0x0310538AC2C0 Maximum Number of LUs: 0, Number of LUs found: 0, Number of WLUs found: 0, LUs Re-configure: Enabled This UFS is temporarily not supported. UFS Init completed. | |
06-23-2020, 16:59 | #164 (permalink) | |||||
I post link and answer you above You need read my old answer again: Quote:
Quote: Quote:
