GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
09-14-2010, 11:14 | #48 (permalink) | |
No Life Poster Join Date: Dec 2000 Location: J.A.U - Just Another Unlocker Age: 43
Member: 2878 Status: Offline Thanks Meter: 9,123 | Quote:
shure is per GPU, you cant get same calculation power with the fastest CPU´s... and per cluster they have minimum 2 grafikcards build it... some mainboards can old 4 (!!!) cards for paralell calculation... so forget about your "normal" webservers... | |
09-14-2010, 11:27 | #49 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: ..::DZ-25::..
Member: 315181 Status: Offline Sonork: 100.1593455 Thanks Meter: 301 | Quote:
No way !!! | |
09-14-2010, 13:32 | #50 (permalink) | |
No Life Poster Join Date: Jan 2003 Location: Iassy Age: 59
Member: 19723 Status: Offline Thanks Meter: 359 | Quote:
Why can't we do that ? 1 milion computers are faster than 2000 GPU's ... | |
09-14-2010, 16:05 | #52 (permalink) | |
and you will get this 1 million computers to work for your unlocking codes? the are more important calculations, like for cancer or aids and ppl give there computer for this thinks, but not that you can calc your unlock code. you know what i mean? another question: will you be able to write special loader to execute custom code for getting the important value? (because you need to decrypt it, and you cant calculate just by bruteforce, you need more thinks then just bforce...) will you be able to write a bionic software, witch should calculate for you? i think, ppl think its so easy to make sl3 bforce... to make this, you need more softwares then just a unlocking tool... | |
The Following 2 Users Say Thank You to oOXTCOo For This Useful Post: |
09-15-2010, 11:50 | #53 (permalink) |
Member: 19723 Status: Offline Thanks Meter: 359 | I don't say it's easy to make SL3 bruteforce . What cancer and aids people have to do with this ??? Let's just die , all of us , because we are a plague for earth ... Why do we need a bionic software ? Sorry to say but you are on a field full of poppies ... |
The Following User Says Thank You to usernome For This Useful Post: |
09-15-2010, 12:11 | #54 (permalink) | |
Cheater -Don't Deal with him- Join Date: Aug 2004 Location: MicroControllers:: Age: 43
Member: 78619 Status: Offline Thanks Meter: 297 | Quote:
so better to not expect that ..bec after that sl3 market will be killed again by copy paster and price will be droped to 1 or evern half euro.. | |
09-15-2010, 12:21 | #55 (permalink) | |
if solution is based on code calculation it can be protected by making a based server application, but if solution is based on patching, it will be copied in the first hours after be released :-) | |
09-15-2010, 12:35 | #56 (permalink) | |
i think you dont got my point! how you will get 1 million computers working for your code bruteforcing? how you will get this ppl to use theres computers to bforce instead of other usefull thinks? with bionic software i mean, you need to programm same softwares as all others how use this system for researches. and at least you need to find 1 million ppl how will give there calculation power for your unlock codes bruteforcing... i bet, you will not find 1000 ppl how will do this. got my point now? | |
09-15-2010, 18:12 | #58 (permalink) | |
No Life Poster Join Date: Dec 2002 Location: Lithuania Age: 40
Member: 19265 Status: Offline Thanks Meter: 92 | Quote:
B.R. Alkapone | |
09-16-2010, 14:20 | #59 (permalink) |
No Life Poster Join Date: Feb 2000 Location: UK
Member: 1024 Status: Offline Thanks Meter: 5,510 | Hi, It is not. Just one of the 4U cases on the picture of the GT cluster have 3200 cores to crunch in parallel. And each single core in this case works faster as the code could be optimized to use the GPU cash memory that is few nm away from each core. Also i did check those distributed clients, they are very slow and buggy. To make something workable for GSM you need to write your own client and maybe ask users to upgrade to latest i7 workhorse CPU with good watercooling and overclock. But again to have real impact you will need hundreds of thousands of guys that keep their PCs connected 24/7. Just my 2 cents. BR, Alex |
The Following 8 Users Say Thank You to Bph&co For This Useful Post: |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
